OpenCore Ryzen 5 3500X & RTX 2060 sistem macOS Sonoma kurulumunda hata
grknztk
21 Mart 2024
  • Ryzen 5 3500X
  • RTX 2060
  • Gigabyte B450 S2H
Loglarda hata veriyor. Kurulumda Apple logosu da çıkmıyor. Konsola bir şeyler yazıyor sonra kapanıyor.
Kod:
00:000 00:000 AAPL: #[EB.H.IS|!] Err(0xE) <- RT.GV boot-signature 7C436110-AB2A-4BBB-A880-FE41995C9F82
00:036 00:036 AAPL: #[EB.H.IS|!] Err(0xE) <- RT.GV boot-image-key 7C436110-AB2A-4BBB-A880-FE41995C9F82
00:071 00:035 AAPL: #[EB|H:IS] 0
00:107 00:035 AAPL: #[EB|LOG:INIT] 2024-03-21T18:59:58
00:143 00:035 AAPL: #[EB|VERSION] <"bootbase.efi 580~439 (Official), built 2023-08-05T06:56:06-0700">
00:178 00:035 AAPL: #[EB|BUILD] <"BUILD-INFO[400]:{"DisplayName":"bootbase.efi","DisplayVersion":"580~439","RecordUuid":"08567299-4618-43B8-9137-4F6F99975A72","BuildTime":"2023-08-05T06:56:06-0700","ProjectName":"efiboot","ProductName":"bootbase.efi","SourceVersion":"580","BuildVersion":"439","BuildConfiguration":"Release","BuildType":"Official","Compiler":"clang-1500.0.37.1","SdkVersion":"14.0","SdkBuild":"23A316","TargetArchitectures":"x86_64"}">
00:214 00:035 AAPL: #[EB.CFG.DEV|!] Err(0xE) <- RT.GV booter-strict-xmlparser 7C436110-AB2A-4BBB-A880-FE41995C9F82
00:250 00:035 AAPL: #[EB|CFG:DEV] r5 0x0 0x0
00:285 00:035 AAPL: #[EB|H:IS] 0
00:321 00:035 AAPL: #[EB|WL:MODE] 0
00:357 00:035 AAPL: #[EB|CFG:ARG] boot-save-log 0x0000000000000002 (0x0000000000000002 < 0xFFFFFFFFFFFFFFFF) default
00:393 00:035 AAPL: #[EB|CFG:ARG] wake-save-log 0x0000000000000002 (0x0000000000000002 < 0x0000000000000002) default
00:428 00:035 AAPL: #[EB|CFG:ARG] console       0x0000000000000001 (0x0000000000000001 < 0x0000000000000001) default
00:464 00:035 AAPL: #[EB|CFG:ARG] serial        0x0000000000000001 (0x0000000000000001 < 0x0000000000000000) default
00:500 00:035 AAPL: #[EB|CFG:ARG] preoslog      0x0000000000000001 (0x0000000000000001 < 0xFFFFFFFFFFFFFFFF) default
00:535 00:035 AAPL: #[EB|CFG:ARG] timestamps    0x0000000000000000 (0x0000000000000000 < 0xFFFFFFFFFFFFFFFF) default
00:571 00:035 AAPL: #[EB|CFG:ARG] log-level     0x0000000000000001 (0x0000000000000001 & 0x0000000000000021) default
00:607 00:035 AAPL: #[EB|CFG:ARG] breakpoint    0x0000000000000000 (0x0000000000000000 & 0x0000000000000000) default
00:643 00:035 AAPL: #[EB|CFG:ARG] kc-read-size  0x0000000000100000 (0x0000000000100000 < 0xFFFFFFFFFFFFFFFF) default
00:678 00:035 AAPL: #[EB|CFG:ARG] force-error   0x0000000000000000 (0x0000000000000000 & 0x0000000000000000) default
00:714 00:035 AAPL: #[EB|H:IS] 0
00:750 00:035 AAPL: #[EB|WL] 0 0 0x01 0x01   0 0x00
00:785 00:035 AAPL: #[EB|BRD:NV] Mac-7BA5B2D9E42DDD94
00:821 00:035 AAPL: #[EB|B:VAw]
00:857 00:035 AAPL: #[EB|B:IAw]
00:892 00:035 AAPL: #[EB|WL] 0 0 0x01 0x01   2 0x00
00:928 00:035 AAPL: #[EB.BST.IDT|+]
00:964 00:035 AAPL: #[EB|BM] J137AP
01:001 00:037 AAPL: #[EB.BST.IDT|-]
01:036 00:035 AAPL: #[EB|WL] 0 0 0x01 0x01   3 0x00
