Mehmet Doğaç Gezer
- 30 Ocak 2025
SYSTEM_SERVICE_EXCEPTION (3b)
An exception happened while executing a system service routine.
Arguments:
Arg1: 00000000c0000005, Exception code that caused the BugCheck
Arg2: fffff8053e117f38, Address of the instruction which caused the BugCheck
Arg3: fffff08e8fb2e9e0, Address of the context record for the exception that caused the BugCheck
Arg4: 0000000000000000, zero.
Debugging Details:
KEY_VALUES_STRING: 1
Key : Analysis.CPU.mSec
Value: 1375
Key : Analysis.Elapsed.mSec
Value: 3127
Key : Analysis.IO.Other.Mb
Value: 0
Key : Analysis.IO.Read.Mb
Value: 1
Key : Analysis.IO.Write.Mb
Value: 2
Key : Analysis.Init.CPU.mSec
Value: 328
Value: 5523
Value: 91
Key : Analysis.Version.DbgEng
Value: 10.0.27725.1000
Key : Analysis.Version.Description
Value: 10.2408.27.01 amd64fre
Key : Analysis.Version.Ext
Value: 1.2408.27.1
Key : Bugcheck.Code.LegacyAPI
Value: 0x3b
Key : Bugcheck.Code.TargetModel
Value: 0x3b
Key : Dump.Attributes.AsUlong
Value: 21808
Key : Dump.Attributes.DiagDataWrittenToHeader
Value: 1
Key : Dump.Attributes.ErrorCode
Value: 0
Key : Dump.Attributes.KernelGeneratedTriageDump
Value: 1
Key : Dump.Attributes.LastLine
Key : Dump.Attributes.ProgressPercentage
Value: 0
Key : Failure.Bucket
Value: AV_FLTMGR!FltpPerformPreCallbacksWorker
Key : Failure.Hash
Value: {a374902e-70dc-42ac-3104-3d5a9649eb03}
Key : Hypervisor.Enlightenments.ValueHex
Value: 7417df84
Key : Hypervisor.Flags.AnyHypervisorPresent
Value: 1
Key : Hypervisor.Flags.ApicEnlightened
Value: 0
Key : Hypervisor.Flags.ApicVirtualizationAvailable
Value: 1
Key : Hypervisor.Flags.AsyncMemoryHint
Value: 0
Key : Hypervisor.Flags.CoreSchedulerRequested
Value: 0
Key : Hypervisor.Flags.CpuManager
Value: 1
Key : Hypervisor.Flags.DeprecateAutoEoi
Value: 1
Key : Hypervisor.Flags.DynamicCpuDisabled
Value: 1
Key : Hypervisor.Flags.Epf
Value: 0
Key : Hypervisor.Flags.ExtendedProcessorMasks
Value: 1
Key : Hypervisor.Flags.HardwareMbecAvailable
Value: 1
Key : Hypervisor.Flags.MaxBankNumber
Value: 0
Key : Hypervisor.Flags.MemoryZeroingControl
Value: 0
Key : Hypervisor.Flags.NoExtendedRangeFlush
Value: 0
Key : Hypervisor.Flags.NoNonArchCoreSharing
Value: 1
Key : Hypervisor.Flags.Phase0InitDone
Value: 1
Key : Hypervisor.Flags.PowerSchedulerQos
Value: 0
Key : Hypervisor.Flags.RootScheduler
Value: 0
Key : Hypervisor.Flags.SynicAvailable
Value: 1
Key : Hypervisor.Flags.UseQpcBias
Value: 0
Key : Hypervisor.Flags.Value
Value: 55185662
Key : Hypervisor.Flags.ValueHex
Value: 34a10fe
Key : Hypervisor.Flags.VpAssistPage
Value: 1
Key : Hypervisor.Flags.VsmAvailable
Value: 1
Key : Hypervisor.RootFlags.AccessStats
Value: 1
Key : Hypervisor.RootFlags.CrashdumpEnlightened
Value: 1
Key : Hypervisor.RootFlags.CreateVirtualProcessor
Value: 1
Key : Hypervisor.RootFlags.DisableHyperthreading
Value: 0
Key : Hypervisor.RootFlags.HostTimelineSync
Value: 1
Key : Hypervisor.RootFlags.HypervisorDebuggingEnabled
