Çözüldü DRIVER_POWER_STATE_FAILURE, Acpi.sys, volmgr ve Kernel Power hataları
Sistemi aldığınızdan beri hiç BIOS güncelleme yapmamışsınız. İlk işiniz BIOS güncelleme olmalı:
İkinci hata ekran kartı kaynaklı gibi ama XMP de ekran kartının hata vermesine sebep olabiliyor.
Ek olarak sisteminiz hakkında hiçbir detay vermemişsiniz.
Kod:
DRIVER_POWER_STATE_FAILURE (9f)
A driver has failed to complete a power IRP within a specific time.
Arguments:
Arg1: 0000000000000003, A device object has been blocking an IRP for too long a time
Arg2: ffffe704c90f6e10, Physical Device Object of the stack
Arg3: fffff88931467a00, nt!TRIAGE_9F_POWER on Win7 and higher, otherwise the Functional Device Object of the stack
Arg4: ffffe704cffe8010, The blocked IRP
Debugging Details:
KEY_VALUES_STRING: 1
    Key  : Analysis.CPU.mSec
    Value: 1203
    Key  : Analysis.Elapsed.mSec
    Value: 3457
    Key  : Analysis.IO.Other.Mb
    Value: 0
    Key  : Analysis.IO.Read.Mb
    Value: 1
    Key  : Analysis.IO.Write.Mb
    Value: 0
    Key  : Analysis.Init.CPU.mSec
    Value: 265
    Value: 4401
    Value: 93
    Value: 10.0.27725.1000
    Value: 10.2408.27.01 amd64fre
    Key  : Analysis.Version.Ext
    Value: 1.2408.27.1
    Value: 0x9f
    Value: 0x9f
    Value: 21808
    Value: 1
    Value: 0
    Value: 1
    Value: 0
    Key  : Failure.Bucket
    Value: 0x9F_3_amdi2c_DEV_AMDI0010_IMAGE_ACPI.sys
    Key  : Failure.Hash
    Value: {4a47bf2d-33a2-c37b-edc8-078440157129}
    Key  : Hypervisor.Enlightenments.ValueHex
    Value: 7497cf94
    Key  : Hypervisor.Flags.AnyHypervisorPresent
    Value: 1
    Key  : Hypervisor.Flags.ApicEnlightened
    Value: 1
    Key  : Hypervisor.Flags.ApicVirtualizationAvailable
    Value: 0
    Key  : Hypervisor.Flags.AsyncMemoryHint
    Value: 0
    Key  : Hypervisor.Flags.CoreSchedulerRequested
    Value: 0
    Key  : Hypervisor.Flags.CpuManager
    Value: 1
    Key  : Hypervisor.Flags.DeprecateAutoEoi
    Value: 0
    Key  : Hypervisor.Flags.DynamicCpuDisabled
    Value: 1
    Key  : Hypervisor.Flags.Epf
    Value: 0
    Key  : Hypervisor.Flags.ExtendedProcessorMasks
    Value: 1
    Key  : Hypervisor.Flags.HardwareMbecAvailable
    Value: 1
    Key  : Hypervisor.Flags.MaxBankNumber
    Value: 0
    Key  : Hypervisor.Flags.MemoryZeroingControl
    Value: 0
    Key  : Hypervisor.Flags.NoExtendedRangeFlush
    Value: 0
    Key  : Hypervisor.Flags.NoNonArchCoreSharing
    Value: 1
    Key  : Hypervisor.Flags.Phase0InitDone
    Value: 1
    Key  : Hypervisor.Flags.PowerSchedulerQos
    Value: 0
    Key  : Hypervisor.Flags.RootScheduler
    Value: 0
    Key  : Hypervisor.Flags.SynicAvailable
    Value: 1
    Key  : Hypervisor.Flags.UseQpcBias
    Value: 0
    Key  : Hypervisor.Flags.Value
    Value: 38408431
    Key  : Hypervisor.Flags.ValueHex
    Value: 24a10ef
    Key  : Hypervisor.Flags.VpAssistPage
    Value: 1
    Key  : Hypervisor.Flags.VsmAvailable
    Value: 1
    Key  : Hypervisor.RootFlags.AccessStats
    Value: 1
    Key  : Hypervisor.RootFlags.CrashdumpEnlightened
    Value: 1
    Key  : Hypervisor.RootFlags.CreateVirtualProcessor
    Value: 1
    Key  : Hypervisor.RootFlags.DisableHyperthreading
    Value: 0
    Key  : Hypervisor.RootFlags.HostTimelineSync
    Value: 1
    Key  : Hypervisor.RootFlags.HypervisorDebuggingEnabled
    Value: 0
    Key  : Hypervisor.RootFlags.IsHyperV
    Value: 1
    Key  : Hypervisor.RootFlags.LivedumpEnlightened
    Value: 1
    Key  : Hypervisor.RootFlags.MapDeviceInterrupt
    Value: 1
    Key  : Hypervisor.RootFlags.MceEnlightened
    Value: 1
    Key  : Hypervisor.RootFlags.Nested
    Value: 0
    Key  : Hypervisor.RootFlags.StartLogicalProcessor
    Value: 1
    Key  : Hypervisor.RootFlags.Value
    Value: 1015
    Key  : Hypervisor.RootFlags.ValueHex
    Value: 3f7
    Key  : Stack.Pointer
    Value: NMI
BUGCHECK_CODE:  9f
BUGCHECK_P1: 3
