SYSTEM_THREAD_EXCEPTION_NOT_HANDLED (7e)
This is a very common BugCheck. Usually the exception address pinpoints
the driver/function that caused the problem. Always note this address
as well as the link date of the driver/image that contains this address.
Arguments:
Arg1: ffffffffc0000005, The exception code that was not handled
Arg2: fffff8074fcd45c5, The address that the exception occurred at
Arg3: ffffec02b3ed72b8, Exception Record Address
Arg4: ffff9c018838f920, Context Record Address
Debugging Details:
KEY_VALUES_STRING: 1
Key : AV.Fault
Value: Read
Key : Analysis.CPU.mSec
Value: 1187
Key : Analysis.Elapsed.mSec
Value: 12157
Key : Analysis.IO.Other.Mb
Value: 1
Key : Analysis.IO.Read.Mb
Value: 0
Key : Analysis.IO.Write.Mb
Value: 10
Key : Analysis.Init.CPU.mSec
Value: 249
Value: 3160
Value: 89
Key : Bugcheck.Code.LegacyAPI
Value: 0x1000007e
Key : Bugcheck.Code.TargetModel
Value: 0x1000007e
Key : Dump.Attributes.AsUlong
Value: 8
Key : Dump.Attributes.KernelGeneratedTriageDump
Value: 1
Key : Failure.Bucket
Value: AV_nt!MmEnoughMemoryForWrite
Key : Failure.Hash
Value: {b53d6dc6-0be9-7f68-fe27-1d623e912e5b}
BUGCHECK_CODE: 7e
BUGCHECK_P1: ffffffffc0000005
BUGCHECK_P2: fffff8074fcd45c5
BUGCHECK_P3: ffffec02b3ed72b8
BUGCHECK_P4: ffff9c018838f920
FILE_IN_CAB: 090324-11046-01.dmp
DUMP_FILE_ATTRIBUTES: 0x8
Kernel Generated Triage Dump
FAULTING_THREAD: ffff8006d00bd080
EXCEPTION_RECORD: ffffec02b3ed72b8 -- (.exr 0xffffec02b3ed72b8)
ExceptionAddress: fffff8074fcd45c5 (nt!MmEnoughMemoryForWrite+0x0000000000000021)
ExceptionCode: c0000005 (Access violation)
ExceptionFlags: 00000000
NumberParameters: 2
Parameter[0]: 0000000000000000
Parameter[1]: ffff80066121a307
Attempt to read from address ffff80066121a307
CONTEXT: ffff9c018838f920 -- (.cxr 0xffff9c018838f920)
rax=ffffec02b3ed7528 rbx=ffff8006d9731e11 rcx=ffff8006d9731ef8
rdx=0000000000000000 rsi=ffff8006d96cdd00 rdi=ffff8006d700db00
rip=fffff8074fcd45c5 rsp=ffffec02b3ed74f0 rbp=0000000000000000
r8=ffff8006c8512b00 r9=ffff8006d96cdd70 r10=0000000000000000
r11=ffff93800326dd68 r12=0000000000000000 r13=0000000000000008
r14=0000000000000001 r15=0000000000000008
iopl=0 nv up ei pl zr na po nc
cs=0010 ss=0018 ds=002b es=002b fs=0053 gs=002b efl=00050246
nt!MmEnoughMemoryForWrite+0x21:
fffff807`4fcd45c5 4885890f84ae87 test qword ptr [rcx-78517BF1h],rcx ds:002b:ffff8006`6121a307=????????????????
Resetting default scope
BLACKBOXBSD: 1 (!blackboxbsd)
BLACKBOXPNP: 1 (!blackboxpnp)
BLACKBOXWINLOGON: 1
CUSTOMER_CRASH_COUNT: 1
PROCESS_NAME: System
READ_ADDRESS: fffff807506fb390: Unable to get MiVisibleState
Unable to get NonPagedPoolStart
Unable to get NonPagedPoolEnd
Unable to get PagedPoolStart
Unable to get PagedPoolEnd
unable to get nt!MmSpecialPagesInUse
ffff80066121a307
ERROR_CODE: (NTSTATUS) 0xc0000005 - 0x%p adresindeki y nerge 0x%p adresindeki belle e ba vurdu. Bellek u olamaz %s.
