Hayboylenickin
- 22 Aralık 2023
# /etc/tlp.conf - TLP user configuration (version 1.6.1)
# See full explanation: https://linrunner.de/tlp/settings
# Copyright (c) 2023 Thomas Koch <linrunner at gmx.net> and others.
# SPDX-License-Identifier: GPL-2.0-or-later
# Settings are read in the following order:
# 1. Intrinsic defaults
# 2. /etc/tlp.d/*.conf - Drop-in customization snippets
# 3. /etc/tlp.conf - User configuration (this file)
# Notes:
# - In case of identical parameters, the last occurence has precedence
# - This also means, parameters enabled here will override anything else
# - However you may append values to a parameter already defined as intrinsic
# default or in a previously read file: use PARAMETER+="add values"
# - IMPORTANT: all parameters here are disabled; remove the leading '#' if you
# like to enable a feature without default or have a value different from the
# default
# - Default *: intrinsic default that is effective when the parameter is missing
# or disabled by a leading '#'; use PARAM="" to disable an intrinsic default
# - Default <none>: do nothing or use kernel/hardware defaults
# - IMPORTANT: parameters must always be specified pairwise i.e. for
# both AC and BAT. Omitting one of the two makes the set value effective for
# both power sources, since a change only occurs when different values are
# defined.
# tlp - Parameters for power saving
# Set to 0 to disable, 1 to enable TLP.
# Default: 1
TLP_ENABLE=1
# Control how warnings about invalid settings are issued:
# 0=disabled,
# 1=background tasks (boot, resume, change of power source) report to syslog,
# 2=shell commands report to the terminal (stderr),
# 3=combination of 1 and 2
# Default: 3
TLP_WARN_LEVEL=3
# Operation mode when no power supply can be detected: AC, BAT.
# Concerns some desktop and embedded hardware only.
# Default: <none>
#TLP_DEFAULT_MODE=AC
# Operation mode select: 0=depend on power source, 1=always use TLP_DEFAULT_MODE
# Note: use in conjunction with TLP_DEFAULT_MODE=BAT for BAT settings on AC.
# Default: 0
#TLP_PERSISTENT_DEFAULT=0
# Power supply classes to ignore when determining operation mode: AC, USB, BAT.
# Separate multiple classes with spaces.
# Note: try on laptops where operation mode AC/BAT is incorrectly detected.
# Default: <none>
#TLP_PS_IGNORE="BAT"
