Jahrein Fan 3
31 Ocak 2024
05:47:22] NOTE: The failed command's output is above the ^^^ line in the log file: /home/meto/.local/var/pmbootstrap/log.txt
[05:47:22] ERROR: Command failed (exit code 1): (rootfs_sony-sirius) % mkinitfs
[05:47:22] See also: <https://postmarketos.org/troubleshooting>
Run 'pmbootstrap log' for details.
Before you report this error, ensure that pmbootstrap is up to date.
Find the latest version here: https://gitlab.postmarketos.org/postmarketOS/pmbootstrap/-/tags
Your version: 3.6.0
Channel: systemd-edge (pmaports: master)
Device: sony-sirius (armv7)
UI: gnome
systemd: yes ('always' selected in 'pmbootstrap init')
meto@meto-IPXSB-H61:~/Desktop$
Arkadaşlar bu hatayı alıyorum, nasıl çözerim?
@Heribert Yavuz
@Heribert Yavuz çözümü yok mu hocam
Pmbootstrap Update komutunu girerek denedin mi? home/meto/.local/var/pmbootstrap/log.txt'daki log dosyasını da verebilir misin?
Denerim hocam.
Xfce4 ile kendim paketlemeyi deniyorum.
Sağ olun hocam.
Hocam bu pmbootstrap Update'yi nasıl kullancaz.
Hocam. .local klasörü yok.
Gizli çünkü, CTRL + h ile bakar mısın?
Bakayım hocam.
Gizli çünkü, CTRL + H ile bakar mısın?
(005822) [05:26:53] $ pmbootstrap /home/meto/.local/bin/pmbootstrap export
(005822) [05:26:53] Pmbootstrap v3.6.0 (Python 3.12.3 (main, Aug 14 2025, 17:47:21) [GCC 13.3.0])
(005822) [05:26:53] % cd /home/meto/.local/var/pmbootstrap/cache_git/pmaports; git remote -v
(005822) [05:26:53] % cd /home/meto/.local/var/pmbootstrap/cache_git/pmaports; git show origin/master:channels.cfg
(005822) [05:26:53] % mkdir -p /tmp/postmarketOS-export
(005822) [05:26:53] NOTE: Skipped apk version check for chroot 'rootfs_sony-sirius', because it is not installed yet!
(005822) [05:26:53] Attempting to build: postmarketos-mkinitfs
(005822) [05:26:53] armv7/postmarketos-mkinitfs: Generating dependency tree
(005822) [05:26:54] postmarketos-mkinitfs: picked provider(s) with highest priority 999: postmarketos-mkinitfs
(005822) [05:26:54] boot-deploy>=0.9: matches pmaports package
(005822) [05:26:55] postmarketos-mkinitfs: picked provider(s) with highest priority 999: postmarketos-mkinitfs
(005822) [05:26:55] /bin/sh: picked provider(s) with highest priority 100: busybox-binsh
(005822) [05:26:55] (rootfs_sony-sirius) install postmarketos-mkinitfs
(005822) [05:26:55] (rootfs_sony-sirius) chroot not initialized! This is a bug! Please report it.
(005822) [05:26:55] (rootfs_sony-sirius) initializing the chroot for you...
File "/home/meto/.local/bin/pmbootstrap", line 12, in <module>
sys.exit(pmb.main())
File "/home/meto/Desktop/pmbootstrap/pmb/init.py", line 110, in main
run_command(args)
File "/home/meto/Desktop/pmbootstrap/pmb/commands/init.py", line 55, in run_command
getattr(frontend, args.action)(args)
File "/home/meto/Desktop/pmbootstrap/pmb/helpers/frontend.py", line 405, in export
pmb.export.frontend(args)
File "/home/meto/Desktop/pmbootstrap/pmb/export/frontend.py", line 33, in frontend
pmb.chroot.initfs.build(Chroot(ChrootType.ROOTFS, config.device))
File "/home/meto/Desktop/pmbootstrap/pmb/chroot/initfs.py", line 17, in build
pmb.chroot.apk.install(["postmarketos-mkinitfs"], chroot)
File "/home/meto/Desktop/pmbootstrap/pmb/chroot/apk.py", line 222, in install
install_run_apk(to_add, to_add_local, to_del, chroot)
File "/home/meto/Desktop/pmbootstrap/pmb/chroot/apk.py", line 164, in install_run_apk
traceback.print_stack(file=logging.logfd)
(005822) [05:26:55] % sudo mkdir -p /home/meto/.local/var/pmbootstrap/chroot_rootfs_sony-sirius/dev
(005822) [05:26:55] % sudo mount -t tmpfs -o size=1M,noexec,dev tmpfs /home/meto/.local/var/pmbootstrap/chroot_rootfs_sony-sirius/dev
(005822) [05:26:55] % sudo mkdir -p /home/meto/.local/var/pmbootstrap/chroot_rootfs_sony-sirius/dev/pts /home/meto/.local/var/pmbootstrap/chroot_rootfs_sony-sirius/dev/shm
(005822) [05:26:55] % sudo mount -t tmpfs -o nodev,nosuid,noexec tmpfs /home/meto/.local/var/pmbootstrap/chroot_rootfs_sony-sirius/dev/shm
(005822) [05:26:55] % sudo mknod /home/meto/.local/var/pmbootstrap/chroot_rootfs_sony-sirius/dev/null c 1 3
(005822) [05:26:55] % sudo chmod 666 /home/meto/.local/var/pmbootstrap/chroot_rootfs_sony-sirius/dev/null
(005822) [05:26:55] % sudo mknod /home/meto/.local/var/pmbootstrap/chroot_rootfs_sony-sirius/dev/zero c 1 5
(005822) [05:26:55] % sudo chmod 666 /home/meto/.local/var/pmbootstrap/chroot_rootfs_sony-sirius/dev/zero
(005822) [05:26:55] % sudo mknod /home/meto/.local/var/pmbootstrap/chroot_rootfs_sony-sirius/dev/full c 1 7
(005822) [05:26:55] % sudo chmod 666 /home/meto/.local/var/pmbootstrap/chroot_rootfs_sony-sirius/dev/full
(005822) [05:26:55] % sudo mknod /home/meto/.local/var/pmbootstrap/chroot_rootfs_sony-sirius/dev/random c 1 8
(005822) [05:26:55] % sudo chmod 644 /home/meto/.local/var/pmbootstrap/chroot_rootfs_sony-sirius/dev/random
(005822) [05:26:55] % sudo mknod /home/meto/.local/var/pmbootstrap/chroot_rootfs_sony-sirius/dev/urandom c 1 9
(005822) [05:26:55] % sudo chmod 644 /home/meto/.local/var/pmbootstrap/chroot_rootfs_sony-sirius/dev/urandom
(005822) [05:26:55] % sudo ln -sf /proc/self/fd /home/meto/.local/var/pmbootstrap/chroot_rootfs_sony-sirius/dev/
(005822) [05:26:55] % sudo mkdir -p /home/meto/.local/var/pmbootstrap/chroot_rootfs_sony-sirius/proc
(005822) [05:26:55] % sudo mount --bind /proc /home/meto/.local/var/pmbootstrap/chroot_rootfs_sony-sirius/proc
(005822) [05:26:55] % sudo mkdir -p /home/meto/.local/var/pmbootstrap/chroot_rootfs_sony-sirius/sys
(005822) [05:26:55] % sudo mount --bind /sys /home/meto/.local/var/pmbootstrap/chroot_rootfs_sony-sirius/sys
(005822) [05:26:55] % sudo mkdir -p /home/meto/.local/var/pmbootstrap/chroot_rootfs_sony-sirius/var/cache/apk
(005822) [05:26:55] % sudo mount --bind /home/meto/.local/var/pmbootstrap/cache_apk_armv7 /home/meto/.local/var/pmbootstrap/chroot_rootfs_sony-sirius/var/cache/apk
(005822) [05:26:55] % sudo mkdir -p /home/meto/.local/var/pmbootstrap/cache_appstream/armv7/edge
(005822) [05:26:55] % sudo mkdir -p /home/meto/.local/var/pmbootstrap/chroot_rootfs_sony-sirius/mnt/appstream-data
(005822) [05:26:55] % sudo mount --bind /home/meto/.local/var/pmbootstrap/cache_appstream/armv7/edge /home/meto/.local/var/pmbootstrap/chroot_rootfs_sony-sirius/mnt/appstream-data
(005822) [05:26:55] % sudo mkdir -p /home/meto/.local/var/pmbootstrap/cache_ccache_armv7
(005822) [05:26:55] % sudo mkdir -p /home/meto/.local/var/pmbootstrap/chroot_rootfs_sony-sirius/mnt/pmbootstrap/ccache
(005822) [05:26:55] % sudo mount --bind /home/meto/.local/var/pmbootstrap/cache_ccache_armv7 /home/meto/.local/var/pmbootstrap/chroot_rootfs_sony-sirius/mnt/pmbootstrap/ccache
(005822) [05:26:55] % sudo mkdir -p /home/meto/.local/var/pmbootstrap/cache_distfiles
(005822) [05:26:55] % sudo mkdir -p /home/meto/.local/var/pmbootstrap/chroot_rootfs_sony-sirius/var/cache/distfiles
(005822) [05:26:55] % sudo mount --bind /home/meto/.local/var/pmbootstrap/cache_distfiles /home/meto/.local/var/pmbootstrap/chroot_rootfs_sony-sirius/var/cache/distfiles
(005822) [05:26:55] % sudo mkdir -p /home/meto/.local/var/pmbootstrap/chroot_rootfs_sony-sirius/mnt/pmbootstrap/git
(005822) [05:26:55] % sudo mount --bind /home/meto/.local/var/pmbootstrap/cache_git /home/meto/.local/var/pmbootstrap/chroot_rootfs_sony-sirius/mnt/pmbootstrap/git
(005822) [05:26:56] % sudo mkdir -p /home/meto/.local/var/pmbootstrap/cache_go
(005822) [05:26:56] % sudo mkdir -p /home/meto/.local/var/pmbootstrap/chroot_rootfs_sony-sirius/mnt/pmbootstrap/go
(005822) [05:26:56] % sudo mount --bind /home/meto/.local/var/pmbootstrap/cache_go /home/meto/.local/var/pmbootstrap/chroot_rootfs_sony-sirius/mnt/pmbootstrap/go
(005822) [05:26:56] % sudo mkdir -p /home/meto/.local/var/pmbootstrap/cache_rust
(005822) [05:26:56] % sudo mkdir -p /home/meto/.local/var/pmbootstrap/chroot_rootfs_sony-sirius/mnt/pmbootstrap/rust
(005822) [05:26:56] % sudo mount --bind /home/meto/.local/var/pmbootstrap/cache_rust /home/meto/.local/var/pmbootstrap/chroot_rootfs_sony-sirius/mnt/pmbootstrap/rust
(005822) [05:26:56] % sudo mkdir -p /home/meto/.local/var/pmbootstrap/config_abuild
(005822) [05:26:56] % sudo mkdir -p /home/meto/.local/var/pmbootstrap/chroot_rootfs_sony-sirius/mnt/pmbootstrap/abuild-config
(005822) [05:26:56] % sudo mount --bind /home/meto/.local/var/pmbootstrap/config_abuild /home/meto/.local/var/pmbootstrap/chroot_rootfs_sony-sirius/mnt/pmbootstrap/abuild-config
(005822) [05:26:56] % sudo mkdir -p /home/meto/.local/var/pmbootstrap/config_apk_keys
(005822) [05:26:56] % sudo mkdir -p /home/meto/.local/var/pmbootstrap/chroot_rootfs_sony-sirius/etc/apk/keys
(005822) [05:26:56] % sudo mount --bind /home/meto/.local/var/pmbootstrap/config_apk_keys /home/meto/.local/var/pmbootstrap/chroot_rootfs_sony-sirius/etc/apk/keys
(005822) [05:26:56] % sudo mkdir -p /home/meto/.local/var/pmbootstrap/cache_sccache
(005822) [05:26:56] % sudo mkdir -p /home/meto/.local/var/pmbootstrap/chroot_rootfs_sony-sirius/mnt/pmbootstrap/sccache
(005822) [05:26:56] % sudo mount --bind /home/meto/.local/var/pmbootstrap/cache_sccache /home/meto/.local/var/pmbootstrap/chroot_rootfs_sony-sirius/mnt/pmbootstrap/sccache
(005822) [05:26:56] % sudo mkdir -p /home/meto/.local/var/pmbootstrap/images_netboot
(005822) [05:26:56] % sudo mkdir -p /home/meto/.local/var/pmbootstrap/chroot_rootfs_sony-sirius/mnt/pmbootstrap/netboot
