unaxpre
Üyecik
22 Ocak 2025
Merhaba, sürekli aldığım bir mavi ekran hatası var. Çoğu zaman minidump klasörüne kaydetmiyor. Format atma ekran kartı sürücüsünü DDU ile kaldırma gibi şeyleri denedim sorunu çözemedim.
Minidump Linki
DRIVER_IRQL_NOT_LESS_OR_EQUAL (d1)
An attempt was made to access a pageable (or completely invalid) address at an
interrupt request level (IRQL) that is too high. This is usually
caused by drivers using improper addresses.
If kernel debugger is available get stack backtrace.
Arguments:
Arg1: 00000000c00fd0dc, memory referenced
Arg2: 0000000000000002, IRQL
Arg3: 0000000000000000, value 0 = read operation, 1 = write operation
Arg4: fffff8011ccfe5bf, address which referenced memory
Debugging Details:
KEY_VALUES_STRING: 1
Key : Analysis.CPU.mSec
Value: 2796
Key : Analysis.Elapsed.mSec
Value: 6052
Key : Analysis.IO.Other.Mb
Value: 0
Key : Analysis.IO.Read.Mb
Value: 1
Key : Analysis.IO.Write.Mb
Value: 0
Key : Analysis.Init.CPU.mSec
Value: 937
Value: 5126
Value: 89
Key : Analysis.Version.DbgEng
Value: 10.0.27725.1000
Key : Analysis.Version.Description
Value: 10.2408.27.01 amd64fre
Key : Analysis.Version.Ext
Value: 1.2408.27.1
Key : Bugcheck.Code.LegacyAPI
Value: 0xd1
Key : Bugcheck.Code.TargetModel
Value: 0xd1
Key : Dump.Attributes.AsUlong
Value: 31008
Key : Dump.Attributes.DiagDataWrittenToHeader
Value: 1
Key : Dump.Attributes.ErrorCode
Value: 0
Key : Dump.Attributes.KernelGeneratedTriageDump
Value: 1
Key : Dump.Attributes.LastLine
Key : Dump.Attributes.ProgressPercentage
Value: 0
Key : Failure.Bucket
Value: AV_ANALYSIS_INCONCLUSIVE!unknown_function
Key : Failure.Hash
Value: {3dbc1176-592c-7a35-bae8-a878042529f7}
BUGCHECK_CODE: d1
BUGCHECK_P1: c00fd0dc
BUGCHECK_P2: 2
BUGCHECK_P3: 0
BUGCHECK_P4: fffff8011ccfe5bf
FILE_IN_CAB: 012125-985-01.dmp
DUMP_FILE_ATTRIBUTES: 0x31008
Kernel Generated Triage Dump
FAULTING_THREAD: ffff9785bcdae040
READ_ADDRESS: fffff80188bc34b0: Unable to get MiVisibleState
Unable to get NonPagedPoolStart
Unable to get NonPagedPoolEnd
Unable to get PagedPoolStart
Unable to get PagedPoolEnd
unable to get nt!MmSpecialPagesInUse
00000000c00fd0dc
CUSTOMER_CRASH_COUNT: 1
PROCESS_NAME: System
STACK_TEXT:
ffffaa80`514be118 00000000`00000000 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!KeBugCheckEx
SYMBOL_NAME: ANALYSIS_INCONCLUSIVE
MODULE_NAME: Unknown_Module
IMAGE_NAME: Unknown_Image
STACK_COMMAND: .cxr; .ecxr ; kb
FAILURE_BUCKET_ID: AV_ANALYSIS_INCONCLUSIVE!unknown_function
OSPLATFORM_TYPE: x64
OSNAME: Windows 10
FAILURE_ID_HASH: {3dbc1176-592c-7a35-bae8-a878042529f7}
Followup: MachineOwner
