MEMORY_MANAGEMENT (1a) hata analizi
DragonSlayer
30 Aralık 2023
  • Anakart: B550 Gaming Plus.
  • İşlemci: 5700X3D.
  • Ekran kartı: 7800XT.
  • İşletim sistemi: Windows 11.
paylaşılacak - Google Drive
Durduk yere mavi ekran yedim. PC kendini yeniden başlattı. Ne yapmalıyım?
Bellek arızası diyor. Memtest ile bir test edin isterseniz.
Kod:
    # Any other values for parameter 1 must be individually examined.
Arguments:
Arg1: 0000000000041792, A corrupt PTE has been detected. Parameter 2 contains the address of
    the PTE. Parameters 3/4 contain the low/high parts of the PTE.
Arg2: ffffe480d0972600
Arg3: 0000000000040000
Arg4: 0000000000000000
Debugging Details:
KEY_VALUES_STRING: 1
    Key  : Analysis.CPU.mSec
    Value: 1156
    Key  : Analysis.Elapsed.mSec
    Value: 2765
    Key  : Analysis.IO.Other.Mb
    Value: 0
    Key  : Analysis.IO.Read.Mb
    Value: 1
    Key  : Analysis.IO.Write.Mb
    Value: 0
    Key  : Analysis.Init.CPU.mSec
    Value: 265
    Value: 2688
    Value: 88
    Value: 10.0.27793.1000
    Value: 10.2410.02.02 amd64fre
    Key  : Analysis.Version.Ext
    Value: 1.2410.2.2
    Value: 0x1a
    Value: 0x1a
    Value: 0x21808
    Value: 1
    Value: 0x0
    Value: 1
    Value: 0
    Key  : Failure.Bucket
    Value: MEMORY_CORRUPTION_ONE_BIT
    Key  : Failure.Hash
    Value: {e3faf315-c3d0-81db-819a-6c43d23c63a7}
    Key  : Hypervisor.Enlightenments.ValueHex
    Value: 0x7497cf94
    Key  : Hypervisor.Flags.AnyHypervisorPresent
    Value: 1
    Key  : Hypervisor.Flags.ApicEnlightened
    Value: 1
    Key  : Hypervisor.Flags.ApicVirtualizationAvailable
    Value: 0
    Key  : Hypervisor.Flags.AsyncMemoryHint
    Value: 0
    Key  : Hypervisor.Flags.CoreSchedulerRequested
    Value: 0
    Key  : Hypervisor.Flags.CpuManager
    Value: 1
    Key  : Hypervisor.Flags.DeprecateAutoEoi
    Value: 0
    Key  : Hypervisor.Flags.DynamicCpuDisabled
    Value: 1
    Key  : Hypervisor.Flags.Epf
    Value: 0
    Key  : Hypervisor.Flags.ExtendedProcessorMasks
    Value: 1
    Key  : Hypervisor.Flags.HardwareMbecAvailable
    Value: 1
    Key  : Hypervisor.Flags.MaxBankNumber
    Value: 0
    Key  : Hypervisor.Flags.MemoryZeroingControl
    Value: 0
    Key  : Hypervisor.Flags.NoExtendedRangeFlush
    Value: 0
    Key  : Hypervisor.Flags.NoNonArchCoreSharing
    Value: 1
    Key  : Hypervisor.Flags.Phase0InitDone
    Value: 1
    Key  : Hypervisor.Flags.PowerSchedulerQos
    Value: 0
    Key  : Hypervisor.Flags.RootScheduler
    Value: 0
    Key  : Hypervisor.Flags.SynicAvailable
    Value: 1
    Key  : Hypervisor.Flags.UseQpcBias
    Value: 0
    Key  : Hypervisor.Flags.Value
    Value: 38408431
    Key  : Hypervisor.Flags.ValueHex
    Value: 0x24a10ef
    Key  : Hypervisor.Flags.VpAssistPage
    Value: 1
    Key  : Hypervisor.Flags.VsmAvailable
    Value: 1
    Key  : Hypervisor.RootFlags.AccessStats
    Value: 1
    Key  : Hypervisor.RootFlags.CrashdumpEnlightened
