Explosive
- 26 Ocak 2024
Dostlar selam Arch kullanıyorum, Wayland birden çökmeye başladı. Bazen 5 dakikada bir bazen 30 dakika civarında çöküyor. Çökme raporuna baktım ama pek bir şey anlayamadım. Aşağıya bırakıyorum.
[CODE title="Hata"]Application: kwin_wayland (kwin_wayland), signal: Segmentation fault
This GDB supports auto-downloading debuginfo from the following URLs:
<https://debuginfod.archlinux.org>
Enable debuginfod for this session? (y or [n]) [answered N; input not from terminal]
Debuginfod has been disabled.
To make this setting permanent, add 'set debuginfod enabled off' to .gdbinit.
[New LWP 1104]
[New LWP 1098]
[New LWP 1055]
[New LWP 1105]
[New LWP 1125]
[New LWP 1130]
[New LWP 1107]
[New LWP 1131]
[New LWP 1133]
[New LWP 1132]
[New LWP 3966]
[New LWP 1101]
[New LWP 3979]
[New LWP 3984]
[New LWP 1103]
[New LWP 3983]
[New LWP 3982]
[New LWP 1127]
[New LWP 3985]
[New LWP 1129]
[New LWP 3965]
[New LWP 3990]
[New LWP 3964]
[New LWP 3989]
[New LWP 3970]
[New LWP 1102]
[New LWP 1126]
[New LWP 1106]
[New LWP 3978]
[New LWP 1128]
[New LWP 3986]
[Thread debugging using libthread_db enabled]
Using host libthread_db library "/usr/lib/libthread_db.so.1".
Core was generated by `/usr/bin/kwin_wayland --wayland-fd 8 --socket wayland-0 --xwayland-fd 9 --xwayl'.
Program terminated with signal SIGSEGV, Segmentation fault.
#0 0x0000714e6bc4965c in ?? () from /usr/lib/libgallium-24.2.1-arch1.1.so
[Current thread is 1 (Thread 0x714e57e006c0 (LWP 1104))]
Cannot QML trace cores
Thread 31 (Thread 0x714e0d8006c0 (LWP 3986)):
#0 0x0000714e6fa9fa19 in ?? () from /usr/lib/libc.so.6
#1 0x0000714e6faa27e2 in pthread_cond_timedwait () from /usr/lib/libc.so.6
#2 0x0000714e702d1bf8 in QWaitCondition::wait(QMutex*, QDeadlineTimer) () from /usr/lib/libQt6Core.so.6
#3 0x0000714e702cb852 in ?? () from /usr/lib/libQt6Core.so.6
#4 0x0000714e702cd237 in ?? () from /usr/lib/libQt6Core.so.6
#5 0x0000714e6faa339d in ?? () from /usr/lib/libc.so.6
#6 0x0000714e6fb2849c in ?? () from /usr/lib/libc.so.6
Thread 30 (Thread 0x714e4aa006c0 (LWP 1128)):
#1 0x0000714e6faa2479 in pthread_cond_wait () from /usr/lib/libc.so.6
#2 0x0000714e6baa5cae in ?? () from /usr/lib/libgallium-24.2.1-arch1.1.so
#3 0x0000714e6ba826cc in ?? () from /usr/lib/libgallium-24.2.1-arch1.1.so
#4 0x0000714e6baa5bdd in ?? () from /usr/lib/libgallium-24.2.1-arch1.1.so
Thread 29 (Thread 0x714e1be006c0 (LWP 3978)):
Thread 28 (Thread 0x714e568006c0 (LWP 1106)):
Thread 27 (Thread 0x714e4be006c0 (LWP 1126)):
Thread 26 (Thread 0x714e5d4006c0 (LWP 1102)):
Thread 25 (Thread 0x714e012006c0 (LWP 3970)):
#0 0x0000714e6fb1a63d in poll () from /usr/lib/libc.so.6
#1 0x0000714e6ed81e0d in ?? () from /usr/lib/libglib-2.0.so.0
#2 0x0000714e6ed1e795 in g_main_context_iteration () from /usr/lib/libglib-2.0.so.0
