jjEnes
5 Şubat 2024
1.5 aylık laptopumda aşağıdaki mavi ekran hatasını aldım, ne yapmam lazım? Çözümü nedir? Yardımcı olursanız sevinirim.
Sorun çözüldü mü? Çözülmedi ise servise yollamanda fayda var:
Kod:
DPC_WATCHDOG_VIOLATION (133)
The DPC watchdog detected a prolonged run time at an IRQL of DISPATCH_LEVEL
or above.
Arguments:
Arg1: 0000000000000001, The system cumulatively spent an extended period of time at
    DISPATCH_LEVEL or above.
Arg2: 0000000000001e00, The watchdog period (in ticks).
Arg3: fffff8017631c340, cast to nt!DPC_WATCHDOG_GLOBAL_TRIAGE_BLOCK, which contains
    additional information regarding the cumulative timeout
Arg4: 0000000000000000
Debugging Details:
***    Either you specified an unqualified symbol, or your debugger   ***
***    doesn't have full symbol information.  Unqualified symbol      ***
***    resolution is turned off by default. Please either specify a   ***
***    fully qualified symbol module!symbolname, or enable resolution ***
***    of unqualified symbols by typing ".symopt- 100". Note that     ***
***    enabling unqualified symbol resolution with network symbol     ***
***    server shares in the symbol path may cause the debugger to     ***
***    appear to hang for long periods of time when an incorrect      ***
***    symbol name is typed or the network symbol server is down.     ***
***    For some commands to work properly, your symbol path           ***
***    must point to .pdb files that have full type information.      ***
***    Certain .pdb files (such as the public OS symbols) do not      ***
***    contain the required information.  Contact the group that      ***
***    provided you with these symbols if you need this command to    ***
***    work.                                                          ***
***    Type referenced: TickPeriods                                   ***
KEY_VALUES_STRING: 1
    Key  : Analysis.CPU.mSec
    Value: 3312
    Key  : Analysis.Elapsed.mSec
    Value: 6515
    Key  : Analysis.IO.Other.Mb
    Value: 5
    Key  : Analysis.IO.Read.Mb
    Value: 10
    Key  : Analysis.IO.Write.Mb
    Value: 20
    Key  : Analysis.Init.CPU.mSec
    Value: 1187
    Value: 13413
    Value: 98
    Value: 0x133
    Key  : Failure.Bucket
    Value: 0x133_ISR_amdgpio2!unknown_function
    Key  : Failure.Hash
    Value: {d434f6b1-29cd-b7b6-5f14-790f39050aff}
    Key  : Hypervisor.Enlightenments.ValueHex
    Value: 1497cf94
    Key  : Hypervisor.Flags.AnyHypervisorPresent
    Value: 1
    Key  : Hypervisor.Flags.ApicEnlightened
    Value: 1
    Key  : Hypervisor.Flags.ApicVirtualizationAvailable
    Value: 0
    Key  : Hypervisor.Flags.AsyncMemoryHint
    Value: 0
    Key  : Hypervisor.Flags.CoreSchedulerRequested
    Value: 0
    Key  : Hypervisor.Flags.CpuManager
    Value: 1
    Key  : Hypervisor.Flags.DeprecateAutoEoi
    Value: 0
    Key  : Hypervisor.Flags.DynamicCpuDisabled
    Value: 1
    Key  : Hypervisor.Flags.Epf
    Value: 0
    Key  : Hypervisor.Flags.ExtendedProcessorMasks
    Value: 1
    Key  : Hypervisor.Flags.HardwareMbecAvailable
    Value: 1
    Key  : Hypervisor.Flags.MaxBankNumber
    Value: 0
    Key  : Hypervisor.Flags.MemoryZeroingControl
    Value: 0
    Key  : Hypervisor.Flags.NoExtendedRangeFlush
    Value: 0
    Key  : Hypervisor.Flags.NoNonArchCoreSharing
    Value: 1
    Key  : Hypervisor.Flags.Phase0InitDone
    Value: 1
    Key  : Hypervisor.Flags.PowerSchedulerQos
    Value: 0
    Key  : Hypervisor.Flags.RootScheduler
    Value: 0
    Key  : Hypervisor.Flags.SynicAvailable
    Value: 1
    Key  : Hypervisor.Flags.UseQpcBias
    Value: 0
    Key  : Hypervisor.Flags.Value
    Value: 4853999
    Key  : Hypervisor.Flags.ValueHex
    Value: 4a10ef
    Key  : Hypervisor.Flags.VpAssistPage
    Value: 1
    Key  : Hypervisor.Flags.VsmAvailable
    Value: 1
    Key  : Hypervisor.RootFlags.AccessStats
    Value: 1
    Key  : Hypervisor.RootFlags.CrashdumpEnlightened
    Value: 1
    Key  : Hypervisor.RootFlags.CreateVirtualProcessor
    Value: 1
    Key  : Hypervisor.RootFlags.DisableHyperthreading
    Value: 0
    Key  : Hypervisor.RootFlags.HostTimelineSync
    Value: 1
    Key  : Hypervisor.RootFlags.HypervisorDebuggingEnabled
    Value: 0
    Key  : Hypervisor.RootFlags.IsHyperV
    Value: 1
    Key  : Hypervisor.RootFlags.LivedumpEnlightened
    Value: 1
    Key  : Hypervisor.RootFlags.MapDeviceInterrupt
    Value: 1
    Key  : Hypervisor.RootFlags.MceEnlightened
    Value: 1
    Key  : Hypervisor.RootFlags.Nested
    Value: 0
    Key  : Hypervisor.RootFlags.StartLogicalProcessor
    Value: 1
    Key  : Hypervisor.RootFlags.Value
    Value: 1015
    Key  : Hypervisor.RootFlags.ValueHex
    Value: 3f7
    Key  : WER.OS.Branch
    Value: ni_release
    Key  : WER.OS.Version
    Value: 10.0.22621.1
BUGCHECK_CODE:  133
BUGCHECK_P1: 1
BUGCHECK_P2: 1e00
BUGCHECK_P3: fffff8017631c340
BUGCHECK_P4: 0
FILE_IN_CAB:  021524-14140-01.dmp
TAG_NOT_DEFINED_202b:  *** Unknown TAG in analysis list 202b
DPC_TIMEOUT_TYPE:  DPC_QUEUE_EXECUTION_TIMEOUT_EXCEEDED
TRAP_FRAME:  fffff801724aaad0 -- (.trap 0xfffff801724aaad0)
NOTE: The trap frame does not contain all registers.