EXCEPTION_CODE_STR: c0000005
EXCEPTION_PARAMETER1: 0000000000000000
EXCEPTION_PARAMETER2: ffff80066121a307
EXCEPTION_STR: 0xc0000005
STACK_TEXT:
ffffec02`b3ed74f0 fffff807`4fc658a7 : fffff807`4b493a11 ffff8006`d9731ef8 ffffec02`b3ed7598 00000000`00000000 : nt!MmEnoughMemoryForWrite+0x21
ffffec02`b3ed7530 fffff807`4fc60c02 : ffff8006`c8512b00 ffff8006`d96cdd70 00000000`00000000 ffff8006`d700db00 : nt!CcCanIWriteStreamEx+0x277
ffffec02`b3ed75e0 fffff807`4fcd54aa : ffff8006`d9677d50 ffff8006`d9677dd0 00000000`00000000 00000000`00000002 : nt!CcNotifyOfMappedWrite+0x15e
ffffec02`b3ed76b0 fffff807`4fdb786b : fffff807`50650b80 00000000`00000011 ffff8006`d6a13570 00000000`00000000 : nt!MiGatherMappedPages+0x1c6
ffffec02`b3ed7770 fffff807`4fd078e5 : ffff8006`d00bd080 ffff8006`d00bd080 00000000`00000080 000fe067`bcbbbdff : nt!MiMappedPageWriter+0x18b
ffffec02`b3ed7bd0 fffff807`4fe064b8 : ffff9c01`87cc9180 ffff8006`d00bd080 fffff807`4fd07890 00000000`00000000 : nt!PspSystemThreadStartup+0x55
ffffec02`b3ed7c20 00000000`00000000 : ffffec02`b3ed8000 ffffec02`b3ed1000 00000000`00000000 00000000`00000000 : nt!KiStartSystemThread+0x28
SYMBOL_NAME: nt!MmEnoughMemoryForWrite+21
MODULE_NAME: nt
IMAGE_VERSION: 10.0.19041.3803
STACK_COMMAND: .cxr 0xffff9c018838f920 ; kb
IMAGE_NAME: ntkrnlmp.exe
BUCKET_ID_FUNC_OFFSET: 21
FAILURE_BUCKET_ID: AV_nt!MmEnoughMemoryForWrite
OSPLATFORM_TYPE: x64
OSNAME: Windows 10
FAILURE_ID_HASH: {b53d6dc6-0be9-7f68-fe27-1d623e912e5b}
Followup: MachineOwner
PnpActivityId : {00000000-0000-0000-0000-000000000000}
PnpActivityTime : 133698505957093012
PnpEventInformation: 5
PnpEventInProgress : 0
PnpProblemCode : 43
PnpVetoType : 0
DeviceId : USB\VID_0E8D&PID_0608&MI_00\7&330f77bf&0&0000
VetoString :
[SMBIOS Data Tables v2.8]
[DMI Version - 0]
[2.0 Calling Convention - No]
[Table Size - 2685 bytes]
Vendor American Megatrends International, LLC.
BIOS Version 2.81
BIOS Release Date 05/06/2024
BIOS ROM Size 1000000
BIOS Characteristics
07: - PCI Supported
11: - Upgradeable FLASH BIOS
15: - CD-Boot Supported
17: - BIOS ROM Socketed
19: - EDD Supported
22: - 360KB Floppy Supported
23: - 1.2MB Floppy Supported
24: - 720KB Floppy Supported
25: - 2.88MB Floppy Supported
27: - Keyboard Services Supported
32: - BIOS Vendor Reserved
01: - USB Legacy Supported
BIOS Major Revision 5
BIOS Minor Revision 17
EC Firmware Major Revision 255
EC Firmware Minor Revision 255
Extended BIOS ROM Size 32 MB
Manufacturer Micro-Star International Co., Ltd.
Product Name MS-7C91
Version 1.0
Serial Number To be filled by O.E.M.
UUID 00000000-0000-0000-0000-000000000000
Wakeup Type Power Switch
SKUNumber To be filled by O.E.M.
Family To be filled by O.E.M.
Product MAG B550 TOMAHAWK MAX WIFI (MS-7C91)
Version 1.0
Serial Number 07C9114_N91E883989
Asset Tag
Feature Flags 09h
00: - Motherboard
03: - Replaceable
Location To be filled by O.E.M.
Chassis Handle 0003h
Board Type 0ah - Processor/Memory Module
Number of Child Handles 0
Chassis Type Desktop
Version 1.0
Serial Number
Asset Tag Number
Bootup State Safe
Power Supply State Safe
Thermal State Safe
Security Status None
OEM Defined 0
Height 0U
Number of Power Cords 1
Number of Contained Elements 0
Contained Element Size 3
[OEM Strings (Type 11) - Length 5 - Handle 000bh]
