3 Aralık 2023
İstanbul
  • Anakart: MSI Z890 ACE
  • İşlemci: Intel Core Ultra 9 285K
  • Ekran Kartı: RX 9070 XT
  • İşletim Sistemi: Windows 11 24H2 Canary 27781
Kod:
KMODE_EXCEPTION_NOT_HANDLED (1e)
This is a very common BugCheck.  Usually the exception address pinpoints
the driver/function that caused the problem.  Always note this address
as well as the link date of the driver/image that contains this address.
Arguments:
Arg1: ffffffffc0000005, The exception code that was not handled
Arg2: fffff8007e5c709d, The address that the exception occurred at
Arg3: 0000000000000000, Parameter 0 of the exception
Arg4: ffffffffffffffff, Parameter 1 of the exception
Debugging Details:
***    Either you specified an unqualified symbol, or your debugger   ***
***    doesn't have full symbol information.  Unqualified symbol      ***
***    resolution is turned off by default. Please either specify a   ***
***    fully qualified symbol module!symbolname, or enable resolution ***
***    of unqualified symbols by typing ".symopt- 100". Note that     ***
***    enabling unqualified symbol resolution with network symbol     ***
***    server shares in the symbol path may cause the debugger to     ***
***    appear to hang for long periods of time when an incorrect      ***
***    symbol name is typed or the network symbol server is down.     ***
***    For some commands to work properly, your symbol path           ***
***    must point to .pdb files that have full type information.      ***
***    Certain .pdb files (such as the public OS symbols) do not      ***
***    contain the required information.  Contact the group that      ***
***    provided you with these symbols if you need this command to    ***
***    work.                                                          ***
***    Type referenced: ExceptionRecord                               ***
***    work.                                                          ***
***    Type referenced: ContextRecord                                 ***
KEY_VALUES_STRING: 1
    Key  : Analysis.CPU.mSec
    Value: 2140
    Key  : Analysis.Elapsed.mSec
    Value: 13751
    Key  : Analysis.IO.Other.Mb
    Value: 2
    Key  : Analysis.IO.Read.Mb
    Value: 1
    Key  : Analysis.IO.Write.Mb
    Value: 25
    Key  : Analysis.Init.CPU.mSec
    Value: 390
    Value: 16154
    Value: 86
    Value: 10.0.27829.1001
    Value: 10.2503.24.01 amd64fre
    Key  : Analysis.Version.Ext
    Value: 1.2503.24.1
    Value: 0x1e
    Value: 0x1e
    Value: 0x1808
    Value: 1
    Value: 0x0
    Value: 1
    Value: 0
    Key  : Failure.Bucket
    Value: AV_R_nt!RtlXSaveS
    Key  : Failure.Exception.IP.Address
    Value: 0xfffff8007e5c709d
    Key  : Failure.Exception.IP.Module
    Value: nt
    Key  : Failure.Exception.IP.Offset
    Value: 0x3c709d
    Key  : Failure.Hash
    Value: {753b2cfe-f581-0ed8-963d-d18474cf5731}
    Key  : Hypervisor.Enlightenments.ValueHex
    Value: 0x7417df84
    Key  : Hypervisor.Flags.AnyHypervisorPresent
    Value: 1
