17 Aralık 2023
Merhabalar son günlerde sürekli REFERENCE_BY_POINTER mavi ekran hatasını alıyorum ve ara sıra USB cihazlarım yaklaşık 10 saniyeliğine donuyor daha sonra ışıkları gidip geliyor.
Bir alakası olduğunu düşündüğümden aynı konuya yazdım.
Sistem:
  • GTX 1060 6GB
  • Ryzen 5 1600X
  • XPG Gammix D30 2x8GB 3200MHz
  • Kioxia Exceria G2 500GB
Minidump: https://disk.yandex.com.tr/d/yMk8NsQbtDvT5w
Sorun ekran kartınızda gibi.
Kod:
REFERENCE_BY_POINTER (18)
Arguments:
Arg1: 0000000000000000, Object type of the object whose reference count is being lowered
Arg2: fffffe098cca0110, Object whose reference count is being lowered
Arg3: 0000000000000002, Reserved
Arg4: ffffcc824adadfff, Reserved
    The reference count of an object is illegal for the current state of the object.
    Each time a driver uses a pointer to an object the driver calls a kernel routine
    to increment the reference count of the object. When the driver is done with the
    pointer the driver calls another kernel routine to decrement the reference count.
    Drivers must match calls to the increment and decrement routines. This BugCheck
    can occur because an object's reference count goes to zero while there are still
    open handles to the object, in which case the fourth parameter indicates the number
    of opened handles. It may also occur when the object's reference count drops below zero
    whether or not there are open handles to the object, and in that case the fourth parameter
    contains the actual value of the pointer references count.
Debugging Details:
KEY_VALUES_STRING: 1
    Key  : Analysis.CPU.mSec
    Value: 687
    Key  : Analysis.Elapsed.mSec
    Value: 2935
    Key  : Analysis.IO.Other.Mb
    Value: 0
    Key  : Analysis.IO.Read.Mb
    Value: 1
    Key  : Analysis.IO.Write.Mb
    Value: 0
    Key  : Analysis.Init.CPU.mSec
    Value: 171
    Value: 465
    Value: 90
    Value: 10.0.27793.1000
    Value: 10.2410.02.02 amd64fre
    Key  : Analysis.Version.Ext
    Value: 1.2410.2.2
    Value: 0x18
    Value: 0x18
    Key  : Failure.Bucket
    Value: 0x18_CORRUPT_REF_COUNT_dxgkrnl!NotifyPendingFlipPresent
    Key  : Failure.Hash
    Value: {dee632f7-0d74-cf28-3870-04e34a4028ab}
    Key  : WER.OS.Branch
    Value: vb_release
    Key  : WER.OS.Version
    Value: 10.0.19041.1
BUGCHECK_CODE:  18
BUGCHECK_P1: 0
BUGCHECK_P2: fffffe098cca0110
BUGCHECK_P3: 2
BUGCHECK_P4: ffffcc824adadfff
FILE_IN_CAB:  032725-6750-01.dmp
FAULTING_THREAD:  ffffcc825129d080
BLACKBOXBSD: 1 (!blackboxbsd)
BLACKBOXPNP: 1 (!blackboxpnp)
BLACKBOXWINLOGON: 1
CUSTOMER_CRASH_COUNT:  1
PROCESS_NAME:  Discord.exe
STACK_TEXT:
fffffe09`8cca0028 fffff807`0303b51d     : 00000000`00000018 00000000`00000000 fffffe09`8cca0110 00000000`00000002 : nt!KeBugCheckEx
fffffe09`8cca0030 fffff807`02e5ab8e     : fffffe09`8cca0110 ffffb904`b50cf728 ffffb904`b50cf728 00000000`00000000 : nt!ObfDereferenceObjectWithTag+0x1e097d
fffffe09`8cca0070 fffff807`10e147ce     : fffffe09`8cca0119 ffffcc82`4f76d1c0 ffffb904`00000000 ffffb904`cd90c601 : nt!HalPutDmaAdapter+0xe
fffffe09`8cca00a0 fffff807`10e13943     : 00000000`00000000 00000000`00000000 ffffcc82`4dae7000 fffffe09`8cca0a20 : dxgkrnl!NotifyPendingFlipPresent+0x84e
fffffe09`8cca0180 fffff807`10f55db8     : fffffe09`8cca0a28 fffffe09`8cca0210 fffffe09`8cca0910 00000000`00000001 : dxgkrnl!DxgkQuerySwapChainBindingStatus+0x2b
