Emir YOL
17 Nisan 2024
Selam dostlar. Sorunum konu başlığındaki gibi. BIOS ayarlarımı tekrar düzenledim fakat bir türlü Tahoe başlamıyor. config dosyamı ekte bulabilirsiniz.
@yusufklncc @tarko hocalarım sizde bakarsanız çok mutlu olurum :)
Kod:
<?xml version="1.0" encoding="UTF-8"?>
<!DOCTYPE plist PUBLIC "-//Apple//DTD PLIST 1.0//EN" "http://www.apple.com/DTDs/PropertyList-1.0.dtd">
<plist version="1.0">
    <dict>
        <key>ACPI</key>
        <dict>
            <key>Add</key>
            <array>
                <dict>
                    <key>Comment</key>
                    <string>SSDT-EC.aml</string>
                    <key>Enabled</key>
                    <true/>
                    <key>Path</key>
                </dict>
                <dict>
                    <key>Comment</key>
                    <string>SSDT-PLUG.aml</string>
                    <key>Enabled</key>
                    <true/>
                    <key>Path</key>
                </dict>
                <dict>
                    <key>Comment</key>
                    <string>SSDT-USB-Reset.aml</string>
                    <key>Enabled</key>
                    <true/>
                    <key>Path</key>
                </dict>
                <dict>
                    <key>Comment</key>
                    <string>SSDT-USBX.aml</string>
                    <key>Enabled</key>
                    <true/>
                    <key>Path</key>
                </dict>
            </array>
            <key>Delete</key>
            <array/>
            <key>Patch</key>
            <array/>
            <key>Quirks</key>
            <dict>
                <key>FadtEnableReset</key>
                <false/>
                <key>NormalizeHeaders</key>
                <false/>
                <key>RebaseRegions</key>
                <false/>
                <key>ResetHwSig</key>
                <false/>
                <key>ResetLogoStatus</key>
                <true/>
                <key>SyncTableIds</key>
                <false/>
            </dict>
        </dict>
        <key>Booter</key>
        <dict>
            <key>MmioWhitelist</key>
            <array/>
            <key>Patch</key>
            <array/>
            <key>Quirks</key>
            <dict>
                <key>AllowRelocationBlock</key>
                <false/>
                <key>AvoidRuntimeDefrag</key>
                <true/>
                <key>ClearTaskSwitchBit</key>
                <false/>
                <key>DevirtualiseMmio</key>
                <false/>
                <key>DisableSingleUser</key>
                <false/>
                <key>DisableVariableWrite</key>
                <false/>
                <key>DiscardHibernateMap</key>
                <false/>
                <key>EnableSafeModeSlide</key>
                <true/>
                <key>EnableWriteUnprotector</key>
                <false/>
                <key>FixupAppleEfiImages</key>
                <false/>
                <key>ForceBooterSignature</key>
                <false/>
                <key>ForceExitBootServices</key>
                <false/>
                <key>ProtectMemoryRegions</key>
                <false/>
                <key>ProtectSecureBoot</key>
                <false/>
                <key>ProtectUefiServices</key>
                <false/>
                <key>ProvideCustomSlide</key>
                <true/>
                <key>ProvideMaxSlide</key>
                <integer>0</integer>
                <key>RebuildAppleMemoryMap</key>
                <true/>
                <key>ResizeAppleGpuBars</key>
                <key>SetupVirtualMap</key>
                <false/>
                <key>SignalAppleOS</key>
                <false/>
                <key>SyncRuntimePermissions</key>
                <true/>
            </dict>
        </dict>
        <key>DeviceProperties</key>
        <dict>
            <key>Add</key>
            <dict>
                <key>PciRoot(0x0)/Pci(0x8,0x1)/Pci(0x0,0x4)</key>
                <dict>
                    <key>layout-id</key>
                    <integer>66</integer>
                </dict>
            </dict>
            <key>Delete</key>
            <dict/>
        </dict>
        <key>Kernel</key>
        <dict>
            <key>Add</key>
            <array>
                <dict>
                    <key>Arch</key>
                    <string>x86_64</string>
                    <key>BundlePath</key>
                    <string>Lilu.kext</string>
                    <key>Comment</key>
                    <string>V1.7.2</string>
                    <key>Enabled</key>
                    <true/>
                    <key>ExecutablePath</key>
                    <string>Contents/MacOS/Lilu</string>
                    <key>MaxKernel</key>
                    <string></string>
                    <key>MinKernel</key>
                    <string></string>
                    <key>PlistPath</key>
                    <string>Contents/Info.plist</string>
                </dict>
                <dict>
                    <key>Arch</key>
                    <string>VirtualSMC.kext</string>
                    <key>Comment</key>
                    <string>V1.3.8</string>
                    <key>Enabled</key>
                    <true/>
                    <string>Contents/MacOS/VirtualSMC</string>
                    <string></string>
                    <string></string>
                </dict>
                <dict>
                    <key>Arch</key>
                    <string>AppleALC.kext</string>
                    <key>Comment</key>
                    <string>V1.9.6</string>
                    <key>Enabled</key>
                    <true/>
                    <string>Contents/MacOS/AppleALC</string>
                    <string></string>
                    <string></string>
                </dict>
                <dict>
                    <key>Arch</key>
                    <string>AppleMCEReporterDisabler.kext</string>
                    <key>Comment</key>
                    <string>V1.2</string>
