3 Aralık 2023
İstanbul
  • Anakart: MSI Z890 ACE
  • İşlemci: Core Ultra 9 285K
  • Ekran Kartı: RX 9070 XT
  • İşletim Sistemi: Windows 11 27881
Kod:
KMODE_EXCEPTION_NOT_HANDLED (1e)
This is a very common BugCheck.  Usually the exception address pinpoints
the driver/function that caused the problem.  Always note this address
as well as the link date of the driver/image that contains this address.
Arguments:
Arg1: ffffffffc0000005, The exception code that was not handled
Arg2: fffff8077e41ced1, The address that the exception occurred at
Arg3: 0000000000000000, Parameter 0 of the exception
Arg4: ffffffffffffffff, Parameter 1 of the exception
Debugging Details:
***    Either you specified an unqualified symbol, or your debugger   ***
***    doesn't have full symbol information.  Unqualified symbol      ***
***    resolution is turned off by default. Please either specify a   ***
***    fully qualified symbol module!symbolname, or enable resolution ***
***    of unqualified symbols by typing ".symopt- 100". Note that     ***
***    enabling unqualified symbol resolution with network symbol     ***
***    server shares in the symbol path may cause the debugger to     ***
***    appear to hang for long periods of time when an incorrect      ***
***    symbol name is typed or the network symbol server is down.     ***
***    For some commands to work properly, your symbol path           ***
***    must point to .pdb files that have full type information.      ***
***    Certain .pdb files (such as the public OS symbols) do not      ***
***    contain the required information.  Contact the group that      ***
***    provided you with these symbols if you need this command to    ***
***    work.                                                          ***
***    Type referenced: ExceptionRecord                               ***
***    work.                                                          ***
***    Type referenced: ContextRecord                                 ***
KEY_VALUES_STRING: 1
    Key  : Analysis.CPU.mSec
    Value: 1093
    Key  : Analysis.Elapsed.mSec
    Value: 3536
    Key  : Analysis.IO.Other.Mb
    Value: 2
    Key  : Analysis.IO.Read.Mb
    Value: 1
    Key  : Analysis.IO.Write.Mb
    Value: 25
    Key  : Analysis.Init.CPU.mSec
    Value: 515
    Value: 15564
    Value: 85
    Value: 10.0.27829.1001
    Value: 10.2503.24.01 amd64fre
    Key  : Analysis.Version.Ext
    Value: 1.2503.24.1
    Value: 0x1e
    Value: 0x1e
    Value: 0x1808
    Value: 1
    Value: 0x0
    Value: 1
    Value: 0
    Key  : Failure.Bucket
    Value: AV_R_nt!KeContextFromKframes
    Key  : Failure.Exception.IP.Address
    Value: 0xfffff8077e41ced1
    Key  : Failure.Exception.IP.Module
    Value: nt
    Key  : Failure.Exception.IP.Offset
    Value: 0x41ced1
    Key  : Failure.Hash
    Value: {92df748a-7471-c8a1-674d-605406b23dbb}
    Key  : Hypervisor.Enlightenments.ValueHex