    Key  : Hypervisor.Flags.ApicEnlightened
    Value: 0
    Key  : Hypervisor.Flags.ApicVirtualizationAvailable
    Value: 1
    Key  : Hypervisor.Flags.AsyncMemoryHint
    Value: 0
    Key  : Hypervisor.Flags.CoreSchedulerRequested
    Value: 0
    Key  : Hypervisor.Flags.CpuManager
    Value: 1
    Key  : Hypervisor.Flags.DeprecateAutoEoi
    Value: 1
    Key  : Hypervisor.Flags.DynamicCpuDisabled
    Value: 1
    Key  : Hypervisor.Flags.Epf
    Value: 0
    Key  : Hypervisor.Flags.ExtendedProcessorMasks
    Value: 1
    Key  : Hypervisor.Flags.HardwareMbecAvailable
    Value: 1
    Key  : Hypervisor.Flags.MaxBankNumber
    Value: 0
    Key  : Hypervisor.Flags.MemoryZeroingControl
    Value: 0
    Key  : Hypervisor.Flags.NoExtendedRangeFlush
    Value: 0
    Key  : Hypervisor.Flags.NoNonArchCoreSharing
    Value: 1
    Key  : Hypervisor.Flags.Phase0InitDone
    Value: 1
    Key  : Hypervisor.Flags.PowerSchedulerQos
    Value: 0
    Key  : Hypervisor.Flags.RootScheduler
    Value: 0
    Key  : Hypervisor.Flags.SynicAvailable
    Value: 1
    Key  : Hypervisor.Flags.UseQpcBias
    Value: 0
    Key  : Hypervisor.Flags.Value
    Value: 55185662
    Key  : Hypervisor.Flags.ValueHex
    Value: 0x34a10fe
    Key  : Hypervisor.Flags.VpAssistPage
    Value: 1
    Key  : Hypervisor.Flags.VsmAvailable
    Value: 1
    Key  : Hypervisor.RootFlags.AccessStats
    Value: 1
    Key  : Hypervisor.RootFlags.CrashdumpEnlightened
    Value: 1
    Key  : Hypervisor.RootFlags.CreateVirtualProcessor
    Value: 1
    Key  : Hypervisor.RootFlags.DisableHyperthreading
    Value: 0
    Key  : Hypervisor.RootFlags.HostTimelineSync
    Value: 1
    Key  : Hypervisor.RootFlags.HypervisorDebuggingEnabled
    Value: 0
    Key  : Hypervisor.RootFlags.IsHyperV
    Value: 1
    Key  : Hypervisor.RootFlags.LivedumpEnlightened
    Value: 1
    Key  : Hypervisor.RootFlags.MapDeviceInterrupt
    Value: 1
    Key  : Hypervisor.RootFlags.MceEnlightened
    Value: 1
    Key  : Hypervisor.RootFlags.Nested
    Value: 0
    Key  : Hypervisor.RootFlags.StartLogicalProcessor
    Value: 1
    Key  : Hypervisor.RootFlags.Value
    Value: 1015
    Key  : Hypervisor.RootFlags.ValueHex
    Value: 0x3f7
    Key  : Stack.Pointer
    Value: NMI
BUGCHECK_CODE:  1e
BUGCHECK_P1: ffffffffc0000005
BUGCHECK_P2: fffff8007e5c709d
BUGCHECK_P3: 0
BUGCHECK_P4: ffffffffffffffff
FILE_IN_CAB:  061125-11750-01.dmp
TAG_NOT_DEFINED_202b:  *** Unknown TAG in analysis list 202b
DUMP_FILE_ATTRIBUTES: 0x1808
  Kernel Generated Triage Dump
FAULTING_THREAD:  ffff8081386c3080
EXCEPTION_PARAMETER1:  0000000000000000
EXCEPTION_PARAMETER2:  ffffffffffffffff
READ_ADDRESS: fffff8007f1bd4d8: Unable to get MiVisibleState
Unable to get NonPagedPoolStart
Unable to get NonPagedPoolEnd
Unable to get PagedPoolStart
Unable to get PagedPoolEnd
unable to get nt!MmSpecialPagesInUse
 ffffffffffffffff
BLACKBOXBSD: 1 (!blackboxbsd)
BLACKBOXPNP: 1 (!blackboxpnp)
BLACKBOXWINLOGON: 1
CUSTOMER_CRASH_COUNT:  1
PROCESS_NAME:  Diablo IV.exe