                    <key>Enabled</key>
                    <true/>
                    <string></string>
                    <string></string>
                    <string></string>
                </dict>
                <dict>
                    <key>Arch</key>
                    <string>NVMeFix.kext</string>
                    <key>Comment</key>
                    <string>V1.1.4</string>
                    <key>Enabled</key>
                    <true/>
                    <string>Contents/MacOS/NVMeFix</string>
                    <string></string>
                    <string>18.0.0</string>
                </dict>
                <dict>
                    <key>Arch</key>
                    <string>RealtekRTL8111.kext</string>
                    <key>Comment</key>
                    <string>V2.4.2</string>
                    <key>Enabled</key>
                    <true/>
                    <string>Contents/MacOS/RealtekRTL8111</string>
                    <string></string>
                    <string></string>
                </dict>
                <dict>
                    <key>Arch</key>
                    <string>Any</string>
                    <string>USBToolBox.kext</string>
                    <key>Comment</key>
                    <string>V1.1.1</string>
                    <key>Enabled</key>
                    <true/>
                    <string>Contents/MacOS/USBToolBox</string>
                    <string></string>
                    <string></string>
                </dict>
                <dict>
                    <key>Arch</key>
                    <string>UTBMap.kext</string>
                    <key>Comment</key>
                    <string>V1.1</string>
                    <key>Enabled</key>
                    <true/>
                    <string></string>
                    <string></string>
                    <string></string>
                </dict>
                <dict>
                    <key>Arch</key>
                    <string>RestrictEvents.kext</string>
                    <key>Comment</key>
                    <string>V1.1.7</string>
                    <key>Enabled</key>
                    <true/>
                    <string>Contents/MacOS/RestrictEvents</string>
                    <string></string>
                    <string></string>
                </dict>
                <dict>
                    <key>Arch</key>
                    <string>WhateverGreen.kext</string>
                    <key>Comment</key>
                    <string>V1.7.1</string>
                    <key>Enabled</key>
                    <true/>
                    <string>Contents/MacOS/WhateverGreen</string>
                    <string></string>
                    <string></string>
                </dict>
            </array>
            <key>Block</key>
            <array/>
            <key>Emulate</key>
            <dict>
                <key>Cpuid1Data</key>
                <data></data>
                <key>Cpuid1Mask</key>
                <data></data>
                <key>DummyPowerManagement</key>
                <true/>
                <string></string>
                <string></string>
            </dict>
            <key>Force</key>
            <array/>
            <key>Patch</key>
            <array>
                <dict>
                    <key>Arch</key>
                    <key>Base</key>
                    <string>_cpuid_set_info</string>
                    <key>Comment</key>
                    <string>algrey | Force cpuid_cores_per_package to constant (user-specified) | 10.13-10.14</string>
                    <key>Count</key>
                    <integer>1</integer>
                    <key>Enabled</key>
                    <true/>
                    <key>Find</key>
                    <data>wegaAAAA</data>
                    <key>Identifier</key>
                    <string>kernel</string>
                    <key>Limit</key>
                    <key>Mask</key>
                    <data>//3/AAAA</data>
                    <string>18.99.99</string>
                    <string>17.0.0</string>
                    <key>Replace</key>
                    <data>uAYAAAAA</data>
                    <key>ReplaceMask</key>
                    <data>//////8A</data>
                    <key>Skip</key>
                </dict>
                <dict>
                    <key>Arch</key>
                    <key>Base</key>
                    <key>Comment</key>
                    <string>algrey | Force cpuid_cores_per_package to constant (user-specified) | 10.15-11.0</string>
                    <key>Count</key>
                    <key>Enabled</key>
                    <true/>
                    <key>Find</key>
                    <key>Limit</key>
                    <key>Mask</key>
                    <string>20.99.99</string>
                    <string>19.0.0</string>
                    <key>Replace</key>
                    <data>ugYAAAAA</data>
                    <key>Skip</key>
                </dict>
                <dict>
                    <key>Arch</key>
                    <key>Base</key>
                    <key>Comment</key>
                    <string>algrey | Force cpuid_cores_per_package to constant (user-specified) | 12.0-13.2</string>
                    <key>Count</key>
                    <key>Enabled</key>
                    <true/>
                    <key>Find</key>
                    <key>Limit</key>
                    <key>Mask</key>
                    <string>22.3.99</string>
                    <string>21.0.0</string>
                    <key>Replace</key>
                    <data>ugYAAACQ</data>
                    <data></data>
                    <key>Skip</key>
                </dict>
                <dict>
                    <key>Arch</key>
                    <key>Base</key>
                    <key>Comment</key>
                    <string>algrey | Force cpuid_cores_per_package to constant (user-specified) | 13.3+</string>
                    <key>Count</key>
                    <key>Enabled</key>
                    <true/>