# Seconds laptop mode has to wait after the disk goes idle before doing a sync.
# Non-zero value enables, zero disables laptop mode.
# Default: 0 (AC), 2 (BAT)
DISK_IDLE_SECS_ON_AC=0
DISK_IDLE_SECS_ON_BAT=0
# Dirty page values (timeouts in secs).
# Default: 15 (AC), 60 (BAT)
MAX_LOST_WORK_SECS_ON_AC=15
MAX_LOST_WORK_SECS_ON_BAT=15
# Select a CPU scaling driver operation mode.
# Intel CPU with intel_pstate driver:
# active, passive.
# AMD Zen 2 or newer CPU with amd-pstate_driver as of kernel 6.3/6.4(*):
# active, passive, guided(*).
# Default: <none>
CPU_DRIVER_OPMODE_ON_AC=active
CPU_DRIVER_OPMODE_ON_BAT=active
# Select a CPU frequency scaling governor.
# Intel CPU with intel_pstate driver or
# AMD CPU with amd-pstate driver in active mode ('amd-pstate-epp'):
# performance, powersave(*).
# Intel CPU with intel_pstate driver in passive mode ('intel_cpufreq') or
# AMD CPU with amd-pstate driver in passive or guided mode ('amd-pstate') or
# Intel, AMD and other CPU brands with acpi-cpufreq driver:
# conservative, ondemand(*), userspace, powersave, performance, schedutil(*).
# Use tlp-stat -p to show the active driver and available governors.
# Important:
# Governors marked (*) above are power efficient for *almost all* workloads
# and therefore kernel and most distributions have chosen them as defaults.
# You should have done your research about advantages/disadvantages *before*
# changing the governor.
# Default: <none>
CPU_SCALING_GOVERNOR_ON_AC=powersave
CPU_SCALING_GOVERNOR_ON_BAT=powersave
# Set the min/max frequency available for the scaling governor.
# Possible values depend on your CPU. For available frequencies see
# the output of tlp-stat -p.
# Notes:
# - Min/max frequencies must always be specified for both AC *and* BAT
# - Not recommended for use with the intel_pstate driver, use
# CPU_MIN/MAX_PERF_ON_AC/BAT below instead
# Default: <none>
CPU_SCALING_MIN_FREQ_ON_AC=400000
CPU_SCALING_MAX_FREQ_ON_AC=5471000
#CPU_SCALING_MIN_FREQ_ON_BAT=0
#CPU_SCALING_MAX_FREQ_ON_BAT=0
# Set CPU energy/performance policies EPP and EPB:
# performance, balance_performance, default, balance_power, power.
# Values are given in order of increasing power saving.
# Requires:
# * Intel CPU
# EPP: Intel Core i 6th gen. or newer CPU with intel_pstate driver
# EPB: Intel Core i 2nd gen. or newer CPU with intel_pstate driver
# as of kernel 5.2; alternatively module msr and
# x86_energy_perf_policy from linux-tools
# EPP and EPB are mutually exclusive: when EPP is available, Intel CPUs
# will not honor EPB. Only the matching feature will be applied by TLP.
# * AMD Zen 2 or newer CPU
# EPP: amd-pstate driver in active mode ('amd-pstate-epp') as of kernel 6.3
# Default: balance_performance (AC), balance_power (BAT)
CPU_ENERGY_PERF_POLICY_ON_AC=balance_power
CPU_ENERGY_PERF_POLICY_ON_BAT=power
# Set Intel CPU P-state performance: 0..100 (%).
# Limit the max/min P-state to control the power dissipation of the CPU.
# Values are stated as a percentage of the available performance.
# Requires Intel Core i 2nd gen. or newer CPU with intel_pstate driver.
# Default: <none>
#CPU_MIN_PERF_ON_AC=0
#CPU_MAX_PERF_ON_AC=100
#CPU_MIN_PERF_ON_BAT=0
#CPU_MAX_PERF_ON_BAT=30
# Set the CPU "turbo boost" (Intel) or "turbo core" (AMD) feature:
# 0=disable, 1=allow.
# Allows to raise the maximum frequency/P-state of some cores if the
# CPU chip is not fully utilized and below it's intended thermal budget.
# Note: a value of 1 does *not* activate boosting, it just allows it.
# Default: <none>
CPU_BOOST_ON_AC=0
CPU_BOOST_ON_BAT=0
# Set Intel/AMD CPU dynamic boost feature:
# 0=disable, 1=enable.
# Improve performance by increasing minimum P-state limit dynamically
# whenever a task previously waiting on I/O is selected to run.
# Requires:
# * Intel Core i 6th gen. or newer CPU: intel_pstate driver in active mode
# * AMD Zen 2 or newer CPU: amd-pstate driver in active mode ('amd-pstate-epp')
# provided by a yet unreleased kernel 6.x
# Default: <none>
CPU_HWP_DYN_BOOST_ON_AC=1
CPU_HWP_DYN_BOOST_ON_BAT=0
# Kernel NMI Watchdog:
# 0=disable (default, saves power), 1=enable (for kernel debugging only).
# Default: 0
NMI_WATCHDOG=0