    Value: 1
    Key  : Hypervisor.RootFlags.CreateVirtualProcessor
    Value: 1
    Key  : Hypervisor.RootFlags.DisableHyperthreading
    Value: 0
    Key  : Hypervisor.RootFlags.HostTimelineSync
    Value: 1
    Key  : Hypervisor.RootFlags.HypervisorDebuggingEnabled
    Value: 0
    Key  : Hypervisor.RootFlags.IsHyperV
    Value: 1
    Key  : Hypervisor.RootFlags.LivedumpEnlightened
    Value: 1
    Key  : Hypervisor.RootFlags.MapDeviceInterrupt
    Value: 1
    Key  : Hypervisor.RootFlags.MceEnlightened
    Value: 1
    Key  : Hypervisor.RootFlags.Nested
    Value: 0
    Key  : Hypervisor.RootFlags.StartLogicalProcessor
    Value: 1
    Key  : Hypervisor.RootFlags.Value
    Value: 1015
    Key  : Hypervisor.RootFlags.ValueHex
    Value: 0x3f7
    Key  : MemoryManagement.PFN
    Value: 0x40
BUGCHECK_CODE:  1a
BUGCHECK_P1: 41792
BUGCHECK_P2: ffffe480d0972600
BUGCHECK_P3: 40000
BUGCHECK_P4: 0
FILE_IN_CAB:  030125-9593-01.dmp
TAG_NOT_DEFINED_202b:  *** Unknown TAG in analysis list 202b
DUMP_FILE_ATTRIBUTES: 0x21808
  Kernel Generated Triage Dump
FAULTING_THREAD:  ffff8688f51910c0
MEMORY_CORRUPTOR:  ONE_BIT
BLACKBOXBSD: 1 (!blackboxbsd)
BLACKBOXPNP: 1 (!blackboxpnp)
BLACKBOXWINLOGON: 1
CUSTOMER_CRASH_COUNT:  1
PROCESS_NAME:  chrome.exe
STACK_TEXT:
ffffa08e`cddc4fc8 fffff801`a1c391f6     : 00000000`0000001a 00000000`00041792 ffffe480`d0972600 00000000`00040000 : nt!KeBugCheckEx
ffffa08e`cddc4fd0 fffff801`a1c378c7     : 00000000`00040000 00000000`00040000 00000000`00000001 ffffe480`d0972590 : nt!MiDecommitHandlePageFileFormatPte+0x212
ffffa08e`cddc5030 fffff801`a1c366e1     : ffff8689`00000082 ffff8689`00369480 ffffa08e`00000000 ffff8689`00369080 : nt!MiDeleteVa+0x197
ffffa08e`cddc50b0 fffff801`a1c48bce     : 00000000`00000000 ffff8689`00000000 ffffa08e`00000082 ffffffff`ffffffff : nt!MiDeleteVaDirect+0x2b1
ffffa08e`cddc51d0 fffff801`a1c489eb     : 7fffffff`fffffffc ffff8688`f51910c0 00000000`00000000 ffff8689`003692e0 : nt!MiDeletePagablePteRange+0x1ba
ffffa08e`cddc5490 fffff801`a229b730     : 00000000`00000000 ffffa08e`cddc5550 ffff8689`02123a60 ffffa08e`cddc5550 : nt!MiDeleteVirtualAddresses+0x4b
ffffa08e`cddc54e0 fffff801`a229b4f1     : 000001a1`2dcd0000 ffff8689`02123a60 ffff8689`02123a88 00000000`00000000 : nt!MiDeleteVad+0x180
ffffa08e`cddc5590 fffff801`a229b477     : ffff8689`02123a60 00000000`00000000 ffff8688`f51910c0 00000000`00000000 : nt!MiUnmapVad+0x49
ffffa08e`cddc55c0 fffff801`a229b29b     : ffff8689`021239c0 ffff8688`f51910c0 ffff8688`f51910c0 ffff8688`f51910c0 : nt!MiCleanVad+0x2b
ffffa08e`cddc55f0 fffff801`a229a8d2     : ffff8689`00000000 ffff8689`00369268 ffffa08e`cddc5760 00000000`00000000 : nt!MmCleanProcessAddressSpace+0xfb
ffffa08e`cddc5670 fffff801`a229a3c6     : ffff8689`00369080 ffff8689`00369080 ffffa08e`cddc5760 00000000`00000000 : nt!PspRundownSingleProcess+0xc2
