Mithshi
1 Eylül 2024
  • Anakart: ROG STRIX G513IH_G513ıh.
  • İşlemci: AMD Ryzen 7 4800H With Radeon Graphics 2.90GHz
  • Ekran kartı: NVIDIA GeForce GTX 1650.
  • İşletim sistemi: Windows 10 Pro 64 Bit.
Driverlarını yükledim, sildim hala hata veriyordu. Sonra format attım, hala veriyor. Neden kaynaklandığını bulabilir misiniz?
Minidump
BIOS güncellemesi yapın. Sorun devam ederse muhtemelen servise gitmesi gerek zira işlemciye reballing yapılması gerekebilir.
Kod:
PAGE_FAULT_IN_NONPAGED_AREA (50)
Invalid system memory was referenced.  This cannot be protected by try-except.
Typically the address is just plain bad or it is pointing at freed memory.
Arguments:
Arg1: ffff9a0f9e310a58, memory referenced.
Arg2: 0000000000000011, X64: bit 0 set if the fault was due to a not-present PTE.
    bit 1 is set if the fault was due to a write, clear if a read.
    bit 3 is set if the processor decided the fault was due to a corrupted PTE.
    bit 4 is set if the fault was due to attempted execute of a no-execute PTE.
    - ARM64: bit 1 is set if the fault was due to a write, clear if a read.
    bit 3 is set if the fault was due to attempted execute of a no-execute PTE.
Arg3: ffff9a0f9e310a58, If non-zero, the instruction address which referenced the bad memory
    address.
Arg4: 0000000000000002, (reserved)
Debugging Details:
KEY_VALUES_STRING: 1
    Key  : AV.PTE
    Value: Valid
    Key  : AV.Type
    Value: Execute
    Key  : Analysis.CPU.mSec
    Value: 30046
    Key  : Analysis.Elapsed.mSec
    Value: 31851
    Key  : Analysis.IO.Other.Mb
    Value: 2
    Key  : Analysis.IO.Read.Mb
    Value: 0
    Key  : Analysis.IO.Write.Mb
    Value: 18
    Key  : Analysis.Init.CPU.mSec
    Value: 358
    Value: 9977
    Value: 321
    Value: 0x50
    Value: 0x50
    Key  : Failure.Bucket
    Value: AV_X_(null)_nt!MiSystemFault
    Key  : Failure.Hash
    Value: {49578414-34a9-c6dc-c795-b8c5552d5975}
    Key  : WER.OS.Branch
    Value: vb_release
    Key  : WER.OS.Version
    Value: 10.0.19041.1
BUGCHECK_CODE:  50
BUGCHECK_P1: ffff9a0f9e310a58
BUGCHECK_P2: 11
BUGCHECK_P3: ffff9a0f9e310a58
BUGCHECK_P4: 2
FILE_IN_CAB:  091024-8218-01.dmp
FAULTING_THREAD:  ffffc48ef10af080
WRITE_ADDRESS: fffff807394fb390: Unable to get MiVisibleState
Unable to get NonPagedPoolStart
Unable to get NonPagedPoolEnd
Unable to get PagedPoolStart
Unable to get PagedPoolEnd
unable to get nt!MmSpecialPagesInUse
 ffff9a0f9e310a58
MM_INTERNAL_CODE:  2
BLACKBOXBSD: 1 (!blackboxbsd)
BLACKBOXWINLOGON: 1
CUSTOMER_CRASH_COUNT:  1
PROCESS_NAME:  MsMpEng.exe
TRAP_FRAME:  ffff9a0f9e30ff50 -- (.trap 0xffff9a0f9e30ff50)
NOTE: The trap frame does not contain all registers.
Some register values may be zeroed or incorrect.
