GTX 1060 High Sierra nasıl kurulur?
15 Aralık 2023
Avcılar/İstanbul
Merhabalar, iso dosyasını vs. yazdım ancak BIOS ayarlarını bulamıyorum, adamın bahsettiği ayarlardan sadece 2-3'ü var. N'apmam lazım? Girmiyor sisteme. Sistemim:
GTX 1060 6 GB GPU,
Asus H61M-K mainboard,
i7 3770s CPU,
Gigabyte 240 GB SATA SSD,
DDR3 8X2 GB RAM.
Uyguladığım rehber ve dosyalar:
USB dosyaları ve config:
Config dosyası içindekiler:
[CODE title="Config"]<?xml version="1.0" encoding="UTF-8"?>
<!DOCTYPE plist PUBLIC "-//Apple//DTD PLIST 1.0//EN" "http://www.apple.com/DTDs/PropertyList-1.0.dtd">
<plist version="1.0">
<dict>
<key>ACPI</key>
<dict>
<key>Add</key>
<array>
<dict>
<key>Comment</key>
<string></string>
<key>Enabled</key>
<true/>
<key>Path</key>
<string>SSDT-EC-DESKTOP.aml</string>
</dict>
<dict>
<key>Comment</key>
<string></string>
<key>Enabled</key>
<true/>
<key>Path</key>
<string>SSDT-UNC.aml</string>
</dict>
</array>
<key>Delete</key>
<array/>
<key>Patch</key>
<array>
<dict>
<key>Base</key>
<string></string>
<key>BaseSkip</key>
<integer>0</integer>
<key>Comment</key>
<string>Rename EUSB to EH01 (USB)</string>
<key>Count</key>
<key>Enabled</key>
<true/>
<key>Find</key>
<data>RVVTQg==</data>
<key>Limit</key>
<key>Mask</key>
<data></data>
<key>OemTableId</key>
<data></data>
<key>Replace</key>
<data>RUgwMQ==</data>
<key>ReplaceMask</key>
<data></data>
<key>Skip</key>
<key>TableLength</key>
<key>TableSignature</key>
<data>RFNEVA==</data>
</dict>
<dict>
<key>Base</key>
<string></string>
<key>BaseSkip</key>
<key>Comment</key>
<string>Rename USBE to EH02 (USB)</string>
<key>Count</key>
<key>Enabled</key>
<true/>
<key>Find</key>
<data>VVNCRQ==</data>
<key>Limit</key>
<key>Mask</key>
<data></data>
<data></data>
<key>Replace</key>
<data>RUgwMg==</data>
<data></data>
<key>Skip</key>
</dict>
</array>
<key>Quirks</key>
<dict>
<key>FadtEnableReset</key>
<false/>
<key>NormalizeHeaders</key>
<false/>
<key>RebaseRegions</key>
<false/>
<key>ResetHwSig</key>
<false/>
<key>ResetLogoStatus</key>
<false/>
<key>SyncTableIds</key>
<false/>
</dict>
</dict>
<key>Booter</key>
<dict>
<key>MmioWhitelist</key>
<array/>
<key>Patch</key>
<array/>
<key>Quirks</key>
<dict>
<key>AllowRelocationBlock</key>
<false/>
<key>AvoidRuntimeDefrag</key>
<true/>
<key>DevirtualiseMmio</key>
<false/>
<key>DisableSingleUser</key>
<false/>
<key>DisableVariableWrite</key>
<false/>
<key>DiscardHibernateMap</key>
<false/>
<key>EnableSafeModeSlide</key>
<true/>
<key>EnableWriteUnprotector</key>
<true/>
<key>FixupAppleEfiImages</key>
<false/>
<key>ForceBooterSignature</key>
<false/>
<key>ForceExitBootServices</key>
<false/>
<key>ProtectMemoryRegions</key>
<false/>
<key>ProtectSecureBoot</key>
<false/>
<key>ProtectUefiServices</key>
<false/>
<key>ProvideCustomSlide</key>
<true/>
<key>ProvideMaxSlide</key>
<key>RebuildAppleMemoryMap</key>
<false/>
<key>ResizeAppleGpuBars</key>