Value: 0
Key : Hypervisor.RootFlags.IsHyperV
Value: 1
Key : Hypervisor.RootFlags.LivedumpEnlightened
Value: 1
Key : Hypervisor.RootFlags.MapDeviceInterrupt
Value: 1
Key : Hypervisor.RootFlags.MceEnlightened
Value: 1
Key : Hypervisor.RootFlags.Nested
Value: 0
Key : Hypervisor.RootFlags.StartLogicalProcessor
Value: 1
Key : Hypervisor.RootFlags.Value
Value: 1015
Key : Hypervisor.RootFlags.ValueHex
Value: 3f7
BUGCHECK_CODE: 3b
BUGCHECK_P1: c0000005
BUGCHECK_P2: fffff8053e117f38
BUGCHECK_P3: fffff08e8fb2e9e0
BUGCHECK_P4: 0
FILE_IN_CAB: 013025-12062-01.dmp
TAG_NOT_DEFINED_202b: *** Unknown TAG in analysis list 202b
DUMP_FILE_ATTRIBUTES: 0x21808
Kernel Generated Triage Dump
FAULTING_THREAD: ffffd0082811c040
CONTEXT: fffff08e8fb2e9e0 -- (.cxr 0xfffff08e8fb2e9e0)
rax=0000000000000000 rbx=ffffd008214cd010 rcx=ffffd00828e3b0d0
rdx=ffffd0082811c040 rsi=ffffd00827146430 rdi=ffffd008214cd0f8
rip=fffff8053e117f38 rsp=fffff08e8fb2f430 rbp=fffff08e8fb2f530
r8=0000000000000000 r9=0000000000000001 r10=fffff805ac7df3a0
r11=ffffd0082811c040 r12=0000000000000000 r13=ffffd0081e9e4500
r14=ffffd00827146010 r15=ffffd00828e3b0d0
iopl=0 nv up ei pl zr na po nc
cs=0010 ss=0018 ds=002b es=002b fs=0053 gs=002b efl=00050246
FLTMGR!FltpPerformPreCallbacksWorker+0x298:
fffff805`3e117f38 488bd0 mov rdx,rax
Resetting default scope
BLACKBOXBSD: 1 (!blackboxbsd)
BLACKBOXWINLOGON: 1
CUSTOMER_CRASH_COUNT: 1
PROCESS_NAME: TiWorker.exe
STACK_TEXT:
fffff08e`8fb2f430 fffff805`3e11946a : fffff08e`8fb2f740 fffff08e`8fb2f700 ffffd008`214cd000 fffff805`3e11d200 : FLTMGR!FltpPerformPreCallbacksWorker+0x298
fffff08e`8fb2f620 fffff805`3e17caa2 : fffff08e`8fb29000 00000000`00000000 ffffd008`28e3b0d0 00000000`00000000 : FLTMGR!FltpPassThroughFastIo+0xda
fffff08e`8fb2f710 fffff805`acc94834 : fffff08e`8fb2f800 00000000`00000000 00000000`00000000 fffff805`3e17c930 : FLTMGR!FltpFastIoWrite+0x172
fffff08e`8fb2f7c0 fffff805`acc9447f : ffffd008`28e3b0d0 ffffd008`28e3b0a0 00000000`00000000 00000000`00000000 : nt!IopWriteFile+0x1c4
fffff08e`8fb2f8e0 fffff805`aca8d355 : 00000000`0012019f 00000000`00000000 00000000`00000000 00000000`00000000 : nt!NtWriteFile+0x2cf
fffff08e`8fb2f9b0 00007ffb`696ff824 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!KiSystemServiceCopyEnd+0x25
000000e7`44dfb9d8 00000000`00000000 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : 0x00007ffb`696ff824
SYMBOL_NAME: FLTMGR!FltpPerformPreCallbacksWorker+298
MODULE_NAME: FLTMGR
IMAGE_NAME: FLTMGR.SYS
IMAGE_VERSION: 10.0.26100.2605
STACK_COMMAND: .cxr 0xfffff08e8fb2e9e0 ; kb
BUCKET_ID_FUNC_OFFSET: 298
FAILURE_BUCKET_ID: AV_FLTMGR!FltpPerformPreCallbacksWorker
OSPLATFORM_TYPE: x64
OSNAME: Windows 10
FAILURE_ID_HASH: {a374902e-70dc-42ac-3104-3d5a9649eb03}
Followup: MachineOwner
[SMBIOS Data Tables v3.6]
[DMI Version - 0]
[2.0 Calling Convention - No]
[Table Size - 5307 bytes]
Vendor American Megatrends International, LLC.