fffffe09`8cca01b0 fffff807`10efeacb     : ffffb904`b50cf5c0 00000000`00000000 ffffcc82`4dae7000 00000000`00000000 : dxgkrnl!SubmitPresentHistoryTokenPreparation+0x178
fffffe09`8cca0250 fffff807`10f01c61     : ffffb904`b50cf5c0 fffffe09`8cca0b80 00000000`00000000 ffffcc82`4dae7000 : dxgkrnl!DXGCONTEXT::Present+0x9eb
fffffe09`8cca0830 fffff807`03011e08     : ffffcc82`5129d080 ffffcc82`5129d080 00000000`00009000 00000000`00000000 : dxgkrnl!DxgkPresent+0x7f1
fffffe09`8cca0b00 00007fff`7ca25424     : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!KiSystemServiceCopyEnd+0x28
000000f0`f9f1c6a8 00000000`00000000     : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : 0x00007fff`7ca25424
SYMBOL_NAME:  dxgkrnl!NotifyPendingFlipPresent+84e
MODULE_NAME: dxgkrnl
IMAGE_NAME:  dxgkrnl.sys
IMAGE_VERSION:  10.0.19041.5607
STACK_COMMAND:  .process /r /p 0xffffcc8253f5f080; .thread 0xffffcc825129d080 ; kb
BUCKET_ID_FUNC_OFFSET:  84e
FAILURE_BUCKET_ID:  0x18_CORRUPT_REF_COUNT_dxgkrnl!NotifyPendingFlipPresent
OS_VERSION:  10.0.19041.1
BUILDLAB_STR:  vb_release
OSPLATFORM_TYPE:  x64
OSNAME:  Windows 10
FAILURE_ID_HASH:  {dee632f7-0d74-cf28-3870-04e34a4028ab}
Followup:     MachineOwner
    PnpActivityId      : {00000000-0000-0000-0000-000000000000}
    PnpActivityTime    : 133875723939442905
    PnpEventInformation: 3
    PnpEventInProgress : 0
    PnpProblemCode     : 24
    PnpVetoType        : 0
    DeviceId           : SW\{DDF4358E-BB2C-11D0-A42F-00A0C9223196}\{97EBAACB-95BD-11D0-A3EA-00A0C9223196}
    VetoString         :
[SMBIOS Data Tables v3.3]
[DMI Version - 0]
[2.0 Calling Convention - No]
[Table Size - 2598 bytes]
  Vendor                        American Megatrends Inc.
  BIOS Version                  6232
  BIOS Release Date             09/29/2024
  BIOS ROM Size                 1000000
  BIOS Characteristics
       07: - PCI Supported
       10: - APM Supported
       11: - Upgradeable FLASH BIOS
       15: - CD-Boot Supported
       17: - BIOS ROM Socketed
       19: - EDD Supported
       23: - 1.2MB Floppy Supported
       24: - 720KB Floppy Supported
       25: - 2.88MB Floppy Supported
       27: - Keyboard Services Supported
       32: - BIOS Vendor Reserved
       00: - ACPI Supported
       01: - USB Legacy Supported
  BIOS Major Revision           5
  BIOS Minor Revision           17
  EC Firmware Major Revision    255
  EC Firmware Minor Revision    255
  Extended BIOS ROM Size        16 MB
  Manufacturer                  System manufacturer
  Product Name                  System Product Name
  Version                       System Version
  Serial Number                 System Serial Number
  SKUNumber                     SKU
  Family                        To be filled by O.E.M.
  Manufacturer                  ASUSTeK COMPUTER INC.
  Product                       EX-A320M-GAMING
  Version                       Rev X.0x
  Serial Number                 171217087900124
  Asset Tag
       00: - Motherboard
       03: - Replaceable
  Location                      Default string
  Manufacturer                  Default string
  Chassis Type                  Desktop
  Version                       Default string
  Serial Number
  Asset Tag Number
  Contained Element Size        3
[Onboard Devices Information (Type 10) - Length 6 - Handle 001ch]
Note: The On Board Device Information (Type 10) struct is obsolete as of SMBIOs spec v2.6  Number of Devices             1
  01: Type                      Video [enabled]
  01: Description                  To Be Filled By O.E.M.