01:075 00:038 AAPL: #[EB|WL] 0 0 0x01 0x01   4 0x00
01:111 00:035 AAPL: #[EB|BRD:NV] Mac-7BA5B2D9E42DDD94
01:147 00:036 AAPL: #[EB|WL] 0 0 0x01 0x01   5 0x00
01:182 00:035 AAPL: #[EB.H.CHK|BM] 0x0000000000000000
01:218 00:036 AAPL: #[EB.H.LV|!] Err(0xE) <- RT.GV boot-signature 7C436110-AB2A-4BBB-A880-FE41995C9F82
01:254 00:035 AAPL: #[EB|WL] 0 0 0x01 0x01  23 0x0E
01:290 00:035 AAPL: #[EB.H.LV|!] Err(0xE) <- RT.GV boot-image-key 7C436110-AB2A-4BBB-A880-FE41995C9F82
01:326 00:035 AAPL: #[EB|WL] 0 0 0x01 0x01  24 0x0E
01:361 00:035 AAPL: #[EB.H.LV|!] Err(0xE) <- RT.GV boot-image 7C436110-AB2A-4BBB-A880-FE41995C9F82
01:397 00:035 AAPL: #[EB.H.LV|!] Err(0xE) <- RT.SV- boot-signature 7C436110-AB2A-4BBB-A880-FE41995C9F82
01:432 00:035 AAPL: #[EB.H.LV|!] Err(0xE) <- RT.SV- boot-image-key 7C436110-AB2A-4BBB-A880-FE41995C9F82
01:468 00:035 AAPL: #[EB.H.LV|!] Err(0xE) <- RT.SV- boot-image 7C436110-AB2A-4BBB-A880-FE41995C9F82
01:504 00:035 AAPL: #[EB|H:NOT]
01:540 00:035 AAPL: #[EB|SB:P] 0x1
01:576 00:036 AAPL: #[EB.B.MN|BM:+SB]
01:612 00:035 AAPL: #[EB|LIMG:DP] Acpi(PNP0A03,0)/Pci(1|3)/Pci(0|0)/Usb(7, 0)/HD(Part2,SigAA87345C)
01:650 00:038 AAPL: #[EB|LIMG:FP] \System\Library\CoreServices\boot.efi
01:685 00:035 AAPL: #[EB|LIMG:OPT]
01:721 00:035 AAPL: #[EB|RPS] 0 0 0
01:758 00:037 AAPL: #[EB.OPT.LXF|F] <"\\System\\Library\\CoreServices\\com.apple.Boot.plist">
01:794 00:035 AAPL: #[EB.LD.LF|IN] 0 1 <"\\System\\Library\\CoreServices\\com.apple.Boot.plist"> <"0">
01:830 00:036 AAPL: #[EB.LD.OFS|OPEN!] Err(0xE) <"\\System\\Library\\CoreServices\\com.apple.Boot.plist">
01:865 00:035 AAPL: #[EB.OPT.LXF|LF!] Err(0xE)
01:901 00:035 AAPL: #[EB.OPT.LXF|F] <"Library\\Preferences\\SystemConfiguration\\com.apple.Boot.plist">
01:937 00:035 AAPL: #[EB.LD.LF|IN] 0 1 <"Library\\Preferences\\SystemConfiguration\\com.apple.Boot.plist"> <"0">
01:975 00:038 AAPL: #[EB|KF] <"root-dmg=file:///BaseSystem/BaseSystem.dmg">
02:011 00:035 AAPL: #[EB|MBA:CL] <"">
02:046 00:035 AAPL: #[EB|MBA:NV] <"-v keepsyms=1 debug=0x100 alcid=1 slide=248">
02:082 00:036 AAPL: #[EB|MBA:KF] <"root-dmg=file:///BaseSystem/BaseSystem.dmg">
02:118 00:035 AAPL: #[EB|MBA:OUT] <"-v keepsyms=1 debug=0x100 alcid=1 slide=248 root-dmg=file:///BaseSystem/BaseSystem.dmg">
02:172 00:054 AAPL: #[EB|LOG:VERBOSE] 2024-03-21T19:00:00
02:208 00:035 AAPL: #[EB.CSR.S|VAR] 0x00000040
02:243 00:035 AAPL: #[EB|OPT:BM] 0x200082
02:279 00:035 AAPL: #[EB.OPT.LXF|F] <"\\System\\Library\\CoreServices\\PlatformSupport.plist">
02:314 00:035 AAPL: #[EB.LD.LF|IN] 0 1 <"\\System\\Library\\CoreServices\\PlatformSupport.plist"> <"0">
02:353 00:038 AAPL: #[EB|P:CPR] N
02:389 00:035 AAPL: #[EB|P:MPI] N
02:424 00:035 AAPL: #[EB|P:BPI] N
02:460 00:035 AAPL: #[EB.OPT.RKS|!] Err(0xE) <- BS.LocP EDB4A040-6D8A-11EC-8FAD-3E22FB93ADCF
02:496 00:035 AAPL: #[EB|KMR] 372207616
02:532 00:036 AAPL: #[EB.CS.CSKSD|+]
02:568 00:035 AAPL: #[EB.CS.CSKSD|!] Err(0xE) <- RT.GV boot-info-payload 8D63D4FE-BD3C-4AAD-881D-86FD974BC1DF