Number of Strings 1
1 To be filled by O.E.M.
[System Configuration Options (Type 12) - Length 5 - Handle 000ch]
[ (Type 256) - Length 9 - Handle 000eh]
[ (Type 256) - Length 31 - Handle 000fh]
[32Bit Memory Error Information (Type 18) - Length 23 - Handle 0010h]
[Physical Memory Array (Type 16) - Length 23 - Handle 0011h]
Location 03h - SystemBoard/Motherboard
Use 03h - System Memory
Memory Error Correction 03h - None
Maximum Capacity 134217728KB
Memory Error Inf Handle 0010h
Number of Memory Devices 4
[Memory Array Mapped Address (Type 19) - Length 31 - Handle 0012h]
Starting Address 00000000h
Ending Address 0037ffffh
Memory Array Handle 0011h
Partition Width 02
Extended Starting Address 0000000000000000h
Extended Ending Address 0000000000000000h
[Memory Array Mapped Address (Type 19) - Length 31 - Handle 0013h]
Starting Address 00400000h
Ending Address 0207ffffh
Partition Width 02
[Cache Information (Type 7) - Length 19 - Handle 0014h]
Socket Designation L1 - Cache
Cache Configuration 0180h - WBEnabled Int NonSocketed L1
Maximum Cache Size 0200h - 512K
Installed Size 0200h - 512K
Supported SRAM Type 0010h - Pipeline-Burst
Current SRAM Type 0010h - Pipeline-Burst
Cache Speed 1ns
Error Correction Type Specification Reserved
System Cache Type Unified
Associativity 8-way Set-Associative
Maximum Cache Size 2 2d20314c - 757084492l Kb
[Cache Information (Type 7) - Length 19 - Handle 0015h]
Socket Designation L2 - Cache
Cache Configuration 0181h - WBEnabled Int NonSocketed L2
Maximum Cache Size 1000h - 4096K
Installed Size 1000h - 4096K
Cache Speed 1ns
Maximum Cache Size 2 2d20324c - 757084748l Kb
[Cache Information (Type 7) - Length 19 - Handle 0016h]
Socket Designation L3 - Cache
Cache Configuration 0182h - WBEnabled Int NonSocketed L3
Maximum Cache Size 8600h - 98304K
Installed Size 8600h - 98304K
Cache Speed 1ns
Associativity 16-way Set-Associative
Maximum Cache Size 2 2d20334c - 757085004l Kb
[Processor Information (Type 4) - Length 48 - Handle 0017h]
Socket Designation AM4
Processor Type Central Processor
Processor Family 6bh - AMD Zen Processor Family
Processor Manufacturer Advanced Micro Devices, Inc.
Processor ID 120fa200fffb8b17
Processor Version AMD Ryzen 7 5800X3D 8-Core Processor
Processor Voltage 8bh - 1.1V
External Clock 100MHz
Max Speed 3400MHz
Current Speed 3400MHz
Status Enabled Populated
Processor Upgrade Socket AM4
L1 Cache Handle 0014h
L2 Cache Handle 0015h
L3 Cache Handle 0016h
Serial Number
Asset Tag Number
Part Number Unknown
Core Count 8
Core Enabled 8
Thread Count 16
Processor Characteristics fc
Enabled Characteristics:
0x 2: 64-bit Capable
0x 3: Multi-Core
0x 4: Hardware Thread
0x 5: Execute Protection
0x 6: Enhanced Virtualization
Processor Family 2 006bh - AMD Zen Processor Family
Core Count 2 8
Core Enabled 2 8
Thread Count 2 16
DRIVER_UNLOADED_WITHOUT_CANCELLING_PENDING_OPERATIONS (ce)
A driver unloaded without cancelling timers, DPCs, worker threads, etc.
The broken driver's name is displayed on the screen and saved in
KiBugCheckDriver.
Arguments:
Arg1: fffff802e6286c99, memory referenced
Arg2: 0000000000000010, value 0 = read operation, 1 = write operation
Arg3: fffff802e6286c99, If non-zero, the instruction address which referenced the bad memory
address.
Arg4: 0000000000000000, Mm internal code.
Debugging Details:
Value: 1202
Value: 2485
Value: 0
Value: 0
Value: 0
Value: 343
Value: 3218
Value: 90
Value: 0xce
Value: 0xce
Value: 8
Value: 1
Value: 0xCE_ace-game.sys!unknown_function
Key : Failure.Hash
Value: {6d570821-5455-05c8-3d68-57b7d08f92cb}
BUGCHECK_CODE: ce
BUGCHECK_P1: fffff802e6286c99
BUGCHECK_P2: 10
BUGCHECK_P3: fffff802e6286c99
BUGCHECK_P4: 0
FILE_IN_CAB: 090324-5781-01.dmp
FAULTING_THREAD: ffff8981bd94c080
WRITE_ADDRESS: fffff80160cfb390: Unable to get MiVisibleState
fffff802e6286c99
BLACKBOXWINLOGON: 1
TRAP_FRAME: ffffd40536d87830 -- (.trap 0xffffd40536d87830)
NOTE: The trap frame does not contain all registers.