TRAP_FRAME:  85d88bfffd25fbe8 -- (.trap 0x85d88bfffd25fbe8)
Unable to read trap frame at 85d88bff`fd25fbe8
Resetting default scope
STACK_TEXT:
ffffd200`b55cf278 fffff800`7e57a74a     : 00000000`0000001e ffffffff`c0000005 fffff800`7e5c709d 00000000`00000000 : nt!KeBugCheckEx
ffffd200`b55cf280 fffff800`7e8eea8c     : 8b480000`01c0850f ce8b4870`418b480e 85d88bff`fd25fbe8 48000001`ac880fc0 : nt!KiDispatchException+0x21a
ffffd200`b55cf930 fffff800`7e8e944a     : 0c74ff84`450002db e8000000`c88e8d48 05ebc38b`fffc073c c48348c0`00000db8 : nt!KiExceptionDispatch+0x14c
ffffd200`b55cfb10 fffff800`7e5c709d     : 244c8948`c08b4448 f5b90000`0019ba20 964e15ff`480000c1 cc000044`1f0ffffe : nt!KiGeneralProtectionFaultDispatchTrap+0x68
ffffd200`b55cfca0 fffff800`7e5793f6     : 65e84040`8b48078b 8b48078b`48fffd22 00000170`808b48cf 85f08bff`fd2253e8 : nt!RtlXSaveS+0x29
ffffd200`b55cfcd0 fffff800`7e7ae5e4     : ffffd200`b55be3d0 ffffd200`b55cfd30 ffffd200`b55cfe70 ffffd200`b558f180 : nt!KeContextFromKframes+0x236
ffffd200`b55cfd00 fffff800`7e8e63f6     : 00000000`00000100 ffffd200`b55cfef0 00000000`00000000 45e98b4d`30ec8348 : nt!KiSaveProcessorState+0xa4
ffffd200`b55cfd30 fffff800`7e8e6144     : 00000000`00000100 ffffd200`b55cfef0 8b49018b`4c000002 00000000`00000000 : nt!KxNmiInterrupt+0x76
ffffd200`b55cfe70 00007ff7`04c97ca8     : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!KiNmiInterruptDispatchTrap+0xf5
00000080`03c2f5b0 00000000`00000000     : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : 0x00007ff7`04c97ca8
SYMBOL_NAME:  nt!RtlXSaveS+29
MODULE_NAME: nt
IMAGE_NAME:  ntkrnlmp.exe
IMAGE_VERSION:  10.0.27871.1000
STACK_COMMAND: .process /r /p 0xffff808138882080; .thread 0xffff8081386c3080 ; kb
BUCKET_ID_FUNC_OFFSET:  29
FAILURE_BUCKET_ID:  AV_R_nt!RtlXSaveS
OSPLATFORM_TYPE:  x64
OSNAME:  Windows 10
FAILURE_ID_HASH:  {753b2cfe-f581-0ed8-963d-d18474cf5731}
Followup:     MachineOwner
    PnpActivityId      : {00000000-0000-0000-0000-000000000000}
    PnpActivityTime    : 133941397381894465
    PnpEventInformation: 3
    PnpEventInProgress : 0
    PnpProblemCode     : 24
    PnpVetoType        : 0
    DeviceId           : SWD\MMDEVAPI\{0.0.0.00000000}.{d567334f-b5cf-4e1b-a818-3b291893d2c3}
    VetoString         :
[SMBIOS Data Tables v3.8]
[DMI Version - 0]
[2.0 Calling Convention - No]
[Table Size - 4634 bytes]
  Vendor                        American Megatrends International, LLC.
  BIOS Version                  1.A52
  BIOS Release Date             02/12/2025
  BIOS ROM Size                 1000000
  BIOS Characteristics
       07: - PCI Supported
       11: - Upgradeable FLASH BIOS
       15: - CD-Boot Supported
       17: - BIOS ROM Socketed
       19: - EDD Supported
       32: - BIOS Vendor Reserved
       00: - ACPI Supported
  BIOS Major Revision           5
  BIOS Minor Revision           32
  EC Firmware Major Revision    255
  EC Firmware Minor Revision    255
  Extended BIOS ROM Size        32 MB
  Manufacturer                  Micro-Star International Co., Ltd.