rax=0000000000000000 rbx=0000000000000000 rcx=0000000000000002
rdx=fffff7800000060c rsi=0000000000000000 rdi=0000000000000000
rip=ffff9a0f9e310a58 rsp=ffff9a0f9e3100e8 rbp=fffff80738b09be8
 r8=0000000000000004  r9=0000000000000007 r10=0000000000000000
r11=ffff9a0f9e310930 r12=0000000000000000 r13=0000000000000000
r14=0000000000000000 r15=0000000000000000
iopl=0         nv up ei ng nz na pe nc
ffff9a0f`9e310a58 0400            add     al,0
Resetting default scope
SYMBOL_NAME:  nt!MiSystemFault+1cced1
MODULE_NAME: nt
IMAGE_VERSION:  10.0.19041.4842
STACK_COMMAND:  .process /r /p 0xffffc48ef0ea1080; .thread 0xffffc48ef10af080 ; kb
IMAGE_NAME:  ntkrnlmp.exe
BUCKET_ID_FUNC_OFFSET:  1cced1
FAILURE_BUCKET_ID:  AV_X_(null)_nt!MiSystemFault
OS_VERSION:  10.0.19041.1
BUILDLAB_STR:  vb_release
OSPLATFORM_TYPE:  x64
OSNAME:  Windows 10
FAILURE_ID_HASH:  {49578414-34a9-c6dc-c795-b8c5552d5975}
Followup:     MachineOwner
[SMBIOS Data Tables v3.2]
[DMI Version - 0]
[2.0 Calling Convention - No]
[Table Size - 1841 bytes]
  Vendor                        American Megatrends International, LLC.
  BIOS Version                  G513IH.329
  BIOS Release Date             03/01/2023
  BIOS ROM Size                 1000000
  BIOS Characteristics
       07: - PCI Supported
       11: - Upgradeable FLASH BIOS
       15: - CD-Boot Supported
       17: - BIOS ROM Socketed
       19: - EDD Supported
       23: - 1.2MB Floppy Supported
       24: - 720KB Floppy Supported
       25: - 2.88MB Floppy Supported
       32: - BIOS Vendor Reserved
       00: - ACPI Supported
       01: - USB Legacy Supported
  BIOS Major Revision           5
  BIOS Minor Revision           16
  EC Firmware Major Revision    0
  EC Firmware Minor Revision    80
  Extended BIOS ROM Size        16 MB
  Manufacturer                  ASUSTeK COMPUTER INC.
  Product Name                  ROG Strix G513IH_G513IH
  Version                       1.0
  Serial Number                 M7NRKD024995305
  SKUNumber
  Family                        ROG Strix
  Product                       G513IH
  Version                       1.0
  Serial Number                 D815MC059T
  Asset Tag
       00: - Motherboard
       03: - Replaceable
  Location                      Default string
  Chassis Type                  Notebook
  Version                       1.0
  Serial Number
  Asset Tag Number
  Contained Element Size        3
[Onboard Devices Information (Type 10) - Length 6 - Handle 0004h]
Note: The On Board Device Information (Type 10) struct is obsolete as of SMBIOs spec v2.6  Number of Devices             1
  01: Type                      Video [enabled]
  01: Description                  To Be Filled By O.E.M.
[OEM Strings (Type 11) - Length 5 - Handle 0005h]
  Number of Strings             5
   5                            90NR07P1-M00480
[System Configuration Options (Type 12) - Length 5 - Handle 0006h]
[ (Type 256) - Length 31 - Handle 0008h]
[32Bit Memory Error Information (Type 18) - Length 23 - Handle 0009h]
[Physical Memory Array (Type 16) - Length 23 - Handle 000ah]
  Maximum Capacity              33554432KB
  Memory Error Inf Handle       0009h
  Number of Memory Devices      2
[Memory Array Mapped Address (Type 19) - Length 31 - Handle 000bh]
  Ending Address                007fffffh
  Memory Array Handle           000ah
  Partition Width               01
[Cache Information (Type 7) - Length 27 - Handle 000ch]
  Socket Designation            L1 - Cache
  Maximum Cache Size            0200h - 512K
  Installed Size                0200h - 512K
  Supported SRAM Type           0010h - Pipeline-Burst
  Current SRAM Type             0010h - Pipeline-Burst
  Cache Speed                   1ns
  Maximum Cache Size 2          200 - 00000512l Kb
  Installed Cache Size 2        200 - 00000512l Kb
[Cache Information (Type 7) - Length 27 - Handle 000dh]
  Socket Designation            L2 - Cache
  Maximum Cache Size            1000h - 4096K
  Installed Size                1000h - 4096K
  Cache Speed                   1ns
  Maximum Cache Size 2          1000 - 00004096l Kb
  Installed Cache Size 2        1000 - 00004096l Kb
[Cache Information (Type 7) - Length 27 - Handle 000eh]
  Socket Designation            L3 - Cache
  Maximum Cache Size            2000h - 8192K
  Installed Size                2000h - 8192K
  Cache Speed                   1ns
  Associativity                 16-way Set-Associative
  Maximum Cache Size 2          2000 - 00008192l Kb
  Installed Cache Size 2        2000 - 00008192l Kb
[Processor Information (Type 4) - Length 48 - Handle 000fh]
  Socket Designation            FP6
  Processor Family              6bh - AMD Zen Processor Family
  Processor Manufacturer        Advanced Micro Devices, Inc.