BIOS Version 1.50
BIOS Release Date 07/11/2023
BIOS ROM Size 1000000
BIOS Characteristics
07: - PCI Supported
11: - Upgradeable FLASH BIOS
15: - CD-Boot Supported
17: - BIOS ROM Socketed
19: - EDD Supported
22: - 360KB Floppy Supported
23: - 1.2MB Floppy Supported
24: - 720KB Floppy Supported
25: - 2.88MB Floppy Supported
27: - Keyboard Services Supported
32: - BIOS Vendor Reserved
00: - ACPI Supported
01: - USB Legacy Supported
BIOS Major Revision 5
BIOS Minor Revision 27
EC Firmware Major Revision 255
EC Firmware Minor Revision 255
Extended BIOS ROM Size 32 MB
Manufacturer Micro-Star International Co., Ltd.
Product Name MS-7D88
Version 1.0
Serial Number Default string
UUID 00000000-0000-0000-0000-000000000000
Wakeup Type Power Switch
SKUNumber Default string
Family Default string
Product PRO Z790-S WIFI (MS-7D88)
Version 1.0
Serial Number 07D8810_N91E164870
Asset Tag
Feature Flags 09h
00: - Motherboard
03: - Replaceable
Location Default string
Chassis Handle 0003h
Board Type 0ah - Processor/Memory Module
Number of Child Handles 0
Chassis Type Desktop
Version 1.0
Serial Number
Asset Tag Number
Bootup State Safe
Power Supply State Safe
Thermal State Safe
Security Status None
OEM Defined 0
Height 0U
Number of Power Cords 1
Number of Contained Elements 0
Contained Element Size 3
[OEM Strings (Type 11) - Length 5 - Handle 0021h]
Number of Strings 1
1 Default string
[System Configuration Options (Type 12) - Length 5 - Handle 0022h]
[ (Type 256) - Length 9 - Handle 0039h]
[Physical Memory Array (Type 16) - Length 23 - Handle 003ah]
Location 03h - SystemBoard/Motherboard
Use 03h - System Memory
Memory Error Correction 03h - None
Maximum Capacity 134217728KB
Memory Error Inf Handle [Not Provided]
Number of Memory Devices 4
[Memory Device (Type 17) - Length 92 - Handle 003bh]
Memory Error Info Handle [Not Provided]
Total Width 64 bits
Data Width 64 bits
Size 16384MB
Form Factor 09h - DIMM
Device Set [None]
Device Locator Controller0-DIMMA1
Bank Locator BANK 0
Memory Type 22h - DDR5
Type Detail 0080h - Synchronous
Speed 4000MHz
Manufacturer Corsair
Serial Number
Asset Tag Number
Part Number CMH32GX5M2D6000C36
Attributes 1
Extended Size 0
Configured Memory Speed 4000
Minimum Voltage 1100
Maximum Voltage 1350
Configured Voltage 1100
Memory Technology 3
Memory Operating Mode Capability 8
Firmware Version 0
Module Manufacturer Id 40450
Module Product Id 0
Memory Subsystem Controller Manufacturer Id 0
Memory Subsystem Controller Product Id 0
Non-Volatile Size 0
Volatile Size 0
Cache Size 0
Logical Size 0
Extended Speed 0
Extended Configured Memory Speed 0
[Memory Device (Type 17) - Length 92 - Handle 003ch]
Total Width 64 bits
Data Width 64 bits
Size 16384MB
Device Set [None]
Device Locator Controller0-DIMMA2
Bank Locator BANK 0
Speed 4000MHz
Serial Number
Asset Tag Number
Attributes 1
Extended Size 0
