Çözüldü Arch Linux Single GPU passthrough hata
Explosive
26 Ocak 2024
Merhaba arkadaşlar Yusuf'un videosundaki Single GPU passthrough yapmaya çalışırken sonra hata aldım. Makineyi başlattığım zaman ekran kapanıyor ardından tekrar KDE kilit ekranına atıyor. Logları bırakıyorum.
[CODE title="custom_hooks.log"]08/30/2024 17:15:25 : Beginning of Startup!
1149 plasmashell.
08/30/2024 17:15:25 : Display Manager is KDE, running KDE clause!
08/30/2024 17:15:25 : Display Manager = display-manager
08/30/2024 17:15:25 : Unbinding Console 1
/usr/local/bin/vfio-startup: line 136: kill_yusuf_processes_except_ssh: command not found.
0b:00.0 VGA compatible controller [0300]: Advanced Micro Devices, Inc. [AMD/ATI] Navi 21 [Radeon RX 6800/6800 XT / 6900 XT] [1002:73bf] (rev c3)
08/30/2024 17:15:25 : System has an AMD GPU.
/usr/local/bin/vfio-startup: line 160: echo: write error: No such device.
modprobe: FATAL: Module drm_kms_helper is builtin.
modprobe: FATAL: Module drm is builtin.
08/30/2024 17:15:25 : AMD GPU Drivers Unloaded.
08/30/2024 17:15:25 : End of Startup!
08/30/2024 17:15:35 : Beginning of Teardown!
grep: /tmp/vfio-is-nvidia: No such file or directory.
08/30/2024 17:15:35 : Loading AMD GPU Drivers.
08/30/2024 17:15:35 : AMD GPU Drivers Loaded.
/usr/bin/systemctl
08/30/2024 17:15:35 : Var has been collected from file: display-manager
08/30/2024 17:15:35 : Rebinding console 1
08/30/2024 17:15:35 : End of Teardown!
[/CODE]
[CODE title="Qemu Win11 Log"]2024-08-30 13:24:53.704+0000: Starting external device: TPM Emulator.
/usr/bin/swtpm socket --ctrl type=unixio,path=/run/libvirt/qemu/swtpm/1-win11-swtpm.sock,mode=0600 --tpmstate dir=/var/lib/libvirt/swtpm/2679b72b-b24f-4e32-88ee-03bc41c931bd/tpm2,mode=0600 --log file=/var/log/swtpm/libvirt/qemu/win11-swtpm.log --terminate --tpm2
2024-08-30 13:24:53.741+0000: starting up libvirt version: 10.6.0, qemu version: 9.0.2, kernel: 6.10.6-arch1-1, hostname: archlinux.
LC_ALL=C \
PATH=/usr/local/sbin:/usr/local/bin:/usr/bin \
USER=root \
HOME=/var/lib/libvirt/qemu/domain-1-win11 \
XDG_DATA_HOME=/var/lib/libvirt/qemu/domain-1-win11/.local/share \
XDG_CACHE_HOME=/var/lib/libvirt/qemu/domain-1-win11/.cache \
XDG_CONFIG_HOME=/var/lib/libvirt/qemu/domain-1-win11/.config \
/usr/bin/qemu-system-x86_64 \
-name guest=win11,debug-threads=on \
-S \
-object '{"qom-type":"secret","id":"masterKey0","format":"raw","file":"/var/lib/libvirt/qemu/domain-1-win11/master-key.aes"}' \
-blockdev '{"driver":"file","filename":"/usr/share/edk2/x64/OVMF_CODE.secboot.fd","node-name":"libvirt-pflash0-storage","auto-read-only":true,"discard":"unmap"}' \
-blockdev '{"node-name":"libvirt-pflash0-format","read-only":true,"driver":"raw","file":"libvirt-pflash0-storage"}' \
-blockdev '{"driver":"file","filename":"/var/lib/libvirt/qemu/nvram/win11_VARS.fd","node-name":"libvirt-pflash1-storage","read-only":false}' \