Some register values may be zeroed or incorrect.
rax=0000000000000000 rbx=0000000000000000 rcx=0000000000000000
rdx=0000000000000001 rsi=0000000000000000 rdi=0000000000000000
rip=fffff802e6286c99 rsp=ffffd40536d879c0 rbp=ffffffff80004a6c
r8=0000000000000000 r9=0000000000000000 r10=0000000000000000
r11=fffff80160000000 r12=0000000000000000 r13=0000000000000000
r14=0000000000000000 r15=0000000000000000
iopl=0 nv up ei ng nz na po nc
<Unloaded_ace-game.sys>+0x6c99:
fffff802`e6286c99 ?? ???
IP_MODULE_UNLOADED:
ace-game.sys+6c99
STACK_TEXT:
ffffd405`36d87588 fffff801`604456e1 : 00000000`00000050 fffff802`e6286c99 00000000`00000010 ffffd405`36d87830 : nt!KeBugCheckEx
ffffd405`36d87590 fffff801`60239790 : 00000000`00000000 00000000`00000010 ffffd405`36d878b0 00000000`00000000 : nt!MiSystemFault+0x1cd181
ffffd405`36d87690 fffff801`6040e36d : 00000000`00000000 fffff801`5b647100 fffff801`5b643ac0 00000000`00000000 : nt!MmAccessFault+0x400
ffffd405`36d87830 fffff802`e6286c99 : 00000000`000000ee ffff9b05`00000000 0000000b`c8b56e00 000002b2`00000002 : nt!KiPageFault+0x36d
ffffd405`36d879c0 00000000`000000ee : ffff9b05`00000000 0000000b`c8b56e00 000002b2`00000002 00000000`00000000 : <Unloaded_ace-game.sys>+0x6c99
ffffd405`36d879c8 ffff9b05`00000000 : 0000000b`c8b56e00 000002b2`00000002 00000000`00000000 fffff802`e628f2e8 : 0xee
ffffd405`36d879d0 0000000b`c8b56e00 : 000002b2`00000002 00000000`00000000 fffff802`e628f2e8 ffff8981`a42ce1c0 : 0xffff9b05`00000000
ffffd405`36d879d8 000002b2`00000002 : 00000000`00000000 fffff802`e628f2e8 ffff8981`a42ce1c0 ffffffff`fff0bdc0 : 0x0000000b`c8b56e00
ffffd405`36d879e0 00000000`00000000 : fffff802`e628f2e8 ffff8981`a42ce1c0 ffffffff`fff0bdc0 fffff802`e5eb25fe : 0x000002b2`00000002
SYMBOL_NAME: ace-game.sys+6c99
MODULE_NAME: ace-game
IMAGE_NAME: ace-game.sys
STACK_COMMAND: .process /r /p 0xffff8981a42ce1c0; .thread 0xffff8981bd94c080 ; kb
BUCKET_ID_FUNC_OFFSET: 6c99
FAILURE_BUCKET_ID: 0xCE_ace-game.sys!unknown_function
OSNAME: Windows 10
FAILURE_ID_HASH: {6d570821-5455-05c8-3d68-57b7d08f92cb}
PnpActivityTime : 133698632849234927
PnpEventInformation: 3
PnpProblemCode : 24
PnpVetoType : 0
DeviceId : SWD\MMDEVAPI\{0.0.0.00000000}.{7d00c652-2c89-4627-a9a0-5f1d64ff517d}
VetoString :
SYSTEM_SERVICE_EXCEPTION (3b)
An exception happened while executing a system service routine.
Arguments:
Arg1: 00000000c0000005, Exception code that caused the BugCheck
Arg2: fffff8036a05ad66, Address of the instruction which caused the BugCheck
Arg3: ffffbe806cc86920, Address of the context record for the exception that caused the BugCheck
Arg4: 0000000000000000, zero.
Debugging Details:
Value: 1061
Value: 1086
Value: 0
Value: 0
Value: 0
Value: 280
Value: 3206
Value: 81
Value: 0x3b
Value: 0x3b
Value: 8
Value: 1
Value: AV_nt!IopQueueThreadIrp
Key : Failure.Hash
Value: {8a586314-907b-ce1a-3426-a00962ec3fac}
BUGCHECK_CODE: 3b
BUGCHECK_P1: c0000005
BUGCHECK_P2: fffff8036a05ad66
BUGCHECK_P3: ffffbe806cc86920
BUGCHECK_P4: 0
FILE_IN_CAB: 090424-5328-01.dmp
FAULTING_THREAD: ffffd28dbc7a6480
CONTEXT: ffffbe806cc86920 -- (.cxr 0xffffbe806cc86920)
rax=0000000000000000 rbx=ffffd28d000005a8 rcx=0000000000000000
rdx=ffffd28dc0bb4d80 rsi=ffffd28dc0bb4da0 rdi=ffffd28d000004d0
rip=fffff8036a05ad66 rsp=ffff998f302a77b0 rbp=ffffbe806cbec180
r8=ffffd28dc7bbae70 r9=0000000000000900 r10=0000000000000000
r11=0000000000001001 r12=0000000000000000 r13=ffffd28db8eccb20
r14=0000000000000000 r15=ffffffffffffffff
nt!IopQueueThreadIrp+0x76:
fffff803`6a05ad66 f0480fba2b00 lock bts qword ptr [rbx],0 ds:002b:ffffd28d`000005a8=????????????????