(005822) [05:26:56] % sudo mount --bind /home/meto/.local/var/pmbootstrap/images_netboot /home/meto/.local/var/pmbootstrap/chroot_rootfs_sony-sirius/mnt/pmbootstrap/netboot
(005822) [05:26:56] % sudo mkdir -p /home/meto/.local/var/pmbootstrap/packages
(005822) [05:26:56] % sudo mkdir -p /home/meto/.local/var/pmbootstrap/chroot_rootfs_sony-sirius/mnt/pmbootstrap/packages
(005822) [05:26:56] % sudo mount --bind /home/meto/.local/var/pmbootstrap/packages /home/meto/.local/var/pmbootstrap/chroot_rootfs_sony-sirius/mnt/pmbootstrap/packages
(005822) [05:26:56] % sudo mkdir -p /home/meto/.local/var/pmbootstrap/chroot_native/dev
(005822) [05:26:56] % sudo mount -t tmpfs -o size=1M,noexec,dev tmpfs /home/meto/.local/var/pmbootstrap/chroot_native/dev
(005822) [05:26:56] % sudo mkdir -p /home/meto/.local/var/pmbootstrap/chroot_native/dev/pts /home/meto/.local/var/pmbootstrap/chroot_native/dev/shm
(005822) [05:26:56] % sudo mount -t tmpfs -o nodev,nosuid,noexec tmpfs /home/meto/.local/var/pmbootstrap/chroot_native/dev/shm
(005822) [05:26:56] % sudo mknod /home/meto/.local/var/pmbootstrap/chroot_native/dev/null c 1 3
(005822) [05:26:56] % sudo chmod 666 /home/meto/.local/var/pmbootstrap/chroot_native/dev/null
(005822) [05:26:56] % sudo mknod /home/meto/.local/var/pmbootstrap/chroot_native/dev/zero c 1 5
(005822) [05:26:56] % sudo chmod 666 /home/meto/.local/var/pmbootstrap/chroot_native/dev/zero
(005822) [05:26:56] % sudo mknod /home/meto/.local/var/pmbootstrap/chroot_native/dev/full c 1 7
(005822) [05:26:56] % sudo chmod 666 /home/meto/.local/var/pmbootstrap/chroot_native/dev/full
(005822) [05:26:56] % sudo mknod /home/meto/.local/var/pmbootstrap/chroot_native/dev/random c 1 8
(005822) [05:26:56] % sudo chmod 644 /home/meto/.local/var/pmbootstrap/chroot_native/dev/random
(005822) [05:26:56] % sudo mknod /home/meto/.local/var/pmbootstrap/chroot_native/dev/urandom c 1 9
(005822) [05:26:56] % sudo chmod 644 /home/meto/.local/var/pmbootstrap/chroot_native/dev/urandom
(005822) [05:26:56] % sudo ln -sf /proc/self/fd /home/meto/.local/var/pmbootstrap/chroot_native/dev/
(005822) [05:26:56] % sudo mkdir -p /home/meto/.local/var/pmbootstrap/chroot_native/proc
(005822) [05:26:56] % sudo mount --bind /proc /home/meto/.local/var/pmbootstrap/chroot_native/proc
(005822) [05:26:56] % sudo mkdir -p /home/meto/.local/var/pmbootstrap/chroot_native/sys
(005822) [05:26:56] % sudo mount --bind /sys /home/meto/.local/var/pmbootstrap/chroot_native/sys
(005822) [05:26:56] % sudo mkdir -p /home/meto/.local/var/pmbootstrap/cache_apk_x86_64
(005822) [05:26:56] % sudo mkdir -p /home/meto/.local/var/pmbootstrap/chroot_native/var/cache/apk
(005822) [05:26:56] % sudo mount --bind /home/meto/.local/var/pmbootstrap/cache_apk_x86_64 /home/meto/.local/var/pmbootstrap/chroot_native/var/cache/apk
(005822) [05:26:56] % sudo mkdir -p /home/meto/.local/var/pmbootstrap/cache_appstream/x86_64/edge
(005822) [05:26:56] % sudo mkdir -p /home/meto/.local/var/pmbootstrap/chroot_native/mnt/appstream-data
(005822) [05:26:56] % sudo mount --bind /home/meto/.local/var/pmbootstrap/cache_appstream/x86_64/edge /home/meto/.local/var/pmbootstrap/chroot_native/mnt/appstream-data
(005822) [05:26:56] % sudo mkdir -p /home/meto/.local/var/pmbootstrap/cache_ccache_x86_64
(005822) [05:26:56] % sudo mkdir -p /home/meto/.local/var/pmbootstrap/chroot_native/mnt/pmbootstrap/ccache
(005822) [05:26:56] % sudo mount --bind /home/meto/.local/var/pmbootstrap/cache_ccache_x86_64 /home/meto/.local/var/pmbootstrap/chroot_native/mnt/pmbootstrap/ccache
(005822) [05:26:56] % sudo mkdir -p /home/meto/.local/var/pmbootstrap/chroot_native/var/cache/distfiles
(005822) [05:26:56] % sudo mount --bind /home/meto/.local/var/pmbootstrap/cache_distfiles /home/meto/.local/var/pmbootstrap/chroot_native/var/cache/distfiles
(005822) [05:26:56] % sudo mkdir -p /home/meto/.local/var/pmbootstrap/chroot_native/mnt/pmbootstrap/git
(005822) [05:26:56] % sudo mount --bind /home/meto/.local/var/pmbootstrap/cache_git /home/meto/.local/var/pmbootstrap/chroot_native/mnt/pmbootstrap/git
(005822) [05:26:56] % sudo mkdir -p /home/meto/.local/var/pmbootstrap/chroot_native/mnt/pmbootstrap/go
(005822) [05:26:56] % sudo mount --bind /home/meto/.local/var/pmbootstrap/cache_go /home/meto/.local/var/pmbootstrap/chroot_native/mnt/pmbootstrap/go
(005822) [05:26:56] % sudo mkdir -p /home/meto/.local/var/pmbootstrap/chroot_native/mnt/pmbootstrap/rust
(005822) [05:26:56] % sudo mount --bind /home/meto/.local/var/pmbootstrap/cache_rust /home/meto/.local/var/pmbootstrap/chroot_native/mnt/pmbootstrap/rust
(005822) [05:26:56] % sudo mkdir -p /home/meto/.local/var/pmbootstrap/chroot_native/mnt/pmbootstrap/abuild-config
(005822) [05:26:56] % sudo mount --bind /home/meto/.local/var/pmbootstrap/config_abuild /home/meto/.local/var/pmbootstrap/chroot_native/mnt/pmbootstrap/abuild-config
(005822) [05:26:56] % sudo mkdir -p /home/meto/.local/var/pmbootstrap/chroot_native/etc/apk/keys
(005822) [05:26:56] % sudo mount --bind /home/meto/.local/var/pmbootstrap/config_apk_keys /home/meto/.local/var/pmbootstrap/chroot_native/etc/apk/keys
(005822) [05:26:56] % sudo mkdir -p /home/meto/.local/var/pmbootstrap/chroot_native/mnt/pmbootstrap/sccache
(005822) [05:26:56] % sudo mount --bind /home/meto/.local/var/pmbootstrap/cache_sccache /home/meto/.local/var/pmbootstrap/chroot_native/mnt/pmbootstrap/sccache
(005822) [05:26:56] % sudo mkdir -p /home/meto/.local/var/pmbootstrap/chroot_native/mnt/pmbootstrap/netboot
(005822) [05:26:56] % sudo mount --bind /home/meto/.local/var/pmbootstrap/images_netboot /home/meto/.local/var/pmbootstrap/chroot_native/mnt/pmbootstrap/netboot
(005822) [05:26:56] % sudo mkdir -p /home/meto/.local/var/pmbootstrap/chroot_native/mnt/pmbootstrap/packages
(005822) [05:26:56] % sudo mount --bind /home/meto/.local/var/pmbootstrap/packages /home/meto/.local/var/pmbootstrap/chroot_native/mnt/pmbootstrap/packages
(005822) [05:26:56] % sudo touch /home/meto/.local/var/pmbootstrap/chroot_native/in-pmbootstrap
(005822) [05:26:56] APKINDEX outdated (file does not exist yet): http://mirror.postmarketos.org/postmarketos/extra-repos/systemd/master/x86_64/APKINDEX.tar.gz
(005822) [05:26:56] APKINDEX outdated (file does not exist yet): http://mirror.postmarketos.org/postmarketos/master/x86_64/APKINDEX.tar.gz
(005822) [05:26:56] APKINDEX outdated (file does not exist yet): http://dl-cdn.alpinelinux.org/alpine/edge/main/x86_64/APKINDEX.tar.gz
(005822) [05:26:56] APKINDEX outdated (file does not exist yet): http://dl-cdn.alpinelinux.org/alpine/edge/community/x86_64/APKINDEX.tar.gz
(005822) [05:26:56] APKINDEX outdated (file does not exist yet): http://dl-cdn.alpinelinux.org/alpine/edge/testing/x86_64/APKINDEX.tar.gz
(005822) [05:26:56] Update package index for x86_64 (5 file(s))
(005822) [05:26:56] Download http://mirror.postmarketos.org/postmarketos/extra-repos/systemd/master/x86_64/APKINDEX.tar.gz
(005822) [05:26:57] % sudo cp /home/meto/.local/var/pmbootstrap/cache_http/APKINDEX_a690985c85ecfdf2b186b2649a759b3a8dd91a544e2905fad1f0245650f457e6 /home/meto/.local/var/pmbootstrap/cache_apk_x86_64/APKINDEX.fae0ea9b.tar.gz
(005822) [05:26:57] Download http://mirror.postmarketos.org/postmarketos/master/x86_64/APKINDEX.tar.gz
(005822) [05:26:57] % sudo cp /home/meto/.local/var/pmbootstrap/cache_http/APKINDEX_fbf6a6bb13f455234f8410708d660d6939b023713fb7426b3335eb2673669e92 /home/meto/.local/var/pmbootstrap/cache_apk_x86_64/APKINDEX.bdd0d494.tar.gz
(005822) [05:26:57] Download http://dl-cdn.alpinelinux.org/alpine/edge/main/x86_64/APKINDEX.tar.gz
(005822) [05:26:58] % sudo cp /home/meto/.local/var/pmbootstrap/cache_http/APKINDEX_b36af8b1d7f948f0d2fcae5bd60c1b876620e69b987bc066e7a90c810687e76f /home/meto/.local/var/pmbootstrap/cache_apk_x86_64/APKINDEX.066df28d.tar.gz
(005822) [05:26:58] Download http://dl-cdn.alpinelinux.org/alpine/edge/community/x86_64/APKINDEX.tar.gz
(005822) [05:26:59] % sudo cp /home/meto/.local/var/pmbootstrap/cache_http/APKINDEX_0999dbfe3755729bd8aa3997d03dbd36a87187a19b61ce5cea2e01671a6305d6 /home/meto/.local/var/pmbootstrap/cache_apk_x86_64/APKINDEX.b53994b4.tar.gz
(005822) [05:26:59] Download http://dl-cdn.alpinelinux.org/alpine/edge/testing/x86_64/APKINDEX.tar.gz
(005822) [05:27:00] % sudo cp /home/meto/.local/var/pmbootstrap/cache_http/APKINDEX_6ccac8825a1621fb204ad4b3e645b24ffd8fa9acfe97edc265646cafd18d3e4c /home/meto/.local/var/pmbootstrap/cache_apk_x86_64/APKINDEX.30e6f5af.tar.gz
(005822) [05:27:00] Download http://dl-cdn.alpinelinux.org/alpine/edge/main/x86_64/apk-tools-static-3.0.0_rc9-r1.apk
(005822) [05:27:00] sigfilename: sbin/apk.static.SIGN.RSA.sha256.alpine-devel@lists.alpinelinux.org-6165ee59.rsa.pub
(005822) [05:27:00] sigkey: [email protected]
(005822) [05:27:00] extracted: /tmp/pmbootstrapc8g77ftnapk
(005822) [05:27:00] extracted: /tmp/pmbootstrappgrd_4uzsig
(005822) [05:27:00] Verify apk.static signature with /home/meto/Desktop/pmbootstrap/pmb/data/keys/[email protected]
(005822) [05:27:00] % openssl dgst -sha256 -verify /home/meto/Desktop/pmbootstrap/pmb/data/keys/[email protected] -signature /tmp/pmbootstrappgrd_4uzsig /tmp/pmbootstrapc8g77ftnapk
Verified OK
(005822) [05:27:00] Verify the version reported by the apk.static binary (must match the package version 3.0.0_rc9-r1)
(005822) [05:27:00] % /tmp/pmbootstrapc8g77ftnapk --version
apk-tools 3.0.0_rc9-r1, compiled for x86_64.