-machine pc-q35-9.0,usb=off,vmport=off,smm=on,dump-guest-core=off,memory-backend=pc.ram,pflash0=libvirt-pflash0-format,pflash1=libvirt-pflash1-storage,hpet=off,acpi=on \
-accel kvm \
-cpu host,migratable=on,hv-time=on,hv-relaxed=on,hv-vapic=on,hv-spinlocks=0x1fff \
-global driver=cfi.pflash01,property=secure,value=on \
-m size=30720000k \
-object '{"qom-type":"memory-backend-ram","id":"pc.ram","size":31457280000}' \
-overcommit mem-lock=off \
-smp 12,sockets=1,dies=1,clusters=1,cores=6,threads=2 \
-uuid 2679b72b-b24f-4e32-88ee-03bc41c931bd \
-no-user-config \
-nodefaults \
-chardev socket,id=charmonitor,fd=30,server=on,wait=off \
-mon chardev=charmonitor,id=monitor,mode=control \
-rtc base=localtime,driftfix=slew \
-global kvm-pit.lost_tick_policy=delay \
-no-shutdown \
-global ICH9-LPC.disable_s3=1 \
-global ICH9-LPC.disable_s4=1 \
-boot strict=on \
-device '{"driver":"pcie-root-port","port":16,"chassis":1,"id":"pci.1","bus":"pcie.0","multifunction":true,"addr":"0x2"}' \
-device '{"driver":"pcie-root-port","port":17,"chassis":2,"id":"pci.2","bus":"pcie.0","addr":"0x2.0x1"}' \
-device '{"driver":"pcie-root-port","port":18,"chassis":3,"id":"pci.3","bus":"pcie.0","addr":"0x2.0x2"}' \
-device '{"driver":"pcie-root-port","port":19,"chassis":4,"id":"pci.4","bus":"pcie.0","addr":"0x2.0x3"}' \
-device '{"driver":"pcie-root-port","port":20,"chassis":5,"id":"pci.5","bus":"pcie.0","addr":"0x2.0x4"}' \
-device '{"driver":"pcie-root-port","port":21,"chassis":6,"id":"pci.6","bus":"pcie.0","addr":"0x2.0x5"}' \
-device '{"driver":"pcie-root-port","port":22,"chassis":7,"id":"pci.7","bus":"pcie.0","addr":"0x2.0x6"}' \
-device '{"driver":"pcie-root-port","port":23,"chassis":8,"id":"pci.8","bus":"pcie.0","addr":"0x2.0x7"}' \
-device '{"driver":"pcie-root-port","port":24,"chassis":9,"id":"pci.9","bus":"pcie.0","multifunction":true,"addr":"0x3"}' \
-device '{"driver":"pcie-root-port","port":25,"chassis":10,"id":"pci.10","bus":"pcie.0","addr":"0x3.0x1"}' \
-device '{"driver":"pcie-root-port","port":26,"chassis":11,"id":"pci.11","bus":"pcie.0","addr":"0x3.0x2"}' \
-device '{"driver":"pcie-root-port","port":27,"chassis":12,"id":"pci.12","bus":"pcie.0","addr":"0x3.0x3"}' \
-device '{"driver":"pcie-root-port","port":28,"chassis":13,"id":"pci.13","bus":"pcie.0","addr":"0x3.0x4"}' \
-device '{"driver":"pcie-root-port","port":29,"chassis":14,"id":"pci.14","bus":"pcie.0","addr":"0x3.0x5"}' \
-device '{"driver":"qemu-xhci","p2":15,"p3":15,"id":"usb","bus":"pci.2","addr":"0x0"}' \
-device '{"driver":"virtio-serial-pci","id":"virtio-serial0","bus":"pci.3","addr":"0x0"}' \
-blockdev '{"driver":"file","filename":"/var/lib/libvirt/images/win11.qcow2","node-name":"libvirt-3-storage","auto-read-only":true,"discard":"unmap","cache":{"direct":false,"no-flush":false}}' \