[OEM Strings (Type 11) - Length 5 - Handle 001dh]
  Number of Strings             8
   1                            Default string
   2                            Default string
   3                            SID
   4                            Default string
   5                            Default string
   6                            Default string
   7                            Default string
   8                            Default string
[System Configuration Options (Type 12) - Length 5 - Handle 001eh]
[ (Type 256) - Length 11 - Handle 0021h]
[ (Type 256) - Length 9 - Handle 0022h]
[ (Type 256) - Length 31 - Handle 0023h]
[32Bit Memory Error Information (Type 18) - Length 23 - Handle 0024h]
[Physical Memory Array (Type 16) - Length 23 - Handle 0025h]
  Maximum Capacity              134217728KB
  Memory Error Inf Handle       0024h
  Number of Memory Devices      4
[Memory Array Mapped Address (Type 19) - Length 31 - Handle 0026h]
  Ending Address                00ffffffh
  Memory Array Handle           0025h
[Cache Information (Type 7) - Length 27 - Handle 0027h]
  Socket Designation            L1 - Cache
  Maximum Cache Size            0240h - 576K
  Installed Size                0240h - 576K
  Supported SRAM Type           0010h - Pipeline-Burst
  Current SRAM Type             0010h - Pipeline-Burst
  Cache Speed                   1ns
  Maximum Cache Size 2          240 - 00000576l Kb
  Installed Cache Size 2        240 - 00000576l Kb
[Cache Information (Type 7) - Length 27 - Handle 0028h]
  Socket Designation            L2 - Cache
  Maximum Cache Size            0c00h - 3072K
  Installed Size                0c00h - 3072K
  Cache Speed                   1ns
  Maximum Cache Size 2          c00 - 00003072l Kb
  Installed Cache Size 2        c00 - 00003072l Kb
[Cache Information (Type 7) - Length 27 - Handle 0029h]
  Socket Designation            L3 - Cache
  Maximum Cache Size            4000h - 16384K
  Installed Size                4000h - 16384K
  Cache Speed                   1ns
  Associativity                 16-way Set-Associative
  Maximum Cache Size 2          4000 - 00016384l Kb
  Installed Cache Size 2        4000 - 00016384l Kb
[Processor Information (Type 4) - Length 48 - Handle 002ah]
  Socket Designation            AM4
  Processor Family              6bh - AMD Zen Processor Family
  Processor Manufacturer        Advanced Micro Devices, Inc.
  Processor ID                   110f8000fffb8b17
  Processor Version             AMD Ryzen 5 1600X Six-Core Processor
  Processor Voltage             8eh - 1.4V
  Max Speed                     4100MHz
  Current Speed                 3600MHz
  Processor Upgrade             Socket AM4
  L1 Cache Handle               0027h
  L2 Cache Handle               0028h
  L3 Cache Handle               0029h
  Serial Number
  Asset Tag Number
  Part Number                   Unknown
  Core Count                    6
  Core Enabled                  6
  Thread Count                  12
  Processor Characteristics     fc
  Enabled Characteristics:
       0x 2: 64-bit Capable
       0x 3: Multi-Core
       0x 4: Hardware Thread
       0x 5: Execute Protection
       0x 6: Enhanced Virtualization
  Processor Family 2            006bh - AMD Zen Processor Family
  Core Count 2                  6
  Core Enabled 2                6
  Thread Count 2                12
[32Bit Memory Error Information (Type 18) - Length 23 - Handle 002bh]
[Memory Device (Type 17) - Length 92 - Handle 002ch]
  Memory Error Info Handle      002bh
  Size                          8192MB
  Form Factor                   09h - DIMM
  Device Locator                DIMM_A1
  Bank Locator                  BANK 0
  Memory Type                   1ah - DDR4