(005822) [05:27:00] (native) Creating chroot
(005822) [05:27:00] % sudo cp /home/meto/Desktop/pmbootstrap/pmb/data/keys/[email protected] /home/meto/.local/var/pmbootstrap/config_apk_keys/[email protected]
(005822) [05:27:01] % sudo cp /home/meto/Desktop/pmbootstrap/pmb/data/keys/[email protected] /home/meto/.local/var/pmbootstrap/config_apk_keys/[email protected]
(005822) [05:27:01] % sudo cp /home/meto/Desktop/pmbootstrap/pmb/data/keys/build.postmarketos.org.rsa.pub /home/meto/.local/var/pmbootstrap/config_apk_keys/build.postmarketos.org.rsa.pub
(005822) [05:27:01] % sudo cp /etc/resolv.conf /home/meto/.local/var/pmbootstrap/chroot_native/etc/resolv.conf
(005822) [05:27:01] % sudo mkdir -p /home/meto/.local/var/pmbootstrap/chroot_native/etc/apk
(005822) [05:27:01] (chroot_native) update /etc/apk/repositories
(005822) [05:27:01] % sudo sh -c echo http://mirror.postmarketos.org/postmarketos/extra-repos/systemd/master >> /home/meto/.local/var/pmbootstrap/chroot_native/etc/apk/repositories
(005822) [05:27:01] % sudo sh -c echo http://mirror.postmarketos.org/postmarketos/master >> /home/meto/.local/var/pmbootstrap/chroot_native/etc/apk/repositories
(005822) [05:27:01] % sudo sh -c echo http://dl-cdn.alpinelinux.org/alpine/edge/main >> /home/meto/.local/var/pmbootstrap/chroot_native/etc/apk/repositories
(005822) [05:27:01] % sudo sh -c echo http://dl-cdn.alpinelinux.org/alpine/edge/community >> /home/meto/.local/var/pmbootstrap/chroot_native/etc/apk/repositories
(005822) [05:27:01] % sudo sh -c echo http://dl-cdn.alpinelinux.org/alpine/edge/testing >> /home/meto/.local/var/pmbootstrap/chroot_native/etc/apk/repositories
(005822) [05:27:01] % sudo mkdir -p /home/meto/.local/var/pmbootstrap/chroot_native/usr/bin /home/meto/.local/var/pmbootstrap/chroot_native/usr/sbin /home/meto/.local/var/pmbootstrap/chroot_native/usr/lib
(005822) [05:27:01] % sudo ln -s usr/bin usr/sbin usr/lib /home/meto/.local/var/pmbootstrap/chroot_native/
(005822) [05:27:01] % sudo mkdir -p /home/meto/.local/var/pmbootstrap/tmp
(005822) [05:27:01] % sudo mkfifo /home/meto/.local/var/pmbootstrap/tmp/apk_progress_fifo
(005822) [05:27:01] % sudo cat /home/meto/.local/var/pmbootstrap/tmp/apk_progress_fifo
(005822) [05:27:01] % sudo sh -c exec 3>/home/meto/.local/var/pmbootstrap/tmp/apk_progress_fifo; /home/meto/.local/var/pmbootstrap/apk.static --progress-fd 3 --no-progress --root /home/meto/.local/var/pmbootstrap/chroot_native --arch x86_64 --cache-dir /home/meto/.local/var/pmbootstrap/cache_apk_x86_64 --repository /home/meto/.local/var/pmbootstrap/packages/systemd-edge --repository /home/meto/.local/var/pmbootstrap/packages/edge --initdb add --no-interactive alpine-baselayout apk-tools busybox musl-utils ;
(005822) [05:27:01] New background process: pid=6235, output=background
WARNING: opening /home/meto/.local/var/pmbootstrap/packages/systemd-edge/x86_64/APKINDEX.tar.gz: No such file or directory
WARNING: opening /home/meto/.local/var/pmbootstrap/packages/edge/x86_64/APKINDEX.tar.gz: No such file or directory
( 1/15) Installing alpine-baselayout-data (3.7.1-r8)
( 2/15) Installing musl (1.2.5-r21)
( 3/15) Installing busybox (1.37.0-r29)
Executing busybox-1.37.0-r29.post-install
( 4/15) Installing busybox-binsh (1.37.0-r29)
( 5/15) Installing alpine-baselayout (3.7.1-r8)
Executing alpine-baselayout-3.7.1-r8.pre-install
Executing alpine-baselayout-3.7.1-r8.post-install
( 6/15) Installing libcrypto3 (3.5.4-r0)
( 7/15) Installing libssl3 (3.5.4-r0)
( 8/15) Installing ssl_client (1.37.0-r29)
( 9/15) Installing zlib (1.3.1-r2)
(10/15) Installing zstd-libs (1.5.7-r2)
(11/15) Installing libapk (3.0.0_rc9-r1)
(12/15) Installing ca-certificates-bundle (20251003-r0)
(13/15) Installing apk-tools (3.0.0_rc9-r1)
(14/15) Installing scanelf (1.3.8-r2)
(15/15) Installing musl-utils (1.2.5-r21)
Executing busybox-1.37.0-r29.trigger
OK: 8 MiB in 15 packages
(005822) [05:27:04] (native) % adduser -D pmos -u 12345
(005822) [05:27:04] (native) % busybox su pmos -c HOME=/home/pmos ln -s /mnt/pmbootstrap/abuild-config /home/pmos/.abuild ;
(005822) [05:27:04] (native) % chown pmos:pmos /mnt/pmbootstrap/abuild-config
(005822) [05:27:04] (native) % busybox su pmos -c HOME=/home/pmos ln -s /mnt/pmbootstrap/ccache /home/pmos/.ccache ;
(005822) [05:27:04] (native) % chown pmos:pmos /mnt/pmbootstrap/ccache
(005822) [05:27:04] (native) % busybox su pmos -c HOME=/home/pmos mkdir -p /home/pmos/.cache ;
(005822) [05:27:04] (native) % mkdir -p /mnt/pmbootstrap/go/gocache
(005822) [05:27:04] (native) % busybox su pmos -c HOME=/home/pmos ln -s /mnt/pmbootstrap/go/gocache /home/pmos/.cache/go-build ;
(005822) [05:27:04] (native) % chown pmos:pmos /mnt/pmbootstrap/go/gocache
(005822) [05:27:04] (native) % busybox su pmos -c HOME=/home/pmos mkdir -p /home/pmos/go/pkg ;
(005822) [05:27:04] (native) % mkdir -p /mnt/pmbootstrap/go/gomodcache
(005822) [05:27:04] (native) % busybox su pmos -c HOME=/home/pmos ln -s /mnt/pmbootstrap/go/gomodcache /home/pmos/go/pkg/mod ;
(005822) [05:27:04] (native) % chown pmos:pmos /mnt/pmbootstrap/go/gomodcache
(005822) [05:27:04] (native) % busybox su pmos -c HOME=/home/pmos mkdir -p /home/pmos/.cargo/git ;
(005822) [05:27:04] (native) % mkdir -p /mnt/pmbootstrap/rust/git/db
(005822) [05:27:04] (native) % busybox su pmos -c HOME=/home/pmos ln -s /mnt/pmbootstrap/rust/git/db /home/pmos/.cargo/git/db ;
(005822) [05:27:04] (native) % chown pmos:pmos /mnt/pmbootstrap/rust/git/db
(005822) [05:27:04] (native) % busybox su pmos -c HOME=/home/pmos mkdir -p /home/pmos/.cargo/registry ;
(005822) [05:27:04] (native) % mkdir -p /mnt/pmbootstrap/rust/registry/cache
(005822) [05:27:04] (native) % busybox su pmos -c HOME=/home/pmos ln -s /mnt/pmbootstrap/rust/registry/cache /home/pmos/.cargo/registry/cache ;
(005822) [05:27:04] (native) % chown pmos:pmos /mnt/pmbootstrap/rust/registry/cache
(005822) [05:27:04] (native) % mkdir -p /mnt/pmbootstrap/rust/registry/index
(005822) [05:27:04] (native) % busybox su pmos -c HOME=/home/pmos ln -s /mnt/pmbootstrap/rust/registry/index /home/pmos/.cargo/registry/index ;
(005822) [05:27:04] (native) % chown pmos:pmos /mnt/pmbootstrap/rust/registry/index
(005822) [05:27:04] (native) % busybox su pmos -c HOME=/home/pmos ln -s /mnt/pmbootstrap/sccache /home/pmos/.cache/sccache ;
(005822) [05:27:04] (native) % chown pmos:pmos /mnt/pmbootstrap/sccache
(005822) [05:27:04] Attempting to build: qemu-arm
(005822) [05:27:05] (native) install qemu-arm
(005822) [05:27:05] % sudo mkdir -p /home/meto/.local/var/pmbootstrap/tmp
(005822) [05:27:05] % sudo rm -f /home/meto/.local/var/pmbootstrap/tmp/apk_progress_fifo
(005822) [05:27:05] % sudo mkfifo /home/meto/.local/var/pmbootstrap/tmp/apk_progress_fifo
(005822) [05:27:05] % sudo cat /home/meto/.local/var/pmbootstrap/tmp/apk_progress_fifo
(005822) [05:27:05] % sudo sh -c exec 3>/home/meto/.local/var/pmbootstrap/tmp/apk_progress_fifo; /home/meto/.local/var/pmbootstrap/apk.static --progress-fd 3 --no-progress --root /home/meto/.local/var/pmbootstrap/chroot_native --arch x86_64 --cache-dir /home/meto/.local/var/pmbootstrap/cache_apk_x86_64 --repository /home/meto/.local/var/pmbootstrap/packages/systemd-edge --repository /home/meto/.local/var/pmbootstrap/packages/edge --repository /home/meto/.local/var/pmbootstrap/packages/systemd-edge --repository /home/meto/.local/var/pmbootstrap/packages/edge add --no-interactive qemu-arm ;
(005822) [05:27:05] New background process: pid=6371, output=background
(1/1) Installing qemu-arm (10.1.2-r1)
OK: 12 MiB in 16 packages
(005822) [05:27:06] Register qemu binfmt (arm)
(005822) [05:27:06] % sudo sh -c echo ":qemu-arm:M::\x7f\x45\x4c\x46\x01\x01\x01\x00\x00\x00\x00\x00\x00\x00\x00\x00\x02\x00\x28\x00:\xff\xff\xff\xff\xff\xff\xff\x00\xff\xff\xff\xff\xff\xff\xff\xff\xfe\xff\xff\xff:/usr/bin/qemu-arm-static:C" > /proc/sys/fs/binfmt_misc/register
(005822) [05:27:06] % sudo mkdir -p /home/meto/.local/var/pmbootstrap/chroot_rootfs_sony-sirius/usr/bin
(005822) [05:27:06] % sudo touch /home/meto/.local/var/pmbootstrap/chroot_rootfs_sony-sirius/usr/bin/qemu-arm-static
(005822) [05:27:06] % sudo mount --bind /home/meto/.local/var/pmbootstrap/chroot_native/usr/bin/qemu-arm /home/meto/.local/var/pmbootstrap/chroot_rootfs_sony-sirius/usr/bin/qemu-arm-static
(005822) [05:27:06] % sudo touch /home/meto/.local/var/pmbootstrap/chroot_rootfs_sony-sirius/in-pmbootstrap
(005822) [05:27:06] sigfilename: sbin/apk.static.SIGN.RSA.sha256.alpine-devel@lists.alpinelinux.org-6165ee59.rsa.pub
(005822) [05:27:06] sigkey: [email protected]
(005822) [05:27:06] extracted: /tmp/pmbootstrap5v_ty0poapk
(005822) [05:27:06] extracted: /tmp/pmbootstrapbrjhjczqsig
(005822) [05:27:06] Verify apk.static signature with /home/meto/Desktop/pmbootstrap/pmb/data/keys/[email protected]
(005822) [05:27:06] % openssl dgst -sha256 -verify /home/meto/Desktop/pmbootstrap/pmb/data/keys/[email protected] -signature /tmp/pmbootstrapbrjhjczqsig /tmp/pmbootstrap5v_ty0poapk
Verified OK
(005822) [05:27:06] Verify the version reported by the apk.static binary (must match the package version 3.0.0_rc9-r1)
(005822) [05:27:06] % /tmp/pmbootstrap5v_ty0poapk --version
(005822) [05:27:06] (rootfs_sony-sirius) Creating chroot
(005822) [05:27:06] % sudo cp /etc/resolv.conf /home/meto/.local/var/pmbootstrap/chroot_rootfs_sony-sirius/etc/resolv.conf
(005822) [05:27:06] % sudo mkdir -p /home/meto/.local/var/pmbootstrap/chroot_rootfs_sony-sirius/etc/apk
(005822) [05:27:06] (chroot_rootfs_sony-sirius) update /etc/apk/repositories
(005822) [05:27:06] % sudo sh -c echo http://mirror.postmarketos.org/postmarketos/extra-repos/systemd/master >> /home/meto/.local/var/pmbootstrap/chroot_rootfs_sony-sirius/etc/apk/repositories
(005822) [05:27:06] % sudo sh -c echo http://mirror.postmarketos.org/postmarketos/master >> /home/meto/.local/var/pmbootstrap/chroot_rootfs_sony-sirius/etc/apk/repositories
(005822) [05:27:06] % sudo sh -c echo http://dl-cdn.alpinelinux.org/alpine/edge/main >> /home/meto/.local/var/pmbootstrap/chroot_rootfs_sony-sirius/etc/apk/repositories
(005822) [05:27:06] % sudo sh -c echo http://dl-cdn.alpinelinux.org/alpine/edge/community >> /home/meto/.local/var/pmbootstrap/chroot_rootfs_sony-sirius/etc/apk/repositories
(005822) [05:27:06] % sudo sh -c echo http://dl-cdn.alpinelinux.org/alpine/edge/testing >> /home/meto/.local/var/pmbootstrap/chroot_rootfs_sony-sirius/etc/apk/repositories
(005822) [05:27:06] % sudo mkdir -p /home/meto/.local/var/pmbootstrap/chroot_rootfs_sony-sirius/usr/bin /home/meto/.local/var/pmbootstrap/chroot_rootfs_sony-sirius/usr/sbin /home/meto/.local/var/pmbootstrap/chroot_rootfs_sony-sirius/usr/lib
(005822) [05:27:06] % sudo ln -s usr/bin usr/sbin usr/lib /home/meto/.local/var/pmbootstrap/chroot_rootfs_sony-sirius/
(005822) [05:27:06] % sudo mkdir -p /home/meto/.local/var/pmbootstrap/tmp
