23366
27 Haziran 2025
BuildCores Parts List: https://www.buildcores.com/builds/QysIiLm-W?share=true
Case: Zalman T6 ATX Mid Tower Black (Front Panel: USB 3.2 Gen 1 Type-A, USB 2.0 Type-A) - $52.08 (Amazon)
CPU: AMD Ryzen 5 5500 3.6 GHz 6-Core AM4 - $76.00 (Amazon)
Motherboard: MSI A520M-A Pro Micro ATX AM4 - $69.99 (Amazon)
GPU: MSI GeForce RTX 3060 Ventus 2X 12G OC - $299.99 (Amazon)
RAM: Vengeance RGB Pro 32 GB (2 X 16 GB) DDR4 DRAM 3600MHz C18 Memory Kit - $104.99 (Amazon)
CPU Cooler: Cooler Master Hyper 212 Spectrum V3 Air 152mm Black / Silver - $14.95 (Amazon)
Storage: Kingston A400 960GB SATA 3 2.5" Internal SSD SA400S37/960G - HDD Replacement for Increase Performance - $24.99 (Amazon)
Power Supply: Gigabyte UD850GM 850W Fully Modular 80+ Gold Certified - $103.00 (Amazon)
Case Fan: Arctic P12 Max 120mm Black PWM - $6.00 (Amazon)
Monitor: Lenovo G24E-20 23.8" 1080p 120Hz VA Monitor - $99.00 (Amazon)
Total Price: $874.99
Kuzenimin klavye, mouse, hoparlörü var. Yeni bilgisayar alıyor. Sizce attığım sistem iyi midir? ETS 2 ve Assetto Corsa oynayacak.
buildcores parts list: https://www.buildcores.com/builds/QysIiLm-W?share=true
Case: Zalman T6 ATX mid Tower Black (front panel: USB 3.2 gen 1 type-a, USB 2.0 type-a) - $52.08 (Amazon)
GPU: MSI GeForce RTX 3060 Ventus 2X 12g OC - $299.99 (Amazon)
RAM: Vengeance RGB Pro 32 GB (2 X 16 GB) DDR4 DRAM 3600MHz C18 Memory kit - $104.99 (Amazon)
CPU cooler: Cooler Master Hyper 212 Spectrum V3 Air 152mm Black / Silver - $14.95 (Amazon)
Storage: Kingston A400 960GB SATA 3 2.5" ınternal SSD SA400S37/960G - HDD replacement for ıncrease performance - $24.99 (Amazon)
Power Supply: Gigabyte UD850GM 850W fully modular 80+ Gold certified - $103.00 (Amazon)
Case fan: Arctic P12 Max 120mm Black PWM - $6.00 (Amazon)
Monitor: Lenovo G24E-20 23.8" 1080p 120Hz VA monitor - $99.00 (Amazon)
Total price: $874.99
Sistem pahalı tutar. TR'de ben 3 sene önce aynı sistemi almıştım 5500'ü zevkine 5600 le değiştirdim sadece CS de faydası oldu zannettiğiniz kadar önemli değil, 5500 3060'ı rahat besler sadece benim gibi hardcore ve comp oynamayı seviyorsanız 5600'e güncelleyin fakat 3060 bu devirde önermem 2. el 3080 çekip yanına 0 5600 alırsan işini daha iyi görür diğer parçalarda pek önemli değil kafana göre diz.
Düzgün bir PSU almanız daha önemlidir ayrıca elektriksel input lag ihtimaline karşı odanıza ayrı bir elektrik hattı döşemeniz sağlıklı olur fakat yaşınız kaç bilmiyorum yapmasanızda olur.
Oyununa bağlı performans düşüşü. Önbelleği düşük olduğu için performans olarak aşağı yukarı R5 3600 ayarında gücü var 5500'ün. Aşağıdaki testlerde oyunlara göre ne kadar fark olduğuna bakabilirsiniz.
Ama temelde zaten yeni bir sistem alınıyorsa AM4 almak saçmalık olur. İsterse R7 5700 taksın, saçma bir hareket.
Sifir bilgisayar icin olu yatirim AM4. Ancak islemci - anakart - ram' i 3K-3,5K gibi paralara set halinde alirsaniz mantikli olur.
5500'ün en büyük eksisi PCIe 3.0 olması. Önbellek çok önemli değil yine ama sırf PCIe 3.0 olduğu için bile alınmaz.
R7 5700 de PCIe 3.0 bu arada. 5700X ile bağlantısı yok, 5700G ile var.