-blockdev '{"node-name":"libvirt-3-format","read-only":false,"discard":"unmap","cache":{"direct":false,"no-flush":false},"driver":"qcow2","file":"libvirt-3-storage","backing":null}' \
-device '{"driver":"virtio-blk-pci","bus":"pci.4","addr":"0x0","drive":"libvirt-3-format","id":"virtio-disk0","bootindex":2,"write-cache":"on"}' \
-blockdev '{"driver":"file","filename":"/home/explosive/Downloads/Win11_23H2_Turkish_x64v2.iso","node-name":"libvirt-2-storage","read-only":true}' \
-device '{"driver":"ide-cd","bus":"ide.1","drive":"libvirt-2-storage","id":"sata0-0-1","bootindex":1}' \
-blockdev '{"driver":"file","filename":"/home/explosive/Downloads/virtio-win-0.1.262.iso","node-name":"libvirt-1-storage","read-only":true}' \
-device '{"driver":"ide-cd","bus":"ide.2","drive":"libvirt-1-storage","id":"sata0-0-2","bootindex":3}' \
-netdev '{"type":"tap","fd":"31","vhost":true,"vhostfd":"35","id":"hostnet0"}' \
-device '{"driver":"virtio-net-pci","netdev":"hostnet0","id":"net0","mac":"52:54:00:a2:6b:92","bus":"pci.1","addr":"0x0"}' \
-chardev pty,id=charserial0 \
-device '{"driver":"isa-serial","chardev":"charserial0","id":"serial0","index":0}' \
-chardev spicevmc,id=charchannel0,name=vdagent \
-device '{"driver":"virtserialport","bus":"virtio-serial0.0","nr":1,"chardev":"charchannel0","id":"channel0","name":"com.redhat.spice.0"}' \
-chardev socket,id=chrtpm,path=/run/libvirt/qemu/swtpm/1-win11-swtpm.sock \
-tpmdev emulator,id=tpm-tpm0,chardev=chrtpm \
-device '{"driver":"tpm-crb","tpmdev":"tpm-tpm0","id":"tpm0"}' \
-device '{"driver":"usb-tablet","id":"input0","bus":"usb.0","port":"1"}' \
-audiodev '{"id":"audio1","driver":"spice"}' \
-spice port=5900,addr=127.0.0.1,disable-ticketing=on,image-compression=off,seamless-migration=on \
-device '{"driver":"qxl-vga","id":"video0","max_outputs":1,"ram_size":67108864,"vram_size":67108864,"vram64_size_mb":0,"vgamem_mb":16,"bus":"pcie.0","addr":"0x1"}' \
-device '{"driver":"ich9-intel-hda","id":"sound0","bus":"pcie.0","addr":"0x1b"}' \
-device '{"driver":"hda-duplex","id":"sound0-codec0","bus":"sound0.0","cad":0,"audiodev":"audio1"}' \
-global ICH9-LPC.noreboot=off \
-watchdog-action reset \
-chardev spicevmc,id=charredir0,name=usbredir \
-device '{"driver":"usb-redir","chardev":"charredir0","id":"redir0","bus":"usb.0","port":"2"}' \
-chardev spicevmc,id=charredir1,name=usbredir \
-device '{"driver":"usb-redir","chardev":"charredir1","id":"redir1","bus":"usb.0","port":"3"}' \
-device '{"driver":"virtio-balloon-pci","id":"balloon0","bus":"pci.5","addr":"0x0"}' \
-sandbox on,obsolete=deny,elevateprivileges=deny,spawn=deny,resourcecontrol=deny \
-msg timestamp=on
char device redirected to /dev/pts/1 (label charserial0)
2024-08-30T13:24:53.805454Z qemu-system-x86_64: warning: This family of AMD CPU doesn't support hyperthreading(2)
Please configure -smp options properly or try enabling topoext feature.