                    <key>Find</key>
                    <data>wegaAAA=</data>
                    <key>Limit</key>
                    <key>Mask</key>
                    <data>//3/AAA=</data>
                    <string>25.99.99</string>
                    <string>22.4.0</string>
                    <key>Replace</key>
                    <data>ugYAAAA=</data>
                    <data>//////8=</data>
                    <key>Skip</key>
                </dict>
                <dict>
                    <key>Arch</key>
                    <key>Base</key>
                    <string></string>
                    <key>Comment</key>
                    <string>algrey | _commpage_populate | Remove rdmsr | 10.13+</string>
                    <key>Count</key>
                    <key>Enabled</key>
                    <true/>
                    <key>Find</key>
                    <data>uaABAAAPMg==</data>
                    <key>Limit</key>
                    <key>Mask</key>
                    <data></data>
                    <key>Replace</key>
                    <data>ZpBmkGaQkA==</data>
                    <data></data>
                    <key>Skip</key>
                </dict>
                <dict>
                    <key>Arch</key>
                    <key>Base</key>
                    <string></string>
                    <key>Comment</key>
                    <string>algrey | _cpuid_set_cache_info | Set CPUID proper instead of 4 | 10.13+</string>
                    <key>Count</key>
                    <key>Enabled</key>
                    <true/>
                    <key>Find</key>
                    <data>uAQAAABEifFEiQ==</data>
                    <key>Limit</key>
                    <key>Mask</key>
                    <data></data>
                    <key>Replace</key>
                    <data>uB0AAIBEifFEiQ==</data>
                    <data></data>
                    <key>Skip</key>
                </dict>
                <dict>
                    <key>Arch</key>
                    <key>Base</key>
                    <string></string>
                    <key>Comment</key>
                    <string>algrey | _cpuid_set_generic_info | Remove wrmsr(0x8B) | 10.13+</string>
                    <key>Count</key>
                    <key>Enabled</key>
                    <true/>
                    <key>Find</key>
                    <data>uYsAAAAxwDHSDzA=</data>
                    <key>Limit</key>
                    <key>Mask</key>
                    <data></data>
                    <key>Replace</key>
                    <data>ZpBmkGaQZpBmkJA=</data>
                    <data></data>
                    <key>Skip</key>
                </dict>
                <dict>
                    <key>Arch</key>
                    <key>Base</key>
                    <string></string>
                    <key>Comment</key>
                    <string>algrey | _cpuid_set_generic_info | Replace rdmsr(0x8B) with constant 186 | 10.13+</string>
                    <key>Count</key>
                    <key>Enabled</key>
                    <true/>
                    <key>Find</key>
                    <data>uYsAAAAPMg==</data>
                    <key>Limit</key>
                    <key>Mask</key>
                    <data></data>
                    <key>Replace</key>
                    <data>uroAAABmkA==</data>
                    <data></data>
                    <key>Skip</key>
                </dict>
                <dict>
                    <key>Arch</key>
                    <key>Base</key>
                    <string></string>
                    <key>Comment</key>
                    <string>algrey | _cpuid_set_generic_info | Set flag=1 | 10.13+</string>
                    <key>Count</key>
                    <key>Enabled</key>
                    <true/>
                    <key>Find</key>
                    <data>uRcAAAAPMsHqEoDiBw==</data>
                    <key>Limit</key>
                    <key>Mask</key>
                    <data></data>
                    <key>Replace</key>
                    <data>sgFmDx+EAAAAAABmkA==</data>
                    <data></data>
                    <key>Skip</key>
                </dict>
                <dict>
                    <key>Arch</key>
                    <key>Base</key>
                    <string></string>
                    <key>Comment</key>
                    <string>algrey | _cpuid_set_generic_info | Disable check to allow leaf7 | 10.13+</string>
                    <key>Count</key>
                    <key>Enabled</key>
                    <true/>
                    <key>Find</key>
                    <data>ADoPgg==</data>
                    <key>Limit</key>
                    <key>Mask</key>
                    <data></data>
                    <string>23.99.99</string>
                    <key>Replace</key>
                    <data>AAAPgg==</data>
                    <data></data>
                    <key>Skip</key>
                </dict>
                <dict>
                    <key>Arch</key>
                    <key>Base</key>
                    <string></string>
                    <key>Comment</key>
                    <string>algrey | _cpuid_set_generic_info | Disable check to allow leaf7 | 15.0+</string>
                    <key>Count</key>
                    <key>Enabled</key>
                    <true/>
                    <key>Find</key>
                    <data>AAUPgg==</data>
                    <key>Limit</key>
                    <key>Mask</key>
                    <data></data>
                    <string>24.0.0</string>
                    <key>Replace</key>
                    <data></data>
                    <key>Skip</key>
                </dict>
                <dict>
                    <key>Arch</key>
                    <key>Base</key>
                    <string></string>
                    <key>Comment</key>
                    <string>algrey | _cpuid_set_info | GenuineIntel to AuthenticAMD | 10.13-11.0</string>
                    <key>Count</key>
                    <key>Enabled</key>