(005822) [05:27:06] % sudo rm -f /home/meto/.local/var/pmbootstrap/tmp/apk_progress_fifo
(005822) [05:27:06] % sudo mkfifo /home/meto/.local/var/pmbootstrap/tmp/apk_progress_fifo
(005822) [05:27:06] % sudo cat /home/meto/.local/var/pmbootstrap/tmp/apk_progress_fifo
(005822) [05:27:06] % sudo sh -c exec 3>/home/meto/.local/var/pmbootstrap/tmp/apk_progress_fifo; /home/meto/.local/var/pmbootstrap/apk.static --progress-fd 3 --no-progress --root /home/meto/.local/var/pmbootstrap/chroot_rootfs_sony-sirius --arch armv7 --cache-dir /home/meto/.local/var/pmbootstrap/cache_apk_armv7 --repository /home/meto/.local/var/pmbootstrap/packages/systemd-edge --repository /home/meto/.local/var/pmbootstrap/packages/edge --initdb add --no-interactive alpine-baselayout apk-tools busybox musl-utils ;
(005822) [05:27:06] New background process: pid=6433, output=background
WARNING: opening /home/meto/.local/var/pmbootstrap/packages/systemd-edge/armv7/APKINDEX.tar.gz: No such file or directory
WARNING: opening /home/meto/.local/var/pmbootstrap/packages/edge/armv7/APKINDEX.tar.gz: No such file or directory
OK: 5 MiB in 15 packages
(005822) [05:27:09] % sudo mkdir -p /home/meto/.local/var/pmbootstrap/tmp
(005822) [05:27:09] % sudo rm -f /home/meto/.local/var/pmbootstrap/tmp/apk_progress_fifo
(005822) [05:27:09] % sudo mkfifo /home/meto/.local/var/pmbootstrap/tmp/apk_progress_fifo
(005822) [05:27:09] % sudo cat /home/meto/.local/var/pmbootstrap/tmp/apk_progress_fifo
(005822) [05:27:09] % sudo sh -c exec 3>/home/meto/.local/var/pmbootstrap/tmp/apk_progress_fifo; /home/meto/.local/var/pmbootstrap/apk.static --progress-fd 3 --no-progress --root /home/meto/.local/var/pmbootstrap/chroot_rootfs_sony-sirius --arch armv7 --cache-dir /home/meto/.local/var/pmbootstrap/cache_apk_armv7 --repository /home/meto/.local/var/pmbootstrap/packages/systemd-edge --repository /home/meto/.local/var/pmbootstrap/packages/edge --repository /home/meto/.local/var/pmbootstrap/packages/systemd-edge --repository /home/meto/.local/var/pmbootstrap/packages/edge add --no-interactive postmarketos-mkinitfs ;
(005822) [05:27:09] New background process: pid=6489, output=background
(1/2) Installing boot-deploy (0.20.4-r0)
(2/2) Installing postmarketos-mkinitfs (2.7.0-r1)
Executing postmarketos-mkinitfs-2.7.0-r1.trigger
* mkinitfs: skipping (no deviceinfo file found)
OK: 9 MiB in 17 packages
(005822) [05:27:11] (rootfs_sony-sirius) mkinitfs
(005822) [05:27:11] (rootfs_sony-sirius) % mkinitfs
10:27:11.576336 Error reading deviceinfo
10:27:11.581796 /usr/share/deviceinfo/deviceinfo: "/usr/share/deviceinfo/deviceinfo" not found, required by mkinitfs
10:27:11.582737 /etc/deviceinfo: "/etc/deviceinfo" not found, required by mkinitfs
(005822) [05:27:11] ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^
(005822) [05:27:11] NOTE: The failed command's output is above the ^^^ line in the log file: /home/meto/.local/var/pmbootstrap/log.txt
(005822) [05:27:11] ERROR: Command failed (exit code 1): (rootfs_sony-sirius) % mkinitfs
(005822) [05:27:11] See also: <https://postmarketos.org/troubleshooting>
(005822) [05:27:11] Traceback (most recent call last):
run_command(args)
File "/home/meto/Desktop/pmbootstrap/pmb/chroot/initfs.py", line 22, in build
pmb.chroot.root(["mkinitfs"], chroot)
File "/home/meto/Desktop/pmbootstrap/pmb/chroot/run.py", line 169, in root
return rootm(
File "/home/meto/Desktop/pmbootstrap/pmb/chroot/run.py", line 97, in rootm
return pmb.helpers.run_core.core(
File "/home/meto/Desktop/pmbootstrap/pmb/helpers/run_core.py", line 489, in core
check_return_code(code, log_message)
File "/home/meto/Desktop/pmbootstrap/pmb/helpers/run_core.py", line 328, in check_return_code
raise RuntimeError(f"Command failed (exit code {code}): " + log_message)
RuntimeError: Command failed (exit code 1): (rootfs_sony-sirius) % mkinitfs
(005822) [05:27:11] % cd /home/meto/.local/var/pmbootstrap/cache_git/pmaports; git rev-parse --abbrev-ref HEAD
(005822) [05:27:11] % cd /home/meto/.local/var/pmbootstrap/cache_git/pmaports; git status --porcelain
(006713) [05:32:58] $ pmbootstrap /home/meto/.local/bin/pmbootstrap flasher --method=adb sideload
(006713) [05:32:58] Pmbootstrap v3.6.0 (Python 3.12.3 (main, Aug 14 2025, 17:47:21) [GCC 13.3.0])
(006713) [05:32:58] % cd /home/meto/.local/var/pmbootstrap/cache_git/pmaports; git remote -v
(006713) [05:32:58] % cd /home/meto/.local/var/pmbootstrap/cache_git/pmaports; git show origin/master:channels.cfg
(006713) [05:32:58] Attempting to build: android-tools
(006713) [05:33:00] libssl3: picked provider(s) with highest priority 100: libssl3
(006713) [05:33:00] libcrypto3: picked provider(s) with highest priority 100: libcrypto3
(006713) [05:33:00] (native) install android-tools
(006713) [05:33:00] % sudo mkdir -p /home/meto/.local/var/pmbootstrap/tmp
(006713) [05:33:00] % sudo rm -f /home/meto/.local/var/pmbootstrap/tmp/apk_progress_fifo
(006713) [05:33:00] % sudo mkfifo /home/meto/.local/var/pmbootstrap/tmp/apk_progress_fifo
(006713) [05:33:00] % sudo cat /home/meto/.local/var/pmbootstrap/tmp/apk_progress_fifo
(006713) [05:33:00] % sudo sh -c exec 3>/home/meto/.local/var/pmbootstrap/tmp/apk_progress_fifo; /home/meto/.local/var/pmbootstrap/apk.static --progress-fd 3 --no-progress --root /home/meto/.local/var/pmbootstrap/chroot_native --arch x86_64 --cache-dir /home/meto/.local/var/pmbootstrap/cache_apk_x86_64 --repository /home/meto/.local/var/pmbootstrap/packages/systemd-edge --repository /home/meto/.local/var/pmbootstrap/packages/edge --repository /home/meto/.local/var/pmbootstrap/packages/systemd-edge --repository /home/meto/.local/var/pmbootstrap/packages/edge add --no-interactive android-tools ;
(006713) [05:33:00] New background process: pid=6727, output=background
( 1/75) Installing libbz2 (1.0.8-r6)
( 2/75) Installing libexpat (2.7.3-r0)
( 3/75) Installing libffi (3.5.2-r0)
( 4/75) Installing gdbm (1.26-r0)
( 5/75) Installing xz-libs (5.8.1-r0)
( 6/75) Installing libgcc (15.2.0-r2)
( 7/75) Installing libstdc++ (15.2.0-r2)
( 8/75) Installing mpdecimal (4.0.1-r0)
( 9/75) Installing ncurses-terminfo-base (6.5_p20251123-r0)
(10/75) Installing libncursesw (6.5_p20251123-r0)
(11/75) Installing libpanelw (6.5_p20251123-r0)
(12/75) Installing readline (8.3.1-r0)
(13/75) Installing sqlite-libs (3.51.1-r0)
(14/75) Installing python3 (3.12.12-r0)
(15/75) Installing python3-pycache-pyc0 (3.12.12-r0)
(16/75) Installing pyc (3.12.12-r0)
(17/75) Installing python3-pyc (3.12.12-r0)
(18/75) Installing abseil-cpp-leak-check (20250814.1-r0)
(19/75) Installing abseil-cpp-log-internal-nullguard (20250814.1-r0)
(20/75) Installing abseil-cpp-raw-logging-internal (20250814.1-r0)
(21/75) Installing abseil-cpp-strings-internal (20250814.1-r0)
(22/75) Installing abseil-cpp-strings (20250814.1-r0)
(23/75) Installing abseil-cpp-log-internal-check-op (20250814.1-r0)
(24/75) Installing abseil-cpp-spinlock-wait (20250814.1-r0)
(25/75) Installing abseil-cpp-base (20250814.1-r0)
(26/75) Installing abseil-cpp-debugging-internal (20250814.1-r0)
(27/75) Installing abseil-cpp-malloc-internal (20250814.1-r0)
(28/75) Installing abseil-cpp-stacktrace (20250814.1-r0)
(29/75) Installing abseil-cpp-symbolize (20250814.1-r0)
(30/75) Installing abseil-cpp-examine-stack (20250814.1-r0)
(31/75) Installing abseil-cpp-city (20250814.1-r0)
(32/75) Installing abseil-cpp-hash (20250814.1-r0)
(33/75) Installing abseil-cpp-log-globals (20250814.1-r0)
(34/75) Installing abseil-cpp-log-internal-globals (20250814.1-r0)
(35/75) Installing abseil-cpp-int128 (20250814.1-r0)
(36/75) Installing abseil-cpp-str-format-internal (20250814.1-r0)
(37/75) Installing abseil-cpp-time-zone (20250814.1-r0)
(38/75) Installing abseil-cpp-time (20250814.1-r0)
(39/75) Installing abseil-cpp-log-internal-format (20250814.1-r0)
(40/75) Installing abseil-cpp-log-sink (20250814.1-r0)
(41/75) Installing abseil-cpp-kernel-timeout-internal (20250814.1-r0)
(42/75) Installing abseil-cpp-tracing-internal (20250814.1-r0)
(43/75) Installing abseil-cpp-synchronization (20250814.1-r0)
(44/75) Installing abseil-cpp-log-internal-log-sink-set (20250814.1-r0)
(45/75) Installing abseil-cpp-log-internal-proto (20250814.1-r0)
(46/75) Installing abseil-cpp-log-internal-structured-proto (20250814.1-r0)
(47/75) Installing abseil-cpp-strerror (20250814.1-r0)
(48/75) Installing abseil-cpp-log-internal-message (20250814.1-r0)
(49/75) Installing abseil-cpp-crc-internal (20250814.1-r0)
(50/75) Installing abseil-cpp-crc32c (20250814.1-r0)
(51/75) Installing abseil-cpp-crc-cord-state (20250814.1-r0)
(52/75) Installing abseil-cpp-cord-internal (20250814.1-r0)
(53/75) Installing abseil-cpp-exponential-biased (20250814.1-r0)
(54/75) Installing abseil-cpp-cordz-functions (20250814.1-r0)
(55/75) Installing abseil-cpp-cordz-handle (20250814.1-r0)
(56/75) Installing abseil-cpp-cordz-info (20250814.1-r0)
(57/75) Installing abseil-cpp-cord (20250814.1-r0)
(58/75) Installing abseil-cpp-status (20250814.1-r0)
(59/75) Installing brotli-libs (1.1.0-r2)
(60/75) Installing fmt (11.2.0-r1)
(61/75) Installing lz4-libs (1.10.0-r0)
(62/75) Installing pcre2 (10.47-r0)
(63/75) Installing abseil-cpp-die-if-null (20250814.1-r0)
(64/75) Installing abseil-cpp-log-internal-conditions (20250814.1-r0)
(65/75) Installing abseil-cpp-hashtablez-sampler (20250814.1-r0)
(66/75) Installing abseil-cpp-raw-hash-set (20250814.1-r0)
(67/75) Installing abseil-cpp-statusor (20250814.1-r0)
(68/75) Installing abseil-cpp-throw-delegate (20250814.1-r0)
(69/75) Installing abseil-cpp-log-initialize (20250814.1-r0)
(70/75) Installing libprotoc (31.1-r1)
(71/75) Installing protoc (31.1-r1)
(72/75) Installing libprotobuf-lite (31.1-r1)
(73/75) Installing protobuf (31.1-r1)
(74/75) Installing libprotobuf (31.1-r1)
(75/75) Installing android-tools (35.0.2-r17)
OK: 75 MiB in 91 packages
(006713) [05:33:09] % sudo mkdir -p /home/meto/.local/var/pmbootstrap/chroot_buildroot_armv7
(006713) [05:33:09] % sudo mount --bind /home/meto/.local/var/pmbootstrap/chroot_buildroot_armv7 /home/meto/.local/var/pmbootstrap/chroot_buildroot_armv7
(006713) [05:33:09] ERROR: The recovery zip has not been generated yet, please run 'pmbootstrap install' with the '--android-recovery-zip' parameter first!
(006713) [05:33:09] See also: <https://postmarketos.org/troubleshooting>
(006713) [05:33:09] Traceback (most recent call last):
run_command(args)
File "/home/meto/Desktop/pmbootstrap/pmb/commands/init.py", line 112, in run_command
command.run()
File "/home/meto/Desktop/pmbootstrap/pmb/commands/flasher.py", line 106, in run
sideload(
File "/home/meto/Desktop/pmbootstrap/pmb/flasher/frontend.py", line 188, in sideload
raise RuntimeError(
RuntimeError: The recovery zip has not been generated yet, please run 'pmbootstrap install' with the '--android-recovery-zip' parameter first!
