PAGE_FAULT_IN_NONPAGED_AREA (50)
Invalid system memory was referenced. This cannot be protected by try-except.
Typically the address is just plain bad or it is pointing at freed memory.
Arguments:
Arg1: ffffa48f76708032, memory referenced.
Arg2: 0000000000000000, X64: bit 0 set if the fault was due to a not-present PTE.
bit 1 is set if the fault was due to a write, clear if a read.
bit 3 is set if the processor decided the fault was due to a corrupted PTE.
bit 4 is set if the fault was due to attempted execute of a no-execute PTE.
- ARM64: bit 1 is set if the fault was due to a write, clear if a read.
bit 3 is set if the fault was due to attempted execute of a no-execute PTE.
Arg3: fffff8052a09020a, If non-zero, the instruction address which referenced the bad memory
address.
Arg4: 0000000000000002, (reserved)
Debugging Details:
*** WARNING: Unable to verify timestamp for myacdrv1.sys
KEY_VALUES_STRING: 1
Key : AV.Type
Value: Read
Key : Analysis.CPU.mSec
Value: 2940
Key : Analysis.Elapsed.mSec
Value: 3704
Key : Analysis.IO.Other.Mb
Value: 0
Key : Analysis.IO.Read.Mb
Value: 0
Key : Analysis.IO.Write.Mb
Value: 0
Key : Analysis.Init.CPU.mSec
Value: 930
Value: 1519
Value: 59
Key : Bugcheck.Code.LegacyAPI
Value: 0x50
Key : Dump.Attributes.AsUlong
Value: 21008
Key : Dump.Attributes.DiagDataWrittenToHeader
Value: 1
Key : Dump.Attributes.ErrorCode
Value: 0
Key : Dump.Attributes.KernelGeneratedTriageDump
Value: 1
Key : Dump.Attributes.LastLine
Key : Dump.Attributes.ProgressPercentage
Value: 0
Key : Failure.Bucket
Value: IP_MISALIGNED_myacdrv1.sys
Key : Failure.Hash
Value: {423bb917-a6f1-e36f-8434-7684687551ca}
BUGCHECK_CODE: 50
BUGCHECK_P1: ffffa48f76708032
BUGCHECK_P2: 0
BUGCHECK_P3: fffff8052a09020a
BUGCHECK_P4: 2
FILE_IN_CAB: 57871e6a-b6ae-49b1-a1bf-c7ec96401b0c.dmp
DUMP_FILE_ATTRIBUTES: 0x21008
Kernel Generated Triage Dump
READ_ADDRESS: fffff805803c44c8: Unable to get MiVisibleState
Unable to get NonPagedPoolStart
Unable to get NonPagedPoolEnd
Unable to get PagedPoolStart
Unable to get PagedPoolEnd
unable to get nt!MmSpecialPagesInUse
ffffa48f76708032
MM_INTERNAL_CODE: 2
IMAGE_NAME: hardware
MODULE_NAME: hardware
FAULTING_MODULE: fffff8052a050000 myacdrv1
BLACKBOXBSD: 1 (!blackboxbsd)
BLACKBOXPNP: 1 (!blackboxpnp)
BLACKBOXWINLOGON: 1
PROCESS_NAME: AOgame.exe
TRAP_FRAME: fffff3086025e4a0 -- (.trap 0xfffff3086025e4a0)
NOTE: The trap frame does not contain all registers.
Some register values may be zeroed or incorrect.
rax=0000000000000000 rbx=0000000000000000 rcx=ffffa48f76707fb2
rdx=0000000000000001 rsi=0000000000000000 rdi=0000000000000000
rip=fffff8052a09020a rsp=fffff3086025e630 rbp=ffff930c19f17340
r8=00000000746c6644 r9=0000000000000000 r10=fffff8052a0901b4
r11=fffff8052a090202 r12=0000000000000000 r13=0000000000000000
r14=0000000000000000 r15=0000000000000000
iopl=0 nv up ei pl zr na po nc
myacdrv1+0x4020a:
fffff805`2a09020a 8b4350 mov eax,dword ptr [rbx+50h] ds:00000000`00000050=????????