02:604 00:035 AAPL: #[EB.G.CS|-?] Ok(0)
02:640 00:036 AAPL: #[EB.LD.LF|IN] 0 1 <"<null string>"> <"1">
02:711 00:070 AAPL: #[EB.B.SBS|SZ] 723512
02:753 00:041 AAPL: #[EB|B:SHA] <b1e47ec9ae2d59ba0b18756ffd99abe85af8d370>
02:790 00:037 AAPL: #[EB.WL.PWLFNV|!] Err(0xE) <- RT.GV wake-failure 7C436110-AB2A-4BBB-A880-FE41995C9F82
02:826 00:036 AAPL: #[EB.WL.DT|!] Err(0xE) <- EB.WL.PWLFNV
02:862 00:035 AAPL: #[EB.WL.PWLFRTC|NONE]
02:899 00:036 AAPL: #[EB.WL.DT|!] Err(0xE) <- EB.WL.PWLFRTC
02:936 00:037 AAPL: #[EB.LD.LKC|D] <"System\Library\KernelCollections\BootKernelExtensions.kc.development">
02:977 00:040 AAPL: #[EB.LD.LF|IN] 0 1 <"System\\Library\\KernelCollections\\BootKernelExtensions.kc.development"> <"0">
03:016 00:039 AAPL: #[EB.LD.OFS|OPEN!] Err(0xE) <"System\\Library\\KernelCollections\\BootKernelExtensions.kc.development">
03:053 00:037 AAPL: #[EB.LD.LKC|R.2] <"System\Library\KernelCollections\BootKernelExtensions.kc">
03:093 00:039 AAPL: #[EB.LD.LF|IN] 0 1 <"System\\Library\\KernelCollections\\BootKernelExtensions.kc"> <"0">
09:964 06:871 AAPL: #[EB|SB:P] 0x1
10:000 00:036 AAPL: #[EB|SB:SBGMFNS] j137ap.im4m
10:037 00:037 AAPL: #[EB|SB:MF] System\\Library\\KernelCollections\\BootKernelExtensions.kc.j137ap.im4m
10:075 00:037 AAPL: #[EB.LD.LF|IN] 0 1 <"System\\Library\\KernelCollections\\BootKernelExtensions.kc.j137ap.im4m"> <"0">
10:352 00:277 AAPL: #[EB|SB:MKRN]
10:398 00:046 AAPL: #[EB.LD.LKFS|-?] Ok(0)
10:451 00:053 AAPL: #[EB.LD.LKC|-?] Ok(0)
10:490 00:038 AAPL: #[EB|BST:REV1]
10:526 00:036 AAPL: #[EB|CSR:OUT] 0x00000040
10:564 00:038 AAPL: #[EB.BST.FBS|+]
10:601 00:036 AAPL: #[EB.BST.FBS|ADSZ] 0
10:637 00:036 AAPL: #[EB.BST.FBS|KSSZ] 0
10:673 00:035 AAPL: #[EB|SB:SBGMFNS] j137ap.im4m
10:709 00:036 AAPL: #[EB|RH:PF] usr\standalone\OS.dmg.root_hash
10:746 00:036 AAPL: #[EB|RH:MF] <"usr\\standalone\\OS.dmg.root_hash.j137ap.im4m">
10:783 00:036 AAPL: #[EB.LD.LF|IN] 0 1 <"usr\\standalone\\OS.dmg.root_hash"> <"0">
10:820 00:037 AAPL: #[EB.LD.OFS|OPEN!] Err(0xE) <"usr\\standalone\\OS.dmg.root_hash">
10:856 00:036 AAPL: #[EB.RH.LRH|P!] Err(0xE) <- EB.LD.LF
10:893 00:036 AAPL: #[EB.BST.FBS|!] Err(0xE) <- EB.RH.LRH
10:929 00:036 AAPL: #[EB|LOG:DT] 2024-03-21T19:00:09
10:966 00:036 AAPL: #[EB|LOG:EXITBS:START] 2024-03-21T19:00:09
Buyurun Config dosyasının içeriği. Ekran kartı konusunda da ne yapmam gerekiyor? Değiştirmeli miyim?
RTX serisi mi direkt desteklemiyor? Çünkü 3070 ekran kartı da var onu da mı kullanamıyorum?
Ekran kartını kesinlikle değiştirmeniz gerekiyor eğer macOS kullanmak istiyorsanız. Bunlardan birine bakabilirsiniz:
  • RX 6600
  • RX 6600 XT
  • RX 6800
  • RX 6800 XT
  • RX 6900 XT
  • RX 5500
  • RX 5500 XT
  • RX 5600
  • RX 5600 XT
  • RX 5700
  • RX 5700 XT
  • RX 5700 XT 50th Anniversary Edition
Radeon Pro:
  • Radeon Pro W5500
  • Radeon Pro W5700
Config konusunda da daha tecrübeli arkadaşlar yardımcı olur.