#3 0x0000714e703a82bd in QEventDispatcherGlib:
rocessEvents(QFlags<QEventLoop:
rocessEventsFlag>) () from /usr/lib/libQt6Core.so.6
#4 0x0000714e7014ff66 in QEventLoop::exec(QFlags<QEventLoop:
#5 0x0000714e7023d7a0 in QThread::run() () from /usr/lib/libQt6Core.so.6
#6 0x0000714e702cd237 in ?? () from /usr/lib/libQt6Core.so.6
#7 0x0000714e6faa339d in ?? () from /usr/lib/libc.so.6
#8 0x0000714e6fb2849c in ?? () from /usr/lib/libc.so.6
Thread 24 (Thread 0x714e0ce006c0 (LWP 3989)):
Thread 23 (Thread 0x714df7e006c0 (LWP 3964)):
Thread 22 (Thread 0x714e03e006c0 (LWP 3990)):
Thread 21 (Thread 0x714df6a006c0 (LWP 3965)):
Thread 20 (Thread 0x714e4a0006c0 (LWP 1129)):
Thread 19 (Thread 0x714e0f0006c0 (LWP 3985)):
Thread 18 (Thread 0x714e4b4006c0 (LWP 1127)):
Thread 17 (Thread 0x714e198006c0 (LWP 3982)):
Thread 16 (Thread 0x714e18e006c0 (LWP 3983)):
Thread 15 (Thread 0x714e5ca006c0 (LWP 1103)):
Thread 14 (Thread 0x714e0fa006c0 (LWP 3984)):
Thread 13 (Thread 0x714e1b4006c0 (LWP 3979)):
Thread 12 (Thread 0x714e5de006c0 (LWP 1101)):
Thread 11 (Thread 0x714e0e2006c0 (LWP 3966)):
Thread 10 (Thread 0x714e3fe006c0 (LWP 1132)):
#2 0x0000714e6fcd6cf1 in __gthread_cond_wait (__cond=<optimized out>, __mutex=<optimized out>) at /usr/src/debug/gcc/gcc-build/x86_64-pc-linux-gnu/libstdc++-v3/include/x86_64-pc-linux-gnu/bits/gthr-default.h:878
#3 std::__condvar::wait (this=<optimized out>, __m=...) at /usr/src/debug/gcc/gcc-build/x86_64-pc-linux-gnu/libstdc++-v3/include/bits/std_mutex.h:171
#4 std::condition_variable::wait (this=<optimized out>, __lock=...) at /usr/src/debug/gcc/gcc/libstdc++-v3/src/c++11/condition_variable.cc:41
#5 0x0000714e72dfb5ee in ?? () from /usr/lib/libkwin.so.6
#6 0x0000714e72defce6 in ?? () from /usr/lib/libkwin.so.6
#7 0x0000714e6faa88fb in ?? () from /usr/lib/libc.so.6
#8 0x0000714e6faa8979 in pthread_once () from /usr/lib/libc.so.6
#9 0x0000714e72df87c0 in ?? () from /usr/lib/libkwin.so.6
#10 0x0000714e7023e2c5 in ?? () from /usr/lib/libQt6Core.so.6
#11 0x0000714e702cd237 in ?? () from /usr/lib/libQt6Core.so.6
#12 0x0000714e6faa339d in ?? () from /usr/lib/libc.so.6
#13 0x0000714e6fb2849c in ?? () from /usr/lib/libc.so.6
Thread 9 (Thread 0x714e3f4006c0 (LWP 1133)):
Thread 8 (Thread 0x714e48c006c0 (LWP 1131)):
Thread 7 (Thread 0x714e55e006c0 (LWP 1107)):
Thread 6 (Thread 0x714e496006c0 (LWP 1130)):
#1 0x0000714e6faa2af2 in pthread_cond_clockwait () from /usr/lib/libc.so.6
#2 0x0000714e72dfb214 in ?? () from /usr/lib/libkwin.so.6
#3 0x0000714e72defce6 in ?? () from /usr/lib/libkwin.so.6
#4 0x0000714e6faa88fb in ?? () from /usr/lib/libc.so.6
#5 0x0000714e6faa8979 in pthread_once () from /usr/lib/libc.so.6
#6 0x0000714e72df87c0 in ?? () from /usr/lib/libkwin.so.6