<integer>-1</integer>
<key>SetupVirtualMap</key>
<true/>
<key>SignalAppleOS</key>
<false/>
<key>SyncRuntimePermissions</key>
<false/>
</dict>
</dict>
<key>DeviceProperties</key>
<dict>
<key>Add</key>
<dict/>
<key>Delete</key>
<dict/>
</dict>
<key>Kernel</key>
<dict>
<key>Add</key>
<array>
<dict>
<key>Arch</key>
<string>Any</string>
<key>BundlePath</key>
<string>Lilu.kext</string>
<key>Comment</key>
<string>V1.5.9</string>
<key>Enabled</key>
<true/>
<key>ExecutablePath</key>
<string>Contents/MacOS/Lilu</string>
<key>MaxKernel</key>
<string></string>
<key>MinKernel</key>
<string>8.0.0</string>
<key>PlistPath</key>
<string>Contents/Info.plist</string>
</dict>
<dict>
<key>Arch</key>
<string>VirtualSMC.kext</string>
<key>Comment</key>
<string>V1.2.8</string>
<key>Enabled</key>
<true/>
<string>Contents/MacOS/VirtualSMC</string>
<string></string>
</dict>
<dict>
<key>Arch</key>
<string>SMCProcessor.kext</string>
<key>Comment</key>
<string></string>
<key>Enabled</key>
<false/>
<string>Contents/MacOS/SMCProcessor</string>
<string></string>
<string>11.0.0</string>
</dict>
<dict>
<key>Arch</key>
<string>SMCSuperIO.kext</string>
<key>Comment</key>
<string></string>
<key>Enabled</key>
<false/>
<string>Contents/MacOS/SMCSuperIO</string>
<string></string>
<string>10.0.0</string>
</dict>
<dict>
<key>Arch</key>
<string>WhateverGreen.kext</string>
<key>Comment</key>
<string>V1.5.6</string>
<key>Enabled</key>
<true/>
<string>Contents/MacOS/WhateverGreen</string>
<string></string>
</dict>
<dict>
<key>Arch</key>
<string>AppleALC.kext</string>
<key>Comment</key>
<string>V1.6.8</string>
<key>Enabled</key>
<false/>
<string>Contents/MacOS/AppleALC</string>
<string></string>
</dict>
<dict>
<key>Arch</key>
<string>USBInjectAll.kext</string>
<key>Comment</key>
<string>V0.7.6</string>
<key>Enabled</key>
<false/>
<string>Contents/MacOS/USBInjectAll</string>
<string></string>
<string>15.0.0</string>
</dict>
</array>
<key>Block</key>
<array/>
<key>Emulate</key>
<dict>
<key>Cpuid1Data</key>
<data></data>
<key>Cpuid1Mask</key>
<data></data>
<key>DummyPowerManagement</key>
<false/>
<string></string>
<string></string>
</dict>
<key>Force</key>
<array/>
<key>Patch</key>
<array/>
<key>Quirks</key>
<dict>
<key>AppleCpuPmCfgLock</key>
<true/>
<key>AppleXcpmCfgLock</key>
<false/>
<key>AppleXcpmExtraMsrs</key>
<true/>
<key>AppleXcpmForceBoost</key>
<false/>
<key>CustomPciSerialDevice</key>
<false/>
<key>CustomSMBIOSGuid</key>
<false/>
<key>DisableIoMapper</key>
<true/>
<key>DisableIoMapperMapping</key>
<false/>
<key>DisableLinkeditJettison</key>
<true/>
<key>DisableRtcChecksum</key>
<false/>
<key>ExtendBTFeatureFlags</key>
<false/>
<key>ExternalDiskIcons</key>
<false/>
<key>ForceAquantiaEthernet</key>
<false/>
<key>ForceSecureBootScheme</key>
<false/>
<key>IncreasePciBarSize</key>
<false/>
<key>LapicKernelPanic</key>
<false/>
<key>LegacyCommpage</key>