Memory Technology 3
Firmware Version 0
Module Product Id 0
Non-Volatile Size 0
Volatile Size 0
Cache Size 0
Logical Size 0
Extended Speed 0
[Memory Device (Type 17) - Length 92 - Handle 003dh]
Total Width 64 bits
Data Width 64 bits
Size 16384MB
Device Set [None]
Device Locator Controller1-DIMMB1
Bank Locator BANK 0
Speed 4000MHz
Serial Number
Asset Tag Number
Attributes 1
Extended Size 0
Memory Technology 3
Firmware Version 0
Module Product Id 0
Non-Volatile Size 0
Volatile Size 0
Cache Size 0
Logical Size 0
Extended Speed 0
[Memory Device (Type 17) - Length 92 - Handle 003eh]
Total Width 64 bits
Data Width 64 bits
Size 16384MB
Device Set [None]
Device Locator Controller1-DIMMB2
Bank Locator BANK 0
Speed 4000MHz
Serial Number
Asset Tag Number
Attributes 1
Extended Size 0
Memory Technology 3
Firmware Version 0
Module Product Id 0
Non-Volatile Size 0
Volatile Size 0
Cache Size 0
Logical Size 0
Extended Speed 0
[Memory Array Mapped Address (Type 19) - Length 31 - Handle 003fh]
Starting Address 00000000h
Ending Address 03ffffffh
Memory Array Handle 003ah
Partition Width 04
Extended Starting Address 0000000000000000h
Extended Ending Address 0000000000000000h
[ (Type 256) - Length 31 - Handle 0040h]
[ (Type 256) - Length 26 - Handle 0041h]
[Memory Device Mapped Address (Type 20) - Length 35 - Handle 0042h]
Ending Address 00ffffffh
Memory Device Handle 003bh
Mem Array Mapped Adr Handle 003fh
Partition Row Position [Unknown]
[Memory Device Mapped Address (Type 20) - Length 35 - Handle 0043h]
Starting Address 01000000h
Ending Address 01ffffffh
Memory Device Handle 003ch
[Memory Device Mapped Address (Type 20) - Length 35 - Handle 0044h]
Starting Address 02000000h
Ending Address 02ffffffh
Memory Device Handle 003dh
[Memory Device Mapped Address (Type 20) - Length 35 - Handle 0045h]
Starting Address 03000000h
Memory Device Handle 003eh
[ (Type 256) - Length 12 - Handle 0046h]
[ (Type 256) - Length 26 - Handle 0047h]
[ (Type 256) - Length 26 - Handle 0048h]
[ (Type 256) - Length 47 - Handle 0049h]
[ (Type 256) - Length 82 - Handle 004ah]
[Cache Information (Type 7) - Length 27 - Handle 004bh]
Socket Designation L1 Cache
Cache Configuration 0180h - WBEnabled Int NonSocketed L1
Maximum Cache Size 0180h - 384K
Installed Size 0180h - 384K
Supported SRAM Type 0020h - Synchronous
Current SRAM Type 0020h - Synchronous
Cache Speed 0ns
Error Correction Type ParitySingle-Bit ECC
System Cache Type Data
Associativity 12-way Set-Associative
Maximum Cache Size 2 180 - 00000384l Kb
Installed Cache Size 2 180 - 00000384l Kb
[Cache Information (Type 7) - Length 27 - Handle 004ch]
Maximum Cache Size 0100h - 256K
Installed Size 0100h - 256K
Cache Speed 0ns
System Cache Type Instruction
Associativity 8-way Set-Associative
Maximum Cache Size 2 100 - 00000256l Kb
Installed Cache Size 2 100 - 00000256l Kb