  Product Name                  MS-7E22
  Version                       1.0
  Serial Number                 Default string
  SKUNumber                     Default string
  Family                        Default string
  Product                       MEG Z890 ACE (MS-7E22)
  Version                       1.0
  Serial Number                 07E2210_O71B369356
  Asset Tag
       00: - Motherboard
       03: - Replaceable
  Location                      Default string
  Chassis Type                  Desktop
  Version                       1.0
  Serial Number
  Asset Tag Number
  Contained Element Size        3
[OEM Strings (Type 11) - Length 5 - Handle 0021h]
  Number of Strings             1
   1                            Default string
[System Configuration Options (Type 12) - Length 5 - Handle 0022h]
[ (Type 256) - Length 9 - Handle 0024h]
[ (Type 256) - Length 31 - Handle 0025h]
[ (Type 256) - Length 26 - Handle 0026h]
[Physical Memory Array (Type 16) - Length 23 - Handle 0027h]
  Maximum Capacity              134217728KB
  Memory Error Inf Handle       [Not Provided]
  Number of Memory Devices      4
[Memory Device (Type 17) - Length 92 - Handle 0028h]
  Memory Error Info Handle      [Not Provided]
  Total Width                   0 bits
  Data Width                    0 bits
  Size                          [Not Populated]
  Form Factor                   02h - Unknown
  Device Locator                DIMMA1
  Bank Locator                  BANK 0
  Memory Type                   02h - Unknown
  Type Detail                   0000h -
  Speed                         0MHz
  Manufacturer                  [String Not Specified]
  Serial Number                 [String Not Specified]
  Asset Tag Number              [String Not Specified]
  Part Number                   [String Not Specified]
  Attributes                    0
  Configured Memory Speed       0
  Minimum Voltage               0
  Maximum Voltage               0
  Configured Voltage            0
  Memory Technology             0
  Memory Operating Mode Capability     0
  Firmware Version              0
  Module Manufacturer Id        0
  Module Product Id             0
  Memory Subsystem Controller Manufacturer Id  0
  Memory Subsystem Controller Product Id       0
  Non-Volatile Size             0
  Volatile Size                 0
  Cache Size                    0
  Logical Size                  0
  Extended Speed                0
  Extended Configured Memory Speed     0
[Memory Device (Type 17) - Length 92 - Handle 0029h]
  Size                          24576MB
  Form Factor                   09h - DIMM
  Device Locator                DIMMA2
  Bank Locator                  BANK 0
  Memory Type                   22h - DDR5
  Type Detail                   0080h - Synchronous
  Speed                         6400MHz
  Manufacturer                  Kingston
  Serial Number
  Asset Tag Number
  Part Number                   KF582C40-24
  Attributes                    1
  Configured Memory Speed       6400
  Minimum Voltage               1100
  Maximum Voltage               1100
  Configured Voltage            1100
  Memory Technology             3
  Memory Operating Mode Capability     8
  Firmware Version              0
  Module Manufacturer Id        38913
  Module Product Id             0
  Non-Volatile Size             0
  Volatile Size                 0
  Cache Size                    0
  Logical Size                  0
  Extended Speed                0
[Memory Device (Type 17) - Length 92 - Handle 002ah]
  Total Width                   0 bits
  Data Width                    0 bits
  Device Locator                DIMMB1
  Bank Locator                  BANK 1
  Type Detail                   0000h -
  Speed                         0MHz
  Attributes                    0
  Minimum Voltage               0
  Maximum Voltage               0
  Memory Technology             0
  Firmware Version              0
  Module Product Id             0
  Non-Volatile Size             0
  Volatile Size                 0
  Cache Size                    0
  Logical Size                  0
  Extended Speed                0
[Memory Device (Type 17) - Length 92 - Handle 002bh]
  Size                          24576MB
  Device Locator                DIMMB2
  Bank Locator                  BANK 1