<false/>
<key>PanicNoKextDump</key>
<true/>
<key>PowerTimeoutKernelPanic</key>
<true/>
<key>ProvideCurrentCpuInfo</key>
<false/>
<key>SetApfsTrimTimeout</key>
<key>ThirdPartyDrives</key>
<false/>
<key>XhciPortLimit</key>
<false/>
</dict>
<key>Scheme</key>
<dict>
<key>CustomKernel</key>
<false/>
<key>FuzzyMatch</key>
<false/>
<key>KernelArch</key>
<string>Auto</string>
<key>KernelCache</key>
</dict>
</dict>
<key>Misc</key>
<dict>
<key>BlessOverride</key>
<array/>
<key>Boot</key>
<dict>
<key>ConsoleAttributes</key>
<key>HibernateMode</key>
<string>None</string>
<key>HibernateSkipsPicker</key>
<true/>
<key>HideAuxiliary</key>
<false/>
<key>InstanceIdentifier</key>
<string></string>
<key>LauncherOption</key>
<string>Full</string>
<key>LauncherPath</key>
<string>Default</string>
<key>PickerAttributes</key>
<integer>17</integer>
<key>PickerAudioAssist</key>
<false/>
<key>PickerMode</key>
<string>External</string>
<key>PickerVariant</key>
<key>PollAppleHotKeys</key>
<true/>
<key>ShowPicker</key>
<true/>
<key>TakeoffDelay</key>
<key>Timeout</key>
<integer>5</integer>
</dict>
<key>Debug</key>
<dict>
<key>AppleDebug</key>
<true/>
<key>ApplePanic</key>
<true/>
<key>DisableWatchDog</key>
<true/>
<key>DisplayDelay</key>
<key>DisplayLevel</key>
<integer>2147483650</integer>
<key>LogModules</key>
<string>*</string>
<key>SysReport</key>
<false/>
<key>Target</key>
<integer>67</integer>
</dict>
<key>Entries</key>
<array/>
<key>Security</key>
<dict>
<key>AllowSetDefault</key>
<true/>
<key>ApECID</key>
<key>AuthRestart</key>
<false/>
<key>BlacklistAppleUpdate</key>
<true/>
<key>DmgLoading</key>
<string>Signed</string>
<key>EnablePassword</key>
<false/>
<key>ExposeSensitiveData</key>
<integer>6</integer>
<key>HaltLevel</key>
<integer>2147483648</integer>
<key>PasswordHash</key>
<data></data>
<key>PasswordSalt</key>
<data></data>
<key>ScanPolicy</key>
<key>SecureBootModel</key>
<string>Disabled</string>
<key>Vault</key>
<string>Optional</string>
</dict>
<key>Serial</key>
<dict>
<key>Custom</key>
<dict>
<key>BaudRate</key>
<integer>115200</integer>
<key>ClockRate</key>
<integer>1843200</integer>
<key>DetectCable</key>
<false/>
<key>ExtendedTxFifoSize</key>
<integer>64</integer>
<key>FifoControl</key>
<integer>7</integer>
<key>LineControl</key>
<key>PciDeviceInfo</key>
<data>/w==</data>
<key>RegisterAccessWidth</key>
<integer>8</integer>
<key>RegisterBase</key>
<integer>1016</integer>
<key>RegisterStride</key>
<integer>1</integer>
<key>UseHardwareFlowControl</key>
<false/>
<key>UseMmio</key>
<false/>
</dict>
<key>Init</key>
<false/>
<key>Override</key>
<false/>
</dict>
<key>Tools</key>
<array>
<dict>
<key>Arguments</key>
<string></string>
<key>Auxiliary</key>
<true/>
<key>Comment</key>
<string></string>
<key>Enabled</key>
<true/>
<key>Flavour</key>
<key>FullNvramAccess</key>
<false/>
<key>Name</key>
<string>OpenShell</string>
<key>Path</key>