  Processor ID                   10f8600fffb8b17
  Processor Version             AMD Ryzen 7 4800H with Radeon Graphics
  Processor Voltage             8ch - 1.2V
  Max Speed                     4300MHz
  Current Speed                 2900MHz
  Processor Upgrade             None
  L1 Cache Handle               000ch
  L2 Cache Handle               000dh
  L3 Cache Handle               000eh
  Serial Number
  Asset Tag Number
  Part Number                   Unknown
  Core Count                    8
  Core Enabled                  8
  Thread Count                  16
  Processor Characteristics     fc
  Enabled Characteristics:
       0x 2: 64-bit Capable
       0x 3: Multi-Core
       0x 4: Hardware Thread
       0x 5: Execute Protection
       0x 6: Enhanced Virtualization
  Processor Family 2            006bh - AMD Zen Processor Family
  Core Count 2                  8
  Core Enabled 2                8
  Thread Count 2                16
[32Bit Memory Error Information (Type 18) - Length 23 - Handle 0010h]
[Memory Device (Type 17) - Length 84 - Handle 0011h]
  Memory Error Info Handle      0010h
  Size                          8192MB
  Form Factor                   0dh - SODIMM
  Device Locator                DIMM 0
  Bank Locator                  P0 CHANNEL A
  Memory Type                   1ah - DDR4
  Type Detail                   4080h - Synchronous Unbuffered (Unregistered)
  Speed                         3200MHz
  Manufacturer                  Micron Technology
  Serial Number
  Asset Tag Number              [String Not Specified]
  Part Number                   8ATF1G64HZ-3G2J1
  Attributes                    1
  Configured Memory Speed       3200
  Minimum Voltage               1200
  Maximum Voltage               1200
  Configured Voltage            1200
  Memory Technology             3
  Memory Operating Mode Capability     8
  Firmware Version              6
  Module Manufacturer Id        11392
  Module Product Id             0
  Memory Subsystem Controller Manufacturer Id  0
  Memory Subsystem Controller Product Id       0
  Non-Volatile Size             0
  Volatile Size                 0
  Cache Size                    0
  Logical Size                  0
[Memory Device Mapped Address (Type 20) - Length 35 - Handle 0012h]
  Memory Device Handle          0011h
  Mem Array Mapped Adr Handle   000bh
  Interleave Position           [None]
  Interleave Data Depth         [None]
[32Bit Memory Error Information (Type 18) - Length 23 - Handle 0013h]
[Memory Device (Type 17) - Length 84 - Handle 0014h]
  Memory Error Info Handle      0013h
  Total Width                   [Unknown]
  Data Width                    [Unknown]
  Size                          [Not Populated]
  Form Factor                   02h - Unknown
  Bank Locator                  P0 CHANNEL B
  Memory Type                   02h - Unknown
  Type Detail                   0004h - Unknown
  Speed                         0MHz
  Manufacturer                  Unknown
  Serial Number
  Part Number                   Unknown
  Attributes                    0
  Configured Memory Speed       0
  Minimum Voltage               0
  Maximum Voltage               0
  Configured Voltage            0
  Memory Technology             2
  Memory Operating Mode Capability     4
  Firmware Version              6
  Module Manufacturer Id        0
  Module Product Id             0
  Non-Volatile Size             0
  Volatile Size                 0
  Cache Size                    0
  Logical Size                  0
[ (Type 256) - Length 11 - Handle 0030h]
[ (Type 256) - Length 11 - Handle 0031h]
[ (Type 256) - Length 4 - Handle 0033h]
KMODE_EXCEPTION_NOT_HANDLED (1e)
This is a very common BugCheck.  Usually the exception address pinpoints
the driver/function that caused the problem.  Always note this address
as well as the link date of the driver/image that contains this address.