2024-08-30T13:27:59.137792Z qemu-system-x86_64: terminating on signal 15 from pid 3280 (/usr/bin/libvirtd)
2024-08-30 13:28:00.004+0000: shutting down, reason=shutdown
2024-08-30 13:28:00.121+0000: Starting external device: TPM Emulator.
/usr/bin/swtpm socket --ctrl type=unixio,path=/run/libvirt/qemu/swtpm/2-win11-swtpm.sock,mode=0600 --tpmstate dir=/var/lib/libvirt/swtpm/2679b72b-b24f-4e32-88ee-03bc41c931bd/tpm2,mode=0600 --log file=/var/log/swtpm/libvirt/qemu/win11-swtpm.log --terminate --tpm2
2024-08-30 13:28:00.148+0000: starting up libvirt version: 10.6.0, qemu version: 9.0.2, kernel: 6.10.6-arch1-1, hostname: archlinux.
LC_ALL=C \
USER=root \
HOME=/var/lib/libvirt/qemu/domain-2-win11 \
XDG_DATA_HOME=/var/lib/libvirt/qemu/domain-2-win11/.local/share \
XDG_CACHE_HOME=/var/lib/libvirt/qemu/domain-2-win11/.cache \
XDG_CONFIG_HOME=/var/lib/libvirt/qemu/domain-2-win11/.config \
-S \
-object '{"qom-type":"secret","id":"masterKey0","format":"raw","file":"/var/lib/libvirt/qemu/domain-2-win11/master-key.aes"}' \
-accel kvm \
-m size=30720000k \
-no-user-config \
-nodefaults \
-no-shutdown \
-boot strict=on \
-chardev socket,id=chrtpm,path=/run/libvirt/qemu/swtpm/2-win11-swtpm.sock \
-msg timestamp=on
2024-08-30T13:28:00.237081Z qemu-system-x86_64: warning: This family of AMD CPU doesn't support hyperthreading(2)
2024-08-30T13:34:29.526402Z qemu-system-x86_64: terminating on signal 15 from pid 3280 (/usr/bin/libvirtd)
2024-08-30 13:34:31.212+0000: shutting down, reason=shutdown
2024-08-30 14:15:31.385+0000: Starting external device: TPM Emulator.
2024-08-30 14:15:31.423+0000: starting up libvirt version: 10.6.0, qemu version: 9.0.2, kernel: 6.10.6-arch1-1, hostname: archlinux.
LC_ALL=C \
USER=root \
-S \
-accel kvm \
-cpu host,migratable=on,topoext=on,hv-time=on,hv-relaxed=on,hv-vapic=on,hv-spinlocks=0x1fff \
-m size=30720000k \
-display none \
-no-user-config \
-nodefaults \
-chardev socket,id=charmonitor,fd=29,server=on,wait=off \
-no-shutdown \
-boot strict=on \
-device '{"driver":"pcie-root-port","port":8,"chassis":15,"id":"pci.15","bus":"pcie.0","addr":"0x1"}' \
-netdev '{"type":"tap","fd":"31","vhost":true,"vhostfd":"34","id":"hostnet0"}' \
-audiodev '{"id":"audio1","driver":"none"}' \
-device '{"driver":"vfio-pci","host":"0000:0b:00.1","id":"hostdev0","bus":"pci.6","addr":"0x0"}' \
-device '{"driver":"vfio-pci","host":"0000:0b:00.0","id":"hostdev1","bus":"pci.7","addr":"0x0","romfile":"/var/lib/libvirt/vgabios/patched.rom"}' \
-device '{"driver":"vfio-pci","host":"0000:08:00.0","id":"hostdev2","bus":"pci.8","addr":"0x0"}' \
-device '{"driver":"vfio-pci","host":"0000:02:00.1","id":"hostdev3","bus":"pci.9","addr":"0x0"}' \
-device '{"driver":"vfio-pci","host":"0000:0d:00.1","id":"hostdev4","bus":"pci.10","addr":"0x0"}' \
-device '{"driver":"vfio-pci","host":"0000:0d:00.0","id":"hostdev5","bus":"pci.11","addr":"0x0"}' \
-device '{"driver":"vfio-pci","host":"0000:0c:00.0","id":"hostdev6","bus":"pci.12","addr":"0x0"}' \