                    <true/>
                    <key>Find</key>
                    <data>R2VudWluZUludGVsAA==</data>
                    <key>Limit</key>
                    <key>Mask</key>
                    <data></data>
                    <key>Replace</key>
                    <data>QXV0aGVudGljQU1EAA==</data>
                    <data></data>
                    <key>Skip</key>
                </dict>
                <dict>
                    <key>Arch</key>
                    <key>Base</key>
                    <key>Comment</key>
                    <string>Goldfish64, algrey | Bypass GenuineIntel check panic | 12.0+</string>
                    <key>Count</key>
                    <key>Enabled</key>
                    <true/>
                    <key>Find</key>
                    <data>AAAAAAAAMdKzAQ==</data>
                    <key>Limit</key>
                    <key>Mask</key>
                    <data>AAAAAAAA/////w==</data>
                    <key>Replace</key>
                    <data>kJCQkJCQMdKzAQ==</data>
                    <data></data>
                    <key>Skip</key>
                </dict>
                <dict>
                    <key>Arch</key>
                    <key>Base</key>
                    <string></string>
                    <key>Comment</key>
                    <string>algrey | _cpuid_set_cpufamily | Force CPUFAMILY_INTEL_PENRYN | 10.13-11.2</string>
                    <key>Count</key>
                    <key>Enabled</key>
                    <true/>
                    <key>Find</key>
                    <data>MduAPQAAAAAGdQA=</data>
                    <key>Limit</key>
                    <key>Mask</key>
                    <data>/////wAAAP///wA=</data>
                    <string>20.3.0</string>
                    <key>Replace</key>
                    <data>u7xP6njpXQAAAJA=</data>
                    <data></data>
                    <key>Skip</key>
                </dict>
                <dict>
                    <key>Arch</key>
                    <key>Base</key>
                    <string>_cpuid_set_info </string>
                    <key>Comment</key>
                    <string>algrey | _cpuid_set_cpufamily | Force CPUFAMILY_INTEL_PENRYN | 11.3+</string>
                    <key>Count</key>
                    <key>Enabled</key>
                    <true/>
                    <key>Find</key>
                    <data>gD0AAAAABnU=</data>
                    <key>Limit</key>
                    <key>Mask</key>
                    <data>//8AAAAA//8=</data>
                    <string>20.4.0</string>
                    <key>Replace</key>
                    <data>urxP6ngx2+s=</data>
                    <data></data>
                    <key>Skip</key>
                </dict>
                <dict>
                    <key>Arch</key>
                    <key>Base</key>
                    <string></string>
                    <key>Comment</key>
                    <string>algrey | _i386_init | Remove 3 rdmsr calls | 10.13+</string>
                    <key>Count</key>
                    <key>Enabled</key>
                    <true/>
                    <key>Find</key>
                    <data>uZkBAAAPMkjB4iCJxkgJ1rmYAQAADzJIweIgicBICcK/WAIxBTHJRTHA</data>
                    <key>Limit</key>
                    <key>Mask</key>
                    <data></data>
                    <key>Replace</key>
                    <data>Zg8fhAAAAAAAZg8fhAAAAAAAZg8fhAAAAAAAZg8fhAAAAAAAZg8fRAAA</data>
                    <data></data>
                    <key>Skip</key>
                </dict>
                <dict>
                    <key>Arch</key>
                    <key>Base</key>
                    <string></string>
                    <key>Comment</key>
                    <string>algrey, XLNC | Remove version check and panic | 10.13+</string>
                    <key>Count</key>
                    <key>Enabled</key>
                    <true/>
                    <key>Find</key>
                    <data>JfwAAACD+BM=</data>
                    <key>Limit</key>
                    <key>Mask</key>
                    <data></data>
                    <key>Replace</key>
                    <data>JfwAAAAPHwA=</data>
                    <data></data>
                    <key>Skip</key>
                </dict>
                <dict>
                    <key>Arch</key>
                    <key>Base</key>
                    <string>__ZN11IOPCIBridge13probeBusGatedEP14probeBusParams</string>
                    <key>Comment</key>
                    <string>CaseySJ | probeBusGated | Disable 10 bit tags | 12.0-15.x</string>
                    <key>Count</key>
                    <key>Enabled</key>
                    <true/>
                    <key>Find</key>
                    <data>4BFyAA==</data>
                    <string>com.apple.iokit.IOPCIFamily</string>
                    <key>Limit</key>
                    <key>Mask</key>
                    <data>8P//8A==</data>
                    <string>24.99.99</string>
                    <key>Replace</key>
                    <data>AAADAA==</data>
                    <data>AAAPAA==</data>
                    <key>Skip</key>
                </dict>
                <dict>
                    <key>Arch</key>
                    <key>Base</key>
                    <key>Comment</key>
                    <string>CaseySJ | probeBusGated | Disable 10 bit tags | 26.0+</string>
                    <key>Count</key>
                    <key>Enabled</key>
                    <true/>
                    <key>Find</key>
                    <data>4BFzQA==</data>
                    <key>Limit</key>
                    <key>Mask</key>
                    <string>25.0.0</string>
                    <key>Replace</key>
                    <data>AAACAA==</data>
                    <key>Skip</key>
                </dict>
                <dict>
                    <key>Arch</key>
                    <key>Base</key>
                    <string>__ZN17IOPCIConfigurator18IOPCIIsHotplugPortEP16IOPCIConfigEntry</string>