Some register values may be zeroed or incorrect.
rax=0000000000000000 rbx=0000000000000000 rcx=ffff9000978ea520
rdx=0000000000000002 rsi=0000000000000000 rdi=0000000000000000
rip=fffff801ccca2935 rsp=fffff801724aac60 rbp=0000000000000003
 r8=0000000000000008  r9=0000000000000094 r10=0000fffff801ccca
r11=fffff801724aac58 r12=0000000000000000 r13=0000000000000000
r14=0000000000000000 r15=0000000000000000
iopl=0         nv up ei ng nz ac po cy
amdgpio2+0x2935:
fffff801`ccca2935 4c8d0564280000  lea     r8,[amdgpio2+0x51a0 (fffff801`ccca51a0)]
Resetting default scope
BLACKBOXBSD: 1 (!blackboxbsd)
BLACKBOXPNP: 1 (!blackboxpnp)
BLACKBOXWINLOGON: 1
CUSTOMER_CRASH_COUNT:  1
PROCESS_NAME:  System
STACK_TEXT:
fffff801`724aa4b8 fffff801`75812bb9     : 00000000`00000133 00000000`00000001 00000000`00001e00 fffff801`7631c340 : nt!KeBugCheckEx
fffff801`724aa4c0 fffff801`75812421     : 00001508`022115bd 00000000`00000000 00000000`00423216 00000000`00000000 : nt!KeAccumulateTicks+0x239
fffff801`724aa520 fffff801`7580fa2f     : 00000000`0000000c 00000000`00001388 00000000`00423201 00000000`002774a8 : nt!KiUpdateRunTime+0xd1
fffff801`724aa6d0 fffff801`75810618     : 00000000`00000000 ffff9000`a28c3b00 fffff801`7213d180 00000000`00000000 : nt!KiUpdateTime+0x63f
fffff801`724aa970 fffff801`7580feda     : fffff801`7625fe50 ffff9000`a28c3bf0 ffff9000`a28c3bf0 00000000`00000000 : nt!KeClockInterruptNotify+0x228
fffff801`724aaa10 fffff801`75924cdc     : 0000009d`d39afc22 fffff801`7630d4f0 fffff801`7630d5a0 fffff801`7213d180 : nt!HalpTimerClockInterrupt+0x10a
fffff801`724aaa40 fffff801`75a18dea     : fffff801`724aab50 fffff801`7630d4f0 00000000`10042a00 00000000`00423216 : nt!KiCallInterruptServiceRoutine+0x9c
fffff801`724aaa80 fffff801`75a19697     : 0000009d`d368eac3 00000000`00000000 00000000`00000000 00000000`00000000 : nt!KiInterruptSubDispatchNoLockNoEtw+0xfa
fffff801`724aaad0 fffff801`ccca2935     : 00000000`0002625f 00000000`0002625f fffff801`ccca51a0 00000000`fed81500 : nt!KiInterruptDispatchNoLockNoEtw+0x37
fffff801`724aac60 00000000`0002625f     : 00000000`0002625f fffff801`ccca51a0 00000000`fed81500 00000000`000002f8 : amdgpio2+0x2935
fffff801`724aac68 00000000`0002625f     : fffff801`ccca51a0 00000000`fed81500 00000000`000002f8 00000000`00200004 : 0x2625f
fffff801`724aac70 fffff801`ccca51a0     : 00000000`fed81500 00000000`000002f8 00000000`00200004 00000000`00000001 : 0x2625f
fffff801`724aac78 00000000`fed81500     : 00000000`000002f8 00000000`00200004 00000000`00000001 fffff801`75810647 : amdgpio2+0x51a0
fffff801`724aac80 00000000`000002f8     : 00000000`00200004 00000000`00000001 fffff801`75810647 00000002`00000000 : 0xfed81500
fffff801`724aac88 00000000`00200004     : 00000000`00000001 fffff801`75810647 00000002`00000000 00200004`7580bfc3 : 0x2f8
fffff801`724aac90 00000000`00000001     : fffff801`75810647 00000002`00000000 00200004`7580bfc3 00000000`00c50000 : 0x200004
fffff801`724aac98 fffff801`75810647     : 00000002`00000000 00200004`7580bfc3 00000000`00c50000 6c400000`0104010d : 0x1
fffff801`724aaca0 fffff801`00200004     : 00000000`00000002 fffff801`7587b379 00000000`00000028 fffff801`724aae68 : nt!KeClockInterruptNotify+0x257
fffff801`724aad40 00000000`00000002     : fffff801`7587b379 00000000`00000028 fffff801`724aae68 00000000`00000000 : 0xfffff801`00200004