-device '{"driver":"vfio-pci","host":"0000:0d:00.3","id":"hostdev7","bus":"pci.13","addr":"0x0"}' \
-device '{"driver":"vfio-pci","host":"0000:0d:00.4","id":"hostdev8","bus":"pci.14","addr":"0x0"}' \
-device '{"driver":"vfio-pci","host":"0000:00:03.0","id":"hostdev9","bus":"pci.15","addr":"0x0"}' \
-msg timestamp=on
char device redirected to /dev/pts/0 (label charserial0)
2024-08-30T14:15:34.684349Z qemu-system-x86_64: -device {"driver":"vfio-pci","host":"0000:0b:00.0","id":"hostdev1","bus":"pci.7","addr":"0x0","romfile":"/var/lib/libvirt/vgabios/patched.rom"}: failed to find romfile "/var/lib/libvirt/vgabios/patched.rom"
2024-08-30 14:15:34.788+0000: shutting down, reason=failed
[/CODE]
[CODE title="libvirtd.log"]2024-08-30 12:35:48.827+0000: 2976: info : libvirt version: 10.6.0
2024-08-30 12:35:48.827+0000: 2976: info : hostname: archlinux.
2024-08-30 12:35:48.827+0000: 2976: error : virConnectGetAllDomainStats:12655 : this function is not supported by the connection driver: virConnectGetAllDomainStats
2024-08-30 12:39:30.936+0000: 3970: info : libvirt version: 10.6.0
2024-08-30 12:39:30.936+0000: 3970: info : hostname: archlinux.
2024-08-30 12:39:30.936+0000: 3970: error : virConnectGetAllDomainStats:12655 : this function is not supported by the connection driver: virConnectGetAllDomainStats
2024-08-30 12:44:22.525+0000: 6079: info : libvirt version: 10.6.0
2024-08-30 12:44:22.525+0000: 6079: info : hostname: archlinux.
2024-08-30 12:44:22.525+0000: 6079: error : virConnectGetAllDomainStats:12655 : this function is not supported by the connection driver: virConnectGetAllDomainStats
2024-08-30 12:44:37.215+0000: 6129: info : libvirt version: 10.6.0
2024-08-30 12:44:37.215+0000: 6129: info : hostname: archlinux.
2024-08-30 12:44:37.215+0000: 6129: error : virConnectGetAllDomainStats:12655 : this function is not supported by the connection driver: virConnectGetAllDomainStats
2024-08-30 12:45:59.203+0000: 6783: info : libvirt version: 10.6.0
2024-08-30 12:45:59.203+0000: 6783: info : hostname: archlinux.
2024-08-30 12:45:59.203+0000: 6783: error : virConnectGetAllDomainStats:12655 : this function is not supported by the connection driver: virConnectGetAllDomainStats
2024-08-30 13:01:31.884+0000: 7661: info : libvirt version: 10.6.0
2024-08-30 13:01:31.884+0000: 7661: info : hostname: archlinux.
2024-08-30 13:01:31.884+0000: 7661: error : virConnectGetAllDomainStats:12655 : this function is not supported by the connection driver: virConnectGetAllDomainStats
2024-08-30 13:03:26.697+0000: 7979: info : libvirt version: 10.6.0
2024-08-30 13:03:26.697+0000: 7979: info : hostname: archlinux.
2024-08-30 13:03:26.697+0000: 7979: error : virConnectGetAllDomainStats:12655 : this function is not supported by the connection driver: virConnectGetAllDomainStats
2024-08-30 13:07:36.630+0000: 21366: info : libvirt version: 10.6.0
2024-08-30 13:07:36.630+0000: 21366: info : hostname: archlinux.