#7 0x0000714e7023e2c5 in ?? () from /usr/lib/libQt6Core.so.6
#8 0x0000714e702cd237 in ?? () from /usr/lib/libQt6Core.so.6
#9 0x0000714e6faa339d in ?? () from /usr/lib/libc.so.6
#10 0x0000714e6fb2849c in ?? () from /usr/lib/libc.so.6
Thread 5 (Thread 0x714e554006c0 (LWP 1125)):
Thread 4 (Thread 0x714e572006c0 (LWP 1105)):
Thread 3 (Thread 0x714e5f1fea80 (LWP 1055)):
#0 0x0000714e6bae530b in ?? () from /usr/lib/libgallium-24.2.1-arch1.1.so
#1 0x0000714e6bae5a06 in ?? () from /usr/lib/libgallium-24.2.1-arch1.1.so
#2 0x0000714e6bac00c1 in ?? () from /usr/lib/libgallium-24.2.1-arch1.1.so
#3 0x0000714e6bac023e in ?? () from /usr/lib/libgallium-24.2.1-arch1.1.so
#4 0x0000714e6bca67b7 in ?? () from /usr/lib/libgallium-24.2.1-arch1.1.so
#5 0x0000714e72c71e35 in KWin::GLVertexBuffer::draw(unsigned int, int, int) () from /usr/lib/libkwin.so.6
#6 0x000059f2e8a76de8 in ?? ()
#7 0x000059f2e8a774e2 in ?? ()
#8 0x0000714e72bd2683 in KWin::EffectsHandler::drawWindow(KWin::RenderTarget const&, KWin::RenderViewport const&, KWin::EffectWindow*, int, QRegion const&, KWin::WindowPaintData&) () from /usr/lib/libkwin.so.6
#9 0x0000714e72bd25c4 in KWin::EffectsHandler:
aintWindow(KWin::RenderTarget const&, KWin::RenderViewport const&, KWin::EffectWindow*, int, QRegion const&, KWin::WindowPaintData&) () from /usr/lib/libkwin.so.6
#10 0x0000714e72bd25c4 in KWin::EffectsHandler:
#11 0x0000714e72bd25c4 in KWin::EffectsHandler:
#12 0x0000714e72cd04d3 in KWin::WorkspaceScene:
aintWindow(KWin::RenderTarget const&, KWin::RenderViewport const&, KWin::WindowItem*, int, QRegion const&) () from /usr/lib/libkwin.so.6
#13 0x0000714e72cd07e7 in KWin::WorkspaceScene:
aintSimpleScreen(KWin::RenderTarget const&, KWin::RenderViewport const&, int, QRegion const&) () from /usr/lib/libkwin.so.6
#14 0x0000714e72bd24f6 in KWin::EffectsHandler:
aintScreen(KWin::RenderTarget const&, KWin::RenderViewport const&, int, QRegion const&, KWin::Output*) () from /usr/lib/libkwin.so.6
#15 0x0000714e72bd24f6 in KWin::EffectsHandler:
#16 0x0000714e72bd24f6 in KWin::EffectsHandler:
#17 0x0000714e72cd0968 in KWin::WorkspaceScene:
aint(KWin::RenderTarget const&, QRegion const&) () from /usr/lib/libkwin.so.6
#18 0x0000714e72cc2125 in KWin::SceneDelegate:
#19 0x0000714e72b66257 in KWin::Compositor:
aintPass(KWin::RenderLayer*, KWin::RenderTarget const&, QRegion const&) () from /usr/lib/libkwin.so.6
#20 0x0000714e72b6d800 in KWin::WaylandCompositor::composite(KWin::RenderLoop*) () from /usr/lib/libkwin.so.6
#21 0x0000714e701a3397 in ?? () from /usr/lib/libQt6Core.so.6
#22 0x0000714e72b7b525 in KWin::RenderLoop::frameRequested(KWin::RenderLoop*) () from /usr/lib/libkwin.so.6
#23 0x0000714e72b81df3 in KWin::RenderLoopPrivate::dispatch() () from /usr/lib/libkwin.so.6