BUGCHECK_P2: ffffe704c90f6e10
BUGCHECK_P3: fffff88931467a00
BUGCHECK_P4: ffffe704cffe8010
FILE_IN_CAB:  122824-14921-01.dmp
TAG_NOT_DEFINED_202b:  *** Unknown TAG in analysis list 202b
DUMP_FILE_ATTRIBUTES: 0x21808
  Kernel Generated Triage Dump
FAULTING_THREAD:  ffffe704e8a47080
DRVPOWERSTATE_SUBCODE:  3
DRIVER_OBJECT: ffffe704c7bf4cf0
IMAGE_NAME:  ACPI.sys
MODULE_NAME: ACPI
FAULTING_MODULE: fffff8052a6f0000 ACPI
BLACKBOXACPI: 1 (!blackboxacpi)
BLACKBOXBSD: 1 (!blackboxbsd)
BLACKBOXPNP: 1 (!blackboxpnp)
BLACKBOXWINLOGON: 1
CUSTOMER_CRASH_COUNT:  1
PROCESS_NAME:  Aac3572MbHal_x
DPC_STACK_BASE:  FFFFF88931467FB0
STACK_TEXT:
fffff889`314679a8 fffff805`98b8f10d     : 00000000`0000009f 00000000`00000003 ffffe704`c90f6e10 fffff889`31467a00 : nt!KeBugCheckEx
fffff889`314679b0 fffff805`98b8ef0c     : ffffe704`e8a47080 fffff889`31467dd0 ffffe704`d0b57280 fffff889`31467b89 : nt!PopIrpWatchdogBugcheck+0x1f5
fffff889`31467a90 fffff805`988ef83a     : ffffa080`00000008 fffff805`00000001 fffff889`00000000 00000000`00000002 : nt!PopIrpWatchdog+0xc
fffff889`31467ac0 fffff805`988f0353     : fffff805`27cfc280 00000000`00000000 00000000`83572216 fffff805`27cff3e0 : nt!KiProcessExpiredTimerList+0x26a
fffff889`31467bf0 fffff805`988b9d61     : ffffa080`d75d9180 00000000`00000020 ffffa080`d75d9180 00000000`00000000 : nt!KiTimerExpiration+0x2e3
fffff889`31467d20 fffff805`98c81aa5     : 00000000`00000000 ffffe704`e895de40 fffff889`3b586ee0 00000000`00000000 : nt!KiRetireDpcList+0xaf1
fffff889`31467fb0 fffff805`98c81a4f     : fffff889`3b586fd0 fffff805`9880c9a5 ffffa080`d75d9180 fffff805`98975cab : nt!KxSwapStacksAndRetireDpcList+0x5
fffff889`3b586ee0 fffff805`9880c9a5     : ffffa080`d75d9180 fffff805`98975cab 00000000`00000000 fffff805`98c75250 : nt!KiPlatformSwapStacksAndCallReturn
fffff889`3b586ef0 fffff805`98c8127b     : 00000000`0000000a 00000000`00000000 ffffe704`c75ccfc0 ffffe704`c75ccfc0 : nt!KiDispatchInterrupt+0x65
fffff889`3b586f20 fffff805`98c7c6d4     : 00000000`5d930179 fffff889`3b586fd0 00000000`5d930181 0000008a`e6363b7c : nt!KiDpcInterruptBypass+0x1b
fffff889`3b586f50 fffff805`98811250     : 00000000`00000001 ffffe704`f2a908a0 ffffe704`e895ddc0 fffff889`3b5871c0 : nt!KiInterruptDispatchNoLockNoEtw+0x64
fffff889`3b5870e0 fffff805`98e964f8     : ffffe704`e895de58 fffff889`00000000 00000000`00000000 00000000`00000000 : nt!IopReleaseFileObjectLock+0x40
fffff889`3b587150 fffff805`98e947b1     : fffff889`3b587260 fffff889`3b587330 00000000`00000004 00000000`00000000 : nt!IopSynchronousServiceTail+0x268
fffff889`3b587200 fffff805`98e9447f     : ffffe704`e895ddc0 ffffe704`e895dd90 ffffe704`f2a908a0 00000000`00000000 : nt!IopWriteFile+0x141
fffff889`3b587320 fffff805`98c8d358     : 00000000`0012019f 00000000`00000000 00000000`00000000 00000000`00000000 : nt!NtWriteFile+0x2cf
fffff889`3b5873f0 00000000`77221f83     : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!KiSystemServiceCopyEnd+0x28
00000000`002ce698 00000000`00000000     : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : 0x77221f83
IMAGE_VERSION:  10.0.26100.2454
STACK_COMMAND:  .process /r /p 0xffffe704e8a45080; .thread 0xffffe704e8a47080 ; kb
FAILURE_BUCKET_ID:  0x9F_3_amdi2c_DEV_AMDI0010_IMAGE_ACPI.sys
OSPLATFORM_TYPE:  x64
OSNAME:  Windows 10
FAILURE_ID_HASH:  {4a47bf2d-33a2-c37b-edc8-078440157129}
Followup:     MachineOwner
    PnpActivityId      : {00000000-0000-0000-0000-000000000000}
    PnpActivityTime    : 133798847902275989
    PnpEventInformation: 3
    PnpEventInProgress : 0
    PnpProblemCode     : 24
    PnpVetoType        : 0
    DeviceId           : SW\{96E080C7-143C-11D1-B40F-00A0C9223196}\{3C0D501A-140B-11D1-B40F-00A0C9223196}
    VetoString         :
[SMBIOS Data Tables v3.6]
[DMI Version - 0]
[2.0 Calling Convention - No]
[Table Size - 3632 bytes]
  Vendor                        American Megatrends Inc.
