[v21.12]
description=Old release (unsupported)
branch_pmaports=v21.12
branch_aports=3.15-stable
mirrordir_alpine=v3.15
[v21.06]
branch_pmaports=v21.06
branch_aports=3.14-stable
mirrordir_alpine=v3.14
[v21.03]
branch_pmaports=v21.03
branch_aports=3.13-stable
mirrordir_alpine=v3.13
[v20.05]
branch_pmaports=v20.05
branch_aports=3.12-stable
mirrordir_alpine=v3.12
(000016) [12:20:33] NOTE: Skipped apk version check for chroot 'native', because it is not installed yet!
(000016) [12:20:33] % sudo mkdir -p /home/xopeSs_/pmbootstrap flasher/chroot_native/dev
(000016) [12:20:36] % sudo mount -t tmpfs -o size=1M,noexec,dev tmpfs /home/xopeSs_/pmbootstrap flasher/chroot_native/dev
(000016) [12:20:36] % sudo mkdir -p /home/xopeSs_/pmbootstrap flasher/chroot_native/dev/pts /home/xopeSs_/pmbootstrap flasher/chroot_native/dev/shm
(000016) [12:20:36] % sudo mount -t tmpfs -o nodev,nosuid,noexec tmpfs /home/xopeSs_/pmbootstrap flasher/chroot_native/dev/shm
(000016) [12:20:36] % sudo mknod -m 666 /home/xopeSs_/pmbootstrap flasher/chroot_native/dev/null c 1 3
(000016) [12:20:36] % sudo mknod -m 666 /home/xopeSs_/pmbootstrap flasher/chroot_native/dev/zero c 1 5
(000016) [12:20:36] % sudo mknod -m 666 /home/xopeSs_/pmbootstrap flasher/chroot_native/dev/full c 1 7
(000016) [12:20:36] % sudo mknod -m 644 /home/xopeSs_/pmbootstrap flasher/chroot_native/dev/random c 1 8
(000016) [12:20:36] % sudo mknod -m 644 /home/xopeSs_/pmbootstrap flasher/chroot_native/dev/urandom c 1 9
(000016) [12:20:36] % sudo ln -sf /proc/self/fd /home/xopeSs_/pmbootstrap flasher/chroot_native/dev/
(000016) [12:20:36] % sudo mount --bind /proc /home/xopeSs_/pmbootstrap flasher/chroot_native/proc
(000016) [12:20:36] ERROR: Mount failed: /proc -> /home/xopeSs_/pmbootstrap flasher/chroot_native/proc
(000016) [12:20:36] See also: <https://postmarketos.org/troubleshooting>
(000016) [12:20:36] Traceback (most recent call last):
File "/usr/lib/python3.12/site-packages/pmb/__init__.py", line 76, in main.
getattr(frontend, args.action)(args)
File "/usr/lib/python3.12/site-packages/pmb/helpers/frontend.py", line 348, in flasher.
pmb.flasher.frontend(args)
File "/usr/lib/python3.12/site-packages/pmb/flasher/frontend.py", line 171, in frontend.
sideload(args)
File "/usr/lib/python3.12/site-packages/pmb/flasher/frontend.py", line 92, in sideload.
pmb.flasher.install_depends(args)
File "/usr/lib/python3.12/site-packages/pmb/flasher/init.py", line 40, in install_depends.
pmb.chroot.apk.install(args, depends)
File "/usr/lib/python3.12/site-packages/pmb/chroot/apk.py", line 236, in install.
pmb.chroot.init(args, suffix)
File "/usr/lib/python3.12/site-packages/pmb/chroot/init.py", line 128, in init.
pmb.chroot.mount(args, suffix)
File "/usr/lib/python3.12/site-packages/pmb/chroot/mount.py", line 96, in mount.
pmb.helpers.mount.bind(args, source, target_full)
File "/usr/lib/python3.12/site-packages/pmb/helpers/mount.py", line 50, in bind.
raise RuntimeError("Mount failed: " + source + " -> " + destination)
RuntimeError: Mount failed: /proc -> /home/xopeSs_/pmbootstrap flasher/chroot_native/proc
(000065) [12:20:40] % tail -n 60 -F /home/xopeSs_/pmbootstrap flasher/log.txt
(000065) [12:20:40] *** output passed to pmbootstrap stdout, not to this log ***
