Çözüm Mtkbtfilterx.sys DRIVER_POWER_STATE_FAILURE (9f)
Bu konu bir çözümü açıklamaktadır. Herhangi bir çözüm açıklanmadığını düşünüyorsanız konuyu rapor edebilirsiniz.
3 Aralık 2023
İstanbul
Sorun Marvell Yukon 88E8040 PCI-E Fast Ethernet Controller kaynaklı. Sürücüsü güncellenirse muhtemelen sorun kalmayacak.
Kod:
PCI\VEN_10EC&DEV_8125&SUBSYS_88E11043&REV_0C
Kod:
A driver has failed to complete a power IRP within a specific time.
Arguments:
Arg1: 0000000000000003, A device object has been blocking an IRP for too long a time
Arg2: ffffdf8796e6c060, Physical Device Object of the stack
Arg3: fffff80538f55a00, nt!TRIAGE_9F_POWER on Win7 and higher, otherwise the Functional Device Object of the stack
Arg4: ffffdf8797fa3010, The blocked IRP
Debugging Details:
Unable to load image mtkbtfilterx.sys, Win32 error 0n2
*** WARNING: Unable to verify timestamp for mtkbtfilterx.sys
Implicit thread is now ffffdf87`8b594040
KEY_VALUES_STRING: 1
    Key  : Analysis.CPU.mSec
    Value: 1890
    Key  : Analysis.Elapsed.mSec
    Value: 25270
    Key  : Analysis.IO.Other.Mb
    Value: 2
    Key  : Analysis.IO.Read.Mb
    Value: 1
    Key  : Analysis.IO.Write.Mb
    Value: 14
    Key  : Analysis.Init.CPU.mSec
    Value: 343
    Value: 4768
    Value: 103
    Value: 10.0.27725.1000
    Value: 10.2408.27.01 amd64fre
    Key  : Analysis.Version.Ext
    Value: 1.2408.27.1
    Value: 0x9f
    Value: 0x9f
    Value: 21808
    Value: 1
    Value: 0
    Value: 1
    Value: 0
    Key  : Failure.Bucket
    Value: 0x9F_3_mtkbtfilterx!unknown_function
    Key  : Failure.Hash
    Value: {c2970afb-352a-f2e6-df57-bf9a037d2445}
    Key  : Hypervisor.Enlightenments.ValueHex
    Value: 7497cf94
    Key  : Hypervisor.Flags.AnyHypervisorPresent
    Value: 1
    Key  : Hypervisor.Flags.ApicEnlightened
    Value: 1
    Key  : Hypervisor.Flags.ApicVirtualizationAvailable
    Value: 0
    Key  : Hypervisor.Flags.AsyncMemoryHint
    Value: 0
    Key  : Hypervisor.Flags.CoreSchedulerRequested
    Value: 0
    Key  : Hypervisor.Flags.CpuManager
    Value: 1
    Key  : Hypervisor.Flags.DeprecateAutoEoi
    Value: 0
    Key  : Hypervisor.Flags.DynamicCpuDisabled
    Value: 1
    Key  : Hypervisor.Flags.Epf
    Value: 0
    Key  : Hypervisor.Flags.ExtendedProcessorMasks
    Value: 1
    Key  : Hypervisor.Flags.HardwareMbecAvailable
    Value: 1
    Key  : Hypervisor.Flags.MaxBankNumber
    Value: 0
    Key  : Hypervisor.Flags.MemoryZeroingControl
    Value: 0
    Key  : Hypervisor.Flags.NoExtendedRangeFlush
    Value: 0
    Key  : Hypervisor.Flags.NoNonArchCoreSharing
    Value: 1
    Key  : Hypervisor.Flags.Phase0InitDone
    Value: 1
    Key  : Hypervisor.Flags.PowerSchedulerQos
    Value: 0
    Key  : Hypervisor.Flags.RootScheduler
    Value: 0
    Key  : Hypervisor.Flags.SynicAvailable
    Value: 1
    Key  : Hypervisor.Flags.UseQpcBias
    Value: 0
    Key  : Hypervisor.Flags.Value
    Value: 38408431