Arguments:
Arg1: ffffffffc0000005, The exception code that was not handled
Arg2: fffff8022f6eee88, The address that the exception occurred at
Arg3: 0000000000000008, Parameter 0 of the exception
Arg4: 0000000000000000, Parameter 1 of the exception
Debugging Details:
***    Either you specified an unqualified symbol, or your debugger   ***
***    doesn't have full symbol information.  Unqualified symbol      ***
***    resolution is turned off by default. Please either specify a   ***
***    fully qualified symbol module!symbolname, or enable resolution ***
***    of unqualified symbols by typing ".symopt- 100". Note that     ***
***    enabling unqualified symbol resolution with network symbol     ***
***    server shares in the symbol path may cause the debugger to     ***
***    appear to hang for long periods of time when an incorrect      ***
***    symbol name is typed or the network symbol server is down.     ***
***    For some commands to work properly, your symbol path           ***
***    must point to .pdb files that have full type information.      ***
***    Certain .pdb files (such as the public OS symbols) do not      ***
***    contain the required information.  Contact the group that      ***
***    provided you with these symbols if you need this command to    ***
***    work.                                                          ***
***    Type referenced: ExceptionRecord                               ***
***    work.                                                          ***
***    Type referenced: ContextRecord                                 ***
    Value: 2656
    Value: 8729
    Value: 2
    Value: 0
    Value: 19
    Value: 437
    Value: 9030
    Value: 83
    Value: 0x1e
    Value: 0x1e
    Value: AV_nt!RtlLookupElementGenericTableAvl
    Key  : Failure.Hash
    Value: {6bfae589-e9a5-4ab6-3cea-e40dd6afa951}
    Key  : WER.OS.Branch
    Value: vb_release
    Value: 10.0.19041.1
BUGCHECK_CODE:  1e
BUGCHECK_P1: ffffffffc0000005
BUGCHECK_P2: fffff8022f6eee88
BUGCHECK_P3: 8
BUGCHECK_P4: 0
FILE_IN_CAB:  091124-11562-01.dmp
FAULTING_THREAD:  ffffb30f2f3dc600
EXCEPTION_PARAMETER1:  0000000000000008
EXCEPTION_PARAMETER2:  0000000000000000
WRITE_ADDRESS: fffff802300fb390: Unable to get MiVisibleState
 0000000000000000
BLACKBOXPNP: 1 (!blackboxpnp)
BLACKBOXWINLOGON: 1
PROCESS_NAME:  MoUsoCoreWorker.exe
TRAP_FRAME:  ffff800000000000 -- (.trap 0xffff800000000000)
Unable to read trap frame at ffff8000`00000000
STACK_TEXT:
ffffc604`5a540698 fffff802`2f86e7d5     : 00000000`0000001e ffffffff`c0000005 fffff802`2f6eee88 00000000`00000008 : nt!KeBugCheckEx
ffffc604`5a5406a0 fffff802`2f812bec     : 00000000`00001000 ffffc604`5a540f40 ffff8000`00000000 00000000`00000000 : nt!KiDispatchException+0x164d05
ffffc604`5a540d60 fffff802`2f80e452     : ffff9d80`04057170 00000000`00000000 ffffc604`5a541041 fffff802`2f64bd01 : nt!KiExceptionDispatch+0x12c
ffffc604`5a540f40 fffff802`2f6eee88     : ffffa287`c27ae230 ffffb30f`2c030d68 ffffca8a`d94ad010 fffff802`34acc799 : nt!KiPageFault+0x452
ffffc604`5a5410d0 ffffca8a`cfbfcc70     : ffffb30f`2c030d00 00000000`00000000 00000000`00000000 00000000`00000000 : nt!RtlLookupElementGenericTableAvl+0x68
ffffc604`5a541100 ffffb30f`2c030d00     : 00000000`00000000 00000000`00000000 00000000`00000000 ffffb30f`00000000 : 0xffffca8a`cfbfcc70
ffffc604`5a541108 00000000`00000000     : 00000000`00000000 00000000`00000000 ffffb30f`00000000 00000000`00000000 : 0xffffb30f`2c030d00
SYMBOL_NAME:  nt!RtlLookupElementGenericTableAvl+68
MODULE_NAME: nt
STACK_COMMAND:  .process /r /p 0xffffb30f2e9560c0; .thread 0xffffb30f2f3dc600 ; kb
BUCKET_ID_FUNC_OFFSET:  68
FAILURE_BUCKET_ID:  AV_nt!RtlLookupElementGenericTableAvl
OSNAME:  Windows 10
FAILURE_ID_HASH:  {6bfae589-e9a5-4ab6-3cea-e40dd6afa951}
    PnpActivityId      : {00000000-0000-0000-0000-000000000000}
    PnpActivityTime    : 133705145083498403