(006713) [05:33:09] % cd /home/meto/.local/var/pmbootstrap/cache_git/pmaports; git rev-parse --abbrev-ref HEAD
(006713) [05:33:09] % cd /home/meto/.local/var/pmbootstrap/cache_git/pmaports; git status --porcelain
(006759) [05:33:15] $ pmbootstrap /home/meto/.local/bin/pmbootstrap flasher --method=adb sideload
(006759) [05:33:15] Pmbootstrap v3.6.0 (Python 3.12.3 (main, Aug 14 2025, 17:47:21) [GCC 13.3.0])
(006759) [05:33:15] % cd /home/meto/.local/var/pmbootstrap/cache_git/pmaports; git remote -v
(006759) [05:33:15] % cd /home/meto/.local/var/pmbootstrap/cache_git/pmaports; git show origin/master:channels.cfg
(006759) [05:33:15] Attempting to build: android-tools
(006759) [05:33:17] libssl3: picked provider(s) with highest priority 100: libssl3
(006759) [05:33:17] libcrypto3: picked provider(s) with highest priority 100: libcrypto3
(006759) [05:33:17] (native) install android-tools
(006759) [05:33:17] % sudo mkdir -p /home/meto/.local/var/pmbootstrap/tmp
(006759) [05:33:17] % sudo rm -f /home/meto/.local/var/pmbootstrap/tmp/apk_progress_fifo
(006759) [05:33:17] % sudo mkfifo /home/meto/.local/var/pmbootstrap/tmp/apk_progress_fifo
(006759) [05:33:17] % sudo cat /home/meto/.local/var/pmbootstrap/tmp/apk_progress_fifo
(006759) [05:33:17] % sudo sh -c exec 3>/home/meto/.local/var/pmbootstrap/tmp/apk_progress_fifo; /home/meto/.local/var/pmbootstrap/apk.static --progress-fd 3 --no-progress --root /home/meto/.local/var/pmbootstrap/chroot_native --arch x86_64 --cache-dir /home/meto/.local/var/pmbootstrap/cache_apk_x86_64 --repository /home/meto/.local/var/pmbootstrap/packages/edge --repository /home/meto/.local/var/pmbootstrap/packages/systemd-edge --repository /home/meto/.local/var/pmbootstrap/packages/edge --repository /home/meto/.local/var/pmbootstrap/packages/systemd-edge add --no-interactive android-tools ;
(006759) [05:33:17] New background process: pid=6773, output=background
(006759) [05:33:18] ERROR: The recovery zip has not been generated yet, please run 'pmbootstrap install' with the '--android-recovery-zip' parameter first!
(006759) [05:33:18] See also: <https://postmarketos.org/troubleshooting>
(006759) [05:33:18] Traceback (most recent call last):
run_command(args)
command.run()
sideload(
raise RuntimeError(
(006759) [05:33:18] % cd /home/meto/.local/var/pmbootstrap/cache_git/pmaports; git rev-parse --abbrev-ref HEAD
(006759) [05:33:18] % cd /home/meto/.local/var/pmbootstrap/cache_git/pmaports; git status --porcelain
(007023) [05:38:50] Location of the 'work' path. Multiple chroots (native, device arch, device rootfs) will be created in there.
[05:38:50] Work path [/home/meto/.local/var/pmbootstrap]: /home/meto/.local/var/pmbootstrap
(007023) [05:38:56] Save config: /home/meto/.config/pmbootstrap.cfg
(007023) [05:38:56] WARNING: Your work folder version needs to be migrated (from version 8 to 6)!
(007023) [05:38:56] ERROR: Sorry, we can't migrate that automatically. Please run 'pmbootstrap shutdown', then delete your current work folder manually ('sudo rm -rf /home/meto/.local/var/pmbootstrap') and start over with 'pmbootstrap init'. All your binary packages and caches will be lost.
(007023) [05:38:56] See also: <https://postmarketos.org/troubleshooting>
(007023) [05:38:56] Traceback (most recent call last):
File "/usr/share/pmbootstrap/pmb/init.py", line 47, in main
return config_init.frontend(args)
File "/usr/share/pmbootstrap/pmb/config/init.py", line 674, in frontend
pmb.helpers.other.migrate_work_folder(args)
File "/usr/share/pmbootstrap/pmb/helpers/other.py", line 235, in migrate_work_folder
raise RuntimeError("Sorry, we can't migrate that automatically. Please"
RuntimeError: Sorry, we can't migrate that automatically. Please run 'pmbootstrap shutdown', then delete your current work folder manually ('sudo rm -rf /home/meto/.local/var/pmbootstrap') and start over with 'pmbootstrap init'. All your binary packages and caches will be lost.
(007031) [05:39:27] Location of the 'work' path. Multiple chroots (native, device arch, device rootfs) will be created in there.
[05:39:27] Work path [/home/meto/.local/var/pmbootstrap]: /home/meto/.local/var/pmbootstrap
(007031) [05:39:28] Save config: /home/meto/.config/pmbootstrap.cfg
(007031) [05:39:28] WARNING: Your work folder version needs to be migrated (from version 8 to 6)!
(007031) [05:39:28] ERROR: Sorry, we can't migrate that automatically. Please run 'pmbootstrap shutdown', then delete your current work folder manually ('sudo rm -rf /home/meto/.local/var/pmbootstrap') and start over with 'pmbootstrap init'. All your binary packages and caches will be lost.
(007031) [05:39:28] See also: <https://postmarketos.org/troubleshooting>
(007031) [05:39:28] Traceback (most recent call last):
(007033) [05:39:43] Location of the 'work' path. Multiple chroots (native, device arch, device rootfs) will be created in there.
[05:39:43] Work path [/home/meto/.local/var/pmbootstrap]: /home/meto/.local/var/pmbootstrap
(007033) [05:39:47] Save config: /home/meto/.config/pmbootstrap.cfg
(007033) [05:39:47] WARNING: Your work folder version needs to be migrated (from version 8 to 6)!
(007033) [05:39:47] ERROR: Sorry, we can't migrate that automatically. Please run 'pmbootstrap shutdown', then delete your current work folder manually ('sudo rm -rf /home/meto/.local/var/pmbootstrap') and start over with 'pmbootstrap init'. All your binary packages and caches will be lost.
(007033) [05:39:47] See also: <https://postmarketos.org/troubleshooting>
(007033) [05:39:47] Traceback (most recent call last):
(007061) [05:43:14] $ pmbootstrap /home/meto/.local/bin/pmbootstrap init
(007061) [05:43:14] Pmbootstrap v3.6.0 (Python 3.12.3 (main, Aug 14 2025, 17:47:21) [GCC 13.3.0])
(007061) [05:43:14] Location of the 'work' path. Multiple chroots (native, device arch, device rootfs) will be created in there.
(007145) [05:44:33] $ pmbootstrap /home/meto/.local/bin/pmbootstrap init
(007145) [05:44:33] Pmbootstrap v3.6.0 (Python 3.12.3 (main, Aug 14 2025, 17:47:21) [GCC 13.3.0])
(007145) [05:44:33] Location of the 'work' path. Multiple chroots (native, device arch, device rootfs) will be created in there.
[05:44:33] Work path [/home/meto/.local/var/pmbootstrap]: /home/meto/.local/var/pmbootstrap
(007145) [05:44:37] Location of the 'pmaports' path, containing package definitions.
[05:44:37] pmaports path [/home/meto/.local/var/pmbootstrap/cache_git/pmaports]: /home/meto/.local/var/pmbootstrap/cache_git/pmaports
(007145) [05:44:40] Save config: /home/meto/.config/pmbootstrap_v3.cfg
(007145) [05:44:40] % cd /home/meto/.local/var/pmbootstrap/cache_git/pmaports; git remote -v
(007145) [05:44:40] % cd /home/meto/.local/var/pmbootstrap/cache_git/pmaports; git show origin/master:channels.cfg
(007145) [05:44:40] Choose the postmarketOS release channel.
(007145) [05:44:40] Available (13):
(007145) [05:44:40] * edge: Rolling release / Most devices / Occasional breakage: https://postmarketos.org/edge
(007145) [05:44:40] * v25.12: Upcoming stable release (DO NOT USE)
(007145) [05:44:40] * v25.06: Latest release / Recommended for best stability
[05:44:40] Channel [edge]: edge
(007145) [05:44:43] % cd /home/meto/.local/var/pmbootstrap/cache_git/pmaports; git rev-parse --abbrev-ref HEAD
master
(007145) [05:44:43] NOTE: pmaports is on master branch, copying git hooks.
(007145) [05:44:43] % cp /home/meto/.local/var/pmbootstrap/cache_git/pmaports/.githooks/pre-commit /home/meto/.local/var/pmbootstrap/cache_git/pmaports/.git/hooks/pre-commit
(007145) [05:44:43] % cp /home/meto/.local/var/pmbootstrap/cache_git/pmaports/.githooks/prepare-commit-msg /home/meto/.local/var/pmbootstrap/cache_git/pmaports/.git/hooks/prepare-commit-msg
(007145) [05:44:43] Choose your target device vendor (either an existing one, or a new one for porting).
(007145) [05:44:43] Available vendors (103): acer, alcatel, amazon, amediatech, amlogic, apple, ark, arrow, asus, ayn, bananapi, barnesnoble, beelink, blackberry, bq, clockworkpi, cubietech, cutiepi, dongshanpi, epson, essential, fairphone, finepower, fly, fxtec, generic, goclever, google, gp, hisense, htc, huawei, inet, infocus, jolla, khadas, klipad, kobo, lark, leeco, lenovo, lg, librecomputer, linksys, lynx, mangopi, medion, meizu, microsoft, mnt, mobvoi, motorola, nextbit, nobby, nokia, nothing, nvidia, odroid, oneplus, oppo, ouya, pine64, planet, pocketbook, postmarketos, powkiddy, purism, qcom, qemu, qualcomm, radxa, raspberry, realme, rockchip, samsung, semc, sharp, shift, sipeed, solidrun, sony, sourceparts, sqfmi, starway, surftab, t2m, thundercomm, tokio, tolino, trekstor, valve, vernee, vivo, volla, wd, wexler, wiko, wileyfox, xiaomi, xunlong, yu, zte, zuk
[05:44:43] Vendor [sony]: sony
(007145) [05:44:49] Devices are categorised as follows, from best to worst:
  • [95mMain[0m: ports where mostly everything works.
  • [94mCommunity[0m: often mostly usable, but may lack important functionality.
  • [92mTesting[0m: anything from "just boots in some sense" to almost fully functioning ports.
  • [93mDownstream[0m: ports that use a downstream kernel — very limited functionality. Not recommended.
Available devices by codename (22): [92mamami[0m (testing), [93maries[0m (downstream), [92mcastor[0m (testing), [93mcoconut[0m (downstream), [93meagle[0m (downstream), [93mhonami[0m (downstream), [93mivy[0m (downstream), [92mleo[0m (testing), [93mmango[0m (downstream), [92mnicki[0m (testing), [92mpioneer[0m (testing), [93mscorpion[0m (downstream), [93mseagull[0m (downstream), [92msirius[0m (testing), [93msumire[0m (downstream), [93msuzu[0m (downstream), [93msuzuran[0m (downstream), [93mtaoshan[0m (downstream), [92mtogari[0m (testing), [93mtuba[0m (downstream), [93mtulip[0m (downstream), [92myuga[0m (testing)
[05:44:49] Device codename [sirius]: sirius
[05:45:02] Username [as]: as
(007145) [05:45:05] Available providers for postmarketos-base-ui-wifi (2):
(007145) [05:45:05] * wpa_supplicant: Use wpa_supplicant as the WiFi backend. [1m(default)[0m
(007145) [05:45:05] * iwd: Use iwd as the WiFi backend (but may not work with all devices)
[05:45:05] Provider [default]: default
(007145) [05:45:07] Available user interfaces (15):
(007145) [05:45:07] * none: Bare minimum OS image for testing and manual customization. The "console" UI should be selected if a graphical UI is not desired.
(007145) [05:45:07] * buffyboard: Plain framebuffer console with modern touchscreen keyboard support
(007145) [05:45:07] * console: Console environment, with no graphical/touch UI
(007145) [05:45:07] * fbkeyboard: Plain framebuffer console with touchscreen keyboard support
(007145) [05:45:07] * gnome: (Wayland) Gnome Shell
(007145) [05:45:07] * gnome-mobile: (Wayland) Gnome Shell patched to adapt better to phones (Experimental)
(007145) [05:45:07] * i3wm: (X11) Tiling WM (keyboard required)
(007145) [05:45:07] * lxqt: (X11) Lightweight Qt Desktop Environment (stylus recommended)
(007145) [05:45:07] * mate: (X11) MATE Desktop Environment, fork of GNOME2 (stylus recommended)
(007145) [05:45:07] * openbox: (X11) A highly configurable and lightweight X11 window manager (keyboard required)
(007145) [05:45:07] * os-installer: UI for installing postmarketOS
(007145) [05:45:07] * plasma-desktop: (Wayland) KDE Desktop Environment (works well with tablets)
(007145) [05:45:07] * shelli: Plain console with touchscreen gesture support
(007145) [05:45:07] * sxmo-de-dwm: Simple Mobile: Mobile environment based on SXMO and running on dwm
(007145) [05:45:07] * sxmo-de-i3: Simple Mobile: Mobile environment based on SXMO and running on i3
(007145) [05:45:07] * xfce4: (X11) Lightweight desktop (stylus recommended)
(007145) [05:45:07] NOTE: 14 UIs are hidden because "deviceinfo_drm" is not set (see https://postmarketos.org/deviceinfo).
[05:45:07] User interface [gnome]: gnome
(007145) [05:45:11] Based on your UI selection, 'default' will result in installing systemd.
[05:45:11] Install systemd? (default/always/never) [default]: always
(007145) [05:45:51] Additional options: extra free space: 0 MB, boot partition size: 256 MB, parallel jobs: 4, ccache per arch: 5G, sudo timer: False, mirror: http://mirror.postmarketos.org/postmarketos/
[05:45:51] Change them? (y/n) [n]: n
(007145) [05:46:03] Additional packages that will be installed to rootfs. Specify them in a comma separated list (e.g.: vim,file) or "none"
[05:46:03] Extra packages [none]: none
(007145) [05:46:08] Your host timezone: America/New_York
[05:46:08] Use this timezone instead of GMT? (y/n) [y]: y
(007145) [05:46:14] Choose your preferred locale, like e.g. en_US. Only UTF-8 is supported, it gets appended automatically. Use tab-completion if needed.
[05:46:14] Locale [en_US]: tr_tr
(007145) [05:46:20] WARNING: this locale is not in the list of known valid locales.