    Key  : Hypervisor.Flags.ValueHex
    Value: 24a10ef
    Key  : Hypervisor.Flags.VpAssistPage
    Value: 1
    Key  : Hypervisor.Flags.VsmAvailable
    Value: 1
    Key  : Hypervisor.RootFlags.AccessStats
    Value: 1
    Key  : Hypervisor.RootFlags.CrashdumpEnlightened
    Value: 1
    Key  : Hypervisor.RootFlags.CreateVirtualProcessor
    Value: 1
    Key  : Hypervisor.RootFlags.DisableHyperthreading
    Value: 0
    Key  : Hypervisor.RootFlags.HostTimelineSync
    Value: 1
    Key  : Hypervisor.RootFlags.HypervisorDebuggingEnabled
    Value: 0
    Key  : Hypervisor.RootFlags.IsHyperV
    Value: 1
    Key  : Hypervisor.RootFlags.LivedumpEnlightened
    Value: 1
    Key  : Hypervisor.RootFlags.MapDeviceInterrupt
    Value: 1
    Key  : Hypervisor.RootFlags.MceEnlightened
    Value: 1
    Key  : Hypervisor.RootFlags.Nested
    Value: 0
    Key  : Hypervisor.RootFlags.StartLogicalProcessor
    Value: 1
    Key  : Hypervisor.RootFlags.Value
    Value: 1015
    Key  : Hypervisor.RootFlags.ValueHex
    Value: 3f7
    Key  : Stack.Pointer
    Value: NMI
BUGCHECK_CODE:  9f
BUGCHECK_P1: 3
BUGCHECK_P2: ffffdf8796e6c060
BUGCHECK_P3: fffff80538f55a00
BUGCHECK_P4: ffffdf8797fa3010
FILE_IN_CAB:  112524-16500-01.dmp
TAG_NOT_DEFINED_202b:  *** Unknown TAG in analysis list 202b
DUMP_FILE_ATTRIBUTES: 0x21808
  Kernel Generated Triage Dump
FAULTING_THREAD:  ffffdf878b594040
DRVPOWERSTATE_SUBCODE:  3
BLACKBOXACPI: 1 (!blackboxacpi)
BLACKBOXBSD: 1 (!blackboxbsd)
BLACKBOXPNP: 1 (!blackboxpnp)
BLACKBOXWINLOGON: 1
CUSTOMER_CRASH_COUNT:  1
PROCESS_NAME:  chrome.exe
DPC_STACK_BASE:  FFFFF80538F55FB0
STACK_TEXT:
ffff9080`a6216a80 fffff805`a6d43788     : 00000000`00000047 ffffa281`3ed2b198 00000000`00000000 ffffdf87`8b640280 : nt!KiSwapContext+0x76
ffff9080`a6216bc0 fffff805`a6c72d83     : 00000000`00000000 00000000`00000000 ffff9080`a6216d48 ffffdf87`00000037 : nt!KiSwapThread+0x928
ffff9080`a6216c50 fffff805`a6c73a44     : ffffa281`3ed2b180 ffffdf87`8b594040 ffffdf87`00000037 00000008`90dc37f2 : nt!KiCommitThreadWait+0x483
ffff9080`a6216ce0 fffff805`823389d3     : ffffdf87`97a3cd48 ffffdf87`00000000 ffffdf87`96e12000 fffff805`82327300 : nt!KeWaitForSingleObject+0x7a4
ffff9080`a6216dc0 fffff805`8231506c     : ffffdf87`97a3c988 ffffdf87`97a3cee0 ffffdf87`97a3cee0 ffffffff`dc3cba00 : usbccgp!WaitForSignal+0x10f
ffff9080`a6216e20 fffff805`82314922     : ffffdf87`97fa3010 ffffdf87`96e6c100 00000000`00000000 ffffdf87`97a3c988 : usbccgp!CancelFdoIdleIrp+0x198
ffff9080`a6216e80 fffff805`82314344     : ffffdf87`97fa3010 ffffdf87`96e6c1b8 ffffdf87`97fa3560 fffff805`8232c008 : usbccgp!ParentSetD0+0x3e
ffff9080`a6216ee0 fffff805`82318c16     : 00000000`00000001 ffffdf87`97fa3010 ffffdf87`96e6c1b0 ffffdf87`97a3c988 : usbccgp!DispatchPdoSetPower+0xb0
ffff9080`a6216f50 fffff805`82318afd     : ffffdf87`96e6c1b8 ffffdf87`96e6c1b8 fffff805`388c9e01 ffffdf87`97fa3010 : usbccgp!DispatchPdoPower+0x72