    PnpEventInformation: 3
    PnpEventInProgress : 0
    PnpProblemCode     : 24
    PnpVetoType        : 0
    DeviceId           : {5d624f94-8850-40c3-a3fa-a4fd2080baf3}\vwifimp_wfd\5&2d5cff58&0&12
    VetoString         :
[DMI Version - 0]
       07: - PCI Supported
       19: - EDD Supported
  Version                       1.0
  SKUNumber
  Family                        ROG Strix
  Product                       G513IH
  Version                       1.0
  Asset Tag
       00: - Motherboard
       03: - Replaceable
  Version                       1.0
  Serial Number
  Asset Tag Number
  Number of Strings             5
   5                            90NR07P1-M00480
  Partition Width               01
  Cache Speed                   1ns
  Cache Speed                   1ns
  Cache Speed                   1ns
  Max Speed                     4300MHz
  Serial Number
  Asset Tag Number
  Part Number                   Unknown
  Core Count                    8
  Core Enabled                  8
  Thread Count                  16
       0x 3: Multi-Core
  Core Count 2                  8
  Core Enabled 2                8
  Thread Count 2                16
  Size                          8192MB
  Speed                         3200MHz
  Serial Number
  Attributes                    1
  Memory Technology             3
  Firmware Version              6
  Module Product Id             0
  Non-Volatile Size             0
  Volatile Size                 0
  Cache Size                    0
  Logical Size                  0
  Speed                         0MHz
  Serial Number
  Part Number                   Unknown
  Attributes                    0
  Minimum Voltage               0
  Maximum Voltage               0
  Memory Technology             2
  Firmware Version              6
  Module Product Id             0
  Non-Volatile Size             0
  Volatile Size                 0
  Cache Size                    0
  Logical Size                  0
IRQL_NOT_LESS_OR_EQUAL (a)
An attempt was made to access a pageable (or completely invalid) address at an
interrupt request level (IRQL) that is too high.  This is usually
caused by drivers using improper addresses.
If a kernel debugger is available get the stack backtrace.
Arguments:
Arg1: 0000000000000004, memory referenced
Arg2: 00000000000000ff, IRQL
Arg3: 000000000000004e, bitfield :
    bit 0 : value 0 = read operation, 1 = write operation
    bit 3 : value 0 = not an execute operation, 1 = execute operation (only on chips which support this level of status)
Arg4: fffff802348699e0, address which referenced memory
Debugging Details:
*** WARNING: Check Image - Checksum mismatch - Dump: 0x39ae8, File: 0x36cb8 - C:\ProgramData\Dbg\sym\amdppm.sys\85FAE0BA3c000\amdppm.sys
    Value: 2233
    Value: 6945
    Value: 2
    Value: 0
    Value: 19
    Value: 531
    Value: 10516
    Value: 83
    Value: 0xa
    Value: 0xa
    Value: IP_MISALIGNED_AuthenticAMD.sys
    Key  : Failure.Hash
    Value: {716d112a-8330-4bbb-160c-ec98297019d2}
    Key  : WER.OS.Branch
    Value: vb_release
    Value: 10.0.19041.1
BUGCHECK_CODE:  a
BUGCHECK_P1: 4
BUGCHECK_P2: ff
BUGCHECK_P3: 4e
BUGCHECK_P4: fffff802348699e0
FILE_IN_CAB:  091024-11828-01.dmp
FAULTING_THREAD:  ffffac808d4ee440
READ_ADDRESS: fffff802352fb390: Unable to get MiVisibleState
 0000000000000004
BLACKBOXWINLOGON: 1
PROCESS_NAME:  System
TRAP_FRAME:  ffff8981eba53560 -- (.trap 0xffff8981eba53560)
rax=0000000000000004 rbx=0000000000000000 rcx=fffff80235325440
rdx=0000000002000000 rsi=0000000000000000 rdi=0000000000000000
rip=fffff802348699e0 rsp=ffff8981eba536f0 rbp=0000000000000000
 r8=00000008fccbfcdd  r9=0000000002000000 r10=ffffbd8e92f250f8
r11=0000000000000000 r12=0000000000000000 r13=0000000000000000
iopl=0         nv up di pl zr na po nc
nt!PpmIdleExecuteTransition+0x6c0:
fffff802`348699e0 0000            add     byte ptr [rax],al ds:00000000`00000004=??