<string>OpenShell.efi</string>
<key>RealPath</key>
<false/>
<key>TextMode</key>
<false/>
</dict>
</array>
</dict>
<key>NVRAM</key>
<dict>
<key>Add</key>
<dict>
<key>4D1EDE05-38C7-4A6A-9CC6-4BCCA8B38C14</key>
<dict>
<key>DefaultBackgroundColor</key>
<data>AAAAAA==</data>
</dict>
<key>4D1FDA02-38C7-4A6A-9CC6-4BCCA8B30102</key>
<dict>
<key>rtc-blacklist</key>
<string></string>
</dict>
<key>7C436110-AB2A-4BBB-A880-FE41995C9F82</key>
<dict>
<key>SystemAudioVolume</key>
<data>Rg==</data>
<key>boot-args</key>
<string>-v keepsyms=1 debug=0x100 alcid=1</string>
<key>csr-active-config</key>
<key>prev-lang:kbd</key>
<data>dHI6VFI6LTM2</data>
<key>run-efi-updater</key>
<string>No</string>
</dict>
</dict>
<key>Delete</key>
<dict>
<array>
<string>DefaultBackgroundColor</string>
</array>
<array>
<string>rtc-blacklist</string>
</array>
<array>
<string>boot-args</string>
</array>
</dict>
<key>LegacyOverwrite</key>
<true/>
<key>LegacySchema</key>
<dict>
<array>
<string>EFILoginHiDPI</string>
<string>EFIBluetoothDelay</string>
<string>LocationServicesEnabled</string>
<string>SystemAudioVolume</string>
<string>SystemAudioVolumeDB</string>
<string>SystemAudioVolumeSaved</string>
<string>bluetoothActiveControllerInfo</string>
<string>bluetoothInternalControllerInfo</string>
<string>flagstate</string>
<string>fmm-computer-name</string>
<string>nvda_drv</string>
<string>prev-lang:kbd</string>
</array>
<key>8BE4DF61-93CA-11D2-AA0D-00E098032B8C</key>
<array>
<string>Boot0080</string>
<string>Boot0081</string>
<string>Boot0082</string>
<string>BootNext</string>
<string>BootOrder</string>
</array>
</dict>
<key>WriteFlash</key>
<true/>
</dict>
<key>PlatformInfo</key>
<dict>
<key>Automatic</key>
<true/>
<key>CustomMemory</key>
<false/>
<key>Generic</key>
<dict>
<key>AdviseFeatures</key>
<false/>
<key>MLB</key>
<string>F5K329130J9FHDDJC</string>
<key>MaxBIOSVersion</key>
<false/>
<key>ProcessorType</key>
<key>ROM</key>
<data>ESIzRFVm</data>
<key>SpoofVendor</key>
<true/>
<key>SystemMemoryStatus</key>
<key>SystemProductName</key>
<string>MacPro6,1</string>
<key>SystemSerialNumber</key>
<string>F5KL308SF9VM</string>
<key>SystemUUID</key>
<string>C1108362-EC55-4818-8D0D-C37A512A0DB2</string>
</dict>
<key>UpdateDataHub</key>
<true/>
<key>UpdateNVRAM</key>
<true/>
<key>UpdateSMBIOS</key>
<true/>
<key>UpdateSMBIOSMode</key>
<string>Create</string>
<key>UseRawUuidEncoding</key>
<false/>
</dict>
<key>UEFI</key>
<dict>
<key>APFS</key>
<dict>
<key>EnableJumpstart</key>
<true/>
<key>GlobalConnect</key>
<false/>
<key>HideVerbose</key>
<true/>
<key>JumpstartHotPlug</key>
<false/>
<key>MinDate</key>
<key>MinVersion</key>
</dict>
<key>AppleInput</key>
<dict>
<key>AppleEvent</key>
<key>CustomDelays</key>
<false/>
<key>GraphicsInputMirroring</key>
<false/>
<key>KeyInitialDelay</key>
<integer>50</integer>
<key>KeySubsequentDelay</key>
<key>PointerDwellClickTimeout</key>