Resetting default scope
MISALIGNED_IP:
myacdrv1+4020a
STACK_TEXT:
fffff308`6025e238 fffff805`7f629dc0 : 00000000`00000050 ffffa48f`76708032 00000000`00000000 fffff308`6025e4a0 : nt!KeBugCheckEx
fffff308`6025e240 fffff805`7f616d96 : ffffb701`272d2180 ffff8000`00000000 ffffa48f`76708032 0000007f`fffffff8 : nt!MiSystemFault+0x850
fffff308`6025e330 fffff805`7fab9ecb : 00000000`00100000 ffffa48f`4e71ec80 ffffa48f`4fe84000 fffff805`2a0901b4 : nt!MmAccessFault+0x646
fffff308`6025e4a0 fffff805`2a09020a : ffffa48f`76707fe2 ffffa48f`76707fe2 ffff930c`2dbeac40 fffff805`2a0901b4 : nt!KiPageFault+0x38b
fffff308`6025e630 ffffa48f`76707fe2 : ffffa48f`76707fe2 ffff930c`2dbeac40 fffff805`2a0901b4 ffff930c`19f17340 : myacdrv1+0x4020a
fffff308`6025e638 ffffa48f`76707fe2 : ffff930c`2dbeac40 fffff805`2a0901b4 ffff930c`19f17340 fffff805`2b033103 : 0xffffa48f`76707fe2
fffff308`6025e640 ffff930c`2dbeac40 : fffff805`2a0901b4 ffff930c`19f17340 fffff805`2b033103 ffff930c`2dbeac40 : 0xffffa48f`76707fe2
fffff308`6025e648 fffff805`2a0901b4 : ffff930c`19f17340 fffff805`2b033103 ffff930c`2dbeac40 00000000`00000000 : 0xffff930c`2dbeac40
fffff308`6025e650 ffff930c`19f17340 : fffff805`2b033103 ffff930c`2dbeac40 00000000`00000000 00000000`00000000 : myacdrv1+0x401b4
fffff308`6025e658 fffff805`2b033103 : ffff930c`2dbeac40 00000000`00000000 00000000`00000000 ffff930c`2dbeac40 : 0xffff930c`19f17340
fffff308`6025e660 ffff930c`2dbeac40 : 00000000`00000000 00000000`00000000 ffff930c`2dbeac40 ffff930c`2dbeac48 : myacdrv1+0xfe3103
fffff308`6025e668 00000000`00000000 : 00000000`00000000 ffff930c`2dbeac40 ffff930c`2dbeac48 00000000`00002710 : 0xffff930c`2dbeac40
SYMBOL_NAME: myacdrv1+4020a
STACK_COMMAND: .cxr; .ecxr ; kb
FAILURE_BUCKET_ID: IP_MISALIGNED_myacdrv1.sys
OSPLATFORM_TYPE: x64
OSNAME: Windows 10
FAILURE_ID_HASH: {423bb917-a6f1-e36f-8434-7684687551ca}
Followup: MachineOwner
start end module name
fffff805`0d540000 fffff805`0d567000 mcupdate (deferred)
fffff805`10d70000 fffff805`10d7b000 kdcom (deferred)
fffff805`10d80000 fffff805`10d8c000 symcryptk (deferred)
fffff805`10d90000 fffff805`10dba000 tm (deferred)
fffff805`10dc0000 fffff805`10e4c000 CLFS (deferred)
fffff805`10e50000 fffff805`10f31000 cng (deferred)
fffff805`10f40000 fffff805`10f55000 winaccel (deferred)
fffff805`10f60000 fffff805`10f7b000 PSHED (deferred)
fffff805`10f80000 fffff805`10f8d000 BOOTVID (deferred)
fffff805`10f90000 fffff805`110a5000 clipsp (deferred)
fffff805`110b0000 fffff805`11144000 FLTMGR (deferred)
fffff805`11150000 fffff805`11181000 ksecdd (deferred)
fffff805`11190000 fffff805`111f5000 msrpc (deferred)
fffff805`11200000 fffff805`11212000 cmimcext (deferred)
fffff805`11220000 fffff805`11236000 werkernel (deferred)
fffff805`11240000 fffff805`1124d000 ntosext (deferred)