  BIOS Version                  0304
  BIOS Release Date             08/08/2024
  BIOS ROM Size                 1000000
  BIOS Characteristics
       07: - PCI Supported
       11: - Upgradeable FLASH BIOS
       15: - CD-Boot Supported
       17: - BIOS ROM Socketed
       19: - EDD Supported
       22: - 360KB Floppy Supported
       23: - 1.2MB Floppy Supported
       24: - 720KB Floppy Supported
       25: - 2.88MB Floppy Supported
       32: - BIOS Vendor Reserved
       00: - ACPI Supported
       01: - USB Legacy Supported
  BIOS Major Revision           3
  BIOS Minor Revision           4
  EC Firmware Major Revision    255
  EC Firmware Minor Revision    255
  Extended BIOS ROM Size        32 MB
  Manufacturer                  ASUS
  Product Name                  System Product Name
  Version                       System Version
  Serial Number                 System Serial Number
  SKUNumber                     SKU
  Family                        To be filled by O.E.M.
  Manufacturer                  ASUSTeK COMPUTER INC.
  Product                       ROG CROSSHAIR X870E HERO
  Version                       Rev 1.xx
  Serial Number                 240943288101085
  Asset Tag
       00: - Motherboard
       03: - Replaceable
  Location                      Default string
  Manufacturer                  Default string
  Chassis Type                  Desktop
  Version                       Default string
  Serial Number
  Asset Tag Number
  Contained Element Size        3
[Onboard Devices Information (Type 10) - Length 6 - Handle 0004h]
Note: The On Board Device Information (Type 10) struct is obsolete as of SMBIOs spec v2.6  Number of Devices             1
  01: Type                      Video [enabled]
  01: Description                  To Be Filled By O.E.M.
[OEM Strings (Type 11) - Length 5 - Handle 0005h]
  Number of Strings             6
   1                            Default string
   2                            Default string
   3                            Default string
   4                            Default string
   5                            Default string
   6                            Default string
[System Configuration Options (Type 12) - Length 5 - Handle 0006h]
[ (Type 256) - Length 59 - Handle 0009h]
[ (Type 256) - Length 9 - Handle 000ah]
[ (Type 256) - Length 31 - Handle 000bh]
[ (Type 256) - Length 26 - Handle 000ch]
[Cache Information (Type 7) - Length 27 - Handle 000dh]
  Socket Designation            L1 - Cache
  Maximum Cache Size            0200h - 512K
  Installed Size                0200h - 512K
  Supported SRAM Type           0010h - Pipeline-Burst
  Current SRAM Type             0010h - Pipeline-Burst
  Cache Speed                   1ns
  Maximum Cache Size 2          200 - 00000512l Kb
  Installed Cache Size 2        200 - 00000512l Kb
[Cache Information (Type 7) - Length 27 - Handle 000eh]
  Socket Designation            L2 - Cache
  Maximum Cache Size            2000h - 8192K
  Installed Size                2000h - 8192K
  Cache Speed                   1ns
  Maximum Cache Size 2          2000 - 00008192l Kb
  Installed Cache Size 2        2000 - 00008192l Kb
[Cache Information (Type 7) - Length 27 - Handle 000fh]
  Socket Designation            L3 - Cache
  Maximum Cache Size            8200h - 32768K
  Installed Size                8200h - 32768K
  Cache Speed                   1ns
  Associativity                 16-way Set-Associative
  Maximum Cache Size 2          80000200 - 00032768l Kb
  Installed Cache Size 2        80000200 - 00032768l Kb
[Processor Information (Type 4) - Length 48 - Handle 0010h]
  Socket Designation            AM5
  Processor Family              6bh - AMD Zen Processor Family
  Processor Manufacturer        Advanced Micro Devices, Inc.
  Processor ID                   120fa600fffb8b17
  Processor Version             AMD Ryzen 7 7700 8-Core Processor
  Processor Voltage             8dh - 1.3V
  Max Speed                     5350MHz
  Current Speed                 3800MHz
  Processor Upgrade             Specification Reserved
  L1 Cache Handle               000dh
  L2 Cache Handle               000eh
  L3 Cache Handle               000fh
  Serial Number
  Asset Tag Number
  Part Number                   Unknown
  Core Count                    8
  Core Enabled                  8
  Thread Count                  16
  Processor Characteristics     fc
  Enabled Characteristics:
       0x 2: 64-bit Capable
       0x 3: Multi-Core
       0x 4: Hardware Thread
       0x 5: Execute Protection
       0x 6: Enhanced Virtualization
  Processor Family 2            006bh - AMD Zen Processor Family
  Core Count 2                  8
  Core Enabled 2                8
  Thread Count 2                16
[ (Type 256) - Length 9 - Handle 0011h]
[32Bit Memory Error Information (Type 18) - Length 23 - Handle 0012h]
[Physical Memory Array (Type 16) - Length 23 - Handle 0013h]