<key>PointerDwellDoubleClickTimeout</key>
<key>PointerDwellRadius</key>
<key>PointerPollMask</key>
<key>PointerPollMax</key>
<integer>80</integer>
<key>PointerPollMin</key>
<integer>10</integer>
<key>PointerSpeedDiv</key>
<key>PointerSpeedMul</key>
</dict>
<key>Audio</key>
<dict>
<key>AudioCodec</key>
<key>AudioDevice</key>
<string>PciRoot(0x0)/Pci(0x1b,0x0)</string>
<key>AudioOutMask</key>
<key>AudioSupport</key>
<false/>
<key>DisconnectHda</key>
<false/>
<key>MaximumGain</key>
<integer>-15</integer>
<key>MinimumAssistGain</key>
<integer>-30</integer>
<key>MinimumAudibleGain</key>
<integer>-55</integer>
<key>PlayChime</key>
<key>ResetTrafficClass</key>
<false/>
<key>SetupDelay</key>
</dict>
<key>ConnectDrivers</key>
<true/>
<key>Drivers</key>
<array>
<dict>
<string></string>
<key>Comment</key>
<string></string>
<key>Enabled</key>
<false/>
<key>LoadEarly</key>
<false/>
<key>Path</key>
<string>HfsPlus.efi</string>
</dict>
<dict>
<string></string>
<key>Comment</key>
<string></string>
<key>Enabled</key>
<true/>
<false/>
<key>Path</key>
<string>HfsPlusLegacy.efi</string>
</dict>
<dict>
<string></string>
<key>Comment</key>
<string></string>
<key>Enabled</key>
<true/>
<false/>
<key>Path</key>
<string>OpenCanopy.efi</string>
</dict>
<dict>
<string></string>
<key>Comment</key>
<string></string>
<key>Enabled</key>
<true/>
<false/>
<key>Path</key>
<string>OpenRuntime.efi</string>
</dict>
<dict>
<string></string>
<key>Comment</key>
<string></string>
<key>Enabled</key>
<false/>
<false/>
<key>Path</key>
<string>OpenUsbKbDxe.efi</string>
</dict>
<dict>
<string></string>
<key>Comment</key>
<string></string>
<key>Enabled</key>
<false/>
<false/>
<key>Path</key>
<string>Ps2KeyboardDxe.efi</string>
</dict>
<dict>
<string></string>
<key>Comment</key>
<string></string>
<key>Enabled</key>
<true/>
<false/>
<key>Path</key>
<string>ToggleSipEntry.efi</string>
</dict>
<dict>
<string></string>
<key>Comment</key>
<string></string>
<key>Enabled</key>
<true/>
<false/>
<key>Path</key>
<string>ResetNvramEntry.efi</string>
</dict>
</array>
<key>Input</key>
<dict>
<key>KeyFiltering</key>
<false/>
<key>KeyForgetThreshold</key>
<key>KeySupport</key>
<false/>
<key>KeySupportMode</key>
<key>KeySwap</key>
<false/>
<key>PointerSupport</key>
<false/>
<key>PointerSupportMode</key>
<string>ASUS</string>
<key>TimerResolution</key>
<integer>50000</integer>
</dict>
<key>Output</key>
<dict>
<key>ClearScreenOnModeSwitch</key>
<false/>
<key>ConsoleFont</key>
<string></string>
<key>ConsoleMode</key>
<string></string>
<key>DirectGopRendering</key>
<false/>
<key>ForceResolution</key>
<false/>
<key>GopBurstMode</key>
<false/>
<key>GopPassThrough</key>
<key>IgnoreTextInGraphics</key>
<false/>
<key>InitialMode</key>
<key>ProvideConsoleGop</key>
<true/>
<key>ReconnectGraphicsOnConnect</key>
<false/>
<key>ReconnectOnResChange</key>
<false/>