fffff801`724aad48 fffff801`7587b379     : 00000000`00000028 fffff801`724aae68 00000000`00000000 6c400000`0104010d : 0x2
fffff801`724aad50 fffff801`7587b730     : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!EtwpReserveTraceBuffer+0x309
fffff801`724aae10 00000000`00000001     : fffff801`00000000 fffff801`00000005 ffffc408`f2817cf8 fffff801`cccc24e1 : nt!EtwpLogKernelEvent+0x2b0
fffff801`724aaec0 fffff801`00000000     : fffff801`00000005 ffffc408`f2817cf8 fffff801`cccc24e1 ffffc408`f2817bb0 : 0x1
fffff801`724aaec8 fffff801`00000005     : ffffc408`f2817cf8 fffff801`cccc24e1 ffffc408`f2817bb0 00000000`00400a02 : 0xfffff801`00000000
fffff801`724aaed0 ffffc408`f2817cf8     : fffff801`cccc24e1 ffffc408`f2817bb0 00000000`00400a02 ffffc408`ec9ca040 : 0xfffff801`00000005
fffff801`724aaed8 fffff801`cccc24e1     : ffffc408`f2817bb0 00000000`00400a02 ffffc408`ec9ca040 fffff801`758750ca : 0xffffc408`f2817cf8
fffff801`724aaee0 fffff801`783c9173     : 00000000`0000000c ffff5657`2b7b1204 fffff801`7626afc0 fffff801`7626bcf8 : msgpioclx!GpioClxEvtInterruptIsr+0x31
fffff801`724aaf10 fffff801`75924dad     : ffff9000`a28c3b40 fffff801`758b8bcc ffffa100`fc44f700 ffff9000`a28c3b40 : Wdf01000!FxInterrupt::_InterruptThunk+0x73 [minkernel\wdf\framework\shared\irphandlers\pnp\km\interruptobjectkm.cpp @ 369]
fffff801`724aaf50 fffff801`75a18b6f     : ffffa100`fc44f5a0 ffff9000`a28c3b40 00000000`00000000 fffff801`75a18dea : nt!KiCallInterruptServiceRoutine+0x16d
fffff801`724aaf90 fffff801`75a18e37     : ffffa100`fc44f5a0 fffff801`7626afc0 ffffa100`fc44f800 ffffa100`fc44f700 : nt!KiInterruptSubDispatch+0x11f
ffffa100`fc44f520 00000000`00000000     : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!KiInterruptDispatch+0x37
SYMBOL_NAME:  amdgpio2+2935
MODULE_NAME: amdgpio2
IMAGE_NAME:  amdgpio2.sys
STACK_COMMAND:  .cxr; .ecxr ; kb
BUCKET_ID_FUNC_OFFSET:  2935
FAILURE_BUCKET_ID:  0x133_ISR_amdgpio2!unknown_function
OS_VERSION:  10.0.22621.1
BUILDLAB_STR:  ni_release
OSPLATFORM_TYPE:  x64
OSNAME:  Windows 10
FAILURE_ID_HASH:  {d434f6b1-29cd-b7b6-5f14-790f39050aff}
Kod:
The DPC watchdog detected a prolonged run time at an IRQL of DISPATCH_LEVEL.
or above.
Arguments:
Arg1: 0000000000000001, The system cumulatively spent an extended period of time at.
Arg3: fffff8017631c340, cast to nt!DPC_WATCHDOG_GLOBAL_TRIAGE_BLOCK, which contains.
 additional information regarding the cumulative timeout.
Arg4: 0000000000000000.
Debugging Details:
*** work. ***
 Value: 3312.
 Value: 6515.
 Value: 5
 Value: 10.
 Value: 20.
 Value: 1187.
 Value: 13413.
 Value: 98.
 Value: 0x133.
 Key : Failure.Hash
 Value: 1497cf94.
 Value: 1
 Value: 1
 Value: 0
 Value: 0
 Value: 0
 Value: 1
 Value: 0
 Value: 1
 Value: 0
 Value: 1
 Value: 1
 Value: 0
 Value: 0
 Value: 0
 Value: 1
 Value: 1
 Value: 0
 Value: 0
 Value: 1
 Value: 0
 Value: 4853999.
 Value: 4a10ef.
 Value: 1
 Value: 1
 Value: 1
 Value: 1
 Value: 1
 Value: 0
 Value: 1
 Value: 0
 Value: 1
 Value: 1
 Value: 1
 Value: 1
 Value: 0
 Value: 1
 Value: 1015.
 Value: 3f7.
 Key : WER.OS.Branch
 Value: ni_release.
 Value: 10.0.22621.1
BUGCHECK_CODE: 133.
BUGCHECK_P1: 1
BUGCHECK_P2: 1e00.
BUGCHECK_P3: fffff8017631c340.
BUGCHECK_P4: 0
TAG_NOT_DEFINED_202b: *** Unknown TAG in analysis list 202b.
iopl=0 nv up ei ng nz ac po cy.
amdgpio2+0x2935:
Resetting default scope.
BLACKBOXWINLOGON: 1
PROCESS_NAME: System.