  Maximum Capacity              134217728KB
  Memory Error Inf Handle       0012h
  Number of Memory Devices      4
[Memory Array Mapped Address (Type 19) - Length 31 - Handle 0014h]
  Ending Address                03ffffffh
  Memory Array Handle           0013h
[32Bit Memory Error Information (Type 18) - Length 23 - Handle 0015h]
[Memory Device (Type 17) - Length 92 - Handle 0016h]
  Memory Error Info Handle      0015h
  Total Width                   [Unknown]
  Data Width                    [Unknown]
  Size                          [Not Populated]
  Form Factor                   02h - Unknown
  Device Locator                DIMM 0
  Bank Locator                  P0 CHANNEL A
  Memory Type                   02h - Unknown
  Type Detail                   0004h - Unknown
  Speed                         0MHz
  Manufacturer                  Unknown
  Serial Number
  Asset Tag Number              [String Not Specified]
  Part Number                   Unknown
  Attributes                    0
  Configured Memory Speed       0
  Minimum Voltage               0
  Maximum Voltage               0
  Configured Voltage            0
  Memory Technology             2
  Memory Operating Mode Capability     4
  Firmware Version              6
  Module Manufacturer Id        0
  Module Product Id             0
  Memory Subsystem Controller Manufacturer Id  0
  Memory Subsystem Controller Product Id       0
  Non-Volatile Size             0
  Volatile Size                 0
  Cache Size                    0
  Logical Size                  0
  Extended Speed                0
  Extended Configured Memory Speed     0
[32Bit Memory Error Information (Type 18) - Length 23 - Handle 0017h]
[Memory Device (Type 17) - Length 92 - Handle 0018h]
  Memory Error Info Handle      0017h
  Size                          32767MB
  Form Factor                   09h - DIMM
  Device Locator                DIMM 1
  Memory Type                   22h - DDR5
  Type Detail                   4080h - Synchronous Unbuffered (Unregistered)
  Speed                         4800MHz
  Manufacturer                  G Skill Intl
  Serial Number
  Part Number                   F5-6000J3238G32G
  Attributes                    2
  Extended Size                 32768
  Configured Memory Speed       6000
  Minimum Voltage               1100
  Maximum Voltage               1100
  Configured Voltage            1100
  Memory Technology             3
  Memory Operating Mode Capability     8
  Firmware Version              6
  Module Manufacturer Id        52612
  Module Product Id             0
  Non-Volatile Size             0
  Volatile Size                 0
  Cache Size                    0
  Logical Size                  0
  Extended Speed                0
[Memory Device Mapped Address (Type 20) - Length 35 - Handle 0019h]
  Ending Address                01ffffffh
  Memory Device Handle          0018h
  Mem Array Mapped Adr Handle   0014h
  Interleave Position           [None]
  Interleave Data Depth         [None]
[32Bit Memory Error Information (Type 18) - Length 23 - Handle 001ah]
[Memory Device (Type 17) - Length 92 - Handle 001bh]
  Memory Error Info Handle      001ah
  Bank Locator                  P0 CHANNEL B
  Speed                         0MHz
  Serial Number
  Part Number                   Unknown
  Attributes                    0
  Minimum Voltage               0
  Maximum Voltage               0
  Memory Technology             2
  Firmware Version              6
  Module Product Id             0
  Non-Volatile Size             0
  Volatile Size                 0
  Cache Size                    0
  Logical Size                  0
  Extended Speed                0
[32Bit Memory Error Information (Type 18) - Length 23 - Handle 001ch]
[Memory Device (Type 17) - Length 92 - Handle 001dh]
  Memory Error Info Handle      001ch
  Size                          32767MB
  Speed                         4800MHz
  Serial Number
  Attributes                    2
  Extended Size                 32768
  Memory Technology             3
  Firmware Version              6
  Module Product Id             0
  Non-Volatile Size             0
  Volatile Size                 0
  Cache Size                    0
  Logical Size                  0
  Extended Speed                0
[Memory Device Mapped Address (Type 20) - Length 35 - Handle 001eh]
  Starting Address              02000000h
  Memory Device Handle          001dh
[ (Type 256) - Length 14 - Handle 001fh]
[ (Type 256) - Length 165 - Handle 0020h]
[ (Type 256) - Length 11 - Handle 0053h]
[ (Type 256) - Length 11 - Handle 0054h]
[ (Type 256) - Length 4 - Handle 0056h]
Kod:
DPC_WATCHDOG_VIOLATION (133)
The DPC watchdog detected a prolonged run time at an IRQL of DISPATCH_LEVEL
or above.
Arguments:
Arg1: 0000000000000001, The system cumulatively spent an extended period of time at
    DISPATCH_LEVEL or above.
Arg2: 0000000000001e00, The watchdog period (in ticks).