fffff805`11250000 fffff805`11316000 win32k (deferred)
fffff805`11320000 fffff805`11340000 watchdog (deferred)
fffff805`11350000 fffff805`11842000 dxgkrnl (deferred)
fffff805`11850000 fffff805`1185d000 WMILIB (deferred)
fffff805`11860000 fffff805`11974000 CI (deferred)
fffff805`11980000 fffff805`119a1000 globmerger (deferred)
fffff805`119b0000 fffff805`11aa0000 Wdf01000 (deferred)
fffff805`11ab0000 fffff805`11ac7000 WDFLDR (deferred)
fffff805`11ad0000 fffff805`11ae4000 WppRecorder (deferred)
fffff805`11af0000 fffff805`11aff000 PRM (deferred)
fffff805`11b10000 fffff805`11b3a000 acpiex (deferred)
fffff805`11b40000 fffff805`11c16000 ACPI (deferred)
fffff805`11c20000 fffff805`11c2c000 msisadrv (deferred)
fffff805`11c30000 fffff805`11cc4000 pci (deferred)
fffff805`11cd0000 fffff805`11d29000 tpm (deferred)
fffff805`11d40000 fffff805`11d4e000 amdwps (deferred)
fffff805`11d60000 fffff805`11d78000 WindowsTrustedRT (deferred)
fffff805`11d80000 fffff805`11e24000 intelpep (deferred)
fffff805`11e30000 fffff805`11e3c000 WindowsTrustedRTProxy (deferred)
fffff805`11e40000 fffff805`11e53000 IntelPMT (deferred)
fffff805`11e60000 fffff805`11e77000 pcw (deferred)
fffff805`11e80000 fffff805`11e9c000 vdrvroot (deferred)
fffff805`11ea0000 fffff805`11eb9000 amdkmpfd (deferred)
fffff805`11ec0000 fffff805`11ef8000 pdc (deferred)
fffff805`11f00000 fffff805`11f18000 CEA (deferred)
fffff805`11f20000 fffff805`11f55000 partmgr (deferred)
fffff805`11f60000 fffff805`12058000 spaceport (deferred)
fffff805`12060000 fffff805`1207e000 volmgr (deferred)
fffff805`12090000 fffff805`120f4000 volmgrx (deferred)
fffff805`12100000 fffff805`1211f000 mountmgr (deferred)
fffff805`12130000 fffff805`12167000 storahci (deferred)
fffff805`12170000 fffff805`123e6000 storport (deferred)
fffff805`123f0000 fffff805`1243b000 stornvme (deferred)
fffff805`12440000 fffff805`12466000 EhStorClass (deferred)
fffff805`12470000 fffff805`1248d000 fileinfo (deferred)
fffff805`12490000 fffff805`124d4000 Wof (deferred)
fffff805`124e0000 fffff805`1257f000 WdFilter (deferred)
fffff805`12590000 fffff805`128f8000 Ntfs (deferred)
fffff805`12900000 fffff805`1290f000 Fs_Rec (deferred)
fffff805`12920000 fffff805`12ae3000 ndis (deferred)
fffff805`12af0000 fffff805`12ba8000 NETIO (deferred)
fffff805`12bb0000 fffff805`12be7000 ksecpkg (deferred)
fffff805`12bf0000 fffff805`12c11000 Kerb3961Kernel (deferred)
fffff805`12c20000 fffff805`12c30000 amdpsp (deferred)
fffff805`12c40000 fffff805`12f9f000 tcpip (deferred)
fffff805`12fb0000 fffff805`1303b000 fwpkclnt (deferred)
fffff805`13040000 fffff805`1307a000 wfplwfs (deferred)
fffff805`13080000 fffff805`1316a000 fvevol (deferred)
fffff805`13170000 fffff805`1317b000 volume (deferred)
fffff805`13180000 fffff805`13202000 volsnap (deferred)