STACK_TEXT:
fffff801`724aac68 00000000`0002625f : fffff801`ccca51a0 00000000`fed81500 00000000`000002f8 00000000`00200004 : 0x2625f.
fffff801`724aac70 fffff801`ccca51a0 : 00000000`fed81500 00000000`000002f8 00000000`00200004 00000000`00000001 : 0x2625f.
fffff801`724aac80 00000000`000002f8 : 00000000`00200004 00000000`00000001 fffff801`75810647 00000002`00000000 : 0xfed81500.
fffff801`724aac88 00000000`00200004 : 00000000`00000001 fffff801`75810647 00000002`00000000 00200004`7580bfc3 : 0x2f8.
fffff801`724aac90 00000000`00000001 : fffff801`75810647 00000002`00000000 00200004`7580bfc3 00000000`00c50000 : 0x200004.
fffff801`724aac98 fffff801`75810647 : 00000002`00000000 00200004`7580bfc3 00000000`00c50000 6c400000`0104010d : 0x1.
fffff801`724aad48 fffff801`7587b379 : 00000000`00000028 fffff801`724aae68 00000000`00000000 6c400000`0104010d : 0x2.
fffff801`724aaec0 fffff801`00000000 : fffff801`00000005 ffffc408`f2817cf8 fffff801`cccc24e1 ffffc408`f2817bb0 : 0x1.
MODULE_NAME: amdgpio2.
STACK_COMMAND: .cxr; .ecxr ; kb.
BUCKET_ID_FUNC_OFFSET: 2935.
BUILDLAB_STR: ni_release.
OSPLATFORM_TYPE: x64.
OSNAME: Windows 10.
Recep abi şu an kadar mavi ekran vermedi ama PC'nin açılışı hiç stabil olmuyor. Ortalama 15 sn'de açılıyor bazen 20 saniyeyi geçiyor. Oyunlarda takılmamasına rağmen Windows'ta gezinirken nadiren takılıyor vb. Acer servisi Türkiye'de pek ilgili değilmiş kaç tane tanıdığım var fazla ısınıyor diye yolladılar 100+ dereceye sorun yok deyip tekrar yollamışlar. Hakem heyetine başvuracak şimdi. Ne yapmam lazım şimdi?
Kod:
or above.
Arguments:
Debugging Details:
*** work. ***
 Value: 3312.
 Value: 6515.
 Value: 5
 Value: 10.
 Value: 20.
 Value: 1187.
 Value: 13413.
 Value: 98.
 Value: 0x133.
 Key : Failure.Hash
 Value: 1497cf94.
 Value: 1
 Value: 1
 Value: 0
 Value: 0
 Value: 0
 Value: 1
 Value: 0
 Value: 1
 Value: 0
 Value: 1
 Value: 1
 Value: 0
 Value: 0
 Value: 0
 Value: 1
 Value: 1
 Value: 0
 Value: 0
 Value: 1
 Value: 0
 Value: 4853999.
 Value: 4a10ef.
 Value: 1
 Value: 1
 Value: 1
 Value: 1
 Value: 1
 Value: 0
 Value: 1
 Value: 0
 Value: 1
 Value: 1
 Value: 1
 Value: 1
 Value: 0
 Value: 1
 Value: 1015.
 Value: 3f7.
 Key : WER.OS.Branch
 Value: ni_release.
 Value: 10.0.22621.1
BUGCHECK_CODE: 133.
BUGCHECK_P1: 1
BUGCHECK_P2: 1e00.
BUGCHECK_P4: 0
amdgpio2+0x2935:
BLACKBOXWINLOGON: 1
STACK_TEXT:
OSNAME: Windows 10.
Vee evet Recep abi üsttek mesajı yazdıktan bir gün sonra tekrar açılırken Acer logosunda takıldı 1 dakika kadar bekledim ve DPC_WATCHDOG_VIOLATION kodlu mavi ekran verdi. Ama bu sefer C'de yeni minidump dosyası oluşturmamış.
@jjEnes @Recep Baltaş
Senin sorunun ısınma değil. Cihazında fiziksel bir sorun var ve bu yüzden de mavi ekran hatası alıyorsun. Servis buna müdahale etmeli.
Korktuğum başıma geldi yani :(
Peki sorun ne diye yollayım Recep abi önceki mesajlarında bir şeyler vardı ama anlamadım ben.
Hiç garantiye bir cihaz yollamadım da.
@Recep Baltaş
Ek olarak şu dosyaları da paylaşayım. Minidump a değil de minidumps diye bir klasöre kaydetmiş. Yeni gördüm bunları.
@Recep Baltaş
@Spyhis
BIOS'u en son gelen 1.20'ye güncelledim bu arada.
Ve şunu da eklemek istiyorum, bu birkaç gündür oluyor kapat dediğimde kapanmıyor laptop. Ekran kapanıyor hafif bir ışık oluyor arkada ama klavye ve fare ışıkları kapanmıyor.
Hatalardan biri yonga seti sürücüsüyle ilgili. İkinci hata da sistem uykudan uyanırken ağ ile ilgili olmuş. Bu cihaza temiz kurulum yaptın mı yoksa Acer'ın kurduğu Windows mu var?
Kod:
or above.