Arg3: fffff800d5fc33a0, cast to nt!DPC_WATCHDOG_GLOBAL_TRIAGE_BLOCK, which contains
    additional information regarding the cumulative timeout
Arg4: 0000000000000000
Debugging Details:
***    Either you specified an unqualified symbol, or your debugger   ***
***    doesn't have full symbol information.  Unqualified symbol      ***
***    resolution is turned off by default. Please either specify a   ***
***    fully qualified symbol module!symbolname, or enable resolution ***
***    of unqualified symbols by typing ".symopt- 100". Note that     ***
***    enabling unqualified symbol resolution with network symbol     ***
***    server shares in the symbol path may cause the debugger to     ***
***    appear to hang for long periods of time when an incorrect      ***
***    symbol name is typed or the network symbol server is down.     ***
***    For some commands to work properly, your symbol path           ***
***    must point to .pdb files that have full type information.      ***
***    Certain .pdb files (such as the public OS symbols) do not      ***
***    contain the required information.  Contact the group that      ***
***    provided you with these symbols if you need this command to    ***
***    work.                                                          ***
***    Type referenced: TickPeriods                                   ***
    Value: 1203
    Value: 1228
    Value: 0
    Value: 1
    Value: 0
    Value: 281
    Value: 1220
    Value: 88
    Value: 1.2408.27.1
    Value: 0x133
    Value: 0x133
    Value: 21808
    Value: 1
    Value: 0
    Value: 1
    Value: 0
    Value: 0x133_ISR_nvlddmkm!unknown_function
    Key  : Failure.Hash
    Value: {f97493a5-ea2b-23ca-a808-8602773c2a86}
    Value: 7497cf94
    Value: 1
    Value: 1
    Value: 0
    Value: 0
    Value: 0
    Value: 1
    Value: 0
    Value: 1
    Value: 0
    Value: 1
    Value: 1
    Value: 0
    Value: 0
    Value: 0
    Value: 1
    Value: 1
    Value: 0
    Value: 0
    Value: 1
    Value: 0
    Value: 38408431
    Value: 24a10ef
    Value: 1
    Value: 1
    Value: 1
    Value: 1
    Value: 1
    Value: 0
    Value: 1
    Value: 0
    Value: 1
    Value: 1
    Value: 1
    Value: 1
    Value: 0
    Value: 1
    Value: 1015
    Value: 3f7
    Key  : Stack.Pointer
    Value: ISR
BUGCHECK_CODE:  133
BUGCHECK_P1: 1
BUGCHECK_P2: 1e00
BUGCHECK_P3: fffff800d5fc33a0
BUGCHECK_P4: 0
FILE_IN_CAB:  121324-16546-01.dmp
FAULTING_THREAD:  fffff800d5fd0640
DPC_TIMEOUT_TYPE:  DPC_QUEUE_EXECUTION_TIMEOUT_EXCEEDED
BLACKBOXWINLOGON: 1
PROCESS_NAME:  System
STACK_TEXT:
fffff800`675cdb48 fffff800`d5375129     : 00000000`00000133 00000000`00000001 00000000`00001e00 fffff800`d5fc33a0 : nt!KeBugCheckEx
fffff800`675cdb50 fffff800`d5367b61     : 00000000`00000000 00000000`00000002 00000000`00000000 00000000`000a18e9 : nt!KeAccumulateTicks+0x589
fffff800`675cdbc0 fffff800`d5367725     : 00000000`000604ba 00000000`00000000 00000018`12ea5787 00000000`0000000d : nt!KiUpdateRunTime+0xc9
fffff800`675cdc40 fffff800`d526e8fe     : fffff800`d5e10980 00000000`00000000 fffff800`62495950 fffff800`d5f20498 : nt!KiUpdateTime+0x2b5
fffff800`675cddd0 fffff800`d52702ad     : fffff800`d5e10980 00000000`00000000 fffff800`d5e10a30 fffff800`d5f8dd98 : nt!KeClockInterruptNotify+0x66e
fffff800`675cdf50 fffff800`d567be9e     : fffff800`675bb902 fffff800`d5e10980 fffff800`675bb760 00000018`12ed6559 : nt!KiCallInterruptServiceRoutine+0x2ed
fffff800`675cdfb0 fffff800`d567c6ac     : ffff808f`32a8a000 fffff800`675bb7e0 fffff800`675bb9a0 fffff800`d567c6cb : nt!KiInterruptSubDispatchNoLockNoEtw+0x4e
fffff800`675bb760 fffff800`ac0b3c2f     : 00000000`00000010 fffff800`675bba50 ffff808f`3b8e2000 00000000`00000048 : nt!KiInterruptDispatchNoLockNoEtw+0x3c
fffff800`675bb8f0 00000000`00000010     : fffff800`675bba50 ffff808f`3b8e2000 00000000`00000048 fffff800`675bb9a0 : nvlddmkm+0xc3c2f
fffff800`675bb8f8 fffff800`675bba50     : ffff808f`3b8e2000 00000000`00000048 fffff800`675bb9a0 fffff800`ac0f2f45 : 0x10
fffff800`675bb900 ffff808f`3b8e2000     : 00000000`00000048 fffff800`675bb9a0 fffff800`ac0f2f45 ffff808f`32a8a000 : 0xfffff800`675bba50
fffff800`675bb908 00000000`00000048     : fffff800`675bb9a0 fffff800`ac0f2f45 ffff808f`32a8a000 ffff808f`3b8e2000 : 0xffff808f`3b8e2000
fffff800`675bb910 fffff800`675bb9a0     : fffff800`ac0f2f45 ffff808f`32a8a000 ffff808f`3b8e2000 00000000`00000000 : 0x48
fffff800`675bb918 fffff800`ac0f2f45     : ffff808f`32a8a000 ffff808f`3b8e2000 00000000`00000000 ffff30e0`3a975066 : 0xfffff800`675bb9a0
fffff800`675bb920 ffff808f`32a8a000     : ffff808f`3b8e2000 00000000`00000000 ffff30e0`3a975066 00000000`00000000 : nvlddmkm+0x102f45
fffff800`675bb928 ffff808f`3b8e2000     : 00000000`00000000 ffff30e0`3a975066 00000000`00000000 fffff800`ac0bdc43 : 0xffff808f`32a8a000
fffff800`675bb930 00000000`00000000     : ffff30e0`3a975066 00000000`00000000 fffff800`ac0bdc43 ffff808f`32a8a000 : 0xffff808f`3b8e2000