[05:46:20] Continue? (y/n) [n]: y
[05:46:23] Device hostname (short form, e.g. 'foo') [sony-sirius]: sony-sirius
(007145) [05:46:40] NOTE: No SSH public keys found to copy to the device.
(007145) [05:46:40] See https://postmarketos.org/ssh-key-glob for more information.
(007145) [05:46:40] After pmaports are changed, the binary packages may be outdated. If you want to install postmarketOS without changes, reply 'n' for a faster installation.
[05:46:40] Build outdated packages during 'pmbootstrap install'? (y/n) [y]: y
(007145) [05:46:47] Save config: /home/meto/.config/pmbootstrap_v3.cfg
[05:46:47] Zap existing chroots to apply configuration? (y/n) [y]: y
(007145) [05:46:58] % sudo losetup --json --list
"loopdevices": [
(007145) [05:46:58] % sudo rm /home/meto/.local/var/pmbootstrap/chroot_native/in-pmbootstrap
(007145) [05:46:58] % sudo rm /home/meto/.local/var/pmbootstrap/chroot_rootfs_sony-sirius/in-pmbootstrap
(007145) [05:46:58] % sudo umount /home/meto/.local/var/pmbootstrap/chroot_native/var/cache/distfiles
(007145) [05:46:58] % sudo umount /home/meto/.local/var/pmbootstrap/chroot_native/var/cache/apk
(007145) [05:46:58] % sudo umount /home/meto/.local/var/pmbootstrap/chroot_native/sys
(007145) [05:46:58] % sudo umount /home/meto/.local/var/pmbootstrap/chroot_native/proc
(007145) [05:46:58] % sudo umount /home/meto/.local/var/pmbootstrap/chroot_native/mnt/pmbootstrap/sccache
(007145) [05:46:58] % sudo umount /home/meto/.local/var/pmbootstrap/chroot_native/mnt/pmbootstrap/rust
(007145) [05:46:58] % sudo umount /home/meto/.local/var/pmbootstrap/chroot_native/mnt/pmbootstrap/packages
(007145) [05:46:58] % sudo umount /home/meto/.local/var/pmbootstrap/chroot_native/mnt/pmbootstrap/netboot
(007145) [05:46:58] % sudo umount /home/meto/.local/var/pmbootstrap/chroot_native/mnt/pmbootstrap/go
(007145) [05:46:58] % sudo umount /home/meto/.local/var/pmbootstrap/chroot_native/mnt/pmbootstrap/git
(007145) [05:46:58] % sudo umount /home/meto/.local/var/pmbootstrap/chroot_native/mnt/pmbootstrap/ccache
(007145) [05:46:58] % sudo umount /home/meto/.local/var/pmbootstrap/chroot_native/mnt/pmbootstrap/abuild-config
(007145) [05:46:58] % sudo umount /home/meto/.local/var/pmbootstrap/chroot_native/mnt/appstream-data
(007145) [05:46:58] % sudo umount /home/meto/.local/var/pmbootstrap/chroot_native/etc/apk/keys
(007145) [05:46:58] % sudo umount /home/meto/.local/var/pmbootstrap/chroot_native/dev/shm
(007145) [05:46:58] % sudo umount /home/meto/.local/var/pmbootstrap/chroot_buildroot_armv7
(007145) [05:46:58] % sudo umount /home/meto/.local/var/pmbootstrap/chroot_rootfs_sony-sirius/var/cache/distfiles
(007145) [05:46:58] % sudo umount /home/meto/.local/var/pmbootstrap/chroot_rootfs_sony-sirius/var/cache/apk
(007145) [05:46:58] % sudo umount /home/meto/.local/var/pmbootstrap/chroot_rootfs_sony-sirius/usr/bin/qemu-arm-static
(007145) [05:46:58] % sudo umount /home/meto/.local/var/pmbootstrap/chroot_rootfs_sony-sirius/sys
(007145) [05:46:58] % sudo umount /home/meto/.local/var/pmbootstrap/chroot_rootfs_sony-sirius/proc
(007145) [05:46:58] % sudo umount /home/meto/.local/var/pmbootstrap/chroot_rootfs_sony-sirius/mnt/pmbootstrap/sccache
(007145) [05:46:58] % sudo umount /home/meto/.local/var/pmbootstrap/chroot_rootfs_sony-sirius/mnt/pmbootstrap/rust
(007145) [05:46:58] % sudo umount /home/meto/.local/var/pmbootstrap/chroot_rootfs_sony-sirius/mnt/pmbootstrap/packages
(007145) [05:46:58] % sudo umount /home/meto/.local/var/pmbootstrap/chroot_rootfs_sony-sirius/mnt/pmbootstrap/netboot
(007145) [05:46:58] % sudo umount /home/meto/.local/var/pmbootstrap/chroot_rootfs_sony-sirius/mnt/pmbootstrap/go
(007145) [05:46:58] % sudo umount /home/meto/.local/var/pmbootstrap/chroot_rootfs_sony-sirius/mnt/pmbootstrap/git
(007145) [05:46:58] % sudo umount /home/meto/.local/var/pmbootstrap/chroot_rootfs_sony-sirius/mnt/pmbootstrap/ccache
(007145) [05:46:58] % sudo umount /home/meto/.local/var/pmbootstrap/chroot_rootfs_sony-sirius/mnt/pmbootstrap/abuild-config
(007145) [05:46:58] % sudo umount /home/meto/.local/var/pmbootstrap/chroot_rootfs_sony-sirius/mnt/appstream-data
(007145) [05:46:58] % sudo umount /home/meto/.local/var/pmbootstrap/chroot_rootfs_sony-sirius/etc/apk/keys
(007145) [05:46:58] % sudo umount /home/meto/.local/var/pmbootstrap/chroot_rootfs_sony-sirius/dev/shm
(007145) [05:46:58] Unregister qemu binfmt (arm)
(007145) [05:46:58] % sudo sh -c echo -1 > /proc/sys/fs/binfmt_misc/qemu-arm
(007145) [05:46:58] Shutdown complete
(007145) [05:46:58] % sudo rm -rf /home/meto/.local/var/pmbootstrap/chroot_rootfs_sony-sirius
(007145) [05:46:59] % sudo rm -rf /home/meto/.local/var/pmbootstrap/chroot_buildroot_armv7
(007145) [05:46:59] % sudo rm -rf /home/meto/.local/var/pmbootstrap/chroot_native
(007145) [05:46:59] DONE!
(007299) [05:47:14] $ pmbootstrap /home/meto/.local/bin/pmbootstrap export
(007299) [05:47:14] Pmbootstrap v3.6.0 (Python 3.12.3 (main, Aug 14 2025, 17:47:21) [GCC 13.3.0])
(007299) [05:47:14] % cd /home/meto/.local/var/pmbootstrap/cache_git/pmaports; git remote -v
(007299) [05:47:14] % cd /home/meto/.local/var/pmbootstrap/cache_git/pmaports; git show origin/master:channels.cfg
(007299) [05:47:14] NOTE: Skipped apk version check for chroot 'rootfs_sony-sirius', because it is not installed yet!
(007299) [05:47:14] Attempting to build: postmarketos-mkinitfs
(007299) [05:47:14] armv7/postmarketos-mkinitfs: Generating dependency tree
(007299) [05:47:15] postmarketos-mkinitfs: picked provider(s) with highest priority 999: postmarketos-mkinitfs
(007299) [05:47:15] boot-deploy>=0.9: matches pmaports package
(007299) [05:47:16] postmarketos-mkinitfs: picked provider(s) with highest priority 999: postmarketos-mkinitfs
(007299) [05:47:16] /bin/sh: picked provider(s) with highest priority 100: busybox-binsh
(007299) [05:47:16] (rootfs_sony-sirius) install postmarketos-mkinitfs
(007299) [05:47:16] (rootfs_sony-sirius) chroot not initialized! This is a bug! Please report it.
(007299) [05:47:16] (rootfs_sony-sirius) initializing the chroot for you...
run_command(args)
(007299) [05:47:16] % sudo mkdir -p /home/meto/.local/var/pmbootstrap/chroot_rootfs_sony-sirius/dev
(007299) [05:47:16] % sudo mount -t tmpfs -o size=1M,noexec,dev tmpfs /home/meto/.local/var/pmbootstrap/chroot_rootfs_sony-sirius/dev
(007299) [05:47:16] % sudo mkdir -p /home/meto/.local/var/pmbootstrap/chroot_rootfs_sony-sirius/dev/pts /home/meto/.local/var/pmbootstrap/chroot_rootfs_sony-sirius/dev/shm
(007299) [05:47:16] % sudo mount -t tmpfs -o nodev,nosuid,noexec tmpfs /home/meto/.local/var/pmbootstrap/chroot_rootfs_sony-sirius/dev/shm
(007299) [05:47:16] % sudo mknod /home/meto/.local/var/pmbootstrap/chroot_rootfs_sony-sirius/dev/null c 1 3
(007299) [05:47:16] % sudo chmod 666 /home/meto/.local/var/pmbootstrap/chroot_rootfs_sony-sirius/dev/null
(007299) [05:47:16] % sudo mknod /home/meto/.local/var/pmbootstrap/chroot_rootfs_sony-sirius/dev/zero c 1 5
(007299) [05:47:16] % sudo chmod 666 /home/meto/.local/var/pmbootstrap/chroot_rootfs_sony-sirius/dev/zero
(007299) [05:47:16] % sudo mknod /home/meto/.local/var/pmbootstrap/chroot_rootfs_sony-sirius/dev/full c 1 7
(007299) [05:47:16] % sudo chmod 666 /home/meto/.local/var/pmbootstrap/chroot_rootfs_sony-sirius/dev/full
(007299) [05:47:16] % sudo mknod /home/meto/.local/var/pmbootstrap/chroot_rootfs_sony-sirius/dev/random c 1 8
(007299) [05:47:16] % sudo chmod 644 /home/meto/.local/var/pmbootstrap/chroot_rootfs_sony-sirius/dev/random
(007299) [05:47:16] % sudo mknod /home/meto/.local/var/pmbootstrap/chroot_rootfs_sony-sirius/dev/urandom c 1 9
(007299) [05:47:16] % sudo chmod 644 /home/meto/.local/var/pmbootstrap/chroot_rootfs_sony-sirius/dev/urandom
(007299) [05:47:16] % sudo ln -sf /proc/self/fd /home/meto/.local/var/pmbootstrap/chroot_rootfs_sony-sirius/dev/
(007299) [05:47:16] % sudo mkdir -p /home/meto/.local/var/pmbootstrap/chroot_rootfs_sony-sirius/proc
(007299) [05:47:16] % sudo mount --bind /proc /home/meto/.local/var/pmbootstrap/chroot_rootfs_sony-sirius/proc
(007299) [05:47:16] % sudo mkdir -p /home/meto/.local/var/pmbootstrap/chroot_rootfs_sony-sirius/sys
(007299) [05:47:16] % sudo mount --bind /sys /home/meto/.local/var/pmbootstrap/chroot_rootfs_sony-sirius/sys
(007299) [05:47:16] % sudo mkdir -p /home/meto/.local/var/pmbootstrap/chroot_rootfs_sony-sirius/var/cache/apk
(007299) [05:47:16] % sudo mount --bind /home/meto/.local/var/pmbootstrap/cache_apk_armv7 /home/meto/.local/var/pmbootstrap/chroot_rootfs_sony-sirius/var/cache/apk
(007299) [05:47:16] % sudo mkdir -p /home/meto/.local/var/pmbootstrap/chroot_rootfs_sony-sirius/mnt/appstream-data
(007299) [05:47:16] % sudo mount --bind /home/meto/.local/var/pmbootstrap/cache_appstream/armv7/edge /home/meto/.local/var/pmbootstrap/chroot_rootfs_sony-sirius/mnt/appstream-data
(007299) [05:47:16] % sudo mkdir -p /home/meto/.local/var/pmbootstrap/chroot_rootfs_sony-sirius/mnt/pmbootstrap/ccache
(007299) [05:47:16] % sudo mount --bind /home/meto/.local/var/pmbootstrap/cache_ccache_armv7 /home/meto/.local/var/pmbootstrap/chroot_rootfs_sony-sirius/mnt/pmbootstrap/ccache
(007299) [05:47:16] % sudo mkdir -p /home/meto/.local/var/pmbootstrap/chroot_rootfs_sony-sirius/var/cache/distfiles
(007299) [05:47:16] % sudo mount --bind /home/meto/.local/var/pmbootstrap/cache_distfiles /home/meto/.local/var/pmbootstrap/chroot_rootfs_sony-sirius/var/cache/distfiles
(007299) [05:47:16] % sudo mkdir -p /home/meto/.local/var/pmbootstrap/chroot_rootfs_sony-sirius/mnt/pmbootstrap/git
(007299) [05:47:16] % sudo mount --bind /home/meto/.local/var/pmbootstrap/cache_git /home/meto/.local/var/pmbootstrap/chroot_rootfs_sony-sirius/mnt/pmbootstrap/git
(007299) [05:47:16] % sudo mkdir -p /home/meto/.local/var/pmbootstrap/chroot_rootfs_sony-sirius/mnt/pmbootstrap/go
(007299) [05:47:16] % sudo mount --bind /home/meto/.local/var/pmbootstrap/cache_go /home/meto/.local/var/pmbootstrap/chroot_rootfs_sony-sirius/mnt/pmbootstrap/go
(007299) [05:47:16] % sudo mkdir -p /home/meto/.local/var/pmbootstrap/chroot_rootfs_sony-sirius/mnt/pmbootstrap/rust
(007299) [05:47:16] % sudo mount --bind /home/meto/.local/var/pmbootstrap/cache_rust /home/meto/.local/var/pmbootstrap/chroot_rootfs_sony-sirius/mnt/pmbootstrap/rust
(007299) [05:47:16] % sudo mkdir -p /home/meto/.local/var/pmbootstrap/chroot_rootfs_sony-sirius/mnt/pmbootstrap/abuild-config