BLACKBOXWINLOGON: 1
PROCESS_NAME: nvcontainer.ex
STACK_TEXT:
ffff998f`302a77b0 fffff803`6a42d0e3 : 00000000`00000001 00000000`00012024 ffffd28d`c7bbae70 ffffd28d`bf1ed080 : nt!IopQueueThreadIrp+0x76
ffff998f`302a77f0 fffff803`6a42cf4a : 00000000`00012024 ffff998f`302a7b40 00000000`00000005 00000000`00012024 : nt!IopSynchronousServiceTail+0x133
ffff998f`302a7890 fffff803`6a42c226 : 00000000`00000001 00000000`00000838 00000000`00000000 00000000`00000000 : nt!IopXxxControlFile+0xd0a
ffff998f`302a79e0 fffff803`6a212208 : 00000000`00000000 00000000`00000000 fffff803`00000000 ffffd28d`c6c53560 : nt!NtDeviceIoControlFile+0x56
ffff998f`302a7a50 00007ffd`58c4d644 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!KiSystemServiceCopyEnd+0x28
000000bb`4c4ff528 00000000`00000000 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : 0x00007ffd`58c4d644
SYMBOL_NAME: nt!IopQueueThreadIrp+76
MODULE_NAME: nt
IMAGE_VERSION: 10.0.19041.4780
STACK_COMMAND: .cxr 0xffffbe806cc86920 ; kb
BUCKET_ID_FUNC_OFFSET: 76
FAILURE_BUCKET_ID: AV_nt!IopQueueThreadIrp
OSNAME: Windows 10
FAILURE_ID_HASH: {8a586314-907b-ce1a-3426-a00962ec3fac}
PnpActivityTime : 133698681938314714
PnpProblemCode : 24
PnpVetoType : 0
VetoString :
KMODE_EXCEPTION_NOT_HANDLED (1e)
Arguments:
Arg2: fffff80558def6c7, The address that the exception occurred at
Arg3: 0000000000000001, Parameter 0 of the exception
Arg4: ffff9b886cdb78fe, Parameter 1 of the exception
Debugging Details:
*** Either you specified an unqualified symbol, or your debugger ***
*** doesn't have full symbol information. Unqualified symbol ***
*** resolution is turned off by default. Please either specify a ***
*** fully qualified symbol module!symbolname, or enable resolution ***
*** of unqualified symbols by typing ".symopt- 100". Note that ***
*** enabling unqualified symbol resolution with network symbol ***
*** server shares in the symbol path may cause the debugger to ***
*** appear to hang for long periods of time when an incorrect ***
*** symbol name is typed or the network symbol server is down. ***
*** For some commands to work properly, your symbol path ***
*** must point to .pdb files that have full type information. ***
*** Certain .pdb files (such as the public OS symbols) do not ***
*** contain the required information. Contact the group that ***
*** provided you with these symbols if you need this command to ***
*** work. ***
*** Type referenced: ExceptionRecord ***
*** work. ***
*** Type referenced: ContextRecord ***
*** work. ***
*** work. ***
Value: 2109
Value: 3895
Value: 0
Value: 0
Value: 0
Value: 311
Value: 6697
Value: 87
Value: 0x1e
Value: 0x1e
Value: 8
Value: 1
Value: MEMORY_CORRUPTION_LARGE
Key : Failure.Hash
Value: {e29154ac-69a4-0eb8-172a-a860f73c0a3c}
BUGCHECK_CODE: 1e
BUGCHECK_P2: fffff80558def6c7
BUGCHECK_P3: 1
BUGCHECK_P4: ffff9b886cdb78fe
FILE_IN_CAB: 090424-5406-01.dmp
FAULTING_THREAD: ffff9b88a629b080
EXCEPTION_PARAMETER1: 0000000000000001
EXCEPTION_PARAMETER2: ffff9b886cdb78fe
WRITE_ADDRESS: fffff805550fb390: Unable to get MiVisibleState
ffff9b886cdb78fe
BLACKBOXWINLOGON: 1
PROCESS_NAME: DeltaForceClie
TRAP_FRAME: ffffea8e12657940 -- (.trap 0xffffea8e12657940)
rax=ffff2bc3d891e092 rbx=0000000000000000 rcx=0000000000000033
rdx=ffff9b889a563020 rsi=0000000000000000 rdi=0000000000000000
rip=fffff80558def6c7 rsp=ffffea8e12657ad0 rbp=ffffea8e12657b39
r8=0000000000000000 r9=0000000000000000 r10=fffff80558def680
r11=0000000000000010 r12=0000000000000000 r13=0000000000000000
storport!StorPortExtendedFunction+0x47:
fffff805`58def6c7 018bde4885d2 add dword ptr [rbx-2D7AB722h],ecx ds:ffffffff`d28548de=????????