    Value: 0x7417df84
    Key  : Hypervisor.Flags.AnyHypervisorPresent
    Value: 1
    Key  : Hypervisor.Flags.ApicEnlightened
    Value: 0
    Key  : Hypervisor.Flags.ApicVirtualizationAvailable
    Value: 1
    Key  : Hypervisor.Flags.AsyncMemoryHint
    Value: 0
    Key  : Hypervisor.Flags.CoreSchedulerRequested
    Value: 0
    Key  : Hypervisor.Flags.CpuManager
    Value: 1
    Key  : Hypervisor.Flags.DeprecateAutoEoi
    Value: 1
    Key  : Hypervisor.Flags.DynamicCpuDisabled
    Value: 1
    Key  : Hypervisor.Flags.Epf
    Value: 0
    Key  : Hypervisor.Flags.ExtendedProcessorMasks
    Value: 1
    Key  : Hypervisor.Flags.HardwareMbecAvailable
    Value: 1
    Key  : Hypervisor.Flags.MaxBankNumber
    Value: 0
    Key  : Hypervisor.Flags.MemoryZeroingControl
    Value: 0
    Key  : Hypervisor.Flags.NoExtendedRangeFlush
    Value: 0
    Key  : Hypervisor.Flags.NoNonArchCoreSharing
    Value: 1
    Key  : Hypervisor.Flags.Phase0InitDone
    Value: 1
    Key  : Hypervisor.Flags.PowerSchedulerQos
    Value: 0
    Key  : Hypervisor.Flags.RootScheduler
    Value: 0
    Key  : Hypervisor.Flags.SynicAvailable
    Value: 1
    Key  : Hypervisor.Flags.UseQpcBias
    Value: 0
    Key  : Hypervisor.Flags.Value
    Value: 55185662
    Key  : Hypervisor.Flags.ValueHex
    Value: 0x34a10fe
    Key  : Hypervisor.Flags.VpAssistPage
    Value: 1
    Key  : Hypervisor.Flags.VsmAvailable
    Value: 1
    Key  : Hypervisor.RootFlags.AccessStats
    Value: 1
    Key  : Hypervisor.RootFlags.CrashdumpEnlightened
    Value: 1
    Key  : Hypervisor.RootFlags.CreateVirtualProcessor
    Value: 1
    Key  : Hypervisor.RootFlags.DisableHyperthreading
    Value: 0
    Key  : Hypervisor.RootFlags.HostTimelineSync
    Value: 1
    Key  : Hypervisor.RootFlags.HypervisorDebuggingEnabled
    Value: 0
    Key  : Hypervisor.RootFlags.IsHyperV
    Value: 1
    Key  : Hypervisor.RootFlags.LivedumpEnlightened
    Value: 1
    Key  : Hypervisor.RootFlags.MapDeviceInterrupt
    Value: 1
    Key  : Hypervisor.RootFlags.MceEnlightened
    Value: 1
    Key  : Hypervisor.RootFlags.Nested
    Value: 0
    Key  : Hypervisor.RootFlags.StartLogicalProcessor
    Value: 1
    Key  : Hypervisor.RootFlags.Value
    Value: 1015
    Key  : Hypervisor.RootFlags.ValueHex
    Value: 0x3f7
    Key  : Stack.Pointer
    Value: NMI
BUGCHECK_CODE:  1e
BUGCHECK_P1: ffffffffc0000005
BUGCHECK_P2: fffff8077e41ced1
BUGCHECK_P3: 0
BUGCHECK_P4: ffffffffffffffff
FILE_IN_CAB:  062425-9203-01.dmp
TAG_NOT_DEFINED_202b:  *** Unknown TAG in analysis list 202b
DUMP_FILE_ATTRIBUTES: 0x1808
  Kernel Generated Triage Dump
FAULTING_THREAD:  ffff9b8e110ca400
EXCEPTION_PARAMETER1:  0000000000000000
EXCEPTION_PARAMETER2:  ffffffffffffffff
READ_ADDRESS: fffff8077efbd4e0: Unable to get MiVisibleState
Unable to get NonPagedPoolStart
Unable to get NonPagedPoolEnd
Unable to get PagedPoolStart
Unable to get PagedPoolEnd
unable to get nt!MmSpecialPagesInUse