[Cache Information (Type 7) - Length 27 - Handle 004dh]
Socket Designation L2 Cache
Cache Configuration 0181h - WBEnabled Int NonSocketed L2
Maximum Cache Size 4000h - 16384K
Installed Size 4000h - 16384K
Cache Speed 0ns
Error Correction Type Multi-Bit ECC
System Cache Type Unified
Associativity 16-way Set-Associative
Maximum Cache Size 2 4000 - 00016384l Kb
Installed Cache Size 2 4000 - 00016384l Kb
[Cache Information (Type 7) - Length 27 - Handle 004eh]
Socket Designation L3 Cache
Cache Configuration 0182h - WBEnabled Int NonSocketed L3
Maximum Cache Size 8240h - 36864K
Installed Size 8240h - 36864K
Cache Speed 0ns
Error Correction Type Specification Reserved
Maximum Cache Size 2 80000240 - 00036864l Kb
Installed Cache Size 2 80000240 - 00036864l Kb
[Cache Information (Type 7) - Length 27 - Handle 004fh]
Maximum Cache Size 0200h - 512K
Installed Size 0200h - 512K
Cache Speed 0ns
Maximum Cache Size 2 200 - 00000512l Kb
Installed Cache Size 2 200 - 00000512l Kb
[Cache Information (Type 7) - Length 27 - Handle 0050h]
Maximum Cache Size 0400h - 1024K
Installed Size 0400h - 1024K
Cache Speed 0ns
Maximum Cache Size 2 400 - 00001024l Kb
Installed Cache Size 2 400 - 00001024l Kb
[Cache Information (Type 7) - Length 27 - Handle 0051h]
Cache Speed 0ns
[Cache Information (Type 7) - Length 27 - Handle 0052h]
Cache Speed 0ns
[Processor Information (Type 4) - Length 48 - Handle 0053h]
Socket Designation U3E1
Processor Type Central Processor
Processor Family cfh - Intel Core 2 Quad processor
Processor Manufacturer Intel(R) Corporation
Processor ID 71060b00fffbebbf
Processor Version Intel(R) Core(TM) i9-14900KS
Processor Voltage 89h - 0.9V
External Clock 100MHz
Max Speed 8500MHz
Current Speed 3168MHz
Status Enabled Populated
Processor Upgrade Specification Reserved
L1 Cache Handle 0050h
L2 Cache Handle 0051h
L3 Cache Handle 0052h
Serial Number
Asset Tag Number
Part Number To Be Filled By O.E.M.
Core Count 24
Core Enabled 24
Thread Count 32
Processor Characteristics fc
Enabled Characteristics:
0x 2: 64-bit Capable
0x 3: Multi-Core
0x 4: Hardware Thread
0x 5: Execute Protection
0x 6: Enhanced Virtualization
Processor Family 2 00cfh - Intel Core 2 Quad processor
Core Count 2 24
Core Enabled 2 24
Thread Count 2 32
[ (Type 256) - Length 64 - Handle 0054h]
[ (Type 256) - Length 11 - Handle 0055h]
[ (Type 256) - Length 11 - Handle 0056h]
[ (Type 256) - Length 11 - Handle 0057h]
[ (Type 256) - Length 11 - Handle 0058h]
[ (Type 256) - Length 11 - Handle 0059h]
[ (Type 256) - Length 11 - Handle 005ah]
[ (Type 256) - Length 11 - Handle 005bh]
[ (Type 256) - Length 11 - Handle 005ch]
[ (Type 256) - Length 11 - Handle 005dh]
[ (Type 256) - Length 11 - Handle 005eh]
[ (Type 256) - Length 11 - Handle 005fh]
[ (Type 256) - Length 11 - Handle 0060h]
[ (Type 256) - Length 103 - Handle 0061h]
[ (Type 256) - Length 16 - Handle 0062h]