                    <key>Comment</key>
                    <string>CaseySJ | IOPCIIsHotplugPort | Fix PCI bus enumeration on AM5 | 13.0+</string>
                    <key>Count</key>
                    <key>Enabled</key>
                    <false/>
                    <key>Find</key>
                    <data>hAB1Sw==</data>
                    <key>Limit</key>
                    <key>Mask</key>
                    <data>/wD//w==</data>
                    <string>22.0.0</string>
                    <key>Replace</key>
                    <data>AADrAA==</data>
                    <data>AAD/AA==</data>
                    <key>Skip</key>
                </dict>
                <dict>
                    <key>Arch</key>
                    <key>Base</key>
                    <string></string>
                    <key>Comment</key>
                    <string>Visual | thread_quantum_expire, thread_unblock, thread_invoke | Remove non-monotonic time panic | 12.0+</string>
                    <key>Count</key>
                    <integer>3</integer>
                    <key>Enabled</key>
                    <true/>
                    <key>Find</key>
                    <data>SAAAAAIAAEgAAFgAAAAPAAAAAAA=</data>
                    <key>Limit</key>
                    <key>Mask</key>
                    <data>/wAAD/////8AAP8AAAD/AAAAAAA=</data>
                    <key>Replace</key>
                    <data>AAAAAAAAAAAAAAAAAABmkGaQZpA=</data>
                    <data>AAAAAAAAAAAAAAAAAAD///////8=</data>
                    <key>Skip</key>
                </dict>
                <dict>
                    <key>Arch</key>
                    <key>Base</key>
                    <string></string>
                    <key>Comment</key>
                    <string>Visual | thread_invoke, thread_dispatch | Remove non-monotonic time panic | 12.0+</string>
                    <key>Count</key>
                    <integer>2</integer>
                    <key>Enabled</key>
                    <true/>
                    <key>Find</key>
                    <data>SAAAgAQAAA8AAAAAAA==</data>
                    <key>Limit</key>
                    <key>Mask</key>
                    <data>SAAA8P////8AAAAAAA==</data>
                    <key>Replace</key>
                    <data>AAAAAAAAAGaQZpBmkA==</data>
                    <data>AAAAAAAAAP///////w==</data>
                    <key>Skip</key>
                </dict>
                <dict>
                    <key>Arch</key>
                    <key>Base</key>
                    <string></string>
                    <key>Comment</key>
                    <string>algrey | _mtrr_update_action | fix PAT | 10.13+</string>
                    <key>Count</key>
                    <key>Enabled</key>
                    <false/>
                    <key>Find</key>
                    <data>icCB4v//AP+BygAAAQC5dwIAAA==</data>
                    <key>Limit</key>
                    <key>Mask</key>
                    <data>////////D////////////////w==</data>
                    <key>Replace</key>
                    <data>uXcCAAC4BgEHALoGAQcADx9AAA==</data>
                    <data></data>
                    <key>Skip</key>
                </dict>
                <dict>
                    <key>Arch</key>
                    <key>Base</key>
                    <string></string>
                    <key>Comment</key>
                    <string>Shaneee | _mtrr_update_action | Fix PAT | 10.13+</string>
                    <key>Count</key>
                    <key>Enabled</key>
                    <true/>
                    <key>Find</key>
                    <key>Limit</key>
                    <key>Mask</key>
                    <key>Replace</key>
                    <data>uXcCAAC4BgYGBroGBgYGDzAPCQ==</data>
                    <data></data>
                    <key>Skip</key>
                </dict>
                <dict>
                    <key>Arch</key>
                    <key>Base</key>
                    <string></string>
                    <key>Comment</key>
                    <string>Algrey / Zormeister | _mtrr_update_action | Fix PAT | 15.0+</string>
                    <key>Count</key>
                    <key>Enabled</key>
                    <false/>
                    <key>Find</key>
                    <data>icCB4v//AP+BygAAAAAPMA==</data>
                    <key>Limit</key>
                    <key>Mask</key>
                    <data>/////////////wAAAAD//w==</data>
                    <key>Replace</key>
                    <data>icC4BgEHALoGAQcADzCQkA==</data>
                    <data></data>
                    <key>Skip</key>
                </dict>
                <dict>
                    <key>Arch</key>
                    <key>Base</key>
                    <string></string>
                    <key>Comment</key>
                    <string>Shaneee / Zormeister | _mtrr_update_action | Fix PAT | 15.0+</string>
                    <key>Count</key>
                    <key>Enabled</key>
                    <true/>
                    <key>Find</key>
                    <key>Limit</key>
                    <key>Mask</key>
                    <key>Replace</key>
                    <data>icC4BgYGBroGBgYGDzCQkA==</data>
                    <data></data>
                    <key>Skip</key>
                </dict>
            </array>
            <key>Quirks</key>
            <dict>
                <key>AppleCpuPmCfgLock</key>
                <false/>
                <key>AppleXcpmCfgLock</key>
                <false/>
                <key>AppleXcpmExtraMsrs</key>
                <false/>
                <key>AppleXcpmForceBoost</key>
                <false/>
                <key>CustomPciSerialDevice</key>
                <false/>
                <key>CustomSMBIOSGuid</key>
                <true/>
                <key>DisableIoMapper</key>
                <false/>
                <key>DisableIoMapperMapping</key>
                <false/>
                <key>DisableLinkeditJettison</key>
                <true/>
