Bütçe nedir
Buradaki her şeyi denedim ama sonuç aynı, logları aşağıya bıraktım. Ne yapmam gerek?
Kod:
2024-08-02_19:46:26 Checking user locale: tr.
2024-08-02_19:46:26 Locale 'tr' wasn't found.
2024-08-02_19:46:33 Failed to read and parse installer embedded payload
2024-08-02_19:46:33 Failed to get mpid value
2024-08-02_19:46:34 Opening file: C:\ProgramData\Corsair\iCUE5 Initial Installer\manager\cuepkg.zip.sha2
2024-08-02_19:46:42 Opening file: C:\ProgramData\Corsair\iCUE5 Initial Installer\manager\cuepkg.zip
2024-08-02_19:46:42 Using bootstrap package from repo: https://www3.corsair.com/software/CUE_V5/public/modules/windows/installerpackage/cuepkg_bootstrap.zip
2024-08-02_19:46:42 Opening file: C:\ProgramData\Corsair\iCUE5 Initial Installer\manager\cuepkg.zip.sha2
2024-08-02_19:46:50 Opening file: C:\ProgramData\Corsair\iCUE5 Initial Installer\manager\cuepkg.zip
2024-08-02_19:46:50 Using bootstrap package from repo: https://www3.corsair.com/software/CUE_V5/public/modules/windows/installerpackage/cuepkg_bootstrap.zip
2024-08-02_19:46:51 Opening file: C:\ProgramData\Corsair\iCUE5 Initial Installer\manager\cuepkg.zip.sha2
2024-08-02_19:46:59 Opening file: C:\ProgramData\Corsair\iCUE5 Initial Installer\manager\cuepkg.zip
2024-08-02_19:46:59 Using bootstrap package from repo: https://www3.corsair.com/software/CUE_V5/public/modules/windows/installerpackage/cuepkg_bootstrap.zip
2024-08-02_19:46:59 Package manager version:
2024-08-02_19:47:02 Package manager failed:
"C:\ProgramData\Corsair\iCUE5 Initial Installer\manager\cuepkg.exe" --installdir="C:\ProgramData\Corsair\iCUE5 Initial Installer\packages" install icue-installer --format=json
code: 1
out:
{"data":{"id":0,"type":"abort-enable"},"method":"input"}
{"data":{"comment":"Failed to download 'cuepkg'.","type":"network"},"method":"error"}
{"data":{"comment":"Starting cleaning of temporary files.","severity":"comment"},"method":"comment"}
{"data":{"comment":"Removed temporary files.","severity":"comment"},"method":"comment"}
{"data":{"percents":1},"method":"progress"}
{"data":{"table":[],"title":"ExecutedActions"},"method":"table"}
2024-08-02_19:47:02 Initial installer version: 1.13.7
2024-08-02_19:47:02 Download failed, retrying in 10 seconds...
2024-08-02_19:47:13 Package manager version: iCUE5 Package Manager 1.17.1
2024-08-02_19:47:15 Package manager failed:
code: 1
out:
{"data":{"comment":"Failed to download 'icue-version'.","type":"network"},"method":"error"}
2024-08-02_19:47:15 Initial installer version: 1.13.7
2024-08-02_19:47:15 Download failed, retrying in 10 seconds...
2024-08-02_19:47:26 Package manager version:
2024-08-02_19:47:26 Package manager failed:
code: 1
out:
{"data":{"comment":"Failed to download 'data-mining-usb'.","type":"network"},"method":"error"}
2024-08-02_19:47:26 Initial installer version: 1.13.7
2024-08-02_19:47:26 Download failed 3 times. Stop