MISALIGNED_IP:
nt!PpmIdleExecuteTransition+6c0
STACK_TEXT:
ffff8981`eba53418 fffff802`34a12aa9     : 00000000`0000000a 00000000`00000004 00000000`000000ff 00000000`0000004e : nt!KeBugCheckEx
ffff8981`eba53420 fffff802`34a0e478     : ffffffff`ffffffff fffff802`349181bb ffffffff`ffffffff fffff802`34b66e40 : nt!KiBugCheckDispatch+0x69
ffff8981`eba53560 fffff802`348699e0     : ffffffff`ffffffff 00000000`ffffff00 00000008`fccbfcdd 00000000`00000000 : nt!KiPageFault+0x478
ffff8981`eba536f0 fffff802`348691a4     : 00000000`00000000 00001f80`00000001 00000000`00000003 00000000`00000002 : nt!PpmIdleExecuteTransition+0x6c0
ffff8981`eba53af0 fffff802`34a02d54     : ffffffff`00000000 ffffac80`8d4ee440 ffffbd8e`a48af640 00000000`00000ff9 : nt!PoIdle+0x374
ffff8981`eba53c60 00000000`00000000     : ffff8981`eba54000 ffff8981`eba4e000 00000000`00000000 00000000`00000000 : nt!KiIdleLoop+0x54
SYMBOL_NAME:  nt!PpmIdleExecuteTransition+6c0
STACK_COMMAND:  .process /r /p 0xfffff80235324a00; .thread 0xffffac808d4ee440 ; kb
MODULE_NAME: AuthenticAMD
IMAGE_NAME:  AuthenticAMD.sys
FAILURE_BUCKET_ID:  IP_MISALIGNED_AuthenticAMD.sys
OSNAME:  Windows 10
FAILURE_ID_HASH:  {716d112a-8330-4bbb-160c-ec98297019d2}
[DMI Version - 0]
       07: - PCI Supported
       19: - EDD Supported
  Version                       1.0
  SKUNumber
  Family                        ROG Strix
  Product                       G513IH
  Version                       1.0
  Asset Tag
       00: - Motherboard
       03: - Replaceable
  Version                       1.0
  Serial Number
  Asset Tag Number
  Number of Strings             5
   5                            90NR07P1-M00480
  Partition Width               01
  Cache Speed                   1ns
  Cache Speed                   1ns
  Cache Speed                   1ns
  Max Speed                     4300MHz
  Serial Number
  Asset Tag Number
  Part Number                   Unknown
  Core Count                    8
  Core Enabled                  8
  Thread Count                  16
       0x 3: Multi-Core
  Core Count 2                  8
  Core Enabled 2                8
  Thread Count 2                16
  Size                          8192MB
  Speed                         3200MHz
  Serial Number
  Attributes                    1
  Memory Technology             3
  Firmware Version              6
  Module Product Id             0
  Non-Volatile Size             0
  Volatile Size                 0
  Cache Size                    0
  Logical Size                  0
  Speed                         0MHz
  Serial Number
  Part Number                   Unknown
  Attributes                    0
  Minimum Voltage               0
  Maximum Voltage               0
  Memory Technology             2
  Firmware Version              6
  Module Product Id             0
  Non-Volatile Size             0
  Volatile Size                 0
  Cache Size                    0
  Logical Size                  0
Arguments:
Arg2: fffff8077f84fe45, The address that the exception occurred at
Arg3: 0000000000000001, Parameter 0 of the exception
Arg4: 0000000000000016, Parameter 1 of the exception
Debugging Details:
***    work.                                                          ***
***    work.                                                          ***
    Value: 2781
    Value: 10854
    Value: 2
    Value: 0
    Value: 20
    Value: 405
    Value: 9018
    Value: 83
    Value: 0x1e
    Value: 0x1e
    Value: AV_W_nt!RtlRbRemoveNode
    Key  : Failure.Hash
    Value: {717b426d-ed0b-a9be-a6ac-30036a25ad29}
    Key  : WER.OS.Branch
    Value: vb_release
