- ASUS B550 Wi-Fi 2
- 32 GB G.Skill 3200
- Samsung 970 EVO
- Gigabyte RX 7600XT
Kod:
DRIVER_POWER_STATE_FAILURE (9F)
A driver has failed to Complete'a Power ırp within a specific time.
Arguments:
Arg1: 0000000000000003, a device object has been blocking an ırp for too long a time.
Arg2: FfffCE85E86B5D30, physical device object of the stack.
Arg3: FffFF8010AAbd7b8, NT! Trıage_9f_power on Windows 7 and higher, otherwise the functional device object of the stack.
Arg4: FfffCE85E872D460, the blocked ırp.
Debugging details:
Implicit thread is now ffffce85'e1F02080.
*** Warnıng: Unable to verify timestamp for AtihdWT6.sys
Key_values_strıng: 1
Key: Analysis. CPU. Msec.
Value: 22250.
Key: Analysis. Elapsed. Msec.
Value: 171370.
Key: Analysis. IO. Other. MB.
Value: 4
Key: Analysis. IO. Read. MB.
Value: 0
Key: Analysis. IO. Write. MB.
Value: 42.
Key: Analysis. Init. CPU. Msec.
Value: 4093.
Key: Analysis. Init. Elapsed. Msec.
Value: 39997.
Key: Analysis. Memory.commitpeak. MB.
Value: 109.
Key: Analysis. Version. Dbgeng.
Value: 10.0.27704.1001
Key: Analysis. Version. Description.
Value: 10.2408.27.01 AMD64fre.
Key: Analysis. Version. Ext.
Value: 1.2408.27.1
Key: Bugcheck. Code. Legacyapı.
Value: 0x9f.
Key: Bugcheck. Code. Targetmodel.
Value: 0x9f.
Key: Dump. Attributes. Asulong.
Value: 1008.
Key: Dump. Attributes. Diagdatawrittentoheader
Value: 1
Key: Dump. Attributes. Errorcode.
Value: 0
Key: Dump. Attributes. Kernelgeneratedtriagedump
Value: 1
Key: Dump. Attributes. Lastline.
Key: Dump. Attributes. Progresspercentage.
Value: 0
Key: Failure. Bucket.
Value: 0x9F_3_HDAudBus!HdaController::TransferCodecVerbs
Key: Failure. Hash.
Value: {D537D977-4D49-4313-8130-09CC882BD617}
Bugcheck_code: 9F.
Bugcheck_p1: 3
Bugcheck_p2: FfffCE85E86B5D30.
Bugcheck_p3: FffFF8010AAbd7b8.
Bugcheck_p4: FfffCE85E872D460.
Fıle_ın_cab: 101324-8265-01.dmp
Dump_fıle_attrıbutes: 0x1008.
Kernel generated triage dump.
Faultıng_thread: FfffCE85E1F02080.
Drvpowerstate_subcode: 3
Blackboxbsd: 1 (!blackboxbsd)
Blackboxntfs: 1 (!blackboxntfs)
Blackboxpnp: 1 (!blackboxpnp)
Blackboxwınlogon: 1
Customer_crash_count: 1
Process_name: System.
Stack_text:
Ffffbb89'30e1e8e0 fffff801'0D6201A5: Fffff801'09831180 00000000'00000000 fffff801'0E14D700 00000000'00000000: NT! Kiswapcontext+0x76
Ffffbb89'30e1EA20 fffff801'0D6215C7: 00000000'00000000 00000000'00000000 ffff516D'13ecde87 00000000'00000000: NT! Kiswapthread+0xaa5
Ffffbb89'30e1eb70 fffff801'0D6810C6: 00000000'00000000 00000000'00000001 00000000'00000000 00000000'00000000: NT! Kicommitthreadwait+0x137
Ffffbb89'30e1ec20 fffff801'40ba29bd: Ffffce85'E87af000 ffffce85'E87af000 00000000'00000001 ffffce85'F2F89b00: NT! Kewaitforsingleobject+0x256
Ffffbb89'30e1efc0 fffff801'40ba27C2: Ffffce85'E87af000 ffffce85'E87af000 00000000'ffffffff fffff801'0D6685B9: Hdaudbus! Hdacontroller: Transfercodecverbs+0x17D
Ffffbb89'30e1F060 fffff801'39454904: 00000000'00000110 ffffce85'E86ca310 00000000'00000000 ffffce85'E82da310: Hdaudbus! Hdabusınterface: Transfercodecverbs+0x202
Ffffbb89'30e1F110 00000000'00000110: Ffffce85'E86ca310 00000000'00000000 ffffce85'E82da310 00000000'00000000: Atihdwt6+0x4904
Ffffbb89'30e1F118 ffffce85'E86ca310: 00000000'00000000 ffffce85'E82da310 00000000'00000000 00000000'00000001: 0x110.