ffff9080`a6216fa0 fffff805`82317631     : ffffdf87`96e6c1b8 fffff805`388c9e01 ffffdf87`96e6c1b0 fffff805`388c9e01 : usbccgp!USBC_Power+0x39
ffff9080`a6217000 fffff805`a6d9b9bb     : ffffdf87`96e6c060 ffff9080`a6217400 fffff805`00000002 ffffdf87`97fa3010 : usbccgp!USBC_Dispatch+0x231
ffff9080`a62170a0 fffff805`a6cf7a33     : 00000008`46e0d310 00000008`00000000 00000004`2a5e6298 ffffdf87`8b595b40 : nt!IopPoHandleIrp+0x3b
ffff9080`a62170d0 fffff805`3bdb996d     : ffffdf87`97fa3010 ffffa281`3efc0180 ffffa281`3efd0000 ffffa281`00000000 : nt!IofCallDriver+0xf3
ffff9080`a6217110 ffffdf87`97fa3010     : ffffa281`3efc0180 ffffa281`3efd0000 ffffa281`00000000 ffffdf87`97fa3560 : mtkbtfilterx+0x2996d
ffff9080`a6217118 ffffa281`3efc0180     : ffffa281`3efd0000 ffffa281`00000000 ffffdf87`97fa3560 ffffdf87`97fa35a8 : 0xffffdf87`97fa3010
ffff9080`a6217120 ffffa281`3efd0000     : ffffa281`00000000 ffffdf87`97fa3560 ffffdf87`97fa35a8 ffffdf87`a73f08b0 : 0xffffa281`3efc0180
ffff9080`a6217128 ffffa281`00000000     : ffffdf87`97fa3560 ffffdf87`97fa35a8 ffffdf87`a73f08b0 fffff805`3bd9b91f : 0xffffa281`3efd0000
ffff9080`a6217130 ffffdf87`97fa3560     : ffffdf87`97fa35a8 ffffdf87`a73f08b0 fffff805`3bd9b91f ffffdf87`b1547180 : 0xffffa281`00000000
ffff9080`a6217138 ffffdf87`97fa35a8     : ffffdf87`a73f08b0 fffff805`3bd9b91f ffffdf87`b1547180 ffffdf87`97fa3010 : 0xffffdf87`97fa3560
ffff9080`a6217140 ffffdf87`a73f08b0     : fffff805`3bd9b91f ffffdf87`b1547180 ffffdf87`97fa3010 00000000`00000000 : 0xffffdf87`97fa35a8
ffff9080`a6217148 fffff805`3bd9b91f     : ffffdf87`b1547180 ffffdf87`97fa3010 00000000`00000000 fffff805`388c9e01 : 0xffffdf87`a73f08b0
ffff9080`a6217150 ffffdf87`b1547180     : ffffdf87`97fa3010 00000000`00000000 fffff805`388c9e01 00000000`00000001 : mtkbtfilterx+0xb91f
ffff9080`a6217158 ffffdf87`97fa3010     : 00000000`00000000 fffff805`388c9e01 00000000`00000001 fffff805`a6d9bd01 : 0xffffdf87`b1547180
ffff9080`a6217160 00000000`00000000     : fffff805`388c9e01 00000000`00000001 fffff805`a6d9bd01 ffffdf87`b1547180 : 0xffffdf87`97fa3010
SYMBOL_NAME:  mtkbtfilterx+2996d
MODULE_NAME: mtkbtfilterx
IMAGE_NAME:  mtkbtfilterx.sys
STACK_COMMAND:  .process /r /p 0xffffdf878b558040; .thread 0xffffdf878b594040 ; kb
BUCKET_ID_FUNC_OFFSET:  2996d
FAILURE_BUCKET_ID:  0x9F_3_mtkbtfilterx!unknown_function
OSPLATFORM_TYPE:  x64
OSNAME:  Windows 10
FAILURE_ID_HASH:  {c2970afb-352a-f2e6-df57-bf9a037d2445}
Followup:     MachineOwner
    PnpActivityId      : {00000000-0000-0000-0000-000000000000}
    PnpActivityTime    : 133769829683305348
    PnpEventInformation: 0
    PnpEventInProgress : 0
    PnpProblemCode     : 22
    PnpVetoType        : 0
    DeviceId           : PCI\VEN_10EC&DEV_8125&SUBSYS_88E11043&REV_0C\01000000684CE00000
    VetoString         :
[SMBIOS Data Tables v3.6]
[DMI Version - 0]
[2.0 Calling Convention - No]
[Table Size - 3396 bytes]
  Vendor                        American Megatrends Inc.