STACK_TEXT:
ffffad81`f3860158 fffff805`548fbdce : 00000000`0000001e ffffffff`c0000005 fffff805`58def6c7 00000000`00000001 : nt!KeBugCheckEx
ffffad81`f3860160 fffff805`54808de2 : fffff805`548fbdac 00000000`00000000 00000000`00000000 00000000`00000000 : nt!HvlpVtlCallExceptionHandler+0x22
ffffad81`f38601a0 fffff805`546e4117 : ffffad81`f3860710 00000000`00000000 ffffea8e`12657fb0 fffff805`54806b55 : nt!RtlpExecuteHandlerForException+0x12
ffffad81`f38601d0 fffff805`54709c56 : ffffea8e`12657898 ffffad81`f3860e20 ffffea8e`12657898 00000000`c1000002 : nt!RtlDispatchException+0x297
ffffad81`f38608f0 fffff805`547ff402 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!KiDispatchException+0x186
ffffad81`f3860fb0 fffff805`547ff3d0 : fffff805`54812be5 ffff9b88`6cdb78fe ffffea8e`12657860 00000000`00000001 : nt!KxExceptionDispatchOnExceptionStack+0x12
ffffea8e`12657758 fffff805`54812be5 : ffff9b88`6cdb78fe ffffea8e`12657860 00000000`00000001 00000000`0000002f : nt!KiExceptionDispatchOnExceptionStackContinue
ffffea8e`12657760 fffff805`5480e452 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!KiExceptionDispatch+0x125
ffffea8e`12657940 fffff805`58def6c7 : 00000000`000078d8 ffff9b88`9a563020 00000000`00000003 00000000`00000000 : nt!KiPageFault+0x452
ffffea8e`12657ad0 fffff805`58ea669a : ffff9b88`9a5a71a0 ffff9b88`9a563020 00000000`00000000 00000000`00000000 : storport!StorPortExtendedFunction+0x47
ffffea8e`12657ba0 fffff805`58de1168 : ffff9b88`a93c5080 00000000`00000000 ffff9b88`a93c51f0 00000000`00000000 : stornvme!NVMeFStateIdleTimerCallback+0x5a
ffffea8e`12657be0 fffff805`5461fb32 : 00000000`00000002 ffffad81`f3840180 ffffad81`f3840180 ffff9b88`00000002 : storport!StorportTimerDpc+0x58
ffffea8e`12657c30 fffff805`5461ebad : ffffad81`f3840180 00010000`00000000 00000000`00000008 00000000`0000481f : nt!KiProcessExpiredTimerList+0x172
ffffea8e`12657d20 fffff805`54806b55 : 00000000`00000000 ffffad81`f3840180 ffff9b88`97938e60 00000001`c441e8f0 : nt!KiRetireDpcList+0x5dd
ffffea8e`12657fb0 fffff805`54806940 : fffff805`547fa350 fffff805`546fc36a 00000001`c4d90bf0 00000000`00000000 : nt!KxRetireDpcList+0x5
ffffea8e`16ed7a80 fffff805`54806085 : 00000001`c441e8f0 fffff805`54800b81 00000001`c44cf580 00000000`00000000 : nt!KiDispatchInterruptContinue
ffffea8e`16ed7ab0 fffff805`54800b81 : 00000001`c44cf580 00000000`00000000 ffffea8e`16ed7ac0 ffff9b88`00000000 : nt!KiDpcInterruptBypass+0x25
ffffea8e`16ed7ac0 00007ff8`1f4be2a1 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!KiInterruptDispatchNoLockNoEtw+0xb1
00000000`3ebabd80 00000000`00000000 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : 0x00007ff8`1f4be2a1
CHKIMG_EXTENSION: !chkimg -lo 50 -d !storport
fffff80558def01b-fffff80558def01c 2 bytes - storport!StorPortNotification+86b
[ 48 ff:4c 8b ]
fffff80558def022-fffff80558def026 5 bytes - storport!StorPortNotification+872 (+0x07)
[ 0f 1f 44 00 00:e8 b9 39 94 fb ]
fffff80558def0f7-fffff80558def0f8 2 bytes - storport!StorPortNotification+947 (+0xd5)
[ 48 ff:4c 8b ]
fffff80558def0fe-fffff80558def102 5 bytes - storport!StorPortNotification+94e (+0x07)
[ 0f 1f 44 00 00:e8 9d 7b 87 fb ]