                <key>DisableRtcChecksum</key>
                <true/>
                <key>ExtendBTFeatureFlags</key>
                <false/>
                <key>ExternalDiskIcons</key>
                <false/>
                <key>ForceAquantiaEthernet</key>
                <false/>
                <key>ForceSecureBootScheme</key>
                <false/>
                <key>IncreasePciBarSize</key>
                <false/>
                <key>LapicKernelPanic</key>
                <false/>
                <key>LegacyCommpage</key>
                <false/>
                <key>PanicNoKextDump</key>
                <true/>
                <key>PowerTimeoutKernelPanic</key>
                <true/>
                <key>ProvideCurrentCpuInfo</key>
                <true/>
                <key>SetApfsTrimTimeout</key>
                <integer>-1</integer>
                <key>ThirdPartyDrives</key>
                <false/>
                <key>XhciPortLimit</key>
                <false/>
            </dict>
            <key>Scheme</key>
            <dict>
                <key>CustomKernel</key>
                <false/>
                <key>FuzzyMatch</key>
                <true/>
                <key>KernelArch</key>
                <string>Auto</string>
                <key>KernelCache</key>
            </dict>
        </dict>
        <key>Misc</key>
        <dict>
            <key>BlessOverride</key>
            <array/>
            <key>Boot</key>
            <dict>
                <key>ConsoleAttributes</key>
                <key>HibernateMode</key>
                <string>None</string>
                <key>HibernateSkipsPicker</key>
                <false/>
                <key>HideAuxiliary</key>
                <false/>
                <key>InstanceIdentifier</key>
                <string></string>
                <key>LauncherOption</key>
                <string>Disabled</string>
                <key>LauncherPath</key>
                <string>Default</string>
                <key>PickerAttributes</key>
                <integer>17</integer>
                <key>PickerAudioAssist</key>
                <false/>
                <key>PickerMode</key>
                <string>External</string>
                <key>PickerVariant</key>
                <key>PollAppleHotKeys</key>
                <false/>
                <key>ShowPicker</key>
                <true/>
                <key>TakeoffDelay</key>
                <key>Timeout</key>
                <integer>5</integer>
            </dict>
            <key>Debug</key>
            <dict>
                <key>AppleDebug</key>
                <false/>
                <key>ApplePanic</key>
                <false/>
                <key>DisableWatchDog</key>
                <true/>
                <key>DisplayDelay</key>
                <key>DisplayLevel</key>
                <integer>2147483650</integer>
                <key>LogModules</key>
                <string>*</string>
                <key>SysReport</key>
                <false/>
                <key>Target</key>
            </dict>
            <key>Entries</key>
            <array/>
            <key>Security</key>
            <dict>
                <key>AllowSetDefault</key>
                <true/>
                <key>ApECID</key>
                <key>AuthRestart</key>
                <false/>
                <key>BlacklistAppleUpdate</key>
                <true/>
                <key>DmgLoading</key>
                <string>Signed</string>
                <key>EnablePassword</key>
                <false/>
                <key>ExposeSensitiveData</key>
                <integer>6</integer>
                <key>HaltLevel</key>
                <integer>2147483648</integer>
                <key>PasswordHash</key>
                <data></data>
                <key>PasswordSalt</key>
                <data></data>
                <key>ScanPolicy</key>
                <key>SecureBootModel</key>
                <key>Vault</key>
                <string>Optional</string>
            </dict>
            <key>Serial</key>
            <dict>
                <key>Custom</key>
                <dict>
                    <key>BaudRate</key>
                    <integer>115200</integer>
                    <key>ClockRate</key>
                    <integer>1843200</integer>
                    <key>DetectCable</key>
                    <false/>
                    <key>ExtendedTxFifoSize</key>
                    <integer>64</integer>
                    <key>FifoControl</key>
                    <integer>7</integer>
                    <key>LineControl</key>
                    <key>PciDeviceInfo</key>
                    <data>/w==</data>
                    <key>RegisterAccessWidth</key>
                    <integer>8</integer>
                    <key>RegisterBase</key>
                    <integer>1016</integer>
                    <key>RegisterStride</key>
                    <key>UseHardwareFlowControl</key>
                    <false/>
                    <key>UseMmio</key>
                    <false/>
                </dict>
                <key>Init</key>
                <false/>
                <key>Override</key>
                <false/>
            </dict>
            <key>Tools</key>
            <array/>
        </dict>
        <key>NVRAM</key>
        <dict>
            <key>Add</key>
            <dict>
                <key>4D1EDE05-38C7-4A6A-9CC6-4BCCA8B38C14</key>
                <dict>
                    <key>DefaultBackgroundColor</key>
                    <data>AAAAAA==</data>
                </dict>
                <key>4D1FDA02-38C7-4A6A-9CC6-4BCCA8B30102</key>
                <dict>
                    <key>revcpu</key>
                    <key>revcpuname</key>
                    <string>AMD Ryzen 5 3600 6-Core Processor</string>
                    <key>revpatch</key>
                    <string>sbvmm,cpuname</string>
                    <key>rtc-blacklist</key>
                    <data></data>
                </dict>
                <key>7C436110-AB2A-4BBB-A880-FE41995C9F82</key>
                <dict>