#24 0x0000714e701a3397 in ?? () from /usr/lib/libQt6Core.so.6
#25 0x0000714e701ab5e5 in QTimer::timerEvent(QTimerEvent*) () from /usr/lib/libQt6Core.so.6
#26 0x0000714e7018d859 in QObject::event(QEvent*) () from /usr/lib/libQt6Core.so.6
#27 0x0000714e712fc8cc in QApplicationPrivate::notify_helper(QObject*, QEvent*) () from /usr/lib/libQt6Widgets.so.6
#28 0x0000714e70145aa8 in QCoreApplication::notifyInternal2(QObject*, QEvent*) () from /usr/lib/libQt6Core.so.6
#29 0x0000714e702c7658 in QTimerInfoList::activateTimers() () from /usr/lib/libQt6Core.so.6
#30 0x0000714e702c9da8 in QEventDispatcherUNIX:
#31 0x0000714e70e04203 in QUnixEventDispatcherQPA:
rocessEventsFlag>) () from /usr/lib/libQt6Gui.so.6
#32 0x0000714e7014ff66 in QEventLoop::exec(QFlags<QEventLoop:
#33 0x0000714e7014a11d in QCoreApplication::exec() () from /usr/lib/libQt6Core.so.6
#34 0x000059f2e8a36035 in ?? ()
#35 0x0000714e6fa34e08 in ?? () from /usr/lib/libc.so.6
#36 0x0000714e6fa34ecc in __libc_start_main () from /usr/lib/libc.so.6
#37 0x000059f2e8a3c065 in ?? ()
Thread 2 (Thread 0x714e5ec006c0 (LWP 1098)):
#5 0x0000714e7023d650 in QThread::exec() () from /usr/lib/libQt6Core.so.6
#6 0x0000714e71175f0e in ?? () from /usr/lib/libQt6DBus.so.6
#7 0x0000714e702cd237 in ?? () from /usr/lib/libQt6Core.so.6
#8 0x0000714e6faa339d in ?? () from /usr/lib/libc.so.6
#9 0x0000714e6fb2849c in ?? () from /usr/lib/libc.so.6
Thread 1 (Thread 0x714e57e006c0 (LWP 1104)):
#1 0x0000714e6bc4a300 in ?? () from /usr/lib/libgallium-24.2.1-arch1.1.so
#2 0x0000714e6bcaeef4 in ?? () from /usr/lib/libgallium-24.2.1-arch1.1.so
#3 0x0000714e6bc49499 in ?? () from /usr/lib/libgallium-24.2.1-arch1.1.so
#4 0x0000714e6ba83bae in ?? () from /usr/lib/libgallium-24.2.1-arch1.1.so
#5 0x0000714e6c2a6791 in ?? () from /usr/lib/libgallium-24.2.1-arch1.1.so
#6 0x0000714e6c2aa78e in ?? () from /usr/lib/libgallium-24.2.1-arch1.1.so
#7 0x0000714e6c2ab96d in ?? () from /usr/lib/libgallium-24.2.1-arch1.1.so
#8 0x0000714e6c2e192b in ?? () from /usr/lib/libgallium-24.2.1-arch1.1.so
#9 0x0000714e6ba827a4 in ?? () from /usr/lib/libgallium-24.2.1-arch1.1.so
#10 0x0000714e6baa5bdd in ?? () from /usr/lib/libgallium-24.2.1-arch1.1.so
#11 0x0000714e6faa339d in ?? () from /usr/lib/libc.so.6
#12 0x0000714e6fb2849c in ?? () from /usr/lib/libc.so.6[/CODE]
[New LWP 1104]
[New LWP 1098]
[New LWP 1055]
[New LWP 1105]
[New LWP 1125]
[New LWP 1130]
[New LWP 1107]
[New LWP 1131]
[New LWP 1133]
[New LWP 1132]
[New LWP 3966]
[New LWP 1101]
[New LWP 3979]
[New LWP 3984]
[New LWP 1103]
[New LWP 3983]
[New LWP 3982]
[New LWP 1127]
[New LWP 3985]
[New LWP 1129]
[New LWP 3965]
[New LWP 3990]
[New LWP 3964]
[New LWP 3989]
[New LWP 3970]
[New LWP 1102]
[New LWP 1126]
[New LWP 1106]
[New LWP 3978]
[New LWP 1128]
[New LWP 3986]