 ffffffffffffffff
BLACKBOXBSD: 1 (!blackboxbsd)
BLACKBOXPNP: 1 (!blackboxpnp)
BLACKBOXWINLOGON: 1
CUSTOMER_CRASH_COUNT:  1
PROCESS_NAME:  Diablo IV.exe
STACK_TEXT:
ffffcc81`275582a8 fffff807`7e41d4ed     : 00000000`0000001e ffffffff`c0000005 fffff807`7e41ced1 00000000`00000000 : nt!KeBugCheckEx
ffffcc81`275582b0 fffff807`7e744f8c     : 6489158d`0286c283 741ff1aa`ccbe991c 0552f88b`d463b8cc db4ad8c0`92f34a8c : nt!KiDispatchException+0x23d
ffffcc81`27558960 fffff807`7e73f94a     : ee6d3a06`5f064549 afc48166`db440c42 2206dbf9`699acd2b f217121a`e05dbe5f : nt!KiExceptionDispatch+0x14c
ffffcc81`27558b40 fffff807`7e41ced1     : 9b4d50e4`f0c3ed23 986d28a4`def8b023 a1e1f9ad`131c950c 43bb1c5c`21cc47e4 : nt!KiGeneralProtectionFaultDispatchTrap+0x68
ffffcc81`27558cd0 fffff807`7e613f84     : ffffcc81`275683d0 ffffcc81`27558d30 ffffcc81`27558e70 ffffcc81`274c9180 : nt!KeContextFromKframes+0x231
ffffcc81`27558d00 fffff807`7e73c8f6     : 00000000`00000100 ffffcc81`27558ef0 00000000`00000000 e5ddf948`b4495253 : nt!KiSaveProcessorState+0xa4
ffffcc81`27558d30 fffff807`7e73c644     : 00000000`00000100 ffffcc81`27558ef0 a0e2a6a0`21b7f53e 00000000`00000000 : nt!KxNmiInterrupt+0x76
ffffcc81`27558e70 00000261`2b93eb93     : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!KiNmiInterruptDispatchTrap+0xf5
000000b1`4dadcf78 00000000`00000000     : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : 0x00000261`2b93eb93
SYMBOL_NAME:  nt!KeContextFromKframes+231
MODULE_NAME: nt
IMAGE_NAME:  ntkrnlmp.exe
IMAGE_VERSION:  10.0.27881.1000
STACK_COMMAND: .process /r /p 0xffff9b8e102ea080; .thread 0xffff9b8e110ca400 ; kb
BUCKET_ID_FUNC_OFFSET:  231
FAILURE_BUCKET_ID:  AV_R_nt!KeContextFromKframes
OSPLATFORM_TYPE:  x64
OSNAME:  Windows 10
FAILURE_ID_HASH:  {92df748a-7471-c8a1-674d-605406b23dbb}
Followup:     MachineOwner
    PnpActivityId      : {00000000-0000-0000-0000-000000000000}
    PnpActivityTime    : 133951816213829296
    PnpEventInformation: 3
    PnpEventInProgress : 0
    PnpProblemCode     : 24
    PnpVetoType        : 0
    DeviceId           : SWD\MMDEVAPI\{0.0.0.00000000}.{90efcc6e-bc89-4353-ad56-f70bba634c9c}
    VetoString         :
[SMBIOS Data Tables v3.8]
[DMI Version - 0]
[2.0 Calling Convention - No]
[Table Size - 4632 bytes]
  Vendor                        American Megatrends International, LLC.
  BIOS Version                  1.A60
  BIOS Release Date             05/08/2025
  BIOS ROM Size                 1000000
  BIOS Characteristics
       07: - PCI Supported
       11: - Upgradeable FLASH BIOS
       15: - CD-Boot Supported
       17: - BIOS ROM Socketed
       19: - EDD Supported
       32: - BIOS Vendor Reserved
       00: - ACPI Supported
  BIOS Major Revision           5
  BIOS Minor Revision           32
  EC Firmware Major Revision    255
  EC Firmware Minor Revision    255
  Extended BIOS ROM Size        32 MB
  Manufacturer                  Micro-Star International Co., Ltd.