  BIOS Version                  0816
  BIOS Release Date             10/29/2024
  BIOS ROM Size                 1000000
  BIOS Characteristics
       07: - PCI Supported
       11: - Upgradeable FLASH BIOS
       15: - CD-Boot Supported
       17: - BIOS ROM Socketed
       19: - EDD Supported
       22: - 360KB Floppy Supported
       23: - 1.2MB Floppy Supported
       24: - 720KB Floppy Supported
       25: - 2.88MB Floppy Supported
       32: - BIOS Vendor Reserved
       00: - ACPI Supported
       01: - USB Legacy Supported
  BIOS Major Revision           8
  BIOS Minor Revision           16
  EC Firmware Major Revision    255
  EC Firmware Minor Revision    255
  Extended BIOS ROM Size        32 MB
  Manufacturer                  ASUS
  Product Name                  System Product Name
  Version                       System Version
  Serial Number                 System Serial Number
  SKUNumber                     SKU
  Family                        To be filled by O.E.M.
  Manufacturer                  ASUSTeK COMPUTER INC.
  Product                       TUF GAMING X870-PLUS WIFI
  Version                       Rev 1.xx
  Serial Number                 240741340100127
  Asset Tag
       00: - Motherboard
       03: - Replaceable
  Location                      Default string
  Manufacturer                  Default string
  Chassis Type                  Desktop
  Version                       Default string
  Serial Number
  Asset Tag Number
  Contained Element Size        3
[Onboard Devices Information (Type 10) - Length 6 - Handle 0004h]
Note: The On Board Device Information (Type 10) struct is obsolete as of SMBIOs spec v2.6  Number of Devices             1
  01: Type                      Video [enabled]
  01: Description                  To Be Filled By O.E.M.
[OEM Strings (Type 11) - Length 5 - Handle 0005h]
  Number of Strings             6
   1                            Default string
   2                            Default string
   3                            Default string
   4                            Default string
   5                            Default string
   6                            Default string
[System Configuration Options (Type 12) - Length 5 - Handle 0006h]
[ (Type 256) - Length 59 - Handle 0009h]
[ (Type 256) - Length 9 - Handle 000ah]
[ (Type 256) - Length 31 - Handle 000bh]
[ (Type 256) - Length 26 - Handle 000ch]
[Cache Information (Type 7) - Length 27 - Handle 000dh]
  Socket Designation            L1 - Cache
  Maximum Cache Size            0500h - 1280K
  Installed Size                0500h - 1280K
  Supported SRAM Type           0010h - Pipeline-Burst
  Current SRAM Type             0010h - Pipeline-Burst
  Cache Speed                   1ns
  Maximum Cache Size 2          500 - 00001280l Kb
  Installed Cache Size 2        500 - 00001280l Kb
[Cache Information (Type 7) - Length 27 - Handle 000eh]
  Socket Designation            L2 - Cache
  Maximum Cache Size            4000h - 16384K
  Installed Size                4000h - 16384K
  Cache Speed                   1ns
  Associativity                 16-way Set-Associative
  Maximum Cache Size 2          4000 - 00016384l Kb
  Installed Cache Size 2        4000 - 00016384l Kb
[Cache Information (Type 7) - Length 27 - Handle 000fh]
  Socket Designation            L3 - Cache
  Maximum Cache Size            8400h - 65536K
  Installed Size                8400h - 65536K
  Cache Speed                   1ns
  Maximum Cache Size 2          80000400 - 00065536l Kb
  Installed Cache Size 2        80000400 - 00065536l Kb
[Processor Information (Type 4) - Length 48 - Handle 0010h]
  Socket Designation            AM5
  Processor Family              6bh - AMD Zen Processor Family
  Processor Manufacturer        Advanced Micro Devices, Inc.