SYMBOL_NAME:  nvlddmkm+c3c2f
MODULE_NAME: nvlddmkm
IMAGE_NAME:  nvlddmkm.sys
STACK_COMMAND:  .process /r /p 0xfffff800d5fcdf80; .thread 0xfffff800d5fd0640 ; kb
BUCKET_ID_FUNC_OFFSET:  c3c2f
FAILURE_BUCKET_ID:  0x133_ISR_nvlddmkm!unknown_function
OSNAME:  Windows 10
FAILURE_ID_HASH:  {f97493a5-ea2b-23ca-a808-8602773c2a86}
    PnpActivityTime    : 133785848987031602
    PnpProblemCode     : 24
    PnpVetoType        : 0
    DeviceId           : HID\{00001812-0000-1000-8000-00805f9b34fb}_Dev_VID&02046d_PID&b036_REV&0006_df68a0436b33&Col02\f&35258c00&0&0001
    VetoString         :
Kod:
Arguments:
Arg2: ffff8207f423f060, Physical Device Object of the stack
Arg3: fffff80707441010, nt!TRIAGE_9F_POWER on Win7 and higher, otherwise the Functional Device Object of the stack
Arg4: ffff8207f43749a0, The blocked IRP
Debugging Details:
    Value: 1093
    Value: 11781
    Value: 1
    Value: 1
    Value: 4
    Value: 328
    Value: 1246
    Value: 99
    Value: 1.2408.27.1
    Value: 0x9f
    Value: 0x9f
    Value: 21808
    Value: 1
    Value: 0
    Value: 1
    Value: 0
    Value: 0x9F_3_ACPI_IMAGE_pci.sys
    Key  : Failure.Hash
    Value: {20ddeb92-07eb-ebdc-bd08-44da71ffbd68}
    Value: 7497cf94
    Value: 1
    Value: 1
    Value: 0
    Value: 0
    Value: 0
    Value: 1
    Value: 0
    Value: 1
    Value: 0
    Value: 1
    Value: 1
    Value: 0
    Value: 0
    Value: 0
    Value: 1
    Value: 1
    Value: 0
    Value: 0
    Value: 1
    Value: 0
    Value: 38408431
    Value: 24a10ef
    Value: 1
    Value: 1
    Value: 1
    Value: 1
    Value: 1
    Value: 0
    Value: 1
    Value: 0
    Value: 1
    Value: 1
    Value: 1
    Value: 1
    Value: 0
    Value: 1
    Value: 1015
    Value: 3f7
    Key  : Stack.Pointer
    Value: NMI
BUGCHECK_CODE:  9f
BUGCHECK_P1: 3
BUGCHECK_P2: ffff8207f423f060
BUGCHECK_P3: fffff80707441010
BUGCHECK_P4: ffff8207f43749a0
FILE_IN_CAB:  120124-16875-01.dmp
FAULTING_THREAD:  fffff80775dd0640
IMAGE_NAME:  pci.sys
MODULE_NAME: pci
FAULTING_MODULE: fffff80707000000 pci
BLACKBOXWINLOGON: 1
DPC_STACK_BASE:  FFFFF80707449FB0
STACK_TEXT:
fffff807`07440fb8 fffff807`7538c7ed     : 00000000`0000009f 00000000`00000003 ffff8207`f423f060 fffff807`07441010 : nt!KeBugCheckEx
fffff807`07440fc0 fffff807`7538c5ec     : fffff807`75dd0640 fffff807`074413f8 ffff8207`f4377298 fffff807`07441199 : nt!PopIrpWatchdogBugcheck+0x1f5
fffff807`074410a0 fffff807`75159c0a     : fffff807`00000008 00000000`00000001 fffff807`00000000 ffff8208`00000002 : nt!PopIrpWatchdog+0xc
fffff807`074410d0 fffff807`751591e3     : fffff807`06114280 fffff807`7529a4f7 0000003e`0499f805 fffff807`06118300 : nt!KiProcessExpiredTimerList+0x26a
fffff807`07441200 fffff807`750f96e1     : fffff807`06110180 00000000`00000020 fffff807`06110180 00000000`00000001 : nt!KiTimerExpiration+0x2e3
fffff807`07441330 fffff807`75477bfe     : fffff807`06110180 fffff807`06110180 00000000`001a7550 00000000`00000000 : nt!KiRetireDpcList+0xaf1
fffff807`074415c0 00000000`00000000     : fffff807`07442000 fffff807`0743b000 00000000`00000000 00000000`00000000 : nt!KiIdleLoop+0x9e
IMAGE_VERSION:  10.0.26100.2161
STACK_COMMAND:  .process /r /p 0xfffff80775dcdf80; .thread 0xfffff80775dd0640 ; kb
FAILURE_BUCKET_ID:  0x9F_3_ACPI_IMAGE_pci.sys
OSNAME:  Windows 10
FAILURE_ID_HASH:  {20ddeb92-07eb-ebdc-bd08-44da71ffbd68}
    PnpActivityTime    : 133774752030660582
    PnpProblemCode     : 24
    PnpVetoType        : 0
    DeviceId           : SWD\MMDEVAPI\{0.0.0.00000000}.{f256a327-c5dd-445c-ab08-c8bbca761f78}
    VetoString         :
Kod:
Arguments:
Debugging Details:
    Value: 1203
    Value: 3457
    Value: 0
    Value: 1
    Value: 0
    Value: 265
    Value: 4401
    Value: 93
    Value: 1.2408.27.1
    Value: 0x9f
    Value: 0x9f
    Value: 21808
    Value: 1
    Value: 0
    Value: 1
    Value: 0
    Key  : Failure.Hash
    Value: 7497cf94
    Value: 1
    Value: 1
    Value: 0
    Value: 0
    Value: 0
    Value: 1
    Value: 0
    Value: 1
    Value: 0
    Value: 1
    Value: 1
    Value: 0
    Value: 0
    Value: 0
    Value: 1
    Value: 1
    Value: 0
    Value: 0
    Value: 1
    Value: 0
    Value: 38408431
    Value: 24a10ef
    Value: 1
    Value: 1
    Value: 1
    Value: 1
    Value: 1
    Value: 0
    Value: 1
    Value: 0
    Value: 1
    Value: 1
    Value: 1
    Value: 1
    Value: 0
    Value: 1
    Value: 1015
    Value: 3f7
    Key  : Stack.Pointer
    Value: NMI
BUGCHECK_CODE:  9f
BUGCHECK_P1: 3
MODULE_NAME: ACPI
BLACKBOXWINLOGON: 1
STACK_TEXT:
OSNAME:  Windows 10
    PnpProblemCode     : 24
    PnpVetoType        : 0
    VetoString         :
[DMI Version - 0]
  BIOS Version                  0304
       07: - PCI Supported
       19: - EDD Supported
  Manufacturer                  ASUS
  SKUNumber                     SKU
  Version                       Rev 1.xx
  Asset Tag
       00: - Motherboard
       03: - Replaceable