# Select platform profile:
# performance, balanced, low-power.
# Controls system operating characteristics around power/performance levels,
# thermal and fan speed. Values are given in order of increasing power saving.
# Note: check the output of tlp-stat -p to determine availability on your
# hardware and additional profiles such as: balanced-performance, quiet, cool.
# Default: <none>
#PLATFORM_PROFILE_ON_AC=performance
#PLATFORM_PROFILE_ON_BAT=low-power
# System suspend mode:
# s2idle: Idle standby - a pure software, light-weight, system sleep state,
# deep: Suspend to RAM - the whole system is put into a low-power state,
# except for memory, usually resulting in higher savings than s2idle.
# CAUTION: changing suspend mode may lead to system instability and even
# data loss. As for the availability of different modes on your system,
# check the output of tlp-stat -s. If unsure, stick with the system default
# by not enabling this.
# Default: <none>
MEM_SLEEP_ON_AC=s2idle
MEM_SLEEP_ON_BAT=deep
# Define disk devices on which the following DISK/AHCI_RUNTIME parameters act.
# Separate multiple devices with spaces.
# Devices can be specified by disk ID also (lookup with: tlp diskid).
# Default: "nvme0n1 sda"
DISK_DEVICES="nvme0n1 nvme1n1 sda"
# Disk advanced power management level: 1..254, 255 (max saving, min, off).
# Levels 1..127 may spin down the disk; 255 allowable on most drives.
# Separate values for multiple disks with spaces. Use the special value 'keep'
# to keep the hardware default for the particular disk.
# Default: 254 (AC), 128 (BAT)
DISK_APM_LEVEL_ON_AC="254 254"
DISK_APM_LEVEL_ON_BAT="254 254"
# Exclude disk classes from advanced power management (APM):
# sata, ata, usb, ieee1394.
# CAUTION: USB and IEEE1394 disks may fail to mount or data may get corrupted
# with APM enabled. Be careful and make sure you have backups of all affected
# media before removing 'usb' or 'ieee1394' from the denylist!
# Default: "usb ieee1394"
#DISK_APM_CLASS_DENYLIST="usb ieee1394"
# Hard disk spin down timeout:
# 0: spin down disabled
# 1..240: timeouts from 5s to 20min (in units of 5s)
# 241..251: timeouts from 30min to 5.5 hours (in units of 30min)
# See 'man hdparm' for details.
# Default: <none>
#DISK_SPINDOWN_TIMEOUT_ON_AC="0 0"
#DISK_SPINDOWN_TIMEOUT_ON_BAT="0 0"
# Select I/O scheduler for the disk devices.
# Multi queue (blk-mq) schedulers:
# mq-deadline(*), none, kyber, bfq
# Single queue schedulers:
# deadline(*), cfq, bfq, noop
# (*) recommended.
# to keep the kernel default scheduler for the particular disk.
# Notes:
# - Multi queue (blk-mq) may need kernel boot option 'scsi_mod.use_blk_mq=1'
# and 'modprobe mq-deadline-iosched|kyber|bfq' on kernels < 5.0
# - Single queue schedulers are legacy now and were removed together with
# the old block layer in kernel 5.0
# Default: keep
DISK_IOSCHED="none none bfq"
# AHCI link power management (ALPM) for SATA disks:
# min_power, med_power_with_dipm(*), medium_power, max_performance.
# (*) recommended.
# Multiple values separated with spaces are tried sequentially until success.
# Default: med_power_with_dipm (AC & BAT)
SATA_LINKPWR_ON_AC="med_power_with_dipm"
SATA_LINKPWR_ON_BAT="med_power_with_dipm"
# Exclude SATA links from AHCI link power management (ALPM).
# SATA links are specified by their host. Refer to the output of
# tlp-stat -d to determine the host; the format is "hostX".
# Separate multiple hosts with spaces.
# Default: <none>
#SATA_LINKPWR_DENYLIST="host1"
# Runtime Power Management for NVMe, SATA, ATA and USB disks
# as well as SATA ports:
# on=disable, auto=enable.
# Note: SATA controllers are PCIe bus devices and handled by RUNTIME_PM further
# down.
# Default: on (AC), auto (BAT)
AHCI_RUNTIME_PM_ON_AC=auto
AHCI_RUNTIME_PM_ON_BAT=auto
# Seconds of inactivity before disk is suspended.
# Note: effective only when AHCI_RUNTIME_PM_ON_AC/BAT is activated.
# Default: 15
AHCI_RUNTIME_PM_TIMEOUT=15
# Power off optical drive in UltraBay/MediaBay: 0=disable, 1=enable.
# Drive can be powered on again by releasing (and reinserting) the eject lever
# or by pressing the disc eject button on newer models.
# Note: an UltraBay/MediaBay hard disk is never powered off.
# Default: 0
#BAY_POWEROFF_ON_AC=0
#BAY_POWEROFF_ON_BAT=0
# Optical drive device to power off
# Default: sr0
#BAY_DEVICE="sr0"
