- 16 Aralık 2023
Hugginface ilk defa kullanıyorum API key tarzı bir şey istiyor hatada, ne yapmalıyım?
Ve API key istemesi normal mi? Ben modelin bilgisayarımda çalışmasını istiyorum chat GPT'den yardım aldım ama kodu değiştirdiği kısımlarda loacalden API'ya dönmüş olabilir.
@brkdnmz
Kod:
Traceback (most recent call last):
File "C:\Users\aero\AppData\Local\Packages\PythonSoftwareFoundation.Python.3.11_qbz5n2kfra8p0\LocalCache\local-packages\Python311\site-packages\huggingface_hub\utils\_http.py", line 406, in hf_raise_for_status.
response.raise_for_status()
File "C:\Users\aero\AppData\Local\Packages\PythonSoftwareFoundation.Python.3.11_qbz5n2kfra8p0\LocalCache\local-packages\Python311\site-packages\requests\models.py", line 1024, in raise_for_status.
raise HTTPError(http_error_msg, response=self)
requests.exceptions.HTTPError: 401 Client Error: Unauthorized for url: https://huggingface.co/meta-llama/Llama-3.2-3B-Instruct/resolve/main/config.json
The above exception was the direct cause of the following exception:
File "C:\Users\aero\AppData\Local\Packages\PythonSoftwareFoundation.Python.3.11_qbz5n2kfra8p0\LocalCache\local-packages\Python311\site-packages\transformers\utils\hub.py", line 403, in cached_file.
resolved_file = hf_hub_download(
File "C:\Users\aero\AppData\Local\Packages\PythonSoftwareFoundation.Python.3.11_qbz5n2kfra8p0\LocalCache\local-packages\Python311\site-packages\huggingface_hub\utils\_deprecation.py", line 101, in inner_f.
return f(*args, **kwargs)
File "C:\Users\aero\AppData\Local\Packages\PythonSoftwareFoundation.Python.3.11_qbz5n2kfra8p0\LocalCache\local-packages\Python311\site-packages\huggingface_hub\utils\_validators.py", line 114, in _inner_fn.
return fn(*args, **kwargs)
File "C:\Users\aero\AppData\Local\Packages\PythonSoftwareFoundation.Python.3.11_qbz5n2kfra8p0\LocalCache\local-packages\Python311\site-packages\huggingface_hub\file_download.py", line 1232, in hf_hub_download.
return _hf_hub_download_to_cache_dir(
File "C:\Users\aero\AppData\Local\Packages\PythonSoftwareFoundation.Python.3.11_qbz5n2kfra8p0\LocalCache\local-packages\Python311\site-packages\huggingface_hub\file_download.py", line 1339, in _hf_hub_download_to_cache_dir
_raise_on_head_call_error(head_call_error, force_download, local_files_only)
File "C:\Users\aero\AppData\Local\Packages\PythonSoftwareFoundation.Python.3.11_qbz5n2kfra8p0\LocalCache\local-packages\Python311\site-packages\huggingface_hub\file_download.py", line 1854, in _raise_on_head_call_error
raise head_call_error.
File "C:\Users\aero\AppData\Local\Packages\PythonSoftwareFoundation.Python.3.11_qbz5n2kfra8p0\LocalCache\local-packages\Python311\site-packages\huggingface_hub\file_download.py", line 1746, in _get_metadata_or_catch_error
@brkdnmz