  Serial Number
  Asset Tag Number
  Number of Strings             6
   1                            Default string
   2                            Default string
   3                            Default string
   4                            Default string
   5                            Default string
   6                            Default string
  Cache Speed                   1ns
  Cache Speed                   1ns
  Cache Speed                   1ns
  Max Speed                     5350MHz
  Serial Number
  Asset Tag Number
  Part Number                   Unknown
  Core Count                    8
  Core Enabled                  8
  Thread Count                  16
       0x 3: Multi-Core
  Core Count 2                  8
  Core Enabled 2                8
  Thread Count 2                16
  Speed                         0MHz
  Serial Number
  Part Number                   Unknown
  Attributes                    0
  Minimum Voltage               0
  Maximum Voltage               0
  Memory Technology             2
  Firmware Version              6
  Module Product Id             0
  Non-Volatile Size             0
  Volatile Size                 0
  Cache Size                    0
  Logical Size                  0
  Extended Speed                0
  Size                          32767MB
  Speed                         4800MHz
  Serial Number
  Attributes                    2
  Extended Size                 32768
  Memory Technology             3
  Firmware Version              6
  Module Product Id             0
  Non-Volatile Size             0
  Volatile Size                 0
  Cache Size                    0
  Logical Size                  0
  Extended Speed                0
  Speed                         0MHz
  Serial Number
  Part Number                   Unknown
  Attributes                    0
  Minimum Voltage               0
  Maximum Voltage               0
  Memory Technology             2
  Firmware Version              6
  Module Product Id             0
  Non-Volatile Size             0
  Volatile Size                 0
  Cache Size                    0
  Logical Size                  0
  Extended Speed                0
  Size                          32767MB
  Speed                         4800MHz
  Serial Number
  Attributes                    2
  Extended Size                 32768
  Memory Technology             3
  Firmware Version              6
  Module Product Id             0
  Non-Volatile Size             0
  Volatile Size                 0
  Cache Size                    0
  Logical Size                  0
  Extended Speed                0
Kod:
or above.
Arguments:
Debugging Details:
***    work.                                                          ***
    Value: 1203
    Value: 1228
    Value: 0
    Value: 1
    Value: 0
    Value: 281
    Value: 1220
    Value: 88
    Value: 1.2408.27.1
    Value: 0x133
    Value: 0x133
    Value: 21808
    Value: 1
    Value: 0
    Value: 1
    Value: 0
    Key  : Failure.Hash
    Value: 7497cf94
    Value: 1
    Value: 1
    Value: 0
    Value: 0
    Value: 0
    Value: 1
    Value: 0
    Value: 1
    Value: 0
    Value: 1
    Value: 1
    Value: 0
    Value: 0
    Value: 0
    Value: 1
    Value: 1
    Value: 0
    Value: 0
    Value: 1
    Value: 0
    Value: 38408431
    Value: 24a10ef
    Value: 1
    Value: 1
    Value: 1
    Value: 1
    Value: 1
    Value: 0
    Value: 1
    Value: 0
    Value: 1
    Value: 1
    Value: 1
    Value: 1
    Value: 0
    Value: 1
    Value: 1015
    Value: 3f7
    Key  : Stack.Pointer
    Value: ISR
BUGCHECK_CODE:  133
BUGCHECK_P1: 1
BUGCHECK_P2: 1e00
BUGCHECK_P4: 0
BLACKBOXWINLOGON: 1
STACK_TEXT:
OSNAME:  Windows 10
    PnpProblemCode     : 24
    PnpVetoType        : 0
    VetoString         :
Kod:
Arguments:
Debugging Details:
    Value: 1093
    Value: 11781
    Value: 1
    Value: 1
    Value: 4
    Value: 328
    Value: 1246
    Value: 99
    Value: 1.2408.27.1
    Value: 0x9f
    Value: 0x9f
    Value: 21808
    Value: 1
    Value: 0
    Value: 1
    Value: 0
    Key  : Failure.Hash
    Value: 7497cf94
    Value: 1
    Value: 1
    Value: 0
    Value: 0
    Value: 0
    Value: 1
    Value: 0
    Value: 1
    Value: 0
    Value: 1
    Value: 1
    Value: 0
    Value: 0
    Value: 0
    Value: 1
    Value: 1
    Value: 0
    Value: 0
    Value: 1
    Value: 0
    Value: 38408431
    Value: 24a10ef
    Value: 1
    Value: 1
    Value: 1
    Value: 1
    Value: 1
    Value: 0
    Value: 1
    Value: 0
    Value: 1
    Value: 1
    Value: 1
    Value: 1
    Value: 0
    Value: 1
    Value: 1015
    Value: 3f7
    Key  : Stack.Pointer
    Value: NMI
BUGCHECK_CODE:  9f
BUGCHECK_P1: 3
IMAGE_NAME:  pci.sys
MODULE_NAME: pci
BLACKBOXWINLOGON: 1
STACK_TEXT:
OSNAME:  Windows 10
    PnpProblemCode     : 24
    PnpVetoType        : 0
    VetoString         :
Selam
BIOS güncelleyeceğim. Buradan tekrar bilgi vereceğim.