[ (Type 256) - Length 44 - Handle 0063h]
[ (Type 256) - Length 8 - Handle 0064h]
[ (Type 256) - Length 106 - Handle 0066h]
[ (Type 256) - Length 6 - Handle 0067h]
[ (Type 256) - Length 4 - Handle 0069h]
Arguments:
Debugging Details:
Value: 1375
Value: 3127
Value: 0
Value: 1
Value: 2
Value: 328
Value: 5523
Value: 91
Value: 1.2408.27.1
Value: 0x3b
Value: 0x3b
Value: 21808
Value: 1
Value: 0
Value: 1
Value: 0
Key : Failure.Hash
Value: 7417df84
Value: 1
Value: 0
Value: 1
Value: 0
Value: 0
Value: 1
Value: 1
Value: 1
Value: 0
Value: 1
Value: 1
Value: 0
Value: 0
Value: 0
Value: 1
Value: 1
Value: 0
Value: 0
Value: 1
Value: 0
Value: 55185662
Value: 34a10fe
Value: 1
Value: 1
Value: 1
Value: 1
Value: 1
Value: 0
Value: 1
Value: 0
Value: 1
Value: 1
Value: 1
Value: 1
Value: 0
Value: 1
Value: 1015
Value: 3f7
BUGCHECK_CODE: 3b
BUGCHECK_P4: 0
BLACKBOXWINLOGON: 1
STACK_TEXT:
MODULE_NAME: FLTMGR
OSNAME: Windows 10
[DMI Version - 0]
BIOS Version 1.50
07: - PCI Supported
19: - EDD Supported
Version 1.0
Version 1.0
Asset Tag
Feature Flags 09h
00: - Motherboard
03: - Replaceable
Version 1.0
Serial Number
Asset Tag Number
Bootup State Safe
Thermal State Safe
OEM Defined 0
Height 0U
Number of Strings 1
1 Default string
Total Width 64 bits
Data Width 64 bits
Size 16384MB
Device Set [None]
Bank Locator BANK 0
Speed 4000MHz
Serial Number
Asset Tag Number
Attributes 1
Extended Size 0
Memory Technology 3
Firmware Version 0
Module Product Id 0
Non-Volatile Size 0
Volatile Size 0
Cache Size 0
Logical Size 0
Extended Speed 0
Total Width 64 bits
Data Width 64 bits
Size 16384MB
Device Set [None]
Bank Locator BANK 0
Speed 4000MHz
Serial Number
Asset Tag Number
Attributes 1
Extended Size 0
Memory Technology 3
Firmware Version 0
Module Product Id 0
Non-Volatile Size 0
Volatile Size 0
Cache Size 0
Logical Size 0
Extended Speed 0
Total Width 64 bits
Data Width 64 bits
Size 16384MB
Device Set [None]
Bank Locator BANK 0
Speed 4000MHz
Serial Number
Asset Tag Number
Attributes 1
Extended Size 0
Memory Technology 3
Firmware Version 0
Module Product Id 0
Non-Volatile Size 0
Volatile Size 0
Cache Size 0
Logical Size 0
Extended Speed 0
Total Width 64 bits
Data Width 64 bits
Size 16384MB
Device Set [None]
Bank Locator BANK 0
Speed 4000MHz
Serial Number
Asset Tag Number
Attributes 1
Extended Size 0
Memory Technology 3
Firmware Version 0
Module Product Id 0
Non-Volatile Size 0
Volatile Size 0
Cache Size 0
Logical Size 0
Extended Speed 0
Partition Width 04
Cache Speed 0ns
Cache Speed 0ns
Cache Speed 0ns
Cache Speed 0ns
Cache Speed 0ns
Cache Speed 0ns
Cache Speed 0ns
Cache Speed 0ns
Max Speed 8500MHz
Serial Number
Asset Tag Number
Core Count 24
Core Enabled 24
Thread Count 32
0x 3: Multi-Core
Core Count 2 24
Core Enabled 2 24
Thread Count 2 32
We use cookies and similar technologies for the following purposes:
Do you accept cookies and these technologies?