2024-08-30 13:07:36.630+0000: 21366: error : virConnectGetAllDomainStats:12655 : this function is not supported by the connection driver: virConnectGetAllDomainStats
2024-08-30 13:11:30.048+0000: 699: info : libvirt version: 10.6.0
2024-08-30 13:11:30.048+0000: 699: info : hostname: archlinux.
2024-08-30 13:11:30.048+0000: 699: error : virConnectGetAllDomainStats:12655 : this function is not supported by the connection driver: virConnectGetAllDomainStats
2024-08-30 13:44:53.414+0000: 701: info : libvirt version: 10.6.0
2024-08-30 13:44:53.414+0000: 701: info : hostname: archlinux.
2024-08-30 13:44:53.414+0000: 701: warning : virNetDaemonRun:873 : Make forcefull daemon shutdown.
2024-08-30 13:53:43.086+0000: 3546: info : libvirt version: 10.6.0
2024-08-30 13:53:43.086+0000: 3546: info : hostname: archlinux.
2024-08-30 13:53:43.086+0000: 3546: error : virConnectGetAllDomainStats:12655 : this function is not supported by the connection driver: virConnectGetAllDomainStats
2024-08-30 14:04:31.207+0000: 5417: info : libvirt version: 10.6.0
2024-08-30 14:04:31.207+0000: 5417: info : hostname: archlinux.
2024-08-30 14:04:31.207+0000: 5417: error : virConnectGetAllDomainStats:12655 : this function is not supported by the connection driver: virConnectGetAllDomainStats
2024-08-30 14:06:39.667+0000: 5419: error : qemuValidateDomainChrSourceDef:2041 : unsupported configuration: chardev 'spicevmc' not supported without spice graphics.
2024-08-30 14:15:25.433+0000: 5415: error : virNetSocketReadWire:1781 : End of file while reading data: Input/output error.
2024-08-30 14:15:25.447+0000: 5415: error : virNetSocketReadWire:1781 : End of file while reading data: Input/output error.
2024-08-30 14:15:34.787+0000: 6350: error : qemuMonitorIORead:396 : Unable to read from monitor: Connection reset by peer.
2024-08-30 14:15:34.788+0000: 6350: error : qemuProcessReportLogError:1929 : internal error: QEMU unexpectedly closed the monitor (vm='win11'): 2024-08-30T14:15:34.684349Z qemu-system-x86_64: -device {"driver":"vfio-pci","host":"0000:0b:00.0","id":"hostdev1","bus":"pci.7","addr":"0x0","romfile":"/var/lib/libvirt/vgabios/patched.rom"}: failed to find romfile "/var/lib/libvirt/vgabios/patched.rom"
2024-08-30 14:16:05.288+0000: 5418: error : virConnectGetAllDomainStats:12655 : this function is not supported by the connection driver: virConnectGetAllDomainStats[/CODE]
AMD GPU'lar için ROM dosyası lazım değil. ROM dosyasına erişememiş. ROM dosyasını /var/lib/libvirt/images kısmına atıp orayı deneyebilirsin ama direkt ROM'suz çalışır. Virt-manager biraz dizin seçiyor diyelim. ROM dosyasının gerçekten dizinde olduğuna ve isminin virt-manager'a yazdığınla denk olduğunu da kontrol et.
Romsuz çalışması soruna yol açar mı?
Secure Boot kapalıymış açıktır diye bakmadım 3 saat boşa uğraş
Sanal makinenin açılması için Secure Boot'a ihtiyacın yok. Kurulumda en fazla "kuramazsın" der Windows 11. Çözebildin mi problemini? sbctl'den bilgisayarındaki sertifikaları çekebilir ve sanal makinenin içine atabilirsin. Çoğu anakartın içinde Microsoft'un seritifikaları vardır.
Sorunu çözemedim, sinirlendim, sildim.