Arguments:
Arg3: fffff8022c31c340, cast to nt!DPC_WATCHDOG_GLOBAL_TRIAGE_BLOCK, which contains
Debugging Details:
*** WARNING: Unable to verify timestamp for amdgpio2.sys
***    work.                                                          ***
    Value: 2843
    Value: 3831
    Value: 0
    Value: 0
    Value: 0
    Value: 733
    Value: 2271
    Value: 99
    Value: 0x133
    Value: 0x133
    Value: 1808
    Value: 1
    Value: 0
    Value: 1
    Value: 0
    Key  : Failure.Hash
    Value: 1497cf94
    Value: 1
    Value: 1
    Value: 0
    Value: 0
    Value: 0
    Value: 1
    Value: 0
    Value: 1
    Value: 0
    Value: 1
    Value: 1
    Value: 0
    Value: 0
    Value: 0
    Value: 1
    Value: 1
    Value: 0
    Value: 0
    Value: 1
    Value: 0
    Value: 4853999
    Value: 4a10ef
    Value: 1
    Value: 1
    Value: 1
    Value: 1
    Value: 1
    Value: 0
    Value: 1
    Value: 0
    Value: 1
    Value: 1
    Value: 1
    Value: 1
    Value: 0
    Value: 1
    Value: 1015
    Value: 3f7
BUGCHECK_CODE:  133
BUGCHECK_P1: 1
BUGCHECK_P2: 1e00
BUGCHECK_P3: fffff8022c31c340
BUGCHECK_P4: 0
FILE_IN_CAB:  030224-14312-01.dmp
DUMP_FILE_ATTRIBUTES: 0x1808
  Kernel Generated Triage Dump
BLACKBOXWINLOGON: 1
STACK_TEXT:
fffff802`27471498 fffff802`2b812bb9     : 00000000`00000133 00000000`00000001 00000000`00001e00 fffff802`2c31c340 : nt!KeBugCheckEx
fffff802`274714a0 fffff802`2b812421     : 00004e9c`8eb08e7f 00000000`00000000 00000000`00843795 00000000`00000000 : nt!KeAccumulateTicks+0x239
fffff802`27471500 fffff802`2b80fa2f     : 00000000`0000000c 00000000`00001388 00000000`00843700 00000000`004ecebb : nt!KiUpdateRunTime+0xd1
fffff802`274716b0 fffff802`2b810618     : 00000000`00000000 ffff8101`dd22f500 fffff802`27104180 00000000`00000000 : nt!KiUpdateTime+0x63f
fffff802`27471950 fffff802`2b80feda     : fffff802`2c25ff58 ffff8101`dd22f5b0 ffff8101`dd22f5b0 00000000`00000000 : nt!KeClockInterruptNotify+0x228
fffff802`274719f0 fffff802`2b924cdc     : 0000013b`3f0dbd68 fffff802`2c30d4f0 fffff802`2c30d5a0 00000000`00000000 : nt!HalpTimerClockInterrupt+0x10a
fffff802`27471a20 fffff802`2ba18dea     : fffff802`27471b30 fffff802`2c30d4f0 00000000`10040b00 fffff802`2b92b10a : nt!KiCallInterruptServiceRoutine+0x9c
fffff802`27471a60 fffff802`2ba19697     : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!KiInterruptSubDispatchNoLockNoEtw+0xfa
fffff802`27471ab0 fffff802`84af2935     : ffff918a`a35f23d0 00000000`00000000 fffff802`84af51a0 00000000`fed81500 : nt!KiInterruptDispatchNoLockNoEtw+0x37
fffff802`27471c40 ffff918a`a35f23d0     : 00000000`00000000 fffff802`84af51a0 00000000`fed81500 00000000`000002f8 : amdgpio2+0x2935
fffff802`27471c48 00000000`00000000     : fffff802`84af51a0 00000000`fed81500 00000000`000002f8 ffff5ccd`00200004 : 0xffff918a`a35f23d0
OSNAME:  Windows 10
DRIVER_POWER_STATE_FAILURE (9f)
A driver has failed to complete a power IRP within a specific time.