(007299) [05:47:16] % sudo mount --bind /home/meto/.local/var/pmbootstrap/config_abuild /home/meto/.local/var/pmbootstrap/chroot_rootfs_sony-sirius/mnt/pmbootstrap/abuild-config
(007299) [05:47:16] % sudo mkdir -p /home/meto/.local/var/pmbootstrap/chroot_rootfs_sony-sirius/etc/apk/keys
(007299) [05:47:16] % sudo mount --bind /home/meto/.local/var/pmbootstrap/config_apk_keys /home/meto/.local/var/pmbootstrap/chroot_rootfs_sony-sirius/etc/apk/keys
(007299) [05:47:16] % sudo mkdir -p /home/meto/.local/var/pmbootstrap/chroot_rootfs_sony-sirius/mnt/pmbootstrap/sccache
(007299) [05:47:16] % sudo mount --bind /home/meto/.local/var/pmbootstrap/cache_sccache /home/meto/.local/var/pmbootstrap/chroot_rootfs_sony-sirius/mnt/pmbootstrap/sccache
(007299) [05:47:16] % sudo mkdir -p /home/meto/.local/var/pmbootstrap/chroot_rootfs_sony-sirius/mnt/pmbootstrap/netboot
(007299) [05:47:16] % sudo mount --bind /home/meto/.local/var/pmbootstrap/images_netboot /home/meto/.local/var/pmbootstrap/chroot_rootfs_sony-sirius/mnt/pmbootstrap/netboot
(007299) [05:47:16] % sudo mkdir -p /home/meto/.local/var/pmbootstrap/chroot_rootfs_sony-sirius/mnt/pmbootstrap/packages
(007299) [05:47:16] % sudo mount --bind /home/meto/.local/var/pmbootstrap/packages /home/meto/.local/var/pmbootstrap/chroot_rootfs_sony-sirius/mnt/pmbootstrap/packages
(007299) [05:47:16] % sudo mkdir -p /home/meto/.local/var/pmbootstrap/chroot_native/dev
(007299) [05:47:16] % sudo mount -t tmpfs -o size=1M,noexec,dev tmpfs /home/meto/.local/var/pmbootstrap/chroot_native/dev
(007299) [05:47:16] % sudo mkdir -p /home/meto/.local/var/pmbootstrap/chroot_native/dev/pts /home/meto/.local/var/pmbootstrap/chroot_native/dev/shm
(007299) [05:47:16] % sudo mount -t tmpfs -o nodev,nosuid,noexec tmpfs /home/meto/.local/var/pmbootstrap/chroot_native/dev/shm
(007299) [05:47:16] % sudo mknod /home/meto/.local/var/pmbootstrap/chroot_native/dev/null c 1 3
(007299) [05:47:16] % sudo chmod 666 /home/meto/.local/var/pmbootstrap/chroot_native/dev/null
(007299) [05:47:16] % sudo mknod /home/meto/.local/var/pmbootstrap/chroot_native/dev/zero c 1 5
(007299) [05:47:16] % sudo chmod 666 /home/meto/.local/var/pmbootstrap/chroot_native/dev/zero
(007299) [05:47:16] % sudo mknod /home/meto/.local/var/pmbootstrap/chroot_native/dev/full c 1 7
(007299) [05:47:16] % sudo chmod 666 /home/meto/.local/var/pmbootstrap/chroot_native/dev/full
(007299) [05:47:16] % sudo mknod /home/meto/.local/var/pmbootstrap/chroot_native/dev/random c 1 8
(007299) [05:47:16] % sudo chmod 644 /home/meto/.local/var/pmbootstrap/chroot_native/dev/random
(007299) [05:47:16] % sudo mknod /home/meto/.local/var/pmbootstrap/chroot_native/dev/urandom c 1 9
(007299) [05:47:16] % sudo chmod 644 /home/meto/.local/var/pmbootstrap/chroot_native/dev/urandom
(007299) [05:47:16] % sudo ln -sf /proc/self/fd /home/meto/.local/var/pmbootstrap/chroot_native/dev/
(007299) [05:47:16] % sudo mkdir -p /home/meto/.local/var/pmbootstrap/chroot_native/proc
(007299) [05:47:16] % sudo mount --bind /proc /home/meto/.local/var/pmbootstrap/chroot_native/proc
(007299) [05:47:16] % sudo mkdir -p /home/meto/.local/var/pmbootstrap/chroot_native/sys
(007299) [05:47:16] % sudo mount --bind /sys /home/meto/.local/var/pmbootstrap/chroot_native/sys
(007299) [05:47:16] % sudo mkdir -p /home/meto/.local/var/pmbootstrap/chroot_native/var/cache/apk
(007299) [05:47:16] % sudo mount --bind /home/meto/.local/var/pmbootstrap/cache_apk_x86_64 /home/meto/.local/var/pmbootstrap/chroot_native/var/cache/apk
(007299) [05:47:16] % sudo mkdir -p /home/meto/.local/var/pmbootstrap/chroot_native/mnt/appstream-data
(007299) [05:47:16] % sudo mount --bind /home/meto/.local/var/pmbootstrap/cache_appstream/x86_64/edge /home/meto/.local/var/pmbootstrap/chroot_native/mnt/appstream-data
(007299) [05:47:16] % sudo mkdir -p /home/meto/.local/var/pmbootstrap/chroot_native/mnt/pmbootstrap/ccache
(007299) [05:47:16] % sudo mount --bind /home/meto/.local/var/pmbootstrap/cache_ccache_x86_64 /home/meto/.local/var/pmbootstrap/chroot_native/mnt/pmbootstrap/ccache
(007299) [05:47:16] % sudo mkdir -p /home/meto/.local/var/pmbootstrap/chroot_native/var/cache/distfiles
(007299) [05:47:17] % sudo mount --bind /home/meto/.local/var/pmbootstrap/cache_distfiles /home/meto/.local/var/pmbootstrap/chroot_native/var/cache/distfiles
(007299) [05:47:17] % sudo mkdir -p /home/meto/.local/var/pmbootstrap/chroot_native/mnt/pmbootstrap/git
(007299) [05:47:17] % sudo mount --bind /home/meto/.local/var/pmbootstrap/cache_git /home/meto/.local/var/pmbootstrap/chroot_native/mnt/pmbootstrap/git
(007299) [05:47:17] % sudo mkdir -p /home/meto/.local/var/pmbootstrap/chroot_native/mnt/pmbootstrap/go
(007299) [05:47:17] % sudo mount --bind /home/meto/.local/var/pmbootstrap/cache_go /home/meto/.local/var/pmbootstrap/chroot_native/mnt/pmbootstrap/go
(007299) [05:47:17] % sudo mkdir -p /home/meto/.local/var/pmbootstrap/chroot_native/mnt/pmbootstrap/rust
(007299) [05:47:17] % sudo mount --bind /home/meto/.local/var/pmbootstrap/cache_rust /home/meto/.local/var/pmbootstrap/chroot_native/mnt/pmbootstrap/rust
(007299) [05:47:17] % sudo mkdir -p /home/meto/.local/var/pmbootstrap/chroot_native/mnt/pmbootstrap/abuild-config
(007299) [05:47:17] % sudo mount --bind /home/meto/.local/var/pmbootstrap/config_abuild /home/meto/.local/var/pmbootstrap/chroot_native/mnt/pmbootstrap/abuild-config
(007299) [05:47:17] % sudo mkdir -p /home/meto/.local/var/pmbootstrap/chroot_native/etc/apk/keys
(007299) [05:47:17] % sudo mount --bind /home/meto/.local/var/pmbootstrap/config_apk_keys /home/meto/.local/var/pmbootstrap/chroot_native/etc/apk/keys
(007299) [05:47:17] % sudo mkdir -p /home/meto/.local/var/pmbootstrap/chroot_native/mnt/pmbootstrap/sccache
(007299) [05:47:17] % sudo mount --bind /home/meto/.local/var/pmbootstrap/cache_sccache /home/meto/.local/var/pmbootstrap/chroot_native/mnt/pmbootstrap/sccache
(007299) [05:47:17] % sudo mkdir -p /home/meto/.local/var/pmbootstrap/chroot_native/mnt/pmbootstrap/netboot
(007299) [05:47:17] % sudo mount --bind /home/meto/.local/var/pmbootstrap/images_netboot /home/meto/.local/var/pmbootstrap/chroot_native/mnt/pmbootstrap/netboot
(007299) [05:47:17] % sudo mkdir -p /home/meto/.local/var/pmbootstrap/chroot_native/mnt/pmbootstrap/packages
(007299) [05:47:17] % sudo mount --bind /home/meto/.local/var/pmbootstrap/packages /home/meto/.local/var/pmbootstrap/chroot_native/mnt/pmbootstrap/packages
(007299) [05:47:17] % sudo touch /home/meto/.local/var/pmbootstrap/chroot_native/in-pmbootstrap
(007299) [05:47:17] sigfilename: sbin/apk.static.SIGN.RSA.sha256.alpine-devel@lists.alpinelinux.org-6165ee59.rsa.pub
(007299) [05:47:17] sigkey: [email protected]
(007299) [05:47:17] extracted: /tmp/pmbootstrap15fn167dapk
(007299) [05:47:17] extracted: /tmp/pmbootstrap6z2k6fmmsig
(007299) [05:47:17] Verify apk.static signature with /home/meto/Desktop/pmbootstrap/pmb/data/keys/[email protected]
(007299) [05:47:17] % openssl dgst -sha256 -verify /home/meto/Desktop/pmbootstrap/pmb/data/keys/[email protected] -signature /tmp/pmbootstrap6z2k6fmmsig /tmp/pmbootstrap15fn167dapk
Verified OK
(007299) [05:47:17] Verify the version reported by the apk.static binary (must match the package version 3.0.0_rc9-r1)
(007299) [05:47:17] % /tmp/pmbootstrap15fn167dapk --version
(007299) [05:47:17] (native) Creating chroot
(007299) [05:47:17] % sudo cp /etc/resolv.conf /home/meto/.local/var/pmbootstrap/chroot_native/etc/resolv.conf
(007299) [05:47:17] (chroot_native) update /etc/apk/repositories
(007299) [05:47:17] % sudo sh -c echo http://mirror.postmarketos.org/postmarketos/extra-repos/systemd/master >> /home/meto/.local/var/pmbootstrap/chroot_native/etc/apk/repositories
(007299) [05:47:17] % sudo sh -c echo http://mirror.postmarketos.org/postmarketos/master >> /home/meto/.local/var/pmbootstrap/chroot_native/etc/apk/repositories
(007299) [05:47:17] % sudo sh -c echo http://dl-cdn.alpinelinux.org/alpine/edge/main >> /home/meto/.local/var/pmbootstrap/chroot_native/etc/apk/repositories
(007299) [05:47:17] % sudo sh -c echo http://dl-cdn.alpinelinux.org/alpine/edge/community >> /home/meto/.local/var/pmbootstrap/chroot_native/etc/apk/repositories
(007299) [05:47:17] % sudo sh -c echo http://dl-cdn.alpinelinux.org/alpine/edge/testing >> /home/meto/.local/var/pmbootstrap/chroot_native/etc/apk/repositories
(007299) [05:47:17] % sudo mkdir -p /home/meto/.local/var/pmbootstrap/chroot_native/usr/bin /home/meto/.local/var/pmbootstrap/chroot_native/usr/sbin /home/meto/.local/var/pmbootstrap/chroot_native/usr/lib
(007299) [05:47:17] % sudo ln -s usr/bin usr/sbin usr/lib /home/meto/.local/var/pmbootstrap/chroot_native/
(007299) [05:47:17] % sudo mkdir -p /home/meto/.local/var/pmbootstrap/tmp
(007299) [05:47:17] % sudo rm -f /home/meto/.local/var/pmbootstrap/tmp/apk_progress_fifo
(007299) [05:47:17] % sudo mkfifo /home/meto/.local/var/pmbootstrap/tmp/apk_progress_fifo
(007299) [05:47:17] % sudo cat /home/meto/.local/var/pmbootstrap/tmp/apk_progress_fifo
(007299) [05:47:17] % sudo sh -c exec 3>/home/meto/.local/var/pmbootstrap/tmp/apk_progress_fifo; /home/meto/.local/var/pmbootstrap/apk.static --progress-fd 3 --no-progress --root /home/meto/.local/var/pmbootstrap/chroot_native --arch x86_64 --cache-dir /home/meto/.local/var/pmbootstrap/cache_apk_x86_64 --repository /home/meto/.local/var/pmbootstrap/packages/edge --repository /home/meto/.local/var/pmbootstrap/packages/systemd-edge --initdb add --no-interactive alpine-baselayout apk-tools busybox musl-utils ;
(007299) [05:47:17] New background process: pid=7604, output=background
(007299) [05:47:18] (native) % adduser -D pmos -u 12345
(007299) [05:47:18] (native) % busybox su pmos -c HOME=/home/pmos ln -s /mnt/pmbootstrap/abuild-config /home/pmos/.abuild ;
(007299) [05:47:18] (native) % chown pmos:pmos /mnt/pmbootstrap/abuild-config
(007299) [05:47:18] (native) % busybox su pmos -c HOME=/home/pmos ln -s /mnt/pmbootstrap/ccache /home/pmos/.ccache ;
(007299) [05:47:18] (native) % chown pmos:pmos /mnt/pmbootstrap/ccache
(007299) [05:47:18] (native) % busybox su pmos -c HOME=/home/pmos mkdir -p /home/pmos/.cache ;
(007299) [05:47:18] (native) % busybox su pmos -c HOME=/home/pmos ln -s /mnt/pmbootstrap/go/gocache /home/pmos/.cache/go-build ;