fffff805`13210000 fffff805`1325e000 rdyboost (deferred)
fffff805`13270000 fffff805`1328d000 nvmedisk (deferred)
fffff805`13290000 fffff805`132bb000 mup (deferred)
fffff805`132c0000 fffff805`132d5000 iorate (deferred)
fffff805`13300000 fffff805`13321000 disk (deferred)
fffff805`13330000 fffff805`133a9000 CLASSPNP (deferred)
fffff805`1da00000 fffff805`1de11000 win32kfull (deferred)
fffff805`1de20000 fffff805`1de82000 WUDFRd (deferred)
fffff805`1de90000 fffff805`1df22000 cldflt (deferred)
fffff805`1df30000 fffff805`1dfa7000 UnionFS (deferred)
fffff805`1dfb0000 fffff805`1dfdd000 bindflt (deferred)
fffff805`1dfe0000 fffff805`1dff9000 lltdio (deferred)
fffff805`1e000000 fffff805`1e01a000 mslldp (deferred)
fffff805`1e020000 fffff805`1e03e000 rspndr (deferred)
fffff805`1e050000 fffff805`1e070000 wanarp (deferred)
fffff805`1e080000 fffff805`1e097000 mmcss (deferred)
fffff805`1e0a0000 fffff805`1e2ab000 HTTP (deferred)
fffff805`1e2b0000 fffff805`1e2da000 bowser (deferred)
fffff805`1e2e0000 fffff805`1e2fc000 mpsdrv (deferred)
fffff805`1e300000 fffff805`1e3e2000 mrxsmb (deferred)
fffff805`1e3f0000 fffff805`1e44d000 mrxsmb20 (deferred)
fffff805`1e450000 fffff805`1e480000 AMDRyzenMasterDriver (deferred)
fffff805`1e490000 fffff805`1e4c0000 AMDRyzenMasterDriver_fffff8051e490000 (deferred)
fffff805`1e4d0000 fffff805`1e534000 srvnet (deferred)
fffff805`1e540000 fffff805`1e56f000 Ndu (deferred)
fffff805`1e5a0000 fffff805`1e674000 peauth (deferred)
fffff805`1e680000 fffff805`1e696000 tcpipreg (deferred)
fffff805`1e6a0000 fffff805`1e6bd000 wtd (deferred)
fffff805`1e6c0000 fffff805`1e7b9000 srv2 (deferred)
fffff805`1e7c0000 fffff805`1e7d4000 condrv (deferred)
fffff805`1e7e0000 fffff805`1e808000 crashdmp (deferred)
fffff805`1e810000 fffff805`1e828000 KslD (deferred)
fffff805`1e830000 fffff805`1e84a000 WdNisDrv (deferred)
fffff805`1e850000 fffff805`1e866000 qwavedrv (deferred)
fffff805`1ea00000 fffff805`1ea1a000 BasicDisplay (deferred)
fffff805`1ea20000 fffff805`1ea33000 BasicRender (deferred)
fffff805`1ea40000 fffff805`1ea5c000 Npfs (deferred)
fffff805`1ea60000 fffff805`1ea74000 Msfs (deferred)
fffff805`1ea80000 fffff805`1eac5000 CimFS (deferred)
fffff805`1ead0000 fffff805`1eafb000 tdx (deferred)
fffff805`1eb00000 fffff805`1eb12000 TDI (deferred)
fffff805`1eb20000 fffff805`1eb77000 netbt (deferred)
fffff805`1eb80000 fffff805`1eb96000 afunix (deferred)
fffff805`1eba0000 fffff805`1ec53000 afd (deferred)
fffff805`1ec60000 fffff805`1ec7e000 vwififlt (deferred)
fffff805`1ec90000 fffff805`1ecc0000 pacer (deferred)
fffff805`1ecd0000 fffff805`1ece5000 ndiscap (deferred)
fffff805`1ecf0000 fffff805`1ed06000 netbios (deferred)
fffff805`1ed10000 fffff805`1edec000 Vid (deferred)
fffff805`1edf0000 fffff805`1ee19000 winhvr (deferred)