  Speed                         6400MHz
  Serial Number
  Asset Tag Number
  Attributes                    1
  Memory Technology             3
  Firmware Version              0
  Module Product Id             0
  Non-Volatile Size             0
  Volatile Size                 0
  Cache Size                    0
  Logical Size                  0
  Extended Speed                0
[Memory Array Mapped Address (Type 19) - Length 31 - Handle 002ch]
  Ending Address                02ffffffh
  Memory Array Handle           0027h
[Memory Device Mapped Address (Type 20) - Length 35 - Handle 002dh]
  Ending Address                017fffffh
  Memory Device Handle          0029h
  Mem Array Mapped Adr Handle   002ch
  Interleave Position           [None]
  Interleave Data Depth         [None]
[Memory Device Mapped Address (Type 20) - Length 35 - Handle 002eh]
  Starting Address              01800000h
  Memory Device Handle          002bh
[ (Type 256) - Length 12 - Handle 002fh]
[ (Type 256) - Length 26 - Handle 0030h]
[ (Type 256) - Length 26 - Handle 0031h]
[ (Type 256) - Length 47 - Handle 0032h]
[ (Type 256) - Length 82 - Handle 0033h]
[Cache Information (Type 7) - Length 27 - Handle 0034h]
  Socket Designation            L1 Cache
  Maximum Cache Size            0180h - 384K
  Installed Size                0180h - 384K
  Supported SRAM Type           0020h - Synchronous
  Current SRAM Type             0020h - Synchronous
  Cache Speed                   0ns
  Error Correction Type         ParitySingle-Bit ECC
  System Cache Type             Data
  Associativity                 12-way Set-Associative
  Maximum Cache Size 2          180 - 00000384l Kb
  Installed Cache Size 2        180 - 00000384l Kb
[Cache Information (Type 7) - Length 27 - Handle 0035h]
  Maximum Cache Size            0200h - 512K
  Installed Size                0200h - 512K
  Cache Speed                   0ns
  System Cache Type             Instruction
  Associativity                 16-way Set-Associative
  Maximum Cache Size 2          200 - 00000512l Kb
  Installed Cache Size 2        200 - 00000512l Kb
[Cache Information (Type 7) - Length 27 - Handle 0036h]
  Socket Designation            L2 Cache
  Maximum Cache Size            6000h - 24576K
  Installed Size                6000h - 24576K
  Cache Speed                   0ns
  Error Correction Type         Multi-Bit ECC
  Maximum Cache Size 2          6000 - 00024576l Kb
  Installed Cache Size 2        6000 - 00024576l Kb
[Cache Information (Type 7) - Length 27 - Handle 0037h]
  Socket Designation            L3 Cache
  Maximum Cache Size            8240h - 36864K
  Installed Size                8240h - 36864K
  Cache Speed                   0ns
  Maximum Cache Size 2          80000240 - 00036864l Kb
  Installed Cache Size 2        80000240 - 00036864l Kb
[Cache Information (Type 7) - Length 27 - Handle 0038h]
  Cache Speed                   0ns
[Cache Information (Type 7) - Length 27 - Handle 0039h]
  Maximum Cache Size            0400h - 1024K
  Installed Size                0400h - 1024K
  Cache Speed                   0ns
  Maximum Cache Size 2          400 - 00001024l Kb
  Installed Cache Size 2        400 - 00001024l Kb
[Cache Information (Type 7) - Length 27 - Handle 003ah]
  Maximum Cache Size            4000h - 16384K
  Installed Size                4000h - 16384K
  Cache Speed                   0ns
  Maximum Cache Size 2          4000 - 00016384l Kb
  Installed Cache Size 2        4000 - 00016384l Kb
[Cache Information (Type 7) - Length 27 - Handle 003bh]
  Cache Speed                   0ns
[Processor Information (Type 4) - Length 51 - Handle 003ch]
  Socket Designation            U3E1
  Processor Family              feh - Specification Reserved
  Processor Manufacturer        Intel(R) Corporation
  Processor ID                   62060c00fffbebbf
  Processor Version             Intel(R) Core(TM) Ultra 9 285K
  Processor Voltage             8ch - 1.2V
  Max Speed                     8500MHz
  Current Speed                 5247MHz
  Processor Upgrade             Specification Reserved
  L1 Cache Handle               0039h
  L2 Cache Handle               003ah
  L3 Cache Handle               003bh
  Serial Number
  Asset Tag Number
  Part Number                   To Be Filled By O.E.M.