# Set the min/max/turbo frequency for the Intel GPU.
# Possible values depend on your hardware. For available frequencies see
# the output of tlp-stat -g.
# Default: <none>
#INTEL_GPU_MIN_FREQ_ON_AC=0
#INTEL_GPU_MIN_FREQ_ON_BAT=0
#INTEL_GPU_MAX_FREQ_ON_AC=0
#INTEL_GPU_MAX_FREQ_ON_BAT=0
#INTEL_GPU_BOOST_FREQ_ON_AC=0
#INTEL_GPU_BOOST_FREQ_ON_BAT=0
# AMD GPU power management.
# Performance level (DPM): auto, low, high; auto is recommended.
# Note: requires amdgpu or radeon driver.
# Default: auto
RADEON_DPM_PERF_LEVEL_ON_AC=auto
RADEON_DPM_PERF_LEVEL_ON_BAT=auto
# Dynamic power management method (DPM): balanced, battery, performance.
# Note: radeon driver only.
# Default: <none>
RADEON_DPM_STATE_ON_AC=balanced
RADEON_DPM_STATE_ON_BAT=battery
# Graphics clock speed (profile method): low, mid, high, auto, default;
# auto = mid on BAT, high on AC.
# Note: radeon driver on legacy ATI hardware only (where DPM is not available).
# Default: default
#RADEON_POWER_PROFILE_ON_AC=default
#RADEON_POWER_PROFILE_ON_BAT=default
# Wi-Fi power saving mode: on=enable, off=disable.
# Default: off (AC), on (BAT)
WIFI_PWR_ON_AC=off
WIFI_PWR_ON_BAT=off
# Disable Wake-on-LAN: Y/N.
# Default: Y
WOL_DISABLE=Y
# Enable audio power saving for Intel HDA, AC97 devices (timeout in secs).
# A value of 0 disables, >= 1 enables power saving.
# Note: 1 is recommended for Linux desktop environments with PulseAudio,
# systems without PulseAudio may require 10.
# Default: 1
SOUND_POWER_SAVE_ON_AC=1
SOUND_POWER_SAVE_ON_BAT=1
# Disable controller too (HDA only): Y/N.
# Note: effective only when SOUND_POWER_SAVE_ON_AC/BAT is activated.
# Default: Y
SOUND_POWER_SAVE_CONTROLLER=Y
# PCIe Active State Power Management (ASPM):
# default(*), performance, powersave, powersupersave.
# (*) keeps BIOS ASPM defaults (recommended)
# Default: <none>
PCIE_ASPM_ON_AC=default
PCIE_ASPM_ON_BAT=default
# Runtime Power Management for PCIe bus devices: on=disable, auto=enable.
# Exclude listed PCIe device adresses from Runtime PM.
# Note: this preserves the kernel driver default, to force a certain state
# use RUNTIME_PM_ENABLE/DISABLE instead.
# Separate multiple addresses with spaces.
# Use lspci to get the adresses (1st column).
# Default: <none>
#RUNTIME_PM_DENYLIST="11:22.3 44:55.6"
# Exclude PCIe devices assigned to the listed drivers from Runtime PM.
# Separate multiple drivers with spaces.
# Default: "mei_me nouveau radeon", use "" to disable completely.
#RUNTIME_PM_DRIVER_DENYLIST="mei_me nouveau radeon"
# Permanently enable/disable Runtime PM for listed PCIe device addresses
# (independent of the power source). This has priority over all preceding
# Runtime PM settings. Separate multiple addresses with spaces.
# Default: <none>
#RUNTIME_PM_ENABLE="11:22.3"
#RUNTIME_PM_DISABLE="44:55.6"
# Set to 0 to disable, 1 to enable USB autosuspend feature.
# Default: 1
USB_AUTOSUSPEND=0
# Exclude listed devices from USB autosuspend (separate with spaces).
# Use lsusb to get the ids.
# Note: input devices (usbhid) and libsane-supported scanners are excluded
# automatically.
# Default: <none>
#USB_DENYLIST="1111:2222 3333:4444"
# Exclude audio devices from USB autosuspend:
# 0=do not exclude, 1=exclude.
# Default: 1
#USB_EXCLUDE_AUDIO=1
# Exclude bluetooth devices from USB autosuspend:
# Default: 0
#USB_EXCLUDE_BTUSB=0
# Exclude phone devices from USB autosuspend:
# 0=do not exclude, 1=exclude (enable charging).
# Default: 0
#USB_EXCLUDE_PHONE=0
# Exclude printers from USB autosuspend:
# Default: 1
#USB_EXCLUDE_PRINTER=1
# Exclude WWAN devices from USB autosuspend:
# Default: 0
#USB_EXCLUDE_WWAN=0
# Allow USB autosuspend for listed devices even if already denylisted or
# excluded above (separate with spaces). Use lsusb to get the ids.
# Default: 0
#USB_ALLOWLIST="1111:2222 3333:4444"