(007299) [05:47:18] (native) % chown pmos:pmos /mnt/pmbootstrap/go/gocache
(007299) [05:47:18] (native) % busybox su pmos -c HOME=/home/pmos mkdir -p /home/pmos/go/pkg ;
(007299) [05:47:18] (native) % busybox su pmos -c HOME=/home/pmos ln -s /mnt/pmbootstrap/go/gomodcache /home/pmos/go/pkg/mod ;
(007299) [05:47:18] (native) % chown pmos:pmos /mnt/pmbootstrap/go/gomodcache
(007299) [05:47:18] (native) % busybox su pmos -c HOME=/home/pmos mkdir -p /home/pmos/.cargo/git ;
(007299) [05:47:18] (native) % busybox su pmos -c HOME=/home/pmos ln -s /mnt/pmbootstrap/rust/git/db /home/pmos/.cargo/git/db ;
(007299) [05:47:18] (native) % chown pmos:pmos /mnt/pmbootstrap/rust/git/db
(007299) [05:47:18] (native) % busybox su pmos -c HOME=/home/pmos mkdir -p /home/pmos/.cargo/registry ;
(007299) [05:47:18] (native) % busybox su pmos -c HOME=/home/pmos ln -s /mnt/pmbootstrap/rust/registry/cache /home/pmos/.cargo/registry/cache ;
(007299) [05:47:18] (native) % chown pmos:pmos /mnt/pmbootstrap/rust/registry/cache
(007299) [05:47:18] (native) % busybox su pmos -c HOME=/home/pmos ln -s /mnt/pmbootstrap/rust/registry/index /home/pmos/.cargo/registry/index ;
(007299) [05:47:18] (native) % chown pmos:pmos /mnt/pmbootstrap/rust/registry/index
(007299) [05:47:18] (native) % busybox su pmos -c HOME=/home/pmos ln -s /mnt/pmbootstrap/sccache /home/pmos/.cache/sccache ;
(007299) [05:47:18] (native) % chown pmos:pmos /mnt/pmbootstrap/sccache
(007299) [05:47:18] Attempting to build: qemu-arm
(007299) [05:47:19] (native) install qemu-arm
(007299) [05:47:19] % sudo mkdir -p /home/meto/.local/var/pmbootstrap/tmp
(007299) [05:47:19] % sudo rm -f /home/meto/.local/var/pmbootstrap/tmp/apk_progress_fifo
(007299) [05:47:19] % sudo mkfifo /home/meto/.local/var/pmbootstrap/tmp/apk_progress_fifo
(007299) [05:47:19] % sudo cat /home/meto/.local/var/pmbootstrap/tmp/apk_progress_fifo
(007299) [05:47:19] % sudo sh -c exec 3>/home/meto/.local/var/pmbootstrap/tmp/apk_progress_fifo; /home/meto/.local/var/pmbootstrap/apk.static --progress-fd 3 --no-progress --root /home/meto/.local/var/pmbootstrap/chroot_native --arch x86_64 --cache-dir /home/meto/.local/var/pmbootstrap/cache_apk_x86_64 --repository /home/meto/.local/var/pmbootstrap/packages/edge --repository /home/meto/.local/var/pmbootstrap/packages/systemd-edge --repository /home/meto/.local/var/pmbootstrap/packages/edge --repository /home/meto/.local/var/pmbootstrap/packages/systemd-edge add --no-interactive qemu-arm ;
(007299) [05:47:19] New background process: pid=7720, output=background
(007299) [05:47:20] Register qemu binfmt (arm)
(007299) [05:47:20] % sudo sh -c echo ":qemu-arm:M::\x7f\x45\x4c\x46\x01\x01\x01\x00\x00\x00\x00\x00\x00\x00\x00\x00\x02\x00\x28\x00:\xff\xff\xff\xff\xff\xff\xff\x00\xff\xff\xff\xff\xff\xff\xff\xff\xfe\xff\xff\xff:/usr/bin/qemu-arm-static:C" > /proc/sys/fs/binfmt_misc/register
(007299) [05:47:20] % sudo mkdir -p /home/meto/.local/var/pmbootstrap/chroot_rootfs_sony-sirius/usr/bin
(007299) [05:47:20] % sudo touch /home/meto/.local/var/pmbootstrap/chroot_rootfs_sony-sirius/usr/bin/qemu-arm-static
(007299) [05:47:20] % sudo mount --bind /home/meto/.local/var/pmbootstrap/chroot_native/usr/bin/qemu-arm /home/meto/.local/var/pmbootstrap/chroot_rootfs_sony-sirius/usr/bin/qemu-arm-static
(007299) [05:47:20] % sudo touch /home/meto/.local/var/pmbootstrap/chroot_rootfs_sony-sirius/in-pmbootstrap
(007299) [05:47:20] sigfilename: sbin/apk.static.SIGN.RSA.sha256.alpine-devel@lists.alpinelinux.org-6165ee59.rsa.pub
(007299) [05:47:20] sigkey: [email protected]
(007299) [05:47:20] extracted: /tmp/pmbootstrapdy7jc7x6apk
(007299) [05:47:20] extracted: /tmp/pmbootstrap0o5lnydysig
(007299) [05:47:20] Verify apk.static signature with /home/meto/Desktop/pmbootstrap/pmb/data/keys/[email protected]
(007299) [05:47:20] % openssl dgst -sha256 -verify /home/meto/Desktop/pmbootstrap/pmb/data/keys/[email protected] -signature /tmp/pmbootstrap0o5lnydysig /tmp/pmbootstrapdy7jc7x6apk
Verified OK
(007299) [05:47:20] Verify the version reported by the apk.static binary (must match the package version 3.0.0_rc9-r1)
(007299) [05:47:20] % /tmp/pmbootstrapdy7jc7x6apk --version
(007299) [05:47:20] (rootfs_sony-sirius) Creating chroot
(007299) [05:47:20] % sudo cp /etc/resolv.conf /home/meto/.local/var/pmbootstrap/chroot_rootfs_sony-sirius/etc/resolv.conf
(007299) [05:47:20] % sudo mkdir -p /home/meto/.local/var/pmbootstrap/chroot_rootfs_sony-sirius/etc/apk
(007299) [05:47:20] (chroot_rootfs_sony-sirius) update /etc/apk/repositories
(007299) [05:47:20] % sudo sh -c echo http://mirror.postmarketos.org/postmarketos/extra-repos/systemd/master >> /home/meto/.local/var/pmbootstrap/chroot_rootfs_sony-sirius/etc/apk/repositories
(007299) [05:47:20] % sudo sh -c echo http://mirror.postmarketos.org/postmarketos/master >> /home/meto/.local/var/pmbootstrap/chroot_rootfs_sony-sirius/etc/apk/repositories
(007299) [05:47:20] % sudo sh -c echo http://dl-cdn.alpinelinux.org/alpine/edge/main >> /home/meto/.local/var/pmbootstrap/chroot_rootfs_sony-sirius/etc/apk/repositories
(007299) [05:47:20] % sudo sh -c echo http://dl-cdn.alpinelinux.org/alpine/edge/community >> /home/meto/.local/var/pmbootstrap/chroot_rootfs_sony-sirius/etc/apk/repositories
(007299) [05:47:20] % sudo sh -c echo http://dl-cdn.alpinelinux.org/alpine/edge/testing >> /home/meto/.local/var/pmbootstrap/chroot_rootfs_sony-sirius/etc/apk/repositories
(007299) [05:47:20] % sudo mkdir -p /home/meto/.local/var/pmbootstrap/chroot_rootfs_sony-sirius/usr/bin /home/meto/.local/var/pmbootstrap/chroot_rootfs_sony-sirius/usr/sbin /home/meto/.local/var/pmbootstrap/chroot_rootfs_sony-sirius/usr/lib
(007299) [05:47:20] % sudo ln -s usr/bin usr/sbin usr/lib /home/meto/.local/var/pmbootstrap/chroot_rootfs_sony-sirius/
(007299) [05:47:20] % sudo mkdir -p /home/meto/.local/var/pmbootstrap/tmp
(007299) [05:47:20] % sudo rm -f /home/meto/.local/var/pmbootstrap/tmp/apk_progress_fifo
(007299) [05:47:20] % sudo mkfifo /home/meto/.local/var/pmbootstrap/tmp/apk_progress_fifo
(007299) [05:47:20] % sudo cat /home/meto/.local/var/pmbootstrap/tmp/apk_progress_fifo
(007299) [05:47:20] % sudo sh -c exec 3>/home/meto/.local/var/pmbootstrap/tmp/apk_progress_fifo; /home/meto/.local/var/pmbootstrap/apk.static --progress-fd 3 --no-progress --root /home/meto/.local/var/pmbootstrap/chroot_rootfs_sony-sirius --arch armv7 --cache-dir /home/meto/.local/var/pmbootstrap/cache_apk_armv7 --repository /home/meto/.local/var/pmbootstrap/packages/edge --repository /home/meto/.local/var/pmbootstrap/packages/systemd-edge --initdb add --no-interactive alpine-baselayout apk-tools busybox musl-utils ;
(007299) [05:47:20] New background process: pid=7782, output=background
(007299) [05:47:21] % sudo mkdir -p /home/meto/.local/var/pmbootstrap/tmp
(007299) [05:47:21] % sudo rm -f /home/meto/.local/var/pmbootstrap/tmp/apk_progress_fifo
(007299) [05:47:21] % sudo mkfifo /home/meto/.local/var/pmbootstrap/tmp/apk_progress_fifo
(007299) [05:47:21] % sudo cat /home/meto/.local/var/pmbootstrap/tmp/apk_progress_fifo
(007299) [05:47:21] % sudo sh -c exec 3>/home/meto/.local/var/pmbootstrap/tmp/apk_progress_fifo; /home/meto/.local/var/pmbootstrap/apk.static --progress-fd 3 --no-progress --root /home/meto/.local/var/pmbootstrap/chroot_rootfs_sony-sirius --arch armv7 --cache-dir /home/meto/.local/var/pmbootstrap/cache_apk_armv7 --repository /home/meto/.local/var/pmbootstrap/packages/edge --repository /home/meto/.local/var/pmbootstrap/packages/systemd-edge --repository /home/meto/.local/var/pmbootstrap/packages/edge --repository /home/meto/.local/var/pmbootstrap/packages/systemd-edge add --no-interactive postmarketos-mkinitfs ;
(007299) [05:47:21] New background process: pid=7838, output=background
(007299) [05:47:22] (rootfs_sony-sirius) mkinitfs
(007299) [05:47:22] (rootfs_sony-sirius) % mkinitfs
10:47:22.303917 Error reading deviceinfo
10:47:22.309304 /usr/share/deviceinfo/deviceinfo: "/usr/share/deviceinfo/deviceinfo" not found, required by mkinitfs
10:47:22.310493 /etc/deviceinfo: "/etc/deviceinfo" not found, required by mkinitfs
(007299) [05:47:22] ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^
(007299) [05:47:22] NOTE: The failed command's output is above the ^^^ line in the log file: /home/meto/.local/var/pmbootstrap/log.txt
(007299) [05:47:22] ERROR: Command failed (exit code 1): (rootfs_sony-sirius) % mkinitfs
(007299) [05:47:22] See also: <https://postmarketos.org/troubleshooting>
(007299) [05:47:22] Traceback (most recent call last):
File "/home/meto/Desktop/pmbootstrap/pmb/init.py", line 110, in main
run_command(args)
File "/home/meto/Desktop/pmbootstrap/pmb/commands/init.py", line 55, in run_command
getattr(frontend, args.action)(args)
File "/home/meto/Desktop/pmbootstrap/pmb/helpers/frontend.py", line 405, in export
pmb.export.frontend(args)
File "/home/meto/Desktop/pmbootstrap/pmb/export/frontend.py", line 33, in frontend
pmb.chroot.initfs.build(Chroot(ChrootType.ROOTFS, config.device))
return rootm(
(007299) [05:47:22] % cd /home/meto/.local/var/pmbootstrap/cache_git/pmaports; git rev-parse --abbrev-ref HEAD
(007299) [05:47:22] % cd /home/meto/.local/var/pmbootstrap/cache_git/pmaports; git status --porcelain
Bunlar yazıyor hocam.
Pmbootstrap zap.
Pmbootstrap init.
Pmbootstrap install --F'de
Bu şekilde deneyebilir misin?
Deneyeyim hocam.
Pmbootstrap zap.
Pmbootstrap init.
Meto@meto-IPXSB-H61:~/desktop$ pmbootstrap init.
[06:28:08] location of the 'work' path. Multiple chroots (native, device Arch, device rootfs) will be created in there.
[06:28:08] work path [/home/meto/.local/var/pmbootstrap]:
[06:28:10] location of the 'pmaports' path, containing package definitions.
[06:28:10] pmaports path [/home/meto/.local/var/pmbootstrap/cache_git/pmaports]:
[06:28:13] choose the postmarketOS release channel.
[06:28:13] available (13):
[06:28:13] * Edge: Rolling release / most devices / occasional breakage: https://postmarketos.org/edge
[06:28:13] * v25.12: Upcoming stable release (do not use)
[06:28:13] * v25.06: Latest release / recommended for best stability.
[06:28:13] channel [edge]: Pmbootstrap zap.
[06:28:36] error: Invalid channel specified, please type in One from the list above.
[06:28:36] channel [edge]:
Böyle oluyor hocam başka cihazda deneyeceğim.