BIOS'tan AMD on board ekran kartını kapadım. Ek olarak EXPO - D.O.C.P Profili enabled ve EXPO tweaked ayarında çalışıyor.
Ben sistemi aldığımdan beri sorun yaşıyorum. Oyun oynarken ekran saving moda geçmiş gibi siyah ekran geliyor, fanlar son hız dönüyor veya siyah ekran geldiğinde Skype vb. çalışıyor ama sonra kendiliğinden reset atıyor makine. Bu hatalar 10 gündür olmuyor. Şimdi sadece bu mavi ekran hatasını alıyorum. Gerçekten uğraşmaktan yoruldum ve desteğe ihtiyacım var
DP kablo, kullandığım prize kadar değiştirdim ve bir yandan upgrade ihtiyacım var.
Sistem özellikler şu şekilde;
  1. ROG X870e Hero ASUS Crosshair (Eski anakartım arızalandığı için bunu aldım. Önceki anakartta mavi ekran almamıştım ama siyah ekran sorunları vardı.)
  2. Ryzen 7 7700 (Daha önce garantiden değişti reset ve boot sorunu vardı ama yeni işlemi OCCT test başarılı, şu an idareten kullanıyorum, ek olarak 360 mm sıvı soğutma takılı. Upgrade edeceğim X3D geçeceğim)
  3. F5-6000J3238G32GX2-TZ5NR / G.Skill 64 GB (2x32 GB) Trident Z5 Neo RGB DDR5 6000MHz CL32 1.40V PC RAM (Memtest86 ile 4 saat civarı test ettim sonuç başarılı. Ek olarak TestMem5 gibi vb. programlarda baktım. Sorun yok gözüküyor.)
  4. Ekran Kartı ROG STRIX GeForce RTX 4070 Ti 12 GB GDDR6X OC Edition ( daha önce FurMark testinde siyah ekran verip resetliyordu, servis macun ve bakım yapıp yolladı. Başka sorun görülmedi. Bazen yeniden başlat dediğimde Beyaz LED Q panel 97 hatası alıyorum, sanırım monitörüm çok çabuk saving moda geçiyor.)
  5. Sistemde Samsung SSD'ler kullanıyorum. 970 EVO Plus, 980 Pro ve 990 Pro. Samsung Magician ile sağlık durumları ile ve Firmware'ler güncel.
  6. PSU = Thermaltake Toughpower GF3 1000W Gold 80Plus kullanıyorum.
  7. Monitörde LG 850B nano var 2K monitör - 4 senedir kullanıyorum
  8. Windows 11 24H2 kullanıyorum güncel.
PSU veya ekran kartından şüpheliyim. Garantileri devam ediyor ama hangisi sorunlu donanımsal mı ya da başka bir şey mi var bilmiyorum. Artık işin içinden de çıkamıyorum. Sistem stabil çalışmıyor. O nedenle bu DMP dosyalarını analizini istedim cevabınız için teşekkür ederim başka ne önerirsiniz?
Bundan hoşlanmadım evlat. BIOS güncelle, EXPO kapat, sorun devam ederse başka PSU ile dene.
Garantiye göndersem acaba gerçekten iyi incelenir mi? Thermaltake'in servisi yurt dışında sanırım.
ATX 3.1 gen 5.1 bekliyorum sanırım 2025'te gelir yaygınlaşır bu konuda önerebileceğiniz bir marka var mı?
Bir de 1200W ve Platinium titanyum tarzında bir şey alacağım galiba ileriye dönük
Ek olarak artık PSU’larda Coilwhine çıkması benim canımı sıkıyor. Son zamanda kalitesiz ürünler üretiliyor.
EXPO kapatınca 4800 MHz'e iniyor RAM'ler, EXPO ayarı hiç açmadan 4800 MHz’de mi kullanayım? Ayar açınca 6000MHz'e çıkıyor, çok fazla FPS oynamaz sanırım ya da ben hissettmem
Servis yurt dışında mı bilmiyorum ama garantiye gönderdiğin zaman açıkçası yeterince ilgileneceğini düşünmüyorum.
Seasonic, ASUS, MSI, Corsair genelde kullandığım ve iyi markalar. Antec de olabilir.
Bir sürü EXPO kapalı kullan ama sorun devam ediyorsa muhtemelen güç kaynağında sorun.
BIOS güncelleme yapmadım ama default ayarlara getirdim. EXPO kapalı.
İlk açılışta 5 dk bir şey dokunmayınca aynı mavi ekranı veriyor.
EXPO ile alakalı değil o zaman dediğiniz gibi.
Bu da yeni DMP dosyası: 122924-17187-01.dmp 122924-17187-01.dmp
Diyelim ki PSU'dan emin olduk, Bu PSU ile kullanım diğer parçalara zarar verir mi sizce?
Bir de işin ilginç tarafı OCCT Power testinde başarılı
BIOS 0706’ya güncelledim, default ayarlarda şimdilik sorun yok.