                    <key>ForceDisplayRotationInEFI</key>
                    <key>SystemAudioVolume</key>
                    <data>Rg==</data>
                    <key>boot-args</key>
                    <string>-v debug=0x100 keepsyms=1 agdpmod=pikera -lilubetaall</string>
                    <key>csr-active-config</key>
                    <data>AwoAAA==</data>
                    <key>prev-lang:kbd</key>
                    <data></data>
                    <key>run-efi-updater</key>
                    <string>No</string>
                </dict>
            </dict>
            <key>Delete</key>
            <dict>
                <array>
                    <string>DefaultBackgroundColor</string>
                </array>
                <array>
                    <string>rtc-blacklist</string>
                    <string>revcpu</string>
                    <string>revcpuname</string>
                    <string>revpatch</string>
                </array>
                <array>
                    <string>ForceDisplayRotationInEFI</string>
                    <string>SystemAudioVolume</string>
                    <string>boot-args</string>
                    <string>csr-active-config</string>
                    <string>prev-lang:kbd</string>
                    <string>run-efi-updater</string>
                </array>
            </dict>
            <key>LegacyOverwrite</key>
            <false/>
            <key>LegacySchema</key>
            <dict>
                <array>
                    <string>EFILoginHiDPI</string>
                    <string>EFIBluetoothDelay</string>
                    <string>LocationServicesEnabled</string>
                    <string>SystemAudioVolumeDB</string>
                    <string>SystemAudioVolumeSaved</string>
                    <string>bluetoothActiveControllerInfo</string>
                    <string>bluetoothInternalControllerInfo</string>
                    <string>flagstate</string>
                    <string>fmm-computer-name</string>
                    <string>fmm-mobileme-token-FMM</string>
                    <string>fmm-mobileme-token-FMM-BridgeHasAccount</string>
                    <string>nvda_drv</string>
                    <string>backlight-level</string>
                    <string>BootCampHD</string>
                </array>
                <key>8BE4DF61-93CA-11D2-AA0D-00E098032B8C</key>
                <array>
                    <string>Boot0080</string>
                    <string>Boot0081</string>
                    <string>Boot0082</string>
                    <string>BootNext</string>
                    <string>BootOrder</string>
                </array>
            </dict>
            <key>WriteFlash</key>
            <true/>
        </dict>
        <key>PlatformInfo</key>
        <dict>
            <key>Automatic</key>
            <true/>
            <key>CustomMemory</key>
            <false/>
            <key>Generic</key>
            <dict>
                <key>AdviseFeatures</key>
                <false/>
                <key>MLB</key>
                <string>F5K206600CDK3F7JC</string>
                <key>MaxBIOSVersion</key>
                <false/>
                <key>ProcessorType</key>
                <integer>1537</integer>
                <key>ROM</key>
                <data>3bBoj2Mf</data>
                <key>SpoofVendor</key>
                <true/>
                <key>SystemMemoryStatus</key>
                <key>SystemProductName</key>
                <string>MacPro7,1</string>
                <key>SystemSerialNumber</key>
                <string>F5KH7XZ2P7QM</string>
                <key>SystemUUID</key>
                <string>438B3B24-91A3-4750-9554-A2923AE54F3F</string>
            </dict>
            <key>UpdateDataHub</key>
            <true/>
            <key>UpdateNVRAM</key>
            <true/>
            <key>UpdateSMBIOS</key>
            <true/>
            <key>UpdateSMBIOSMode</key>
            <string>Custom</string>
            <key>UseRawUuidEncoding</key>
            <false/>
        </dict>
        <key>UEFI</key>
        <dict>
            <key>APFS</key>
            <dict>
                <key>EnableJumpstart</key>
                <true/>
                <key>GlobalConnect</key>
                <false/>
                <key>HideVerbose</key>
                <true/>
                <key>JumpstartHotPlug</key>
                <false/>
                <key>MinDate</key>
                <key>MinVersion</key>
            </dict>
            <key>AppleInput</key>
            <dict>
                <key>AppleEvent</key>
                <string>Builtin</string>
                <key>CustomDelays</key>
                <false/>
                <key>GraphicsInputMirroring</key>
                <true/>
                <key>KeyInitialDelay</key>
                <integer>50</integer>
                <key>KeySubsequentDelay</key>
                <key>PointerDwellClickTimeout</key>
                <key>PointerDwellDoubleClickTimeout</key>
                <key>PointerDwellRadius</key>
                <key>PointerPollMask</key>
                <key>PointerPollMax</key>
                <integer>80</integer>
                <key>PointerPollMin</key>
                <integer>10</integer>
                <key>PointerSpeedDiv</key>
                <key>PointerSpeedMul</key>
            </dict>
            <key>Audio</key>
            <dict>
                <key>AudioCodec</key>
                <key>AudioDevice</key>
                <string>PciRoot(0x0)/Pci(0x1b,0x0)</string>
                <key>AudioOutMask</key>
                <key>AudioSupport</key>
                <false/>
                <key>DisconnectHda</key>
                <false/>
                <key>MaximumGain</key>
                <integer>-15</integer>
                <key>MinimumAssistGain</key>
                <integer>-30</integer>
                <key>MinimumAudibleGain</key>
                <integer>-55</integer>
                <key>PlayChime</key>
                <key>ResetTrafficClass</key>
                <false/>