  Type Detail                   4080h - Synchronous Unbuffered (Unregistered)
  Speed                         3200MHz
  Manufacturer                  A-DATA
  Serial Number
  Asset Tag Number              [String Not Specified]
  Part Number                   AX4U32008G16A-DR30
  Attributes                    1
  Configured Memory Speed       3200
  Minimum Voltage               1200
  Maximum Voltage               1200
  Configured Voltage            1200
  Memory Technology             3
  Memory Operating Mode Capability     8
  Firmware Version              6
  Module Manufacturer Id        51972
  Module Product Id             0
  Memory Subsystem Controller Manufacturer Id  0
  Memory Subsystem Controller Product Id       0
  Non-Volatile Size             0
  Volatile Size                 0
  Cache Size                    0
  Logical Size                  0
  Extended Speed                0
  Extended Configured Memory Speed     0
[Memory Device Mapped Address (Type 20) - Length 35 - Handle 002dh]
  Memory Device Handle          002ch
  Mem Array Mapped Adr Handle   0026h
  Interleave Position           [Unknown]
  Interleave Data Depth         [Unknown]
[32Bit Memory Error Information (Type 18) - Length 23 - Handle 002eh]
[Memory Device (Type 17) - Length 92 - Handle 002fh]
  Memory Error Info Handle      002eh
  Total Width                   [Unknown]
  Data Width                    [Unknown]
  Size                          [Not Populated]
  Form Factor                   02h - Unknown
  Device Locator                DIMM_A2
  Bank Locator                  BANK 1
  Memory Type                   02h - Unknown
  Type Detail                   0004h - Unknown
  Speed                         0MHz
  Manufacturer                  Unknown
  Serial Number
  Part Number                   Unknown
  Attributes                    0
  Minimum Voltage               0
  Maximum Voltage               0
  Configured Voltage            0
  Memory Technology             2
  Memory Operating Mode Capability     4
  Firmware Version              6
  Module Manufacturer Id        0
  Module Product Id             0
  Non-Volatile Size             0
  Volatile Size                 0
  Cache Size                    0
  Logical Size                  0
  Extended Speed                0
[32Bit Memory Error Information (Type 18) - Length 23 - Handle 0030h]
[Memory Device (Type 17) - Length 92 - Handle 0031h]
  Memory Error Info Handle      0030h
  Size                          8192MB
  Device Locator                DIMM_B1
  Bank Locator                  BANK 2
  Speed                         3200MHz
  Manufacturer                  A-DATA
  Serial Number
  Attributes                    1
  Memory Technology             3
  Firmware Version              6
  Module Product Id             0
  Non-Volatile Size             0
  Volatile Size                 0
  Cache Size                    0
  Logical Size                  0
  Extended Speed                0
[Memory Device Mapped Address (Type 20) - Length 35 - Handle 0032h]
  Memory Device Handle          0031h
[32Bit Memory Error Information (Type 18) - Length 23 - Handle 0033h]
[Memory Device (Type 17) - Length 92 - Handle 0034h]
  Memory Error Info Handle      0033h
  Device Locator                DIMM_B2
  Bank Locator                  BANK 3
  Speed                         0MHz
  Serial Number
  Part Number                   Unknown
  Attributes                    0
  Minimum Voltage               0
  Maximum Voltage               0
  Memory Technology             2
  Firmware Version              6
  Module Product Id             0
  Non-Volatile Size             0
  Volatile Size                 0
  Cache Size                    0
