rpmb 53
1 Ocak 2024
4 GB DDR3 RAM'im var. Para da çok yok. İkinci bir 4 GB almak istiyorum ama aynı RAM'den bulamayacağıma eminim. Farklı markaları stabil bir şekilde kullanmanın bir yolu yok mu? 1333 MHz'de olsa ikisi de mesela?
PassMark RAMMon raporu. Buradaki değerlerin hangilerinin aynı olması gerekir mesela?
RAMMon v3.4 Build: 1000 built with SysInfo v3.3 Build: 1000
PassMark (R) Software - www.passmark.com
Memory settings
Transfer rate 1334 MT/s
Memory timings 9-9-9-24
Channel mode 1
Memory capacity / benchmarks
L1 cache 64 KB (83.5 GB/s)
L2 cache 256 KB (44.7 GB/s)
L3 cache 6144 KB (10.5 GB/s)
Physical RAM (7038 MB/s)
Latency 44.862 ns
Memory SPD information​
ItemSlot #1Slot #2Slot #3Slot #4
Ram Type DDR3 Not Populated Not Populated Not Populated
Maximum Clock Speed (MHz) 667 (JEDEC)
Maximum Transfer Speed (MT/s) DDR3-1333
Maximum Bandwidth (MB/s) PC3-10600
Memory Capacity (MB) 4096
DIMM Temperature N/A
Jedec Manufacture Name
Search Amazon.com Search!
SPD Revision 1.0
Registered No
ECC No
On-Die ECC No
DIMM Slot # 1
Manufactured Week 8 of Year 2012
Module Part #
Module Revision 0x0
Module Serial # 00000000 (000000120800000000)
Module Manufacturing Location 0
# of Row Addressing Bits 15
# of Column Addressing Bits 10
# of Banks 8
# of Ranks 2
Device Width in Bits 8
Bus Width in Bits 64
Module Voltage 1.5V
CAS Latencies Supported 5 6 7 8 9 10
Timings @ Max Frequency (JEDEC) 9-9-9-24
Maximum frequency (MHz) 667
Minimum Clock Cycle Time, tCK (ns) 1.500
Minimum CAS Latency Time, tAA (ns) 13.125
Minimum RAS to CAS Delay, tRCD (ns) 13.125
Minimum Row Precharge Time, tRP (ns) 13.125
Minimum Active to Precharge Time, tRAS (ns) 36.000
Minimum Row Active to Row Active Delay, tRRD (ns) 6.000
Minimum Auto-Refresh to Active/Auto-Refresh Time, tRC (ns) 49.125
Minimum Auto-Refresh to Active/Auto-Refresh Command Period, tRFC (ns) 160.000
DDR3 Specific SPD Attributes
Write Recovery Time, tWR (ns) 15.000
Internal Write to Read Command Delay, tWTR (ns) 7.500
Internal Read to Precharge Command Delay, tRTP (ns) 7.500
Minimum Four Activate Window Delay, tFAW (ns) 30.000
Maximum Activate Window in units of tREFI 0
RZQ / 6 Supported No
RZQ / 7 Supported Yes
DLL-Off Mode Supported Yes
Maximum Operating Temperature Range (C) 0-95
Refresh Rate at Extended Operating Temperature Range 2X
Auto-self Refresh Supported Yes
On-die Thermal Sensor Readout Supported No
Partial Array Self Refresh Supported No
Thermal Sensor Present No
Non-standard SDRAM Type Standard Monolithic
Maxium Activate Count (MAC)
Module Type UDIMM
Module Height (mm) 30
Module Thickness (front), (mm) 2
Module Thickness (back), (mm) 2
Module Width (mm) 133.5
Reference Raw Card Used Raw Card B Rev. 0
DRAM Manufacture
DDR5 kadar önemli değil. Zamanında ben de çok kullandım. Bir sorun yaşamadım. Düz açıp kullanınca pek bir sorunla karşılaşılmıyor.