fffff805`1ee20000 fffff805`1eead000 rdbss (deferred)
fffff805`1eeb0000 fffff805`1eec3000 nsiproxy (deferred)
fffff805`1eed0000 fffff805`1eedf000 npsvctrig (deferred)
fffff805`1eef0000 fffff805`1ef01000 mssmbios (deferred)
fffff805`1ef10000 fffff805`1ef40000 dfsc (deferred)
fffff805`1ef50000 fffff805`1ef8c000 wcifs (deferred)
fffff805`1efa0000 fffff805`1efab000 CtiIo64 (deferred)
fffff805`1efb0000 fffff805`1efcc000 bam (deferred)
fffff805`1efd0000 fffff805`1f02c000 ahcache (deferred)
fffff805`1f030000 fffff805`1f03f000 amdxe (deferred)
fffff805`1f050000 fffff805`1f0ac000 amdfendr (deferred)
fffff805`1f0b0000 fffff805`1f0c4000 CompositeBus (deferred)
fffff805`1f0d0000 fffff805`1f0e1000 kdnic (deferred)
fffff805`1f0f0000 fffff805`1f10c000 amdsafd (deferred)
fffff805`1f110000 fffff805`1f185000 portcls (deferred)
fffff805`1f190000 fffff805`1f1ae000 drmk (deferred)
fffff805`1f1c0000 fffff805`1f245000 ks (deferred)
fffff805`1f250000 fffff805`1f262000 ksthunk (deferred)
fffff805`1f270000 fffff805`1f286000 umbus (deferred)
fffff805`1f290000 fffff805`1f33f000 USBXHCI (deferred)
fffff805`1f350000 fffff805`1f39a000 ucx01000 (deferred)
fffff805`1f3a0000 fffff805`1f4ba000 rt640x64 (deferred)
fffff805`1f4c0000 fffff805`1f7ef000 win32kbase (deferred)
fffff805`1f800000 fffff805`1f923000 dxgmms2 (deferred)
fffff805`1f930000 fffff805`1f981000 cdd (deferred)
fffff805`1f990000 fffff805`1f9be000 luafv (deferred)
fffff805`1f9d0000 fffff805`1f9ec000 storqosflt (deferred)
fffff805`1f9f0000 fffff805`22f00000 vgk (deferred)
fffff805`22f10000 fffff805`22f46000 cdrom (deferred)
fffff805`22f50000 fffff805`22f67000 filecrypt (deferred)
fffff805`22f70000 fffff805`22f80000 tbs (deferred)
fffff805`22f90000 fffff805`22fbb000 UCPD (deferred)
fffff805`22fc0000 fffff805`22fcb000 Null (deferred)
fffff805`22fd0000 fffff805`22fda000 Beep (deferred)
fffff805`22fe0000 fffff805`22ff1000 uiomap (deferred)
fffff805`23000000 fffff805`23032000 HDAudBus (deferred)
fffff805`23040000 fffff805`2304b000 AMDPCIDev (deferred)
fffff805`23050000 fffff805`2306e000 serial (deferred)
fffff805`23080000 fffff805`23090000 serenum (deferred)
fffff805`230a0000 fffff805`230ae000 amdgpio2 (deferred)
fffff805`230c0000 fffff805`230f5000 msgpioclx (deferred)
fffff805`23100000 fffff805`2310e000 wmiacpi (deferred)
fffff805`23120000 fffff805`2316a000 amdppm (deferred)
fffff805`23170000 fffff805`2317a000 amdgpio3 (deferred)
fffff805`23180000 fffff805`23193000 UEFI (deferred)
fffff805`231a0000 fffff805`231aa000 amdfendrmgr (deferred)
fffff805`231b0000 fffff805`231be000 NdisVirtualBus (deferred)
fffff805`231d0000 fffff805`231dc000 swenum (deferred)
fffff805`231e0000 fffff805`231ef000 ssdevfactory (deferred)
fffff805`23200000 fffff805`23217000 AmdTools64 (deferred)