ffffa08e`cddc5700 fffff801`a2357b1b     : 00000016`998b2000 00000000`00000000 ffffa08e`cddc5928 ffff8688`f51910c0 : nt!PspExitLastThread+0xe6
ffffa08e`cddc5790 fffff801`a2357174     : 00000000`00000001 fffff801`a1c72d01 00000000`00000000 00000000`00000000 : nt!PspExitThread+0x7bb
ffffa08e`cddc5880 fffff801`a1c6e00c     : 00000000`40eb0088 00000000`00000000 00000000`00000000 ffffb281`29162180 : nt!KiSchedulerApcTerminate+0x34
ffffa08e`cddc58c0 fffff801`a207dae0     : 00000000`00000000 ffffa08e`cddc5960 00000000`00000000 00000000`00000000 : nt!KiDeliverApc+0x47c
ffffa08e`cddc5960 fffff801`a208c60d     : 00000071`37431540 00000000`000005e4 ffffa08e`cddc5ab8 ffffffff`ff81cf50 : nt!KiInitiateUserApc+0x70
ffffa08e`cddc5aa0 00007ffc`0177f854     : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!KiSystemServiceExit+0xad
00000016`a69ff9d8 00000000`00000000     : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : 0x00007ffc`0177f854
MODULE_NAME: hardware
IMAGE_NAME:  memory_corruption
STACK_COMMAND:  .process /r /p 0xffff868900369080; .thread 0xffff8688f51910c0 ; kb
FAILURE_BUCKET_ID:  MEMORY_CORRUPTION_ONE_BIT
OSPLATFORM_TYPE:  x64
OSNAME:  Windows 10
FAILURE_ID_HASH:  {e3faf315-c3d0-81db-819a-6c43d23c63a7}
Followup:     MachineOwner
    PnpActivityId      : {00000000-0000-0000-0000-000000000000}
    PnpActivityTime    : 133852966331175240
    PnpEventInformation: 3
    PnpEventInProgress : 0
    PnpProblemCode     : 24
    PnpVetoType        : 0
    DeviceId           : DISPLAY\PHLC244\7&10cc816&a&UID260
    VetoString         :
[SMBIOS Data Tables v2.8]
[DMI Version - 0]
[2.0 Calling Convention - No]
[Table Size - 2651 bytes]
  Vendor                        American Megatrends International, LLC.
  BIOS Version                  1.I0
  BIOS Release Date             07/13/2024
  BIOS ROM Size                 1000000
  BIOS Characteristics
       07: - PCI Supported
       11: - Upgradeable FLASH BIOS
       15: - CD-Boot Supported
       17: - BIOS ROM Socketed
       19: - EDD Supported
       22: - 360KB Floppy Supported
       23: - 1.2MB Floppy Supported
       24: - 720KB Floppy Supported
       25: - 2.88MB Floppy Supported
       27: - Keyboard Services Supported
       32: - BIOS Vendor Reserved
       01: - USB Legacy Supported
  BIOS Major Revision           5
  BIOS Minor Revision           17
  EC Firmware Major Revision    255
  EC Firmware Minor Revision    255
  Extended BIOS ROM Size        32 MB
  Manufacturer                  Micro-Star International Co., Ltd.
  Product Name                  MS-7C56
  Version                       1.0
  Serial Number                 To be filled by O.E.M.
  SKUNumber                     To be filled by O.E.M.
  Family                        To be filled by O.E.M.
  Product                       MPG B550 GAMING PLUS (MS-7C56)
  Version                       1.0
  Asset Tag
       00: - Motherboard
       03: - Replaceable
  Location                      To be filled by O.E.M.