  Logical Size                  0
  Extended Speed                0
[ (Type 256) - Length 4 - Handle 0039h]
Arguments:
Arg2: ffff810147e6f110, Object whose reference count is being lowered
Arg4: ffffd9822a36dfff, Reserved
Debugging Details:
    Value: 718
    Value: 3209
    Value: 0
    Value: 1
    Value: 0
    Value: 218
    Value: 467
    Value: 90
    Value: 1.2410.2.2
    Value: 0x18
    Value: 0x18
    Key  : Failure.Hash
    Key  : WER.OS.Branch
    Value: vb_release
    Value: 10.0.19041.1
BUGCHECK_CODE:  18
BUGCHECK_P1: 0
BUGCHECK_P2: ffff810147e6f110
BUGCHECK_P3: 2
BUGCHECK_P4: ffffd9822a36dfff
FILE_IN_CAB:  032925-6062-01.dmp
FAULTING_THREAD:  ffffd98234174080
BLACKBOXWINLOGON: 1
PROCESS_NAME:  DCS.exe
STACK_TEXT:
ffff8101`47e6f028 fffff801`5523b51d     : 00000000`00000018 00000000`00000000 ffff8101`47e6f110 00000000`00000002 : nt!KeBugCheckEx
ffff8101`47e6f030 fffff801`5505ab8e     : ffff8101`47e6f110 ffffb886`9d3eb9c8 ffffb886`9d3eb9c8 00000000`00000000 : nt!ObfDereferenceObjectWithTag+0x1e097d
ffff8101`47e6f070 fffff801`61da47ce     : ffff8101`47e6f119 ffffd982`2e7401c0 ffffb886`00000000 ffffb886`9e21e801 : nt!HalPutDmaAdapter+0xe
ffff8101`47e6f0a0 fffff801`61da3943     : 00000000`00000000 00000000`00000000 ffffd982`2cab8000 ffff8101`47e6fa20 : dxgkrnl!NotifyPendingFlipPresent+0x84e
ffff8101`47e6f180 fffff801`61ee5db8     : ffff8101`47e6fa28 ffff8101`47e6f210 ffff8101`47e6f910 00000000`00000001 : dxgkrnl!DxgkQuerySwapChainBindingStatus+0x2b
ffff8101`47e6f1b0 fffff801`61e8eacb     : ffffb886`9d3eb860 00000000`00000000 ffffd982`2cab8000 00000000`00000000 : dxgkrnl!SubmitPresentHistoryTokenPreparation+0x178
ffff8101`47e6f250 fffff801`61e91c61     : ffffb886`9d3eb860 ffff8101`47e6fb80 00000000`00000000 ffffd982`2cab8000 : dxgkrnl!DXGCONTEXT::Present+0x9eb
ffff8101`47e6f830 fffff801`55211e08     : ffffd982`34174080 ffffd982`34174080 00000000`00009000 00000000`00000000 : dxgkrnl!DxgkPresent+0x7f1
ffff8101`47e6fb00 00007ff8`c8095424     : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!KiSystemServiceCopyEnd+0x28
00000006`0afbc298 00000000`00000000     : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : 0x00007ff8`c8095424
STACK_COMMAND:  .process /r /p 0xffffd98236e9b340; .thread 0xffffd98234174080 ; kb
OSNAME:  Windows 10
    PnpActivityTime    : 133877385068615376
    PnpProblemCode     : 24
    PnpVetoType        : 0
    DeviceId           : USB\VID_1532&PID_008C\6&1d1f0399&0&2
    VetoString         :
Arguments:
Arg2: ffffd50006a0a110, Object whose reference count is being lowered
Arg4: ffffe70895e2cfff, Reserved
Debugging Details:
    Value: 921
    Value: 4190
    Value: 0
    Value: 1
    Value: 0
    Value: 203
    Value: 459
    Value: 90
    Value: 1.2410.2.2
    Value: 0x18
    Value: 0x18
    Key  : Failure.Hash
    Key  : WER.OS.Branch
    Value: vb_release
    Value: 10.0.19041.1
BUGCHECK_CODE:  18
BUGCHECK_P1: 0
BUGCHECK_P2: ffffd50006a0a110
BUGCHECK_P3: 2
BUGCHECK_P4: ffffe70895e2cfff
FILE_IN_CAB:  040125-5281-01.dmp
FAULTING_THREAD:  ffffe708a55b8080
BLACKBOXWINLOGON: 1
STACK_TEXT:
ffffd500`06a0a028 fffff807`7043b51d     : 00000000`00000018 00000000`00000000 ffffd500`06a0a110 00000000`00000002 : nt!KeBugCheckEx
ffffd500`06a0a030 fffff807`7025ab8e     : ffffd500`06a0a110 ffffaa0d`2daca178 ffffaa0d`2daca178 00000000`00000000 : nt!ObfDereferenceObjectWithTag+0x1e097d
ffffd500`06a0a070 fffff807`7d0147ce     : ffffd500`06a0a119 ffffe708`9b9341c0 ffffaa0d`00000000 ffffaa0d`51c26c01 : nt!HalPutDmaAdapter+0xe
ffffd500`06a0a0a0 fffff807`7d013943     : 00000000`00000000 00000000`00000000 ffffe708`99c5e000 ffffd500`06a0aa20 : dxgkrnl!NotifyPendingFlipPresent+0x84e