fffff80558def18e-fffff80558def18f 2 bytes - storport!StorPortNotification+9de (+0x90)
[ 48 ff:4c 8b ]
fffff80558def195-fffff80558def199 5 bytes - storport!StorPortNotification+9e5 (+0x07)
[ 0f 1f 44 00 00:e8 e6 59 88 fb ]
fffff80558def1b6-fffff80558def1b7 2 bytes - storport!StorPortNotification+a06 (+0x21)
[ 48 ff:4c 8b ]
fffff80558def1bd-fffff80558def1c1 5 bytes - storport!StorPortNotification+a0d (+0x07)
[ 0f 1f 44 00 00:e8 be 59 88 fb ]
fffff80558def21a-fffff80558def21b 2 bytes - storport!StorPortNotification+a6a (+0x5d)
[ 48 ff:4c 8b ]
fffff80558def221-fffff80558def225 5 bytes - storport!StorPortNotification+a71 (+0x07)
[ 0f 1f 44 00 00:e8 5a df 86 fb ]
fffff80558def235-fffff80558def236 2 bytes - storport!StorPortNotification+a85 (+0x14)
[ 48 ff:4c 8b ]
fffff80558def23c-fffff80558def240 5 bytes - storport!StorPortNotification+a8c (+0x07)
[ 0f 1f 44 00 00:e8 8f 85 b2 fb ]
fffff80558def28a-fffff80558def28b 2 bytes - storport!StorPortNotification+ada (+0x4e)
[ 48 ff:4c 8b ]
fffff80558def291-fffff80558def295 5 bytes - storport!StorPortNotification+ae1 (+0x07)
[ 0f 1f 44 00 00:e8 da 59 88 fb ]
fffff80558def3e7-fffff80558def3e8 2 bytes - storport!RaidAdapterRequestComplete+f7 (+0x156)
[ 48 ff:4c 8b ]
fffff80558def3ee-fffff80558def3f2 5 bytes - storport!RaidAdapterRequestComplete+fe (+0x07)
[ 0f 1f 44 00 00:e8 2d 89 a1 fb ]
fffff80558def441-fffff80558def442 2 bytes - storport!RaidAdapterRequestComplete+151 (+0x53)
[ 48 ff:4c 8b ]
fffff80558def448-fffff80558def44c 5 bytes - storport!RaidAdapterRequestComplete+158 (+0x07)
[ 0f 1f 44 00 00:e8 53 78 87 fb ]
fffff80558def45a-fffff80558def45b 2 bytes - storport!RaidAdapterRequestComplete+16a (+0x12)
[ 48 ff:4c 8b ]
fffff80558def461-fffff80558def465 5 bytes - storport!RaidAdapterRequestComplete+171 (+0x07)
[ 0f 1f 44 00 00:e8 ba 88 a1 fb ]
fffff80558def487-fffff80558def488 2 bytes - storport!RaidAdapterRequestComplete+197 (+0x26)
[ 48 ff:4c 8b ]
fffff80558def48e-fffff80558def492 5 bytes - storport!RaidAdapterRequestComplete+19e (+0x07)
[ 0f 1f 44 00 00:e8 ad 39 82 fb ]
fffff80558def6c7 - storport!StorPortExtendedFunction+47 (+0x239)
[ 41:01 ]
fffff80558def72e-fffff80558def732 5 bytes - storport!StorPortExtendedFunction+ae (+0x67)
[ ff e1 cc cc cc:e8 8d 59 0a 00 ]
fffff80558def7df-fffff80558def7e0 2 bytes - storport!StorPortExtendedFunction+15f (+0xb1)
[ 48 ff:4c 8b ]
fffff80558def7e6-fffff80558def7ea 5 bytes - storport!StorPortExtendedFunction+166 (+0x07)
[ 0f 1f 44 00 00:e8 c5 78 fc fb ]
fffff80558defa8e-fffff80558defa8f 2 bytes - storport!StorPortExtendedFunction+40e (+0x2a8)
[ 48 ff:4c 8b ]
fffff80558defa95-fffff80558defa99 5 bytes - storport!StorPortExtendedFunction+415 (+0x07)
[ 0f 1f 44 00 00:e8 a6 33 82 fb ]
fffff80558defacc-fffff80558defacd 2 bytes - storport!StorPortExtendedFunction+44c (+0x37)
[ 48 ff:4c 8b ]
fffff80558defad3-fffff80558defad7 5 bytes - storport!StorPortExtendedFunction+453 (+0x07)
[ 0f 1f 44 00 00:e8 d8 1f 8e fb ]
fffff80558defb06-fffff80558defb07 2 bytes - storport!StorPortExtendedFunction+486 (+0x33)
[ 48 ff:4c 8b ]
fffff80558defb0d-fffff80558defb11 5 bytes - storport!StorPortExtendedFunction+48d (+0x07)
[ 0f 1f 44 00 00:e8 2e 3f 8e fb ]