  Chassis Type                  Desktop
  Version                       1.0
  Serial Number
  Asset Tag Number
  Contained Element Size        3
[OEM Strings (Type 11) - Length 5 - Handle 000bh]
  Number of Strings             1
   1                            To be filled by O.E.M.
[System Configuration Options (Type 12) - Length 5 - Handle 000ch]
[ (Type 256) - Length 9 - Handle 000eh]
[ (Type 256) - Length 31 - Handle 000fh]
[32Bit Memory Error Information (Type 18) - Length 23 - Handle 0010h]
[Physical Memory Array (Type 16) - Length 23 - Handle 0011h]
  Maximum Capacity              134217728KB
  Memory Error Inf Handle       0010h
  Number of Memory Devices      4
[Memory Array Mapped Address (Type 19) - Length 31 - Handle 0012h]
  Ending Address                0037ffffh
  Memory Array Handle           0011h
[Memory Array Mapped Address (Type 19) - Length 31 - Handle 0013h]
  Starting Address              00400000h
  Ending Address                0207ffffh
[Cache Information (Type 7) - Length 19 - Handle 0014h]
  Socket Designation            L1 - Cache
  Maximum Cache Size            0200h - 512K
  Installed Size                0200h - 512K
  Supported SRAM Type           0010h - Pipeline-Burst
  Current SRAM Type             0010h - Pipeline-Burst
  Cache Speed                   1ns
  Maximum Cache Size 2          2d20314c - 757084492l Kb
[Cache Information (Type 7) - Length 19 - Handle 0015h]
  Socket Designation            L2 - Cache
  Maximum Cache Size            1000h - 4096K
  Installed Size                1000h - 4096K
  Cache Speed                   1ns
  Maximum Cache Size 2          2d20324c - 757084748l Kb
[Cache Information (Type 7) - Length 19 - Handle 0016h]
  Socket Designation            L3 - Cache
  Maximum Cache Size            8600h - 98304K
  Installed Size                8600h - 98304K
  Cache Speed                   1ns
  Associativity                 16-way Set-Associative
  Maximum Cache Size 2          2d20334c - 757085004l Kb
[Processor Information (Type 4) - Length 48 - Handle 0017h]
  Socket Designation            AM4
  Processor Family              6bh - AMD Zen Processor Family
  Processor Manufacturer        Advanced Micro Devices, Inc.
  Processor ID                   120fa200fffb8b17
  Processor Version             AMD Ryzen 7 5700X3D 8-Core Processor
  Processor Voltage             8bh - 1.1V
  Max Speed                     3400MHz
  Current Speed                 3000MHz
  Processor Upgrade             Socket AM4
  L1 Cache Handle               0014h
  L2 Cache Handle               0015h
  L3 Cache Handle               0016h
  Serial Number
  Asset Tag Number
  Part Number                   Unknown
  Core Count                    8
  Core Enabled                  8
  Thread Count                  16
  Processor Characteristics     fc
  Enabled Characteristics:
       0x 2: 64-bit Capable
       0x 3: Multi-Core
       0x 4: Hardware Thread
       0x 5: Execute Protection
       0x 6: Enhanced Virtualization
  Processor Family 2            006bh - AMD Zen Processor Family
  Core Count 2                  8
  Core Enabled 2                8
  Thread Count 2                16
Teşekkür ederim test edip sonucu buradan paylaşacağım.
@pesimist34 @Recep Baltaş. Testi başarıyla geçti RAM'ler hocam. Tavsiye ettiğiniz bir şey var mıdır bu durumda?
    6,1 MB · Görüntüleme: 61
    6 MB · Görüntüleme: 64
    4,6 MB · Görüntüleme: 65
XMP'yi kapatıp dener misiniz? Hata almaya devam ederseniz XMP'den RAM frekansını ve voltajını düşük miktarlarda düşürün. Her IMC her RAM'le tam uyumlu olmuyor maalesef.
RAM'leri JEDEC standartında çalıştır bir süre, AM4'de illaki performans düşüşü olacak ancak yavaş yavaş yükselterek bunu test edersin.
Ayrıca bütün bu işlemlerden önce BIOS güncellemesi yap güncel değilse.
Son beta sürümü hariç BIOS güncel. Hata almaya devam ederseniz demişsiniz ama testte hata çıkmadı hocam. Bir yanlış anlaşılma söz konusu sanırım.
Hata derken mavi ekran hatasını kastettim . Memtest86'yı başarıyla geçmese zaten direk RAM'ler bozuktu diye söylerdim.
@DragonSlayer , son durum nedir?