ffffd500`06a0a180 fffff807`7d155db8     : ffffd500`06a0aa28 ffffd500`06a0a210 ffffd500`06a0a910 00000000`00000001 : dxgkrnl!DxgkQuerySwapChainBindingStatus+0x2b
ffffd500`06a0a1b0 fffff807`7d0feacb     : ffffaa0d`2daca010 00000000`00000000 ffffe708`99c5e000 00000000`00000000 : dxgkrnl!SubmitPresentHistoryTokenPreparation+0x178
ffffd500`06a0a250 fffff807`7d101c61     : ffffaa0d`2daca010 ffffd500`06a0ab80 00000000`00000000 ffffe708`99c5e000 : dxgkrnl!DXGCONTEXT::Present+0x9eb
ffffd500`06a0a830 fffff807`70411e08     : ffffe708`a55b8080 ffffe708`a55b8080 00000000`00009000 00000000`00000000 : dxgkrnl!DxgkPresent+0x7f1
ffffd500`06a0ab00 00007ffc`71e95424     : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!KiSystemServiceCopyEnd+0x28
00000001`0207c458 00000000`00000000     : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : 0x00007ffc`71e95424
STACK_COMMAND:  .process /r /p 0xffffe708980a0340; .thread 0xffffe708a55b8080 ; kb
OSNAME:  Windows 10
    PnpActivityTime    : 133880060481596846
    PnpProblemCode     : 24
    PnpVetoType        : 0
    DeviceId           : SW\{96E080C7-143C-11D1-B40F-00A0C9223196}\{3C0D501A-140B-11D1-B40F-00A0C9223196}
    VetoString         :
Arguments:
Arg2: ffffd7083dc29110, Object whose reference count is being lowered
Arg4: ffffd807018adfff, Reserved
Debugging Details:
    Value: 890
    Value: 3461
    Value: 0
    Value: 1
    Value: 0
    Value: 203
    Value: 473
    Value: 90
    Value: 1.2410.2.2
    Value: 0x18
    Value: 0x18
    Key  : Failure.Hash
    Key  : WER.OS.Branch
    Value: vb_release
    Value: 10.0.19041.1
BUGCHECK_CODE:  18
BUGCHECK_P1: 0
BUGCHECK_P2: ffffd7083dc29110
BUGCHECK_P3: 2
BUGCHECK_P4: ffffd807018adfff
FILE_IN_CAB:  040225-5515-01.dmp
FAULTING_THREAD:  ffffd807112e3340
BLACKBOXWINLOGON: 1
STACK_TEXT:
ffffd708`3dc29028 fffff804`3aa3b51d     : 00000000`00000018 00000000`00000000 ffffd708`3dc29110 00000000`00000002 : nt!KeBugCheckEx
ffffd708`3dc29030 fffff804`3a85ab8e     : ffffd708`3dc29110 ffff888a`52ba8708 ffff888a`52ba8708 00000000`00000000 : nt!ObfDereferenceObjectWithTag+0x1e097d
ffffd708`3dc29070 fffff804`488847ce     : ffffd708`3dc29119 ffffd807`05a531c0 ffff888a`00000000 ffff888a`7f56ed01 : nt!HalPutDmaAdapter+0xe
ffffd708`3dc290a0 fffff804`48883943     : 00000000`00000000 00000000`00000000 ffffd807`03dea000 ffffd708`3dc29a20 : dxgkrnl!NotifyPendingFlipPresent+0x84e
ffffd708`3dc29180 fffff804`489c5db8     : ffffd708`3dc29a28 ffffd708`3dc29210 ffffd708`3dc29910 00000000`00000001 : dxgkrnl!DxgkQuerySwapChainBindingStatus+0x2b
ffffd708`3dc291b0 fffff804`4896eacb     : ffff888a`52ba85a0 00000000`00000000 ffffd807`03dea000 00000000`00000000 : dxgkrnl!SubmitPresentHistoryTokenPreparation+0x178
ffffd708`3dc29250 fffff804`48971c61     : ffff888a`52ba85a0 ffffd708`3dc29b80 00000000`00000000 ffffd807`03dea000 : dxgkrnl!DXGCONTEXT::Present+0x9eb
ffffd708`3dc29830 fffff804`3aa11e08     : ffffd807`112e3340 ffffd807`112e3340 00000000`00009000 00000000`00000000 : dxgkrnl!DxgkPresent+0x7f1
ffffd708`3dc29b00 00007ffd`29ef5424     : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!KiSystemServiceCopyEnd+0x28
00000057`b9fdc538 00000000`00000000     : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : 0x00007ffd`29ef5424
STACK_COMMAND:  .process /r /p 0xffffd80709a020c0; .thread 0xffffd807112e3340 ; kb
OSNAME:  Windows 10
    PnpActivityTime    : 133880801642770258
    PnpProblemCode     : 24
    PnpVetoType        : 0
    VetoString         :
Arguments:
Arg2: ffffe403b174f110, Object whose reference count is being lowered
Arg4: ffffe60665401fff, Reserved
Debugging Details:
    Value: 640
    Value: 1790
    Value: 0
    Value: 1
    Value: 0
    Value: 203
    Value: 479
    Value: 90
    Value: 1.2410.2.2
    Value: 0x18
    Value: 0x18
    Key  : Failure.Hash