Ffffbb89'30e1F120 00000000'00000000: Ffffce85'E82da310 00000000'00000000 00000000'00000001 ffffce85'00170530: 0xffffce85`e86ca310
Symbol_name: Hdaudbus! Hdacontroller: Transfercodecverbs+17D
Module_name: Hdaudbus.
Image_name: HDAudBus.sys
Image_versıon: 10.0.22621.4034
Stack_command: Process /r /p 0xffffce85e1eff040;.thread 0xffffce85e1f02080; KB.
Bucket_ıd_func_offset: 17D.
Faılure_bucket_ıd: 0x9F_3_HDAudBus!HdaController::TransferCodecVerbs
Osplatform_type: X64.
Osname: Windows 10.
Faılure_ıd_hash: {D537D977-4D49-4313-8130-09CC882BD617}
Hdaudbustext.
Audstart end module name.
Fffff801'40ba0000 fffff801'40bcf000 hdaudbus # (pdb symbols) C:\ProgramData\Dbg\sym\hdaudbus.pdb\011784EFCF9AEF289D6A5DA6C892E59E1\hdaudbus.pdb
Loaded symbol image file: HDAudBus.sys
Mapped Memory image file: C:\ProgramData\Dbg\sym\HDAudBus.sys\4D2452062f000\HDAudBus.sys
Image path: HDAudBus.sys
Image name: HDAudBus.sys
Browse all global symbols functions data symbol reload.
Image was built with /brepro flag.
Timestamp: 4D245206 (this is a reproducible Build file hash, not a timestamp)
Checksum: 0002F7A4.
Imagesize: 0002F000.
File version: 10.0.22621.4034
Product version: 10.0.22621.4034
File flags: 0 (mask 3F)
File OS: 40004 NT Win32.
File type: 3.9 driver.
File date: 00000000.00000000
Translations: 0409.04b0
Information from resource tables:
Companyname: Microsoft Corporation.
Productname: Microsoft® windows® operating System.
Internalname: hdaudbus.sys
Originalfilename: hdaudbus.sys
Productversion: 10.0.22621.4034
Fileversion: 10.0.22621.4034 (winbuild.160101.0800)
Filedescription: High Definition Audio bus driver.
Legalcopyright: © Microsoft Corporation. All rights reserved.
Blackboxntfs.
Kd>!blackboxntfs
NTFS blackbox data.
0 Slow I/O timeout records found.
0 oplock break timeout records found.
Blackboxbsd.
0: Kd>!blackboxbsd
Version: 0xc0.
Product type: 1
Auto Advanced boot: False.
Advanced boot menu timeout: 30.
Last boot succeeded: True.
Last boot shutdown: False.
Sleep in progress: False.
Power button timestamp: 0x0.
System running: True.
Connected standby in progress: False.
User shutdown in progress: False.
System shutdown in progress: False.
Sleep in progress: 0
Connected standby scenario instance ID: 0
Connected standby entry reason: 20.
Connected standby exit reason: 1
System sleep transitions to on: 17.
Last reference time: 0x1db1d752dbebbcb.
2024-10-13t13:38:25.341Z
Last reference time checksum: 0x24d94a2d.
Last Update boot ID: 29.
Boot attempt count: 1
Last boot checkpoint: True.
Checksum: 0x86.
Last boot ID: 29.
Last successful shutdown boot ID: 28.
Last reported abnormal shutdown boot ID: 28.
Error info boot ID: 0
Error info repeat count: 0
Error info other error count: 0
Error info code: 0
Error info status: 0x0.
Power button last press time: 0x0.
Power button cumulative press count: 0
Power button last press boot ID: 0
Power button last Power watchdog stage: 0
Power button watchdog armed: False.
Power button shutdown in progress: False.
Power button last release time: 0x0.
Power button cumulative release count: 0
Power button last release boot ID: 0
Power button error count: 0
Power button current connected standby phase: 0
Power button transition latest checkpoint ID: 0
Power button transition latest checkpoint type: 0
Power button transition latest checkpoint sequence number: 0
Power transition shutdown device type: 255.
Power transition setup ın progress: False.
Power transition OOBE'ın progress: False.
Power transition sleep checkpoint Source: 0
Power transition sleep checkpoint: 16.
Power transition connected standby entry reason category: 0
Power transition connected standby exit reason category: 0
Power transition connected standby entry scenario ınstance ID: 0x5c.
Blackboxpnp.
Pnpactivityıd: {00000000-0000-0000-0000-000000000000}
Pnpactivitytime: 133733127676427992.
Pnpeventınformation: 3
Pnpeventınprogress: 0
Pnpproblemcode: 24.
Pnpvetotype: 0
Deviceıd: SWD\MMDEVAPI\{0.0.0.00000000}.{55fb9a46-7e49-473f-8715-fee6e8845076}
Vetostring:
101324-8265-01
DMP dosyası.