Arguments:
Arg1: 0000000000000003, A device object has been blocking an IRP for too long a time
Arg2: ffffc50e5be32e00, Physical Device Object of the stack
Arg3: fffff804528517b8, nt!TRIAGE_9F_POWER on Win7 and higher, otherwise the Functional Device Object of the stack
Arg4: ffffc50e5be21010, The blocked IRP
Debugging Details:
    Value: 2499
    Value: 5992
    Value: 0
    Value: 0
    Value: 0
    Value: 562
    Value: 1847
    Value: 88
    Value: 0x9f
    Value: 0x9f
    Value: 1808
    Value: 1
    Value: 0
    Value: 1
    Value: 0
    Value: 0x9F_3_POWER_DOWN_IMAGE_ntkrnlmp
    Key  : Failure.Hash
    Value: {678b3384-34e9-dafc-d401-53951e725571}
    Value: 1497cf94
    Value: 1
    Value: 1
    Value: 0
    Value: 0
    Value: 0
    Value: 1
    Value: 0
    Value: 1
    Value: 0
    Value: 1
    Value: 1
    Value: 0
    Value: 0
    Value: 0
    Value: 1
    Value: 1
    Value: 0
    Value: 0
    Value: 1
    Value: 0
    Value: 4853999
    Value: 4a10ef
    Value: 1
    Value: 1
    Value: 1
    Value: 1
    Value: 1
    Value: 0
    Value: 1
    Value: 0
    Value: 1
    Value: 1
    Value: 1
    Value: 1
    Value: 0
    Value: 1
    Value: 1015
    Value: 3f7
BUGCHECK_CODE:  9f
BUGCHECK_P1: 3
BUGCHECK_P2: ffffc50e5be32e00
BUGCHECK_P3: fffff804528517b8
BUGCHECK_P4: ffffc50e5be21010
FILE_IN_CAB:  022124-13250-01.dmp
DRVPOWERSTATE_SUBCODE:  3
IMAGE_NAME:  ntkrnlmp
MODULE_NAME: ntkrnlmp
FAULTING_MODULE: fffff804d6500000 raspppoe
IRP_ADDRESS: ffffc50e5be21010
DEVICE_OBJECT: ffffc50e4b50f050
DRIVER_OBJECT: ffffc50e500fbe50
BLACKBOXWINLOGON: 1
STACK_TEXT:
fffff804`52851768 fffff804`54d80f36     : 00000000`0000009f 00000000`00000003 ffffc50e`5be32e00 fffff804`528517b8 : nt!KeBugCheckEx
fffff804`52851770 fffff804`54d80e0c     : 00000000`00000002 fffff804`524f3180 fffff804`524f3180 00000000`00000000 : nt!PopIrpWatchdogBugcheck+0x122
fffff804`528517f0 fffff804`54a763ab     : ffffc50e`47e0fcf8 00000000`00000000 fffff804`52851ab8 00000000`00000000 : nt!PopIrpWatchdog+0xc
fffff804`52851820 fffff804`54a73084     : 00000000`00000000 00000000`00000000 00000000`00000000 fffff804`524fa1a8 : nt!KiProcessExpiredTimerList+0x1eb
fffff804`52851950 fffff804`54c1bb5e     : 00000000`00000000 fffff804`524f3180 fffff804`5554c700 ffffc50e`50bfc080 : nt!KiRetireDpcList+0xaf4
fffff804`52851c00 00000000`00000000     : fffff804`52852000 fffff804`5284b000 00000000`00000000 00000000`00000000 : nt!KiIdleLoop+0x9e
FAILURE_BUCKET_ID:  0x9F_3_POWER_DOWN_IMAGE_ntkrnlmp
OSNAME:  Windows 10
FAILURE_ID_HASH:  {678b3384-34e9-dafc-d401-53951e725571}
Kod:
0: kd> dt nt!_TRIAGE_9F_POWER fffff804528517b8
   +0x000 Signature        : 0x8000
   +0x002 Revision         : 2
   +0x008 IrpList          : 0xfffff804`5543d090 _LIST_ENTRY [ 0xffffc50e`47e376b0 - 0xffffc50e`47e0fcc0 ]
   +0x010 ThreadList       : 0xfffff804`5543a040 _LIST_ENTRY [ 0xffffac80`f3017b48 - 0xffffac80`f562fb48 ]
   +0x018 DelayedWorkQueue : 0xffffc50e`3bd11010 _TRIAGE_EX_WORK_QUEUE
   +0x020 DelayedIoWorkQueue : 0xffffc50e`3bd08ca0 _TRIAGE_EX_WORK_QUEUE
0: kd> !irp ffffc50e5be21010
Irp is active with 3 stacks 2 is current (= 0xffffc50e5be21128)
 No Mdl: No System Buffer: Thread 00000000:  Irp stack trace.
     cmd  flg cl Device   File     Completion-Context
 [N/A(0), N/A(0)]
            0  0 00000000 00000000 00000000-00000000
            Args: 00000000 00000000 00000000 00000000
>[IRP_MJ_POWER(16), IRP_MN_SET_POWER(2)]
            0 e1 ffffc50e4b50f050 00000000 fffff804552a5550-ffffc50e47e0fcc0 Success Error Cancel pending
           \Driver\RasPppoe    nt!PopSystemIrpCompletion
            Args: 00015600 00000000 00000005 00000003
 [N/A(0), N/A(0)]
            0  0 00000000 00000000 00000000-ffffc50e47e0fcc0
0: kd> !devstack ffffc50e5be32e00
  !DevObj           !DrvObj            !DevExt           ObjectName
  ffffc50e4b50f050  \Driver\RasPppoe   ffffc50e4b50f1a0  InfoMask field not found for _OBJECT_HEADER at ffffc50e4b50f020
> ffffc50e5be32e00  \Driver\SoftwareDeviceffffc50e5be32f50  Cannot read info offset from nt!ObpInfoMaskToOffset
!DevNode ffffc50e5ad5c010 :
  DeviceInst is "SWD\MSRRAS\MS_PPPOEMINIPORT"
  ServiceName is "RasPppoe"
0: kd> !poaction
PopAction: fffff8045543c8a0
  State..........: 3 - Set System State
  Updates........: 0
  Action.........: Sleep
  Lightest State.: Hibernate
  Flags..........: 8000000c OverrideApps|Critical
  Irp minor......: SetPower
  System State...: Hibernate
  Hiber Context..: ffffc50e40ecd410
Allocated power irps (PopIrpList - fffff8045543d090)
  IRP: ffffc50e4fe97010
Irp worker threads (PopIrpThreadList - fffff8045543a040)
  THREAD: ffffc50e3bd28200 (static)
  THREAD: ffffc50e3bd30080 (static)
  THREAD: ffffc50e43ab15c0 (dynamic)
  THREAD: ffffc50e4fa22040 (dynamic), IRP: ffffc50e5eada010, DEVICE: ffffc50e4b4ae050
  THREAD: ffffc50e3eae6040 (dynamic)
  THREAD: ffffc50e5ae90040 (dynamic)
  THREAD: ffffc50e3becc040 (dynamic), IRP: ffffc50e4f2217c0, DEVICE: ffffc50e5c997050
  THREAD: ffffc50e5c5bf040 (dynamic), IRP: ffffc50e5d991010, DEVICE: ffffc50e4ba98050
  THREAD: ffffc50e529fa040 (dynamic)
  THREAD: ffffc50e5a6d6040 (dynamic)
Error resolving nt!_POP_CURRENT_BROADCAST...