    Key  : WER.OS.Branch
    Value: vb_release
    Value: 10.0.19041.1
BUGCHECK_CODE:  18
BUGCHECK_P1: 0
BUGCHECK_P2: ffffe403b174f110
BUGCHECK_P3: 2
BUGCHECK_P4: ffffe60665401fff
FILE_IN_CAB:  040325-6593-01.dmp
FAULTING_THREAD:  ffffe60669dc2080
BLACKBOXWINLOGON: 1
STACK_TEXT:
ffffe403`b174f028 fffff803`3783b51d     : 00000000`00000018 00000000`00000000 ffffe403`b174f110 00000000`00000002 : nt!KeBugCheckEx
ffffe403`b174f030 fffff803`3765ab8e     : ffffe403`b174f110 ffffce87`e2644178 ffffce87`e2644178 00000000`00000000 : nt!ObfDereferenceObjectWithTag+0x1e097d
ffffe403`b174f070 fffff803`434147ce     : ffffe403`b174f119 ffffe606`69a4f1c0 ffffce87`00000000 ffffce87`dd626101 : nt!HalPutDmaAdapter+0xe
ffffe403`b174f0a0 fffff803`43413943     : 00000000`00000000 00000000`00000000 ffffe606`67dc3000 ffffe403`b174fa20 : dxgkrnl!NotifyPendingFlipPresent+0x84e
ffffe403`b174f180 fffff803`43555db8     : ffffe403`b174fa28 ffffe403`b174f210 ffffe403`b174f910 00000000`00000001 : dxgkrnl!DxgkQuerySwapChainBindingStatus+0x2b
ffffe403`b174f1b0 fffff803`434feacb     : ffffce87`e2644010 00000000`00000000 ffffe606`67dc3000 00000000`00000000 : dxgkrnl!SubmitPresentHistoryTokenPreparation+0x178
ffffe403`b174f250 fffff803`43501c61     : ffffce87`e2644010 ffffe403`b174fb80 00000000`00000000 ffffe606`67dc3000 : dxgkrnl!DXGCONTEXT::Present+0x9eb
ffffe403`b174f830 fffff803`37811e08     : ffffe606`69dc2080 ffffe606`69dc2080 00000000`00009000 ffffe606`00000000 : dxgkrnl!DxgkPresent+0x7f1
ffffe403`b174fb00 00007ff8`19545424     : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!KiSystemServiceCopyEnd+0x28
000000ea`7b97c218 00000000`00000000     : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : 0x00007ff8`19545424
STACK_COMMAND:  .process /r /p 0xffffe60671ced080; .thread 0xffffe60669dc2080 ; kb
OSNAME:  Windows 10
    PnpActivityTime    : 133881500172058373
    PnpProblemCode     : 24
    PnpVetoType        : 0
    VetoString         :
Kod:
Arguments:
Debugging Details:
    Value: 687
    Value: 2935
    Value: 0
    Value: 1
    Value: 0
    Value: 171
    Value: 465
    Value: 90
    Value: 1.2410.2.2
    Value: 0x18
    Value: 0x18
    Key  : Failure.Hash
    Key  : WER.OS.Branch
    Value: vb_release
    Value: 10.0.19041.1
BUGCHECK_CODE:  18
BUGCHECK_P1: 0
BUGCHECK_P3: 2
BLACKBOXWINLOGON: 1
STACK_TEXT:
OSNAME:  Windows 10
    PnpProblemCode     : 24
    PnpVetoType        : 0
    VetoString         :
[DMI Version - 0]
  BIOS Version                  6232
       07: - PCI Supported
       10: - APM Supported
       19: - EDD Supported
  SKUNumber                     SKU
  Version                       Rev X.0x
  Asset Tag
       00: - Motherboard
       03: - Replaceable
  Serial Number
  Asset Tag Number
  Number of Strings             8
   1                            Default string
   2                            Default string
   3                            SID
   4                            Default string
   5                            Default string
   6                            Default string
   7                            Default string
   8                            Default string
  Cache Speed                   1ns
  Cache Speed                   1ns
  Cache Speed                   1ns
  Max Speed                     4100MHz
  Serial Number
  Asset Tag Number
  Part Number                   Unknown
  Core Count                    6
  Core Enabled                  6
  Thread Count                  12
       0x 3: Multi-Core
  Core Count 2                  6
  Core Enabled 2                6
  Thread Count 2                12
  Size                          8192MB
  Bank Locator                  BANK 0
  Speed                         3200MHz
  Manufacturer                  A-DATA