    Value: 10.0.19041.1
BUGCHECK_CODE:  1e
BUGCHECK_P2: fffff8077f84fe45
BUGCHECK_P3: 1
BUGCHECK_P4: 16
FILE_IN_CAB:  091024-7281-01.dmp
FAULTING_THREAD:  ffff930e915ef080
EXCEPTION_PARAMETER1:  0000000000000001
EXCEPTION_PARAMETER2:  0000000000000016
WRITE_ADDRESS: fffff807802fb390: Unable to get MiVisibleState
 0000000000000016
BLACKBOXWINLOGON: 1
PROCESS_NAME:  svchost.exe
STACK_TEXT:
ffffc780`bdcecb68 fffff807`7fa6e7d5     : 00000000`0000001e ffffffff`c0000005 fffff807`7f84fe45 00000000`00000001 : nt!KeBugCheckEx
ffffc780`bdcecb70 fffff807`7fa12bec     : 00000000`00001000 ffffc780`bdced410 ffff8000`00000000 00000000`00000000 : nt!KiDispatchException+0x164d05
ffffc780`bdced230 fffff807`7fa0e452     : 00000246`002b0000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!KiExceptionDispatch+0x12c
ffffc780`bdced410 fffff807`7f84fe45     : ffffc780`bdced618 00000000`00000037 ffffb60c`816cfc10 00000000`0000003d : nt!KiPageFault+0x452
ffffc780`bdced5a0 ffffb60c`816cfc10     : 00000000`0000003d 00000000`00000000 00000000`00000000 00000000`00000000 : nt!RtlRbRemoveNode+0x1e5
ffffc780`bdced5b8 00000000`0000003d     : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : 0xffffb60c`816cfc10
ffffc780`bdced5c0 00000000`00000000     : 00000000`00000000 00000000`00000000 00000000`00000000 ffff930e`915ef6d0 : 0x3d
SYMBOL_NAME:  nt!RtlRbRemoveNode+1e5
MODULE_NAME: nt
STACK_COMMAND:  .process /r /p 0xffff930e90fd10c0; .thread 0xffff930e915ef080 ; kb
BUCKET_ID_FUNC_OFFSET:  1e5
FAILURE_BUCKET_ID:  AV_W_nt!RtlRbRemoveNode
OSNAME:  Windows 10
FAILURE_ID_HASH:  {717b426d-ed0b-a9be-a6ac-30036a25ad29}
[DMI Version - 0]
       07: - PCI Supported
       19: - EDD Supported
  Version                       1.0
  SKUNumber
  Family                        ROG Strix
  Product                       G513IH
  Version                       1.0
  Asset Tag
       00: - Motherboard
       03: - Replaceable
  Version                       1.0
  Serial Number
  Asset Tag Number
  Number of Strings             5
   5                            90NR07P1-M00480
  Partition Width               01
  Cache Speed                   1ns
  Cache Speed                   1ns
  Cache Speed                   1ns
  Max Speed                     4300MHz
  Serial Number
  Asset Tag Number
  Part Number                   Unknown
  Core Count                    8
  Core Enabled                  8
  Thread Count                  16
       0x 3: Multi-Core
  Core Count 2                  8
  Core Enabled 2                8
  Thread Count 2                16
  Size                          8192MB
  Speed                         3200MHz
  Serial Number
  Attributes                    1
  Memory Technology             3
  Firmware Version              6
  Module Product Id             0
  Non-Volatile Size             0
  Volatile Size                 0
  Cache Size                    0
  Logical Size                  0
  Speed                         0MHz
  Serial Number
  Part Number                   Unknown
  Attributes                    0
  Minimum Voltage               0
  Maximum Voltage               0
  Memory Technology             2
  Firmware Version              6
  Module Product Id             0
  Non-Volatile Size             0
  Volatile Size                 0
  Cache Size                    0
  Logical Size                  0
Arguments:
Arg1: 0000000048001e33, memory referenced
Arg3: 0000000000000085, bitfield :
Arg4: fffff801322d3db0, address which referenced memory
Debugging Details:
    Value: 1812
    Value: 6065
    Value: 1
    Value: 0
    Value: 10
    Value: 656
    Value: 9815