  Product Name                  MS-7E22
  Version                       1.0
  Serial Number                 Default string
  SKUNumber                     Default string
  Family                        Default string
  Product                       MEG Z890 ACE (MS-7E22)
  Version                       1.0
  Serial Number                 07E2210_O71B369356
  Asset Tag
       00: - Motherboard
       03: - Replaceable
  Location                      Default string
  Chassis Type                  Desktop
  Version                       1.0
  Serial Number
  Asset Tag Number
  Contained Element Size        3
[OEM Strings (Type 11) - Length 5 - Handle 0021h]
  Number of Strings             1
   1                            Default string
[System Configuration Options (Type 12) - Length 5 - Handle 0022h]
[ (Type 256) - Length 9 - Handle 0024h]
[ (Type 256) - Length 31 - Handle 0025h]
[ (Type 256) - Length 26 - Handle 0026h]
[Physical Memory Array (Type 16) - Length 23 - Handle 0027h]
  Maximum Capacity              134217728KB
  Memory Error Inf Handle       [Not Provided]
  Number of Memory Devices      4
[Memory Device (Type 17) - Length 92 - Handle 0028h]
  Memory Error Info Handle      [Not Provided]
  Total Width                   0 bits
  Data Width                    0 bits
  Size                          [Not Populated]
  Form Factor                   02h - Unknown
  Device Locator                DIMMA1
  Bank Locator                  BANK 0
  Memory Type                   02h - Unknown
  Type Detail                   0000h -
  Speed                         0MHz
  Manufacturer                  [String Not Specified]
  Serial Number                 [String Not Specified]
  Asset Tag Number              [String Not Specified]
  Part Number                   [String Not Specified]
  Attributes                    0
  Configured Memory Speed       0
  Minimum Voltage               0
  Maximum Voltage               0
  Configured Voltage            0
  Memory Technology             0
  Memory Operating Mode Capability     0
  Firmware Version              0
  Module Manufacturer Id        0
  Module Product Id             0
  Memory Subsystem Controller Manufacturer Id  0
  Memory Subsystem Controller Product Id       0
  Non-Volatile Size             0
  Volatile Size                 0
  Cache Size                    0
  Logical Size                  0
  Extended Speed                0
  Extended Configured Memory Speed     0
[Memory Device (Type 17) - Length 92 - Handle 0029h]
  Size                          24576MB
  Form Factor                   09h - DIMM
  Device Locator                DIMMA2
  Bank Locator                  BANK 0
  Memory Type                   22h - DDR5
  Type Detail                   0080h - Synchronous
  Speed                         6400MHz
  Manufacturer                  Kingston
  Serial Number
  Asset Tag Number
  Part Number                   KF582C40-24
  Attributes                    1
  Configured Memory Speed       6400
  Minimum Voltage               1100
  Maximum Voltage               1100
  Configured Voltage            1100
  Memory Technology             3
  Memory Operating Mode Capability     8
  Firmware Version              0
  Module Manufacturer Id        38913
  Module Product Id             0
  Non-Volatile Size             0
  Volatile Size                 0
  Cache Size                    0
  Logical Size                  0
  Extended Speed                0
[Memory Device (Type 17) - Length 92 - Handle 002ah]
  Total Width                   0 bits
  Data Width                    0 bits
  Device Locator                DIMMB1
  Bank Locator                  BANK 1
  Type Detail                   0000h -
  Speed                         0MHz
  Attributes                    0
  Minimum Voltage               0
  Maximum Voltage               0
  Memory Technology             0
  Firmware Version              0
  Module Product Id             0
  Non-Volatile Size             0
  Volatile Size                 0
  Cache Size                    0
  Logical Size                  0
  Extended Speed                0
[Memory Device (Type 17) - Length 92 - Handle 002bh]
  Size                          24576MB
  Device Locator                DIMMB2
  Bank Locator                  BANK 1