# Set to 1 to disable autosuspend before shutdown, 0 to do nothing
# Note: use as a workaround for USB devices that cause shutdown problems.
# Default: 0
#USB_AUTOSUSPEND_DISABLE_ON_SHUTDOWN=0
# Restore radio device state (Bluetooth, WiFi, WWAN) from previous shutdown
# on system startup: 0=disable, 1=enable.
# Note: the parameters DEVICES_TO_DISABLE/ENABLE_ON_STARTUP/SHUTDOWN below
# are ignored when this is enabled.
# Default: 0
#RESTORE_DEVICE_STATE_ON_STARTUP=0
# Radio devices to disable on startup: bluetooth, nfc, wifi, wwan.
# Default: <none>
#DEVICES_TO_DISABLE_ON_STARTUP="bluetooth nfc wifi wwan"
# Radio devices to enable on startup: bluetooth, nfc, wifi, wwan.
# Default: <none>
#DEVICES_TO_ENABLE_ON_STARTUP="wifi"
# Radio devices to disable on shutdown: bluetooth, nfc, wifi, wwan.
# Note: use as a workaround for devices that are blocking shutdown.
# Default: <none>
#DEVICES_TO_DISABLE_ON_SHUTDOWN="bluetooth nfc wifi wwan"
# Radio devices to enable on shutdown: bluetooth, nfc, wifi, wwan.
# (to prevent other operating systems from missing radios).
# Default: <none>
#DEVICES_TO_ENABLE_ON_SHUTDOWN="wwan"
# Radio devices to enable on AC: bluetooth, nfc, wifi, wwan.
# Default: <none>
#DEVICES_TO_ENABLE_ON_AC="bluetooth nfc wifi wwan"
# Radio devices to disable on battery: bluetooth, nfc, wifi, wwan.
# Default: <none>
#DEVICES_TO_DISABLE_ON_BAT="bluetooth nfc wifi wwan"
# Radio devices to disable on battery when not in use (not connected):
# bluetooth, nfc, wifi, wwan.
# Default: <none>
#DEVICES_TO_DISABLE_ON_BAT_NOT_IN_USE="bluetooth nfc wifi wwan"
# Battery Care -- Charge thresholds
# Charging starts when the charger is connected and the charge level
# is below the start threshold. Charging stops when the charge level
# is above the stop threshold.
# Required hardware: Lenovo ThinkPads and select other laptop brands
# are driven via specific plugins
# - Active plugin and support status are shown by tlp-stat -b
# - Vendor specific threshold levels are shown by tlp-stat -b, some
# laptops support only 1 (on)/ 0 (off) instead of a percentage level
# - When your hardware supports a start *and* a stop threshold, you must
# specify both, otherwise TLP will refuse to apply the single threshold
# - When your hardware supports only a stop threshold, set the start
# value to 0
# - Older ThinkPads may require an external kernel module, refer to the
# output of tlp-stat -b
# For further explanation and vendor specific details refer to
# - https://linrunner.de/tlp/settings/battery.html
# - https://linrunner.de/tlp/settings/bc-vendors.html
# BAT0: Primary / Main / Internal battery
# Note: also use for batteries BATC, BATT and CMB0
# Default: <none>
# Battery charge level below which charging will begin.
#START_CHARGE_THRESH_BAT0=75
# Battery charge level above which charging will stop.
#STOP_CHARGE_THRESH_BAT0=80
# BAT1: Secondary / Ultrabay / Slice / Replaceable battery
# Note: primary on some laptops
# Default: <none>
#START_CHARGE_THRESH_BAT1=75
#STOP_CHARGE_THRESH_BAT1=80
# Restore charge thresholds when AC is unplugged: 0=disable, 1=enable.
# Default: 0
#RESTORE_THRESHOLDS_ON_BAT=1
# Control battery care drivers: 0=disable, 1=enable.
# Default: 1 (all)
#NATACPI_ENABLE=1
#TPACPI_ENABLE=1
#TPSMAPI_ENABLE=1
# tlp-rdw - Parameters for the radio device wizard
# Possible devices: bluetooth, wifi, wwan.
# Separate multiple radio devices with spaces.
# Default: <none> (for all parameters below)
# Radio devices to disable on connect.
#DEVICES_TO_DISABLE_ON_LAN_CONNECT="wifi wwan"
#DEVICES_TO_DISABLE_ON_WIFI_CONNECT="wwan"
#DEVICES_TO_DISABLE_ON_WWAN_CONNECT="wifi"