                <key>SetupDelay</key>
            </dict>
            <key>ConnectDrivers</key>
            <true/>
            <key>Drivers</key>
            <array>
                <dict>
                    <key>Arguments</key>
                    <string></string>
                    <key>Comment</key>
                    <string></string>
                    <key>Enabled</key>
                    <true/>
                    <key>LoadEarly</key>
                    <false/>
                    <key>Path</key>
                    <string>HfsPlus.efi</string>
                </dict>
                <dict>
                    <string></string>
                    <key>Comment</key>
                    <string></string>
                    <key>Enabled</key>
                    <true/>
                    <false/>
                    <key>Path</key>
                    <string>OpenCanopy.efi</string>
                </dict>
                <dict>
                    <string></string>
                    <key>Comment</key>
                    <string></string>
                    <key>Enabled</key>
                    <true/>
                    <false/>
                    <key>Path</key>
                    <string>OpenRuntime.efi</string>
                </dict>
                <dict>
                    <string></string>
                    <key>Comment</key>
                    <string></string>
                    <key>Enabled</key>
                    <true/>
                    <false/>
                    <key>Path</key>
                    <string>ResetNvramEntry.efi</string>
                </dict>
            </array>
            <key>Input</key>
            <dict>
                <key>KeyFiltering</key>
                <false/>
                <key>KeyForgetThreshold</key>
                <key>KeySupport</key>
                <true/>
                <key>KeySupportMode</key>
                <key>KeySwap</key>
                <false/>
                <key>PointerSupport</key>
                <false/>
                <key>PointerSupportMode</key>
                <string>ASUS</string>
                <key>TimerResolution</key>
                <integer>50000</integer>
            </dict>
            <key>Output</key>
            <dict>
                <key>ClearScreenOnModeSwitch</key>
                <false/>
                <key>ConsoleFont</key>
                <string></string>
                <key>ConsoleMode</key>
                <string></string>
                <key>DirectGopRendering</key>
                <false/>
                <key>ForceResolution</key>
                <false/>
                <key>GopBurstMode</key>
                <false/>
                <key>GopPassThrough</key>
                <key>IgnoreTextInGraphics</key>
                <false/>
                <key>InitialMode</key>
                <string></string>
                <key>ProvideConsoleGop</key>
                <true/>
                <key>ReconnectGraphicsOnConnect</key>
                <false/>
                <key>ReconnectOnResChange</key>
                <false/>
                <key>ReplaceTabWithSpace</key>
                <false/>
                <key>Resolution</key>
                <string>Max</string>
                <key>SanitiseClearScreen</key>
                <false/>
                <key>TextRenderer</key>
                <string>BuiltinGraphics</string>
                <key>UIScale</key>
                <key>UgaPassThrough</key>
                <false/>
            </dict>
            <key>ProtocolOverrides</key>
            <dict>
                <key>AppleAudio</key>
                <false/>
                <key>AppleBootPolicy</key>
                <false/>
                <key>AppleDebugLog</key>
                <false/>
                <key>AppleEg2Info</key>
                <false/>
                <key>AppleFramebufferInfo</key>
                <false/>
                <key>AppleImageConversion</key>
                <false/>
                <key>AppleImg4Verification</key>
                <false/>
                <key>AppleKeyMap</key>
                <false/>
                <key>AppleRtcRam</key>
                <false/>
                <key>AppleSecureBoot</key>
                <false/>
                <key>AppleSmcIo</key>
                <false/>
                <key>AppleUserInterfaceTheme</key>
                <false/>
                <key>DataHub</key>
                <false/>
                <false/>
                <key>FirmwareVolume</key>
                <true/>
                <key>HashServices</key>
                <false/>
                <key>OSInfo</key>
                <false/>
                <key>PciIo</key>
                <false/>
                <key>UnicodeCollation</key>
                <false/>
            </dict>
            <key>Quirks</key>
            <dict>
                <key>ActivateHpetSupport</key>
                <false/>
                <key>DisableSecurityPolicy</key>
                <false/>
                <key>EnableVectorAcceleration</key>
                <true/>
                <key>EnableVmx</key>
                <false/>
                <key>ExitBootServicesDelay</key>
                <key>ForceOcWriteFlash</key>
                <false/>
                <key>ForgeUefiSupport</key>
                <false/>
                <key>IgnoreInvalidFlexRatio</key>
                <false/>
                <key>ReleaseUsbOwnership</key>
                <true/>
                <key>ReloadOptionRoms</key>
                <false/>
                <key>RequestBootVarRouting</key>
                <true/>
                <key>ResizeGpuBars</key>
                <key>ResizeUsePciRbIo</key>
                <false/>
                <key>ShimRetainProtocol</key>
                <false/>
                <key>TscSyncTimeout</key>
                <key>UnblockFsConnect</key>
                <false/>
            </dict>
            <key>ReservedMemory</key>
            <array/>
            <key>Unload</key>
            <array/>
        </dict>
    </dict>
</plist>