    Value: 83
    Value: 0xa
    Value: 0xa
    Value: AV_nt!KxWaitForSpinLockAndAcquire
    Key  : Failure.Hash
    Value: {1d1425a5-67ae-45d4-ab8e-76808f3319cb}
    Key  : WER.OS.Branch
    Value: vb_release
    Value: 10.0.19041.1
BUGCHECK_CODE:  a
BUGCHECK_P1: 48001e33
BUGCHECK_P2: ff
BUGCHECK_P3: 85
BUGCHECK_P4: fffff801322d3db0
FILE_IN_CAB:  091024-8203-01.dmp
FAULTING_THREAD:  ffff9b816f0ee440
WRITE_ADDRESS: fffff80132cfb390: Unable to get MiVisibleState
 0000000048001e33
BLACKBOXWINLOGON: 1
TRAP_FRAME:  ffff860e6c8534c0 -- (.trap 0xffff860e6c8534c0)
rax=ffffd68ece69f7a0 rbx=0000000000000000 rcx=ffffd68ece69f7a0
rdx=000000015d947d43 rsi=0000000000000000 rdi=0000000000000000
rip=fffff801322d3db0 rsp=ffff860e6c853650 rbp=0000000000000001
 r8=0000000000000001  r9=0000000000000001 r10=0000fffff8013230
iopl=0         nv up di ng nz na po nc
nt!KxWaitForSpinLockAndAcquire:
fffff801`322d3db0 48895c2408      mov     qword ptr [rsp+8],rbx ss:0018:ffff860e`6c853658=0000000000000000
STACK_TEXT:
ffff860e`6c853378 fffff801`32412aa9     : 00000000`0000000a 00000000`48001e33 00000000`000000ff 00000000`00000085 : nt!KeBugCheckEx
ffff860e`6c853380 fffff801`3240e478     : ffff9b81`6f0e3180 00000001`5d705a74 ffff860e`6c853500 ffff860e`6c853520 : nt!KiBugCheckDispatch+0x69
ffff860e`6c8534c0 fffff801`322d3db0     : 00000000`00000000 00000000`00000000 00000000`00000004 ffff9b81`6f0e3180 : nt!KiPageFault+0x478
ffff860e`6c853650 00000000`00000000     : 00000000`00000000 00000000`00000004 ffff9b81`6f0e3180 ffff9b81`6f0e3180 : nt!KxWaitForSpinLockAndAcquire
SYMBOL_NAME:  nt!KxWaitForSpinLockAndAcquire+0
MODULE_NAME: nt
STACK_COMMAND:  .process /r /p 0xfffff80132d24a00; .thread 0xffff9b816f0ee440 ; kb
BUCKET_ID_FUNC_OFFSET:  0
FAILURE_BUCKET_ID:  AV_nt!KxWaitForSpinLockAndAcquire
OSNAME:  Windows 10
FAILURE_ID_HASH:  {1d1425a5-67ae-45d4-ab8e-76808f3319cb}
[DMI Version - 0]
       07: - PCI Supported
       19: - EDD Supported
  Version                       1.0
  SKUNumber
  Family                        ROG Strix
  Product                       G513IH
  Version                       1.0
  Asset Tag
       00: - Motherboard
       03: - Replaceable
  Version                       1.0
  Serial Number
  Asset Tag Number
  Number of Strings             5
   5                            90NR07P1-M00480
  Partition Width               01
  Cache Speed                   1ns
  Cache Speed                   1ns
  Cache Speed                   1ns
  Max Speed                     4300MHz
  Serial Number
  Asset Tag Number
  Part Number                   Unknown
  Core Count                    8
  Core Enabled                  8
  Thread Count                  16
       0x 3: Multi-Core
  Core Count 2                  8
  Core Enabled 2                8
  Thread Count 2                16
  Size                          8192MB
  Speed                         3200MHz
  Serial Number
  Attributes                    1
  Memory Technology             3
  Firmware Version              6
  Module Product Id             0
  Non-Volatile Size             0
  Volatile Size                 0
  Cache Size                    0
  Logical Size                  0
  Speed                         0MHz
  Serial Number
  Part Number                   Unknown
  Attributes                    0
  Minimum Voltage               0
  Maximum Voltage               0
  Memory Technology             2
  Firmware Version              6
  Module Product Id             0
  Non-Volatile Size             0
  Volatile Size                 0
  Cache Size                    0
  Logical Size                  0