  Processor ID                   400fb400fffb8b17
  Processor Version             AMD Ryzen 9 9950X 16-Core Processor
  Processor Voltage             8dh - 1.3V
  Max Speed                     5750MHz
  Current Speed                 4300MHz
  Processor Upgrade             Specification Reserved
  L1 Cache Handle               000dh
  L2 Cache Handle               000eh
  L3 Cache Handle               000fh
  Serial Number
  Asset Tag Number
  Part Number                   Unknown
  Core Count                    16
  Core Enabled                  16
  Thread Count                  32
  Processor Characteristics     fc
  Enabled Characteristics:
       0x 2: 64-bit Capable
       0x 3: Multi-Core
       0x 4: Hardware Thread
       0x 5: Execute Protection
       0x 6: Enhanced Virtualization
  Processor Family 2            006bh - AMD Zen Processor Family
  Core Count 2                  16
  Core Enabled 2                16
  Thread Count 2                32
[ (Type 256) - Length 9 - Handle 0011h]
[32Bit Memory Error Information (Type 18) - Length 23 - Handle 0012h]
[Physical Memory Array (Type 16) - Length 23 - Handle 0013h]
  Maximum Capacity              134217728KB
  Memory Error Inf Handle       0012h
  Number of Memory Devices      4
[Memory Array Mapped Address (Type 19) - Length 31 - Handle 0014h]
  Ending Address                03ffffffh
  Memory Array Handle           0013h
[32Bit Memory Error Information (Type 18) - Length 23 - Handle 0015h]
[Memory Device (Type 17) - Length 92 - Handle 0016h]
  Memory Error Info Handle      0015h
  Total Width                   [Unknown]
  Data Width                    [Unknown]
  Size                          [Not Populated]
  Form Factor                   02h - Unknown
  Device Locator                DIMM 0
  Bank Locator                  P0 CHANNEL A
  Memory Type                   02h - Unknown
  Type Detail                   0004h - Unknown
  Speed                         0MHz
  Manufacturer                  Unknown
  Serial Number
  Asset Tag Number              [String Not Specified]
  Part Number                   Unknown
  Attributes                    0
  Configured Memory Speed       0
  Minimum Voltage               0
  Maximum Voltage               0
  Configured Voltage            0
  Memory Technology             2
  Memory Operating Mode Capability     4
  Firmware Version              6
  Module Manufacturer Id        0
  Module Product Id             0
  Memory Subsystem Controller Manufacturer Id  0
  Memory Subsystem Controller Product Id       0
  Non-Volatile Size             0
  Volatile Size                 0
  Cache Size                    0
  Logical Size                  0
  Extended Speed                0
  Extended Configured Memory Speed     0
[32Bit Memory Error Information (Type 18) - Length 23 - Handle 0017h]
[Memory Device (Type 17) - Length 92 - Handle 0018h]
  Memory Error Info Handle      0017h
  Size                          32767MB
  Form Factor                   09h - DIMM
  Device Locator                DIMM 1
  Memory Type                   22h - DDR5
  Type Detail                   4080h - Synchronous Unbuffered (Unregistered)
  Speed                         4800MHz
  Manufacturer                  G Skill Intl
  Serial Number
  Part Number                   F5-6000J3040G32G
  Attributes                    2
  Extended Size                 32768
  Configured Memory Speed       6000
  Minimum Voltage               1100
  Maximum Voltage               1100
  Configured Voltage            1100
  Memory Technology             3
  Memory Operating Mode Capability     8
  Firmware Version              6
  Module Manufacturer Id        52484
  Module Product Id             0
  Non-Volatile Size             0
  Volatile Size                 0
  Cache Size                    0
  Logical Size                  0
  Extended Speed                0
[Memory Device Mapped Address (Type 20) - Length 35 - Handle 0019h]
  Ending Address                01ffffffh
  Memory Device Handle          0018h
  Mem Array Mapped Adr Handle   0014h
  Interleave Position           [Unknown]
  Interleave Data Depth         [Unknown]
[32Bit Memory Error Information (Type 18) - Length 23 - Handle 001ah]
[Memory Device (Type 17) - Length 92 - Handle 001bh]
  Memory Error Info Handle      001ah
  Bank Locator                  P0 CHANNEL B
  Speed                         0MHz
  Serial Number
  Part Number                   Unknown
  Attributes                    0
  Minimum Voltage               0
  Maximum Voltage               0
  Memory Technology             2
  Firmware Version              6
  Module Product Id             0
  Non-Volatile Size             0
  Volatile Size                 0
  Cache Size                    0
  Logical Size                  0
  Extended Speed                0
[32Bit Memory Error Information (Type 18) - Length 23 - Handle 001ch]
[Memory Device (Type 17) - Length 92 - Handle 001dh]
  Memory Error Info Handle      001ch
  Size                          32767MB
  Speed                         4800MHz
  Serial Number
  Attributes                    2
  Extended Size                 32768
  Memory Technology             3
  Firmware Version              6
  Module Product Id             0
  Non-Volatile Size             0
  Volatile Size                 0
  Cache Size                    0
  Logical Size                  0
  Extended Speed                0
[Memory Device Mapped Address (Type 20) - Length 35 - Handle 001eh]
  Starting Address              02000000h
  Memory Device Handle          001dh
[ (Type 256) - Length 14 - Handle 001fh]
[ (Type 256) - Length 165 - Handle 0020h]
[ (Type 256) - Length 11 - Handle 004ah]
[ (Type 256) - Length 11 - Handle 004bh]
[ (Type 256) - Length 4 - Handle 004dh]
Geri
Yukarı Alt