Transition Thread Stack:
Entry 1:
  - Process: 0x0
  - Recorded Time: 0x0
  - Callback: 0x0
  - Context: 0x0
00000000: Unable to get thread contents
Kod:
or above.
Arguments:
Arg3: fffff8022c31c340, cast to nt!DPC_WATCHDOG_GLOBAL_TRIAGE_BLOCK, which contains.
Debugging Details:
*** work. ***
 Value: 2843.
 Value: 3831.
 Value: 0
 Value: 0
 Value: 0
 Value: 733.
 Value: 2271.
 Value: 99.
 Value: 0x133.
 Value: 0x133.
 Value: 1808.
 Value: 1
 Value: 0
 Value: 1
 Value: 0
 Key : Failure.Hash
 Value: 1497cf94.
 Value: 1
 Value: 1
 Value: 0
 Value: 0
 Value: 0
 Value: 1
 Value: 0
 Value: 1
 Value: 0
 Value: 1
 Value: 1
 Value: 0
 Value: 0
 Value: 0
 Value: 1
 Value: 1
 Value: 0
 Value: 0
 Value: 1
 Value: 0
 Value: 4853999.
 Value: 4a10ef.
 Value: 1
 Value: 1
 Value: 1
 Value: 1
 Value: 1
 Value: 0
 Value: 1
 Value: 0
 Value: 1
 Value: 1
 Value: 1
 Value: 1
 Value: 0
 Value: 1
 Value: 1015.
 Value: 3f7.
BUGCHECK_CODE: 133.
BUGCHECK_P1: 1
BUGCHECK_P2: 1e00.
BUGCHECK_P3: fffff8022c31c340.
BUGCHECK_P4: 0
DUMP_FILE_ATTRIBUTES: 0x1808.
 Kernel Generated Triage Dump.
BLACKBOXWINLOGON: 1
STACK_TEXT:
OSNAME: Windows 10.
Arguments:
Arg1: 0000000000000003, A device object has been blocking an IRP for too long a time.
Arg2: ffffc50e5be32e00, Physical Device Object of the stack.
Arg3: fffff804528517b8, nt!TRIAGE_9F_POWER on Win7 and higher, otherwise the Functional Device Object of the stack.
Arg4: ffffc50e5be21010, The blocked IRP.
Debugging Details:
 Value: 2499.
 Value: 5992.
 Value: 0
 Value: 0
 Value: 0
 Value: 562.
 Value: 1847.
 Value: 88.
 Value: 0x9f.
 Value: 0x9f.
 Value: 1808.
 Value: 1
 Value: 0
 Value: 1
 Value: 0
 Key : Failure.Hash
 Value: 1497cf94.
 Value: 1
 Value: 1
 Value: 0
 Value: 0
 Value: 0
 Value: 1
 Value: 0
 Value: 1
 Value: 0
 Value: 1
 Value: 1
 Value: 0
 Value: 0
 Value: 0
 Value: 1
 Value: 1
 Value: 0
 Value: 0
 Value: 1
 Value: 0
 Value: 4853999.
 Value: 4a10ef.
 Value: 1
 Value: 1
 Value: 1
 Value: 1
 Value: 1
 Value: 0
 Value: 1
 Value: 0
 Value: 1
 Value: 1
 Value: 1
 Value: 1
 Value: 0
 Value: 1
 Value: 1015.
 Value: 3f7.
BUGCHECK_CODE: 9f.
BUGCHECK_P1: 3
BUGCHECK_P2: ffffc50e5be32e00.
BUGCHECK_P3: fffff804528517b8.
BUGCHECK_P4: ffffc50e5be21010.
IMAGE_NAME: ntkrnlmp.
MODULE_NAME: ntkrnlmp.
FAULTING_MODULE: fffff804d6500000 raspppoe.
IRP_ADDRESS: ffffc50e5be21010.
DEVICE_OBJECT: ffffc50e4b50f050.
DRIVER_OBJECT: ffffc50e500fbe50.
BLACKBOXWINLOGON: 1
STACK_TEXT:
OSNAME: Windows 10.
Kod:
0: kd> dt nt!_TRIAGE_9F_POWER fffff804528517b8.
 +0x000 Signature : 0x8000.
 +0x002 Revision : 2
0: kd> !irp ffffc50e5be21010.
 [N/A(0), N/A(0)]
 Args: 00000000 00000000 00000000 00000000.
 0 e1 ffffc50e4b50f050 00000000 fffff804552a5550-ffffc50e47e0fcc0 Success Error Cancel pending.
 Args: 00015600 00000000 00000005 00000003.
 [N/A(0), N/A(0)]
0: kd> !devstack ffffc50e5be32e00.
 !DevObj !DrvObj !DevExt ObjectName.
 ffffc50e4b50f050 \Driver\RasPppoe ffffc50e4b50f1a0 InfoMask field not found for _OBJECT_HEADER at ffffc50e4b50f020.