# Radio devices to enable on disconnect.
#DEVICES_TO_ENABLE_ON_LAN_DISCONNECT="wifi wwan"
#DEVICES_TO_ENABLE_ON_WIFI_DISCONNECT=""
#DEVICES_TO_ENABLE_ON_WWAN_DISCONNECT=""
# Radio devices to enable/disable when docked.
#DEVICES_TO_ENABLE_ON_DOCK=""
#DEVICES_TO_DISABLE_ON_DOCK=""
# Radio devices to enable/disable when undocked.
#DEVICES_TO_ENABLE_ON_UNDOCK="wifi"
#DEVICES_TO_DISABLE_ON_UNDOCK=""
Bu arada config dosyasini kaydedip ciktiktan sonraHocam turbo Boost'u kapatmak ya da Max 3200 MHz olacak şekilde sabitlemek istiyorum işlemciyi. Zaten Turbo Boost'u kapatınca da en fazla 3200 MHz oluyordu işlemci.
Muhtemelen başka bir şeyle çakıştığı için yapamıyorum. Emin değilim.
sudo tlp start komutunu girmen gerekiyor yoksa yeniden baslatana kadar konfigurasyon degisikligi uygulanmaz.Öncelikle şunu belirteyim Linux'ta yeniyim. 5-6 aydır kullanıyorum ama ara ara kullandığım için çok fazla şeye hakim değilim. Şu an kullandığım ise Fedora.
Problem şu ki işlemci frekansını belli bir değere sabitlemek istiyorum. Aslında ilk olarak Turbo Boost'u kapatmak istedim ama bir türlü beceremedim. Ondan dolayı işlemci hızını sabitlemek daha iyi olur dedim ama sorun şu ki işlemci hızını sabitledikten çok kısa bir süre sonra eski haline dönüyor. Bazen birkaç saniye bazen birkaç dakika. Sonuçta sabit kalmıyor. Yardımcı olursanız sevinirim.
-ASUS TUF A15 Ryzen 7 7735HS RTX 4050 Fedora -
TLP hiç aklıma gelmemişti açıkçası. İşlemci hızını düşürmek istememin sebebi anlayamadığım bir şekilde oyunlarda normalde olduğundan fazla güç çekmesi dolayısıyla da ısınması. Normalde zaten sınırda geziyor denebilir, 75 80 85 civarında. Linuxta ise 95 sabitleniyor direkt cihaz. Ondan dolayı ya Turbo Boost'u kapatmak ya da işlemci hızını sabitlemek istiyorum. Undervolt da bir seçenek ama laptopta ne kadar sağlıklı olur bilemediğim için yeltenmedim. Sağlıktan kastım direkt bios yüzünden voltaj ayarıyla oynanmaya izin verilmiyor diye biliyorum .Bahsettigin sebeplerden dolayi TLP kurabilirsin, hem islemci sinirlama hem de Turbo Boost kapatma islemini konfigurasyon dosyasindan ayarlayabilirsin. Oncelikle islemcinin hizini dusurmek istemenin sebebini ogrenebilir miyim?
Normalden kastım Windowsta oynadığım oyunlar için, yanlış bir tabir olduTLP hiç aklıma gelmemişti açıkçası. İşlemci hızını düşürmek istememin sebebi anlayamadığım bir şekilde oyunlarda normalde olduğundan fazla güç çekmesi dolayısıyla da ısınması. Normalde zaten sınırda geziyor denebilir, 75 80 85 civarında. Linuxta ise 95 sabitleniyor direkt cihaz. Ondan dolayı ya Turbo Boost'u kapatmak ya da işlemci hızını sabitlemek istiyorum. Undervolt da bir seçenek ama laptopta ne kadar sağlıklı olur bilemediğim için yeltenmedim. Sağlıktan kastım direkt bios yüzünden voltaj ayarıyla oynanmaya izin verilmiyor diye biliyorum .
TLP indirdim kurdum. İşlemci hızı 400 MHz'e sabitlendi ne yaparsam yapayım gram oynamıyor. TLP'yi disable ettim hatta kaldırdım filan yine de çare etmedi. Ne yapmam lazımBu ilginc bir durum guc miktari Windows'ta oldugundan cok farkli olmamali aslinda. Dedigim gibi TLP uzerinden hem frekans sinirlandirmasi hem de Turbo Boost'u kapatabiliyorsun denersin hangisi calisirsa onu kullanirsin. 95 derece sicaklik gunumuz islemcileri icin hiçbir sorun teskil etmiyor aslinda ama illa dusurmek istiyorum dersen TLP kullanabilirsin.
