System:
Kernel: 5.15.0-107-generic x86_64 bits: 64 compiler: gcc v: 11.4.0 Desktop: Cinnamon 6.0.4
tk: GTK 3.24.33 wm: muffin vt: 7 dm: LightDM 1.30.0 Distro: Linux Mint 21.3 Virginia
base: Ubuntu 22.04 jammy
Machine:
Type: Desktop System: Gigabyte product: N/A v: N/A serial: <superuser required> Chassis: type: 3
Mobo: Gigabyte model: 970A-DS3P serial: <superuser required> UEFI: American Megatrends v: F2j
date: 12/29/2014
CPU:
Info: 6-core model: AMD FX-6300 bits: 64 type: MT MCP smt: enabled arch: Piledriver rev: 0
cache: L1: 288 KiB L2: 6 MiB L3: 8 MiB
Speed (MHz): avg: 2756 high: 3926 min/max: 1400/3500 boost: enabled cores: 1: 1406 2: 1406
3: 3817 4: 3926 5: 2511 6: 3471 bogomips: 42192
Flags: avx ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm
Graphics:
Device-1: NVIDIA GF108 [GeForce GT 730] vendor: ASUSTeK driver: nouveau v: kernel pcie:
speed: 2.5 GT/s lanes: 16 ports: active: DVI-I-1 off: VGA-1 empty: HDMI-A-1 bus-ID: 01:00.0
chip-ID: 10de:0f02 class-ID: 0300
Display: x11 server: X.Org v: 1.21.1.4 driver: X: loaded: modesetting unloaded: fbdev,vesa
gpu: nouveau display-ID: :0 screens: 1
Screen-1: 0 s-res: 1920x1080 s-dpi: 96 s-size: 508x286mm (20.0x11.3") s-diag: 583mm (23")
Monitor-1: DVI-I-1 model: Asus VS228 serial: <filter> res: 1920x1080 hz: 60 dpi: 102
size: 476x268mm (18.7x10.6") diag: 546mm (21.5") modes: max: 1920x1080 min: 720x400
OpenGL: renderer: NVC1 v: 4.3 Mesa 23.2.1-1ubuntu3.1~22.04.2 direct render: Yes
Audio:
Device-1: AMD SBx00 Azalia vendor: Gigabyte driver: snd_hda_intel v: kernel bus-ID: 00:14.2
chip-ID: 1002:4383 class-ID: 0403
Device-2: NVIDIA GF108 High Definition Audio vendor: ASUSTeK driver: snd_hda_intel v: kernel
pcie: speed: 2.5 GT/s lanes: 16 bus-ID: 01:00.1 chip-ID: 10de:0bea class-ID: 0403
Device-3: Texas Instruments PCM2902 Audio Codec type: USB
driver: hid-generic,snd-usb-audio,usbhid bus-ID: 4-2:3 chip-ID: 08bb:2902 class-ID: 0300
Device-4: Razer USA Seiren Mini type: USB driver: hid-generic,snd-usb-audio,usbhid
bus-ID: 5-1:2 chip-ID: 1532:0531 class-ID: 0300 serial: <filter>
Sound Server-1: ALSA v: k5.15.0-107-generic running: yes
Sound Server-2: JACK v: 1.9.20 running: no
Sound Server-3: PulseAudio v: 15.99.1 running: yes
Sound Server-4: PipeWire v: 0.3.48 running: yes
Network:
Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: Gigabyte driver: r8169
v: kernel pcie: speed: 2.5 GT/s lanes: 1 port: d000 bus-ID: 03:00.0 chip-ID: 10ec:8168
class-ID: 0200
IF: enp3s0 state: up speed: 100 Mbps duplex: full mac: <filter>
IF-ID-1: docker0 state: down mac: <filter>
Drives:
Local Storage: total: 931.51 GiB used: 159.54 GiB (17.1%)
ID-1: /dev/sda vendor: Western Digital model: WD10EALX-009BA0 size: 931.51 GiB speed: 3.0 Gb/s
type: HDD rpm: 7200 serial: <filter> rev: 0C10 scheme: GPT
Partition:
ID-1: / size: 382.82 GiB used: 88.79 GiB (23.2%) fs: ext3 dev: /dev/sda3
ID-2: /boot/efi size: 96 MiB used: 31.1 MiB (32.4%) fs: vfat dev: /dev/sda1
Swap:
ID-1: swap-1 type: file size: 2 GiB used: 0 KiB (0.0%) priority: -2 file: /swapfile
USB:
Hub-1: 1-0:1 info: Full speed or root hub ports: 5 rev: 2.0 speed: 480 Mb/s chip-ID: 1d6b:0002
class-ID: 0900
Hub-2: 2-0:1 info: Full speed or root hub ports: 5 rev: 2.0 speed: 480 Mb/s chip-ID: 1d6b:0002
class-ID: 0900
Hub-3: 3-0:1 info: Full speed or root hub ports: 4 rev: 2.0 speed: 480 Mb/s chip-ID: 1d6b:0002
class-ID: 0900
Hub-4: 4-0:1 info: Full speed or root hub ports: 5 rev: 1.1 speed: 12 Mb/s chip-ID: 1d6b:0001
class-ID: 0900
Device-1: 4-1:2 info: Pixart Imaging Optical Mouse type: Mouse driver: hid-generic,usbhid
interfaces: 1 rev: 2.0 speed: 1.5 Mb/s power: 100mA chip-ID: 093a:2510 class-ID: 0301
Device-2: 4-2:3 info: Texas Instruments PCM2902 Audio Codec type: Audio,HID
driver: hid-generic,snd-usb-audio,usbhid interfaces: 4 rev: 1.1 speed: 12 Mb/s power: 100mA
Hub-5: 5-0:1 info: Full speed or root hub ports: 5 rev: 1.1 speed: 12 Mb/s chip-ID: 1d6b:0001
class-ID: 0900
Device-1: 5-1:2 info: Razer USA Seiren Mini type: Audio,HID
driver: hid-generic,snd-usb-audio,usbhid interfaces: 3 rev: 1.1 speed: 12 Mb/s power: 100mA
Hub-6: 6-0:1 info: Full speed or root hub ports: 2 rev: 1.1 speed: 12 Mb/s chip-ID: 1d6b:0001
class-ID: 0900
Hub-7: 7-0:1 info: Full speed or root hub ports: 4 rev: 1.1 speed: 12 Mb/s chip-ID: 1d6b:0001
class-ID: 0900
Device-1: 7-4:2 info: Maxxter Wireless Receiver type: Mouse,Keyboard
driver: hid-generic,usbhid interfaces: 2 rev: 1.1 speed: 12 Mb/s power: 50mA chip-ID: 248a:00da
class-ID: 0301
Sensors:
System Temperatures: cpu: 51.8 C mobo: N/A gpu: nouveau temp: 40.0 C
Fan Speeds (RPM): N/A
Repos:
Packages: 3363 apt: 3338 flatpak: 25
Info:
Processes: 295 Uptime: 11m wakeups: 0 Memory: 7.72 GiB used: 3.37 GiB (43.6%) Init: systemd
v: 249 runlevel: 5 Compilers: gcc: 11.4.0 alt: 11/12 clang: 14.0.0-1ubuntu1.1 Client: Cinnamon
v: 6.0.4 inxi: 3.3.13
Sistem bu kadar.