0: kd> !poaction
PopAction: fffff8045543c8a0.
 State..........: 3 - Set System State.
 Updates........: 0
 Action.........: Sleep.
 Lightest State.: Hibernate.
 Irp minor......: SetPower.
 System State...: Hibernate.
 Hiber Context..: ffffc50e40ecd410.
 IRP: ffffc50e4fe97010.
 THREAD: ffffc50e4fa22040 (dynamic), IRP: ffffc50e5eada010, DEVICE: ffffc50e4b4ae050.
 THREAD: ffffc50e3becc040 (dynamic), IRP: ffffc50e4f2217c0, DEVICE: ffffc50e5c997050.
 THREAD: ffffc50e5c5bf040 (dynamic), IRP: ffffc50e5d991010, DEVICE: ffffc50e4ba98050.
Entry 1:
 - Process: 0x0.
 - Recorded Time: 0x0.
 - Callback: 0x0.
 - Context: 0x0.
00000000: Unable to get thread contents.
Bu mesajı yazdığımda temiz kurulum yapmıştım. 3 gün önce servise yolladım cihazı dün geldi test programı indirilmiş, BIOS Update edilmiş ben zaten güncellemiştim de neyse, donanımsal sorun yok denmiş 1 gün servise kaldı sadecce 1 günde ne kadar anlayabilirsin ki arkadaş. Dün açtım işste bilgisayarı birkaç kere aç kapa yaptım 3. de mavi ekran verdi muhtemelen önemli değil diye düşünüyorum çünkü ondan sonra internete bağlanıp Windows bayağı güncelleme yaptı, Radeon ve NVIDIA grafik sürücülerini de güncelledim. Minidump dosyası bu. Hala düzelmedi diye bir his var içimde biraz daha test edeceğim her şey güncel haliyle bakalım açılırken donacak mı veya mavi ekran verecek mi? @Recep Baltaş.
Olayın üstünden bayağı geçti ama aklıma gelmişken yazayım dedim, cihazı servise 2 kere yolladım ikisinde de dalga geçer gibi format atıp yazılımsal sorun var denip geri yollandı 1 hafta önce 2. servisten aldım 1 hafta içinde 2 kere mavi ekran aldım bile biri watchdog diğeri driver Power state. Minidumpları paylaşacağım aynı sebeplerden dolayı mı acaba @Recep Baltaş ilgilenirseniz çok sevinirim.
Kod:
or above.
Arguments:
Debugging Details:
***    work.                                                          ***
    Value: 2843
    Value: 3831
    Value: 0
    Value: 0
    Value: 0
    Value: 733
    Value: 2271
    Value: 99
    Value: 0x133
    Value: 0x133
    Value: 1808
    Value: 1
    Value: 0
    Value: 1
    Value: 0
    Key  : Failure.Hash
    Value: 1497cf94
    Value: 1
    Value: 1
    Value: 0
    Value: 0
    Value: 0
    Value: 1
    Value: 0
    Value: 1
    Value: 0
    Value: 1
    Value: 1
    Value: 0
    Value: 0
    Value: 0
    Value: 1
    Value: 1
    Value: 0
    Value: 0
    Value: 1
    Value: 0
    Value: 4853999
    Value: 4a10ef
    Value: 1
    Value: 1
    Value: 1
    Value: 1
    Value: 1
    Value: 0
    Value: 1
    Value: 0
    Value: 1
    Value: 1
    Value: 1
    Value: 1
    Value: 0
    Value: 1
    Value: 1015
    Value: 3f7
BUGCHECK_CODE:  133
BUGCHECK_P1: 1
BUGCHECK_P2: 1e00
BUGCHECK_P4: 0
BLACKBOXWINLOGON: 1
STACK_TEXT:
OSNAME:  Windows 10
Arguments:
Debugging Details:
    Value: 2499
    Value: 5992
    Value: 0
    Value: 0
    Value: 0
    Value: 562
    Value: 1847
    Value: 88
    Value: 0x9f
    Value: 0x9f
    Value: 1808
    Value: 1
    Value: 0
    Value: 1
    Value: 0
    Key  : Failure.Hash
    Value: 1497cf94
    Value: 1
    Value: 1
    Value: 0
    Value: 0
    Value: 0
    Value: 1
    Value: 0
    Value: 1
    Value: 0
    Value: 1
    Value: 1
    Value: 0
    Value: 0
    Value: 0
    Value: 1
    Value: 1
    Value: 0
    Value: 0
    Value: 1
    Value: 0
    Value: 4853999
    Value: 4a10ef
    Value: 1
    Value: 1
    Value: 1
    Value: 1
    Value: 1
    Value: 0
    Value: 1
    Value: 0
    Value: 1
    Value: 1
    Value: 1
    Value: 1
    Value: 0
    Value: 1
    Value: 1015
    Value: 3f7
BUGCHECK_CODE:  9f
BUGCHECK_P1: 3
BLACKBOXWINLOGON: 1
STACK_TEXT:
OSNAME:  Windows 10
Kod:
   +0x002 Revision         : 2
 [N/A(0), N/A(0)]
 [N/A(0), N/A(0)]
0: kd> !poaction
  Updates........: 0
Entry 1:
  - Process: 0x0
  - Callback: 0x0
  - Context: 0x0
Yandex
abi bunlar yeni mavi ekranların dosyaları.