  Core Count                    24
  Core Enabled                  24
  Thread Count                  24
  Processor Characteristics     ec
  Enabled Characteristics:
       0x 2: 64-bit Capable
       0x 3: Multi-Core
       0x 5: Execute Protection
       0x 6: Enhanced Virtualization
  Processor Family 2            0307h - Specification Reserved
  Core Count 2                  24
  Core Enabled 2                24
  Thread Count 2                24
[ (Type 256) - Length 64 - Handle 003dh]
[ (Type 256) - Length 11 - Handle 003eh]
[ (Type 256) - Length 11 - Handle 003fh]
[ (Type 256) - Length 11 - Handle 0040h]
[ (Type 256) - Length 11 - Handle 0041h]
[ (Type 256) - Length 11 - Handle 0042h]
[ (Type 256) - Length 11 - Handle 0043h]
[ (Type 256) - Length 11 - Handle 0044h]
[ (Type 256) - Length 11 - Handle 0045h]
[ (Type 256) - Length 11 - Handle 0046h]
[ (Type 256) - Length 11 - Handle 0047h]
[ (Type 256) - Length 11 - Handle 0048h]
[ (Type 256) - Length 11 - Handle 0049h]
[ (Type 256) - Length 11 - Handle 004ah]
[ (Type 256) - Length 11 - Handle 004bh]
[ (Type 256) - Length 11 - Handle 004ch]
[ (Type 256) - Length 11 - Handle 004dh]
[ (Type 256) - Length 117 - Handle 004eh]
[ (Type 256) - Length 16 - Handle 004fh]
[ (Type 256) - Length 44 - Handle 0050h]
[ (Type 256) - Length 8 - Handle 0051h]
[ (Type 256) - Length 6 - Handle 0052h]
[ (Type 256) - Length 106 - Handle 0054h]
[ (Type 256) - Length 4 - Handle 0056h]
Recep abi, gördüğüm kadarıyla Diablo oyununda hata almışsın.
Aldığın hata NMI tarafından tetiklenmiş olacak ki burada bakman gereken 2 kritik şey işlemci ve RAM.
Gördüğüm kadarıyla anakartta 2x24 olmak üzere 2 adet RAM var. DIMMA1 ve DIMMB1 yuvaları boş. Demek oluyor ki A2 ve B2 kullandın.
XMP ayarlarında bir sorun olabilir mi acaba? RAM'ler 1.1V, 6400 MHz çalışıyor okuduğum kadarıyla.
Bu arada hata mesajında SWD\MMDEVAPI ile ilgili bir bilgi var, bu da ses cihazıyla ilgili bir sorun olabilir. Elin değmişken ona da bakıver.
Anakart BIOS sürümü 52 ile bitiyordu yanlış görmediysem. Ona da bakarsın güncel mi diye.
Son olarak da yonga sürücülerini varsa güncelle.
Eh, elimden şimdilik bu kadar okuma geliyor. Geçmişte yardımın dokunduğu için benim de yardımımın dokunmasını isterim.
Sabah zaten sürücüyle ilgili bir konu açmıştınız, ne yaptınız onu? Bu AMD'nin sürücüleri acayip açıkçası, o tetiklemiş olabilir.
Yine RDR 2 oyununda, RX 550 ekran kartıyla oyuna Türkçe yama ekledikten sonra ekran kartı limp moda geçiyor, yani çöküyordu. Stabil bir sürücü buldum, oyunun dosyalarını defalarca doğruladıktan sonra düzeldi.
Ezcevap, hata muhtemelen sürücüden kaynaklı o halde.
Sürücüler hala sorunlu deyince kızıyorlar ama. "RX 5000 serisinden sonra WattMan hatası bitti kardeşim" . Doğru, WattMan gitti ama başka hataların olmadığının / olmayacağının da garantisi yok. Son kullanıcı hiçbir zaman sürücülerle uğraşmamalı, devamlı sürücü değiştirmemeli. Nvidia'yı ne kadar eleştirsek de bu konuda çok daha iyiler. Birim ekran kartı başına düşen sürücü / arıza sorunu çok daha az.
Sorun RX 9070 XT taktıktan sonra oldu :)
Bu 9070'i modlayarak yaptığınız kart mı?
NMI kesmelerinin işlemci seviyesinde işlenmesi hatayı NMI'ye yormak (En azından belli başlı sabit stack sahibi hatalarda bu böyle olsa da) için doğru değil pek. Zati dosyada da bunun pek eşleşen bağlamı yok, evet o an bir NMI dispatch protokolü var ama bu kesmenin async bir fonksiyon dahilinde çalıştığını da unutmamak gerekiyor. Yani o an bu durumda işlemcinin ne yaptığına bakılacak durumda olunmuyor. Bu dosya bir bağlam kurmak için yeterli bir dosya da değil açıp bakılmadan en azından.