  Serial Number
  Attributes                    1
  Memory Technology             3
  Firmware Version              6
  Module Product Id             0
  Non-Volatile Size             0
  Volatile Size                 0
  Cache Size                    0
  Logical Size                  0
  Extended Speed                0
  Bank Locator                  BANK 1
  Speed                         0MHz
  Serial Number
  Part Number                   Unknown
  Attributes                    0
  Minimum Voltage               0
  Maximum Voltage               0
  Memory Technology             2
  Firmware Version              6
  Module Product Id             0
  Non-Volatile Size             0
  Volatile Size                 0
  Cache Size                    0
  Logical Size                  0
  Extended Speed                0
  Size                          8192MB
  Bank Locator                  BANK 2
  Speed                         3200MHz
  Manufacturer                  A-DATA
  Serial Number
  Attributes                    1
  Memory Technology             3
  Firmware Version              6
  Module Product Id             0
  Non-Volatile Size             0
  Volatile Size                 0
  Cache Size                    0
  Logical Size                  0
  Extended Speed                0
  Bank Locator                  BANK 3
  Speed                         0MHz
  Serial Number
  Part Number                   Unknown
  Attributes                    0
  Minimum Voltage               0
  Maximum Voltage               0
  Memory Technology             2
  Firmware Version              6
  Module Product Id             0
  Non-Volatile Size             0
  Volatile Size                 0
  Cache Size                    0
  Logical Size                  0
  Extended Speed                0
Arguments:
Debugging Details:
    Value: 718
    Value: 3209
    Value: 0
    Value: 1
    Value: 0
    Value: 218
    Value: 467
    Value: 90
    Value: 1.2410.2.2
    Value: 0x18
    Value: 0x18
    Key  : Failure.Hash
    Key  : WER.OS.Branch
    Value: vb_release
    Value: 10.0.19041.1
BUGCHECK_CODE:  18
BUGCHECK_P1: 0
BUGCHECK_P3: 2
BLACKBOXWINLOGON: 1
STACK_TEXT:
OSNAME:  Windows 10
    PnpProblemCode     : 24
    PnpVetoType        : 0
    VetoString         :
Arguments:
Debugging Details:
    Value: 921
    Value: 4190
    Value: 0
    Value: 1
    Value: 0
    Value: 203
    Value: 459
    Value: 90
    Value: 1.2410.2.2
    Value: 0x18
    Value: 0x18
    Key  : Failure.Hash
    Key  : WER.OS.Branch
    Value: vb_release
    Value: 10.0.19041.1
BUGCHECK_CODE:  18
BUGCHECK_P1: 0
BUGCHECK_P3: 2
BLACKBOXWINLOGON: 1
STACK_TEXT:
OSNAME:  Windows 10
    PnpProblemCode     : 24
    PnpVetoType        : 0
    VetoString         :
Arguments:
Debugging Details:
    Value: 890
    Value: 3461
    Value: 0
    Value: 1
    Value: 0
    Value: 203
    Value: 473
    Value: 90
    Value: 1.2410.2.2
    Value: 0x18
    Value: 0x18
    Key  : Failure.Hash
    Key  : WER.OS.Branch
    Value: vb_release
    Value: 10.0.19041.1
BUGCHECK_CODE:  18
BUGCHECK_P1: 0
BUGCHECK_P3: 2
BLACKBOXWINLOGON: 1
STACK_TEXT:
OSNAME:  Windows 10
    PnpProblemCode     : 24
    PnpVetoType        : 0
    VetoString         :
Arguments:
Debugging Details:
    Value: 640
    Value: 1790
    Value: 0
    Value: 1
    Value: 0
    Value: 203
    Value: 479
    Value: 90
    Value: 1.2410.2.2
    Value: 0x18
    Value: 0x18
    Key  : Failure.Hash
    Key  : WER.OS.Branch
    Value: vb_release
    Value: 10.0.19041.1
BUGCHECK_CODE:  18
BUGCHECK_P1: 0
BUGCHECK_P3: 2
BLACKBOXWINLOGON: 1
STACK_TEXT:
OSNAME:  Windows 10
    PnpProblemCode     : 24
    PnpVetoType        : 0
    VetoString         :