<key>ReplaceTabWithSpace</key>
<false/>
<key>Resolution</key>
<string>Max</string>
<key>SanitiseClearScreen</key>
<false/>
<key>TextRenderer</key>
<string>BuiltinGraphics</string>
<key>UIScale</key>
<key>UgaPassThrough</key>
<false/>
</dict>
<key>ProtocolOverrides</key>
<dict>
<key>AppleAudio</key>
<false/>
<key>AppleBootPolicy</key>
<false/>
<key>AppleDebugLog</key>
<false/>
<key>AppleEg2Info</key>
<false/>
<key>AppleFramebufferInfo</key>
<false/>
<key>AppleImageConversion</key>
<false/>
<key>AppleImg4Verification</key>
<false/>
<key>AppleKeyMap</key>
<false/>
<key>AppleRtcRam</key>
<false/>
<key>AppleSecureBoot</key>
<false/>
<key>AppleSmcIo</key>
<false/>
<key>AppleUserInterfaceTheme</key>
<false/>
<key>DataHub</key>
<false/>
<false/>
<key>FirmwareVolume</key>
<false/>
<key>HashServices</key>
<false/>
<key>OSInfo</key>
<false/>
<key>PciIo</key>
<false/>
<key>UnicodeCollation</key>
<false/>
</dict>
<key>Quirks</key>
<dict>
<key>ActivateHpetSupport</key>
<false/>
<key>DisableSecurityPolicy</key>
<false/>
<key>EnableVectorAcceleration</key>
<false/>
<key>EnableVmx</key>
<false/>
<key>ExitBootServicesDelay</key>
<key>ForceOcWriteFlash</key>
<false/>
<key>ForgeUefiSupport</key>
<false/>
<key>IgnoreInvalidFlexRatio</key>
<true/>
<key>ReleaseUsbOwnership</key>
<false/>
<key>ReloadOptionRoms</key>
<false/>
<key>RequestBootVarRouting</key>
<true/>
<key>ResizeGpuBars</key>
<key>ResizeUsePciRbIo</key>
<false/>
<key>ShimRetainProtocol</key>
<false/>
<key>TscSyncTimeout</key>
<key>UnblockFsConnect</key>
<false/>
</dict>
<key>ReservedMemory</key>
<array/>
</dict>
</dict>
</plist>
[/CODE]
Config dosyasını kendiniz mi düzenlediniz yoksa hazır mı aldınız? Girmiyor sisteme dediğiniz ne tür bir girmemek acaba? Hiç boot etmiyor mu? Bu arada size tavsiyem o sisteme OCLP ile daha üst sürüm deneyin. High Sierra çok eski.
Hocam mesela sistemde hem Arch Linux USB'si takılı, hem Windows format USB'si hem de MacOS USB'si var. Ancak MacOS USB'sinden açmaya çalışınca direkt Arch Linux USB'sine atıyor, BIOS menüsündeki boot optionstan seçince format menüsüne atmıyor MacOS'in, direkt BIOS'a geri atıyor.
Config dosyasını iso dosyasının içinden çıkardım, Ivy Bridge yazan bir tanesiydi.
USB belleğin içinde adı "boot7" olan dosyanın adını düz boot yapıp, normalde düz boot olan dosyayı bootyedek gibi bir isimle değiştirip açmayı dener misin?
Hemen gelişmeleri aktaracağım hocam.
Hocam yaptım, girdi ama UEFI sürücüleri unauthorized dedi, ben de UEFI'yi other OS yapıp CSM'yi kapadım, şimdi tekrar deneyeceğim.
@umut hocam UEFI'yi other OS yapıp, CSM'yi kapatıp, virtualization ayarını da kapayınca direkt Windows boot managerdan başlattı.
Secure Boot açıksa kapatıp dene yine boot etmezse.
Bir dakika bakayım hocam.
Secure boot menüsünde sadece other OS ve Windows UEFI var hocam.
Other OS seçtikten sonra CSM açık şekilde bir boot etmeyi dener misin USB'den?