fffff80558defb38-fffff80558defb39 2 bytes - storport!StorPortExtendedFunction+4b8 (+0x2b)
[ 48 ff:4c 8b ]
fffff80558defb3f-fffff80558defb43 5 bytes - storport!StorPortExtendedFunction+4bf (+0x07)
[ 0f 1f 44 00 00:e8 dc 3e 8e fb ]
fffff80558defb6d-fffff80558defb6e 2 bytes - storport!StorPortExtendedFunction+4ed (+0x2e)
[ 48 ff:4c 8b ]
fffff80558defb74-fffff80558defb78 5 bytes - storport!StorPortExtendedFunction+4f4 (+0x07)
[ 0f 1f 44 00 00:e8 17 cb 83 fb ]
fffff80558defbd0-fffff80558defbd1 2 bytes - storport!StorPortExtendedFunction+550 (+0x5c)
[ 48 ff:4c 8b ]
fffff80558defbd7-fffff80558defbdb 5 bytes - storport!StorPortExtendedFunction+557 (+0x07)
[ 0f 1f 44 00 00:e8 84 2f 86 fb ]
fffff80558defbf7-fffff80558defbf8 2 bytes - storport!StorPortExtendedFunction+577 (+0x20)
[ 48 ff:4c 8b ]
fffff80558defbfe-fffff80558defc02 5 bytes - storport!StorPortExtendedFunction+57e (+0x07)
[ 0f 1f 44 00 00:e8 fd 4b 97 fb ]
fffff80558defc75-fffff80558defc76 2 bytes - storport!StorPortExtendedFunction+5f5 (+0x77)
[ 48 ff:4c 8b ]
fffff80558defc7c-fffff80558defc80 5 bytes - storport!StorPortExtendedFunction+5fc (+0x07)
[ 0f 1f 44 00 00:e8 af d5 97 fb ]
fffff80558defd1b-fffff80558defd1c 2 bytes - storport!StorPortExtendedFunction+69b (+0x9f)
[ 48 ff:4c 8b ]
fffff80558defd22-fffff80558defd26 5 bytes - storport!StorPortExtendedFunction+6a2 (+0x07)
[ 0f 1f 44 00 00:e8 39 9a 90 fb ]
fffff80558defd3e-fffff80558defd3f 2 bytes - storport!StorPortExtendedFunction+6be (+0x1c)
[ 48 ff:4c 8b ]
fffff80558defd45-fffff80558defd49 5 bytes - storport!StorPortExtendedFunction+6c5 (+0x07)
[ 0f 1f 44 00 00:e8 96 c0 83 fb ]
fffff80558defd72-fffff80558defd73 2 bytes - storport!StorPortExtendedFunction+6f2 (+0x2d)
[ 48 ff:4c 8b ]
fffff80558defd79-fffff80558defd7d 5 bytes - storport!StorPortExtendedFunction+6f9 (+0x07)
[ 0f 1f 44 00 00:e8 b2 f0 8d fb ]
fffff80558defd90-fffff80558defd91 2 bytes - storport!StorPortExtendedFunction+710 (+0x17)
[ 48 ff:4c 8b ]
fffff80558defd97-fffff80558defd9b 5 bytes - storport!StorPortExtendedFunction+717 (+0x07)
[ 0f 1f 44 00 00:e8 c4 7f a1 fb ]
WARNING: !chkimg output was truncated to 50 lines. Invoke !chkimg without '-lo [num_lines]' to view entire output.
209 errors : !storport (fffff80558def01b-fffff80558deff95)
MODULE_NAME: memory_corruption
IMAGE_NAME: memory_corruption
MEMORY_CORRUPTOR: LARGE
STACK_COMMAND: .process /r /p 0xffff9b88afdcd0c0; .thread 0xffff9b88a629b080 ; kb
FAILURE_BUCKET_ID: MEMORY_CORRUPTION_LARGE
OSNAME: Windows 10
FAILURE_ID_HASH: {e29154ac-69a4-0eb8-172a-a860f73c0a3c}
Followup: memory_corruption
PnpActivityTime : 133699175056795414
PnpProblemCode : 43
PnpVetoType : 0
VetoString :
[DMI Version - 0]
BIOS Version 2.81
07: - PCI Supported
19: - EDD Supported
Version 1.0
Version 1.0
Asset Tag
Feature Flags 09h
00: - Motherboard
03: - Replaceable
Version 1.0
Serial Number
Asset Tag Number
Bootup State Safe
Thermal State Safe
OEM Defined 0
Height 0U
Number of Strings 1
Partition Width 02
Partition Width 02
Cache Speed 1ns
Cache Speed 1ns
Cache Speed 1ns
Max Speed 3400MHz
Serial Number
Asset Tag Number
Part Number Unknown
Core Count 8
Core Enabled 8
Thread Count 16
0x 3: Multi-Core
Core Count 2 8
Core Enabled 2 8
Thread Count 2 16