Zira NMI kesmesini sadece RAM ve işlemci tabanında düşünmemek gerekiyor. Örnek olarak Watchdog Timer da bunu gönderebilir. Öyle olsa bile Windows'un bunu nasıl ele aldığı da önemli oluyor bir noktada. Genelde linux tarafında bu WT gibi API'leri tetiklemek için kullanılıyor gibi genel yorumlar da olsa Windows bunu (Açıklanmış değil.) genel olarak ele alıyor diyebiliyor olmamız lazım.
Rich (BB code):
STACK_TEXT:
Stackler'de dikkat çeken şey şu: Hata işleyicisinin, daha sonra da bu hatayı sıraya alıp istisna kayıtlarına yazan fonksiyonların opcode'larının ciddi bozuk durumda olması.
Dosyanın anlattığı olay ilerleme aşamaları da anlattıklarımdan ibaret tabii; nt!KiSaveProcessorState ve nt!KeContextFromKframes devreye giriyor; bunlar İşlemcinin içinde bulunduğu durumdaki kayıtları bellekte bir yapı (CONTEXT) içine aktarmaya çalıştığını gösteriyor. Açıkçası burada IPI eklentisi dahilinde işlemci yönetiminde çalıştıkları belli oluyor öncesinde gelen NMI kesmelerinden. Ancak bu yapı neden çalışıyor, dosyada bu yok. NMI kesmesi halihazırda zaten işlemci istisnai bir durumdayken de gelişmiş olabilir gibi ek bir yorum katabilirim sadece.
bknz.
Sonrasında kaydedilen bu yapı gerisinden gelen nt!RtlXSaveS fonksiyonu ile XSAVE alanını belleğe dökme işleminde başarısız oluyor çünkü fonksiyonda geçersiz bellek erişimi var. TRAP de bozuk tabii. İlk parametreden anlaşılabiliyor ancak. Daha sonra da bunun bir GP işleyicisiyle yorumlandığı da görülebiliyor..
Protected Mode Exceptions ​
#GP(0)If a memory operand effective address is outside the CS, DS, ES, FS, or GS segment limit.
If a memory operand is not aligned on a 64-byte boundary, regardless of segment.
Görünen köyden şöyle 1 2 ihtimal yorumu yapılabilir ancak:
XSAVE yapısının işlemci kayıtlarını XRSTOR ile işlediği linkte detaylanıyor.... Bu noktada ekran kartı sürücüsü ekleyeceği frame'leri eksik/hatalı bırakmışsa bu da aynı şekilde GPF istisnasına neden olabilecek bir durum.
Veyahut da en başta belirttiğim gibi, işleyici ve sonrasındaki hata kayıt kontrollerinin opcode'ları kayıtlar yazıldıktan sonra görülüyor ki bozuk durumdalar (244c8948c08b4448' falan gibi). Buna aynı şekilde ya cidden bozuk bir donanım ki -bu ekran kartının- dolaylı olarak işlemcinin yolladığı ISR AMD opcode'una bozuk bir yapı enjekte etmesinden kaynaklanıyor da olabilir ya da sadece basit bir sürücü hatası deyip de geçilebilir belki de. Açıkçası dosyayı görmek lazım ya da dosyaları.
Bunlar dosyayı görmeden yapılabilecek en ileri yorumlar olur tabii. Dosyanın ham halini paylaşabilirsen en azından belki bir seçenek olur diye ham bellek bölgelerine ve kayıtlıysa diğer işlemci çekirdek görüntülerine bakmayı deneyebilirim. Çok umut vermiyor dosya bu bozuk context yapısıyla tabii ama denenebilir yine de hocam.
Ayrıca Plug And Play ile ilgili komutun da Microsoft tarafından bir açıklaması yok. Bunun üstünden bir şeyi suçlamak çok da mantıklı değil eğer kabak gibi bir dosya yoksa. (0x9F örneği.)