Ufak düzeltme. Disable edip yeniden başlatınca düzeldi. Lakin bu yine beni en başa götürdü. 400 MHz sabitleyen ayarı bulsam çözücem ama hangisi bilmiyorum.TLP indirdim kurdum. İşlemci hızı 400 MHz'e sabitlendi ne yaparsam yapayım gram oynamıyor. TLP'yi disable ettim hatta kaldırdım filan yine de çare etmedi. Ne yapmam lazım.
Governor powresave ayarlanmistir.TLP indirdim kurdum. İşlemci hızı 400 MHz'e sabitlendi ne yaparsam yapayım gram oynamıyor. TLP'yi disable ettim hatta kaldırdım filan yine de çare etmedi. Ne yapmam lazım.
Evet hocam o gözümden kaçmış. TLP kullanmadığım için internete baka baka ayarlamaya çalışıyorum. Az daha sıfırlayıp baştan kuracaktım linuxu.Governor powresave ayarlanmistir.
Lakin CPU Boost'u kapatmama ve MHz sabitlememe rağmen hâlâ işe yaramıyor.Governor powresave ayarlanmistir.
Ne yapmak istiyorsun tam olarak? Sen soyle ben editleyip gondereyim sana config dosyasini.Evet hocam o gözümden kaçmış. TLP kullanmadığım için internete baka baka ayarlamaya çalışıyorum. Az daha sıfırlayıp baştan kuracaktım linuxu.
Hocam turbo Boost'u kapatmak ya da Max 3200 MHz olacak şekilde sabitlemek istiyorum işlemciyi. Zaten Turbo Boost'u kapatınca da en fazla 3200 MHz oluyordu işlemci.Ne yapmak istiyorsun tam olarak? Sen soyle ben editleyip gondereyim sana config dosyasini.
Muhtemelen başka bir şeyle çakıştığı için yapamıyorum. Emin değilim.Hocam turbo Boost'u kapatmak ya da Max 3200 MHz olacak şekilde sabitlemek istiyorum işlemciyi. Zaten Turbo Boost'u kapatınca da en fazla 3200 MHz oluyordu işlemci.
# Notes:
# default
# defined.
# Default: 1
TLP_ENABLE=1
# 0=disabled,
# Default: 3
TLP_WARN_LEVEL=3
# Default: <none>
# Default: 0
# Default: <none>
# active, passive.
# Default: <none>
# Important:
# Default: <none>
# Notes:
# Default: <none>
# Requires:
# * Intel CPU
# Default: <none>
# Default: <none>
CPU_BOOST_ON_AC=0
CPU_BOOST_ON_BAT=0
# Requires:
# Default: <none>
# Default: 0
NMI_WATCHDOG=0
# Default: <none>
# Default: <none>
# Default: <none>
# (*) recommended.
# Notes:
# Default: keep
# (*) recommended.
# Default: <none>
# down.
# Default: 15
# Default: 0
# Default: sr0
#BAY_DEVICE="sr0"
# Default: <none>
# Default: auto
# Default: <none>
# Default: default
WIFI_PWR_ON_AC=off
WIFI_PWR_ON_BAT=off
# Default: Y
WOL_DISABLE=Y
# Default: 1
# Default: Y
# Default: <none>
# Default: <none>
# Default: <none>
# Default: 1
USB_AUTOSUSPEND=0
# automatically.
# Default: <none>
# Default: 1
# Default: 0
# Default: 0
# Default: 1
# Default: 0
#USB_EXCLUDE_WWAN=0
# Default: 0
# Default: 0
# Default: 0
# Default: <none>
# Default: <none>
# Default: <none>
# Default: <none>
# Default: <none>
# Default: <none>
# Default: <none>
# value to 0
# Default: <none>
# Default: <none>
# Default: 0
# Default: 1 (all)
#NATACPI_ENABLE=1
#TPACPI_ENABLE=1
#TPSMAPI_ENABLE=1
sudo tlp start komutunu girmen gerekiyor yoksa yeniden baslatana kadar konfigurasyon degisikligi uygulanmaz.We use cookies and similar technologies for the following purposes:
Do you accept cookies and these technologies?