fffff805`23220000 fffff805`23231000 rdpbus (deferred)
fffff805`23240000 fffff805`23256000 SteelSeries_Sonar_VAD (deferred)
fffff805`23260000 fffff805`23314000 UsbHub3 (deferred)
fffff805`23320000 fffff805`23330000 USBD (deferred)
fffff805`23340000 fffff805`2337e000 AtihdWT6 (deferred)
fffff805`23390000 fffff805`239c8000 RTKVHD64 (deferred)
fffff805`239d0000 fffff805`23a04000 usbccgp (deferred)
fffff805`23a10000 fffff805`23a24000 hidusb (deferred)
fffff805`23a30000 fffff805`23a80000 HIDCLASS (deferred)
fffff805`23a90000 fffff805`23aa4000 HIDPARSE (deferred)
fffff805`23ab0000 fffff805`23ac1000 sshid (deferred)
fffff805`23ad0000 fffff805`23adc000 mshidkmdf (deferred)
fffff805`23ae0000 fffff805`23af1000 mouhid (deferred)
fffff805`23b00000 fffff805`23b15000 mouclass (deferred)
fffff805`23b20000 fffff805`23b33000 kbdhid (deferred)
fffff805`23b40000 fffff805`23b55000 kbdclass (deferred)
fffff805`23b60000 fffff805`23b76000 vhf (deferred)
fffff805`23b80000 fffff805`23b95000 logi_lamparray (deferred)
fffff805`23ba0000 fffff805`23c0b000 fastfat (deferred)
fffff805`23c30000 fffff805`23c47000 dump_storport (deferred)
fffff805`23ca0000 fffff805`23ceb000 dump_stornvme (deferred)
fffff805`23d20000 fffff805`23d44000 dump_dumpfve (deferred)
fffff805`23d50000 fffff805`23d76000 win32kbase_rs (deferred)
fffff805`23d80000 fffff805`23d9f000 monitor (deferred)
fffff805`23db0000 fffff805`23dd4000 bfs (deferred)
fffff805`23df0000 fffff805`29fd7000 amdkmdag (deferred)
fffff805`29fe0000 fffff805`29fef000 WpdUpFltr (deferred)
fffff805`2a000000 fffff805`2a040000 ndiswan (deferred)
fffff805`2a050000 fffff805`2bef6000 myacdrv1 T (no symbols)
fffff805`2cab0000 fffff805`2cace000 rassstp (deferred)
fffff805`2cae0000 fffff805`2cafe000 NDProxy (deferred)
fffff805`2cb10000 fffff805`2cb39000 AgileVpn (deferred)
fffff805`2cb40000 fffff805`2cb64000 rasl2tp (deferred)
fffff805`2cb70000 fffff805`2cb94000 raspptp (deferred)
fffff805`2cba0000 fffff805`2cbbe000 raspppoe (deferred)
fffff805`2cbd0000 fffff805`2cbe0000 ndistapi (deferred)
fffff805`7f400000 fffff805`80850000 nt (pdb symbols) c:\symbols\ntkrnlmp.pdb\24DE61DB3A27C5B383DFF181CB51F7E11\ntkrnlmp.pdb
fffff805`80c00000 fffff805`80c06000 hal (deferred)
Unloaded modules:
fffff805`2a050000 fffff805`2bef9000 myacdrv1.sys
fffff805`2ac00000 fffff805`2caa9000 myacdrv1.sys
fffff805`2abd0000 fffff805`2ca79000 myacdrv1.sys
fffff805`1e580000 fffff805`1e5a0000 NetworkPriva
fffff805`1e830000 fffff805`1e84a000 dump_storpor
fffff805`1e8a0000 fffff805`1e8ee000 dump_stornvm
fffff805`1e920000 fffff805`1e947000 dump_dumpfve
fffff805`1ef50000 fffff805`1ef73000 dam.sys
fffff805`1ef80000 fffff805`1ef94000 KMPDC.sys
fffff805`11d30000 fffff805`11d3c000 WdBoot.sys
fffff805`132e0000 fffff805`132f4000 hwpolicy.sys