  Speed                         6400MHz
  Serial Number
  Asset Tag Number
  Attributes                    1
  Memory Technology             3
  Firmware Version              0
  Module Product Id             0
  Non-Volatile Size             0
  Volatile Size                 0
  Cache Size                    0
  Logical Size                  0
  Extended Speed                0
[Memory Array Mapped Address (Type 19) - Length 31 - Handle 002ch]
  Ending Address                02ffffffh
  Memory Array Handle           0027h
[Memory Device Mapped Address (Type 20) - Length 35 - Handle 002dh]
  Ending Address                017fffffh
  Memory Device Handle          0029h
  Mem Array Mapped Adr Handle   002ch
  Interleave Position           [None]
  Interleave Data Depth         [None]
[Memory Device Mapped Address (Type 20) - Length 35 - Handle 002eh]
  Starting Address              01800000h
  Memory Device Handle          002bh
[ (Type 256) - Length 12 - Handle 002fh]
[ (Type 256) - Length 26 - Handle 0030h]
[ (Type 256) - Length 26 - Handle 0031h]
[ (Type 256) - Length 47 - Handle 0032h]
[ (Type 256) - Length 82 - Handle 0033h]
[Cache Information (Type 7) - Length 27 - Handle 0034h]
  Socket Designation            L1 Cache
  Maximum Cache Size            0180h - 384K
  Installed Size                0180h - 384K
  Supported SRAM Type           0020h - Synchronous
  Current SRAM Type             0020h - Synchronous
  Cache Speed                   0ns
  Error Correction Type         ParitySingle-Bit ECC
  System Cache Type             Data
  Associativity                 12-way Set-Associative
  Maximum Cache Size 2          180 - 00000384l Kb
  Installed Cache Size 2        180 - 00000384l Kb
[Cache Information (Type 7) - Length 27 - Handle 0035h]
  Maximum Cache Size            0200h - 512K
  Installed Size                0200h - 512K
  Cache Speed                   0ns
  System Cache Type             Instruction
  Associativity                 16-way Set-Associative
  Maximum Cache Size 2          200 - 00000512l Kb
  Installed Cache Size 2        200 - 00000512l Kb
[Cache Information (Type 7) - Length 27 - Handle 0036h]
  Socket Designation            L2 Cache
  Maximum Cache Size            6000h - 24576K
  Installed Size                6000h - 24576K
  Cache Speed                   0ns
  Error Correction Type         Multi-Bit ECC
  Maximum Cache Size 2          6000 - 00024576l Kb
  Installed Cache Size 2        6000 - 00024576l Kb
[Cache Information (Type 7) - Length 27 - Handle 0037h]
  Socket Designation            L3 Cache
  Maximum Cache Size            8240h - 36864K
  Installed Size                8240h - 36864K
  Cache Speed                   0ns
  Maximum Cache Size 2          80000240 - 00036864l Kb
  Installed Cache Size 2        80000240 - 00036864l Kb
[Cache Information (Type 7) - Length 27 - Handle 0038h]
  Cache Speed                   0ns
[Cache Information (Type 7) - Length 27 - Handle 0039h]
  Maximum Cache Size            0400h - 1024K
  Installed Size                0400h - 1024K
  Cache Speed                   0ns
  Maximum Cache Size 2          400 - 00001024l Kb
  Installed Cache Size 2        400 - 00001024l Kb
[Cache Information (Type 7) - Length 27 - Handle 003ah]
  Maximum Cache Size            4000h - 16384K
  Installed Size                4000h - 16384K
  Cache Speed                   0ns
  Maximum Cache Size 2          4000 - 00016384l Kb
  Installed Cache Size 2        4000 - 00016384l Kb
[Cache Information (Type 7) - Length 27 - Handle 003bh]
  Cache Speed                   0ns
[Processor Information (Type 4) - Length 51 - Handle 003ch]
  Socket Designation            U3E1
  Processor Family              feh - Specification Reserved
  Processor Manufacturer        Intel(R) Corporation
  Processor ID                   62060c00fffbebbf
  Processor Version             Intel(R) Core(TM) Ultra 9 285K
  Processor Voltage             8ch - 1.2V
  Max Speed                     8500MHz
  Current Speed                 5400MHz
  Processor Upgrade             Specification Reserved
  L1 Cache Handle               0039h
  L2 Cache Handle               003ah
  L3 Cache Handle               003bh
  Serial Number
  Asset Tag Number
  Part Number                   To Be Filled By O.E.M.
  Core Count                    24
  Core Enabled                  24
  Thread Count                  24
  Processor Characteristics     ec
  Enabled Characteristics:
       0x 2: 64-bit Capable
       0x 3: Multi-Core
       0x 5: Execute Protection
       0x 6: Enhanced Virtualization
  Processor Family 2            0307h - Specification Reserved
  Core Count 2                  24
  Core Enabled 2                24
  Thread Count 2                24
[ (Type 256) - Length 64 - Handle 003dh]
[ (Type 256) - Length 11 - Handle 003eh]
[ (Type 256) - Length 11 - Handle 003fh]
[ (Type 256) - Length 11 - Handle 0040h]
[ (Type 256) - Length 11 - Handle 0041h]
[ (Type 256) - Length 11 - Handle 0042h]
[ (Type 256) - Length 11 - Handle 0043h]
[ (Type 256) - Length 11 - Handle 0044h]
[ (Type 256) - Length 11 - Handle 0045h]
[ (Type 256) - Length 11 - Handle 0046h]
[ (Type 256) - Length 11 - Handle 0047h]
[ (Type 256) - Length 11 - Handle 0048h]
[ (Type 256) - Length 11 - Handle 0049h]
[ (Type 256) - Length 11 - Handle 004ah]
[ (Type 256) - Length 11 - Handle 004bh]
[ (Type 256) - Length 11 - Handle 004ch]
[ (Type 256) - Length 117 - Handle 004dh]
[ (Type 256) - Length 16 - Handle 004eh]
[ (Type 256) - Length 44 - Handle 004fh]
[ (Type 256) - Length 8 - Handle 0050h]
[ (Type 256) - Length 6 - Handle 0051h]
[ (Type 256) - Length 106 - Handle 0053h]
[ (Type 256) - Length 4 - Handle 0055h]
Recep Abi selamlar,
Belki çok saçma geliyor olabilir ama vaktiyle ben de aynı hatadan muzdariptim. Her türlü çözümü denesem de bir türlü çözüm bulamadım ama klasik çözümleri buraya sıralayayım;
  • BIOS güncellemek,
  • EXPO'yu açmak/devre dışı bırakmak
  • RAM'leri test etmek (mümkünse ödünç alıp kullanabileceğiniz yeni bir RAM takarak aynı hata yaşanıyor mu kontrol etmek)
  • PSU'yu test etmek.
Benim yaşadığım sorun ise "ekran kartını düzgün takamamaktan" kaynaklıydı. Her ne kadar yerine tam olarak otursa da bunu elimde kontrol etmiş dahi olsam ekran kartını çıkartıp tekrar taktığım vakit sorun düzeldi. Çok ilkel ve saçma bir çözüm ama umarım bu şekilde hallolur. Minidump dosyasında çünkü çok fazla elle tutulur bir bilgi göremedim. Genel olarak bu tür sorunu yaşayan kişiler RAM'lerden kaynaklı demiş.
BIOS güncel mi? Insider sürümü yerine standart kullanıcı sürümünü kurma şansınız var mı? Bu mavi ekran genellikle yanlış sürücü veya uyumsuz, hatalı donanımdan kaynaklanır. Bu sistemdeki sorun muhtemelen BIOS veya sürücü kaynaklı olabilir. Ki bence sürücü kaynaklı. "AMD'ye geçtiğimden beri mavi ekran hataları bir tık arttı" demişsiniz. O zaman RX 9070 XT sürücüsü sorunlu olabilir.
